HDD or NVME VPS? We've got you covered! The plan you want most at €10/year.
15791011
  • @foxone said:
    @tenpera said:
    It's gotten better by 0.1MB/S.
    dd if=/dev/zero of=/tmp/test oflag=direct bs=64k count=16000
    16000+0 records in
    16000+0 records out
    1048576000 bytes (1.0 GB, 1000 MiB) copied, 108.387 s, 9.7 MB/s
    From what I see it is you are abusing the resources you have, maybe you have a virus or something?
    Some people tend to think the whole MicroSD storage cluster is dedicated to them.
  • @root said: Some people tend to think the whole MicroSD storage cluster is dedicated to them.
    Your statement reminds me of a cheap MicroSD card of Chinese brand I bought around 10 years old, whose maximum speed is 1.1 MB/s then stabilizes at 800 KB/s. It's useless to me, so I installed it to my mother's smartphone as extended storage.
    After that I only choose famous brands like SanDisk, Toshiba, or the like.
    Thanked by (1)root
  • edited August 2024
    @c1vhosting said:
    Hi,
    we are working on improving IO speeds on the HDD node.
    It has been 3 days.
    Any ETA when this issue is expected to be resolved?
  • @dev_vps said:
    @c1vhosting said:
    Hi,
    It has been 3 days.
    Please be patient. He's working on it. Have you already seen disruptions? You should have got a couple of them before he claims it's solved. Not that it then will be solved, it could be, but it also couldn't.
  • @Calypso said:
    @dev_vps said:
    @c1vhosting said:
    Hi,
    It has been 3 days.
    Does performance advisory apply to ticket resolution speed as well?
    Ofcourse. Just like being patient. And it'll get better.
  • is this offer for vps servers or just web hosting?
    the cost is nice and cheap can i know if the offer for vps or webhosting please?
    because i try to buy one of this plan but until now not paid cuz not see choice the linux system like ubuntu,centos...etc
    or maybe can take the choice after pay for it?
    have a nice day.
  • @DivZezo said: is this offer for vps servers or just web hosting?
    Obviously VPS. Look at the title, there should be no ambiguity.
    @DivZezo said: not see choice the linux system like ubuntu,centos...etc
    Yes, there is. I always choose Debian.
    C1V is very affordable but accordingly may not be as stable as you expect.
  • ^^ Another lamb to the slaughter. :|
    If you know how to install Debian 11 (or any other OS) directly from source iso url, that would be the best way to install OS on this VPS that comes with performance advisory. So keep the advisory in mind.
    I am running Windows Server 2022 Standard edition. Having said that @c1vhosting is not among my list of recommended providers.
    I will not renew c1v VPS at the term expiration.
    Low price clouds the logical decision making
    I have a VPS with them.
    It's offline days ago, they help me to bring it back, and ask me to leave a review to get one resource upgrade.
    The VPS died again after doing that, and nobody replys my tikect: #C1V_9960315_TCUSID.
    What can I say?
    The VPS died again after done, and nobody replys my tikect: #C1V_9960315_TCUSID.
    What can I say?
    you can leave a bad review
    What can I say?
    This is unique, unforgettable, and unmatched performance
    perfect to match with performance advisory.
    When you buy cheap, you often pay twice—
    once for the bargain and again for the regret.
  • [root@italy ~]# time df -h
    Filesystem               Size  Used Avail Use% Mounted on
    devtmpfs                 1.5G     0  1.5G   0% /dev
    tmpfs                    1.5G   84K  1.5G   1% /dev/shm
    tmpfs                    1.5G  161M  1.3G  11% /run
    tmpfs                    1.5G     0  1.5G   0% /sys/fs/cgroup
    /dev/mapper/centos-root   50G  7.9G   43G  16% /
    /dev/mapper/centos-home  846G   33M  846G   1% /home
    /dev/vda1               1014M  202M  813M  20% /boot
    real    0m7.064s
    user    0m0.000s
    sys 0m0.006s
    only 7 seconds for df -h and the server boots. almost 100 IOPS too, zoom zoom zoom
    What can I say?
    how this provider is still allowed here is unbelievable
    Thanked by (3)Peppery runbiscuit dev_vps
    Do you have a guide to boot netboot.xyz onto it?
    @root said: Do you have a guide to boot netboot.xyz onto it?
    You could try this (courtesty of @ehab ).
    Thanked by (3)ehab dev_vps root
    You should find that a netboot ISO is already mounted in the virtual CD-Rom, you can simply change the boot order temporarily, no need to mess with a donor OS. It's configurable via the 'edit pen' icon in the 'information' panel's title bar. You'll need to configure IP manually.
  • @tenpera said:
    @c1vhosting said: Please open a ticket and send me ticket number.
    ticket #C1V_8811836_TCUSID
    is your issue resolved?
    What can I say?
    I am going to investigate this further. @xx7879 we will talk in private.
    Thanked by (2)sh97 dev_vps
  • _MS__MS_ OGSenpai
    edited August 2024
    @xx7879 said: ask me to leave a review to get one resource upgrade
    A bannable offense (by a provider) in some forums.
    Thanked by (1)AuroraZero
    real 0m7.064s
    user 0m0.000s
    sys 0m0.006s
    on my c1v vps
    root@cheapOne:~# time df -h
    udev            3.8G     0  3.8G   0% /dev
    tmpfs           776M  748K  775M   1% /run
    /dev/sda1        79G  2.1G   74G   3% /
    tmpfs           3.8G     0  3.8G   0% /dev/shm
    tmpfs           5.0M     0  5.0M   0% /run/lock
    /dev/sda15      124M   12M  113M  10% /boot/efi
    tmpfs           776M     0  776M   0% /run/user/0
    real    0m0.011s
    user    0m0.000s
    sys     0m0.005s
    What can I say?
    Reviews and C1V is a funny story...
    I did write a negative review about C1V on a well known review site.
    First thing that happened, I got a mail from the review site: "C1V Hosting would love to understand your experience better, so they’ve asked for more details about your review—like an order number or email. If we don’t hear from you within 3 days, your review may be taken offline.". Well, no problem. I provided that.
    Then another mail: "You reviewed C1V Hosting, who believe your review actually belongs to another business.". Well, I know for sure it isn't. So I let the review site know that I wasn't mistaking.
    One month after that: "C1V Hosting has flagged your review for containing harmful or illegal content.". Pardon me? So I filed a complaint. "We’ve assessed your review for the reason it was flagged and determined that it follows our guidelines. Therefore, we’ve now put your review back online."
    So basically, he tries to get negative reviews offline, with several attempts if it fails...
    What can I say?
    Even the most trusted pilots hit turbulence while dealing with such providers.
    Running Windows 11 OS
  • @c1vhosting
    The control panel shows much higher cpu utilization and memory used as compared to Windows Task Manager
  • @dev_vps said: Running Windows 11 OS
    ur a noisy neighbour, because running Windows on such a cheap VPS consumes much more resources, which directly or indirectly deteriorates other customers' experience. ur quota of resources should be lower by C1V's AI scheduler.
    Did you look at the cpu resource utilization… it is around 15-20% range …
    Did you look at memory utilization … it is below 40%
    My storage space utilization is below 30%
    So, kindly explain how I am consuming more resources?
    @bliss
    I have installed Debian 12 version in place to Windows 11, so that I am no longer a "noisy neighbor" :)
    Uptime     : 0 days, 0 hours, 13 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz
    CPU cores  : 2 @ 2596.990 MHz
    RAM        : 7.6 GiB
    Swap       : 0.0 KiB
    Disk       : 78.7 GiB
    Kernel     : 6.1.0-13-amd64
    ISP        : Cinzia Tocci trading as C1V
    ASN        : AS212271 Cinzia Tocci trading as C1V
    Host       : C1V Hosting
    Country    : Italy
    Read       | 77.33 MB/s   (19.3k) | 776.98 MB/s  (12.1k)
    Write      | 77.54 MB/s   (19.3k) | 781.07 MB/s  (12.2k)
    Total      | 154.87 MB/s  (38.7k) | 1.55 GB/s    (24.3k)
    Read       | 1.47 GB/s     (2.8k) | 1.51 GB/s     (1.4k)
    Write      | 1.54 GB/s     (3.0k) | 1.61 GB/s     (1.5k)
    Total      | 3.01 GB/s     (5.8k) | 3.12 GB/s     (3.0k)
    Clouvider       | London, UK (10G)          | 74.2 Mbits/sec  | 764 Mbits/sec   | 30.2 ms
    Eranium         | Amsterdam, NL (100G)      | 561 Mbits/sec   | 1.36 Gbits/sec  | 39.1 ms
    Uztelecom       | Tashkent, UZ (10G)        | 465 Mbits/sec   | 796 Mbits/sec   | 88.1 ms
    Leaseweb        | Singapore, SG (10G)       | 397 Mbits/sec   | 390 Mbits/sec   | 266 ms
    Clouvider       | Los Angeles, CA, US (10G) | 61.1 Mbits/sec  | 357 Mbits/sec   | 206 ms
    Leaseweb        | NYC, NY, US (10G)         | 19.8 Mbits/sec  | 591 Mbits/sec   | 145 ms
    Edgoo           | Sao Paulo, BR (1G)        | 305 Mbits/sec   | 778 Mbits/sec   | 220 ms
    Clouvider       | London, UK (10G)          | 583 Mbits/sec   | 879 Mbits/sec   | 30.1 ms
    Eranium         | Amsterdam, NL (100G)      | 608 Mbits/sec   | 1.75 Gbits/sec  | 33.0 ms
    Uztelecom       | Tashkent, UZ (10G)        | 447 Mbits/sec   | 957 Mbits/sec   | 88.6 ms
    Leaseweb        | Singapore, SG (10G)       | 345 Mbits/sec   | 818 Mbits/sec   | 268 ms
    Clouvider       | Los Angeles, CA, US (10G) | 10.1 Mbits/sec  | 90.4 Mbits/sec  | 205 ms
    Leaseweb        | NYC, NY, US (10G)         | 22.7 Mbits/sec  | 858 Mbits/sec   | 149 ms
    Edgoo           | Sao Paulo, BR (1G)        | 266 Mbits/sec   | 924 Mbits/sec   | 222 ms
    Geekbench 5 Benchmark Test:
    Single Core     | 423
    Multi Core      | 797
    Full Test       | https://browser.geekbench.com/v5/cpu/22823746
    Single Core     | 510
    Multi Core      | 893
    Full Test       | https://browser.geekbench.com/v6/cpu/7561060
    Speedtest by Ookla
    Server: RETN - London
    Idle Latency:    32.67 ms   (jitter: 0.14ms, low: 32.59ms, high: 32.89ms)
        Download:  1336.40 Mbps (data used: 1.7 GB)
                     47.55 ms   (jitter: 31.81ms, low: 29.29ms, high: 409.32ms)
          Upload:   443.66 Mbps (data used: 703.6 MB)
                     33.87 ms   (jitter: 3.62ms, low: 32.56ms, high: 85.64ms)
     Packet Loss:     0.0%
      Result URL: https://www.speedtest.net/result/c/f2d7c83f-c574-42f3-806f-b362a5e408e0
    Server: i3D.net - Dallas, TX
    Idle Latency:   142.87 ms   (jitter: 6.84ms, low: 142.09ms, high: 155.96ms)
        Download:  1385.55 Mbps (data used: 1.6 GB)
                    224.66 ms   (jitter: 67.12ms, low: 140.09ms, high: 325.07ms)
          Upload:   327.95 Mbps (data used: 566.8 MB)
                    210.90 ms   (jitter: 64.62ms, low: 139.88ms, high: 290.87ms)
     Packet Loss:     0.0%
      Result URL: https://www.speedtest.net/result/c/b8413311-db35-4fe9-aba9-fdfe345a11ea
    if there is no or little cpu steal (as in the case of premium providers), the Windows Server OS is pretty resource optimized and does not need much resources.
    Here is one example , the cpu utilization is below 2% ... yes 2%
    Provider is BulletHost (in case you are interested)
    Here is another example.
    This is @host_c storage VPS (10TB one) and I am using as my primary Windows RDP dev machine. Look at the resource utilization below and running for 81+ days. It would have been 140+ days, but it has to be restarted to upgrade the 5TB storage to 10TB.
    So, one can be running Windows RDP and still be resource optimized, provided the provider is premium.
    and @host_c is one such provider.
    Need more examples? @bliss
