@Neoon said: Maintenance Announcement
Most of the Nodes are still running Proxmox 7, which is EOL end of this month.
So they need to be upgraded, you can expect up to 30 minutes of downtime per Node.
I will start upgrading the Nodes next Friday (26.07) at around 20:00 CET, one by one.
Once its done, I will post here again.
All nodes have been upgraded.
If you notice any issues, please lemme know.
> @Neoon said: > All nodes have been upgraded. > If you notice any issues, please lemme know.
My Valdivia node is not accessible. The Dashboard shows it's online, but clicking on Manage gives me an error: "Failed to contact Node, please try again later."
Just thought I'd led you know as you asked. No rush. Thank you for offering the service.
Returning to work with Information Technology and networks, leaving a job as a rescuer in the public service of health, I believe that a vps like this already helps to do the tests and learning I need.
Will be done on Sunday instead, same time though.
41a033760922ee59773dc33631410d4d85859cef
Usage will be searx and a http proxy. Low usage & will be secured so that it's not open - just me
Will process your request shortly, currently migrating the website over to another server.
Thanks! No rush on mine
Deployed.
edit: Oops, wrong service. My bad.
It's pronounced hacker.
Could you check if there's any issue with IPv6 in Fremont? Gateway is reachable but nothing beyond.
Fixed, sorry for that.
89d000a72288b04a2a5fd73522f42fff8f580fff
Hoping for a basic VPS for monitoring and some small services that is a bit out of band from what I currently have...
Deployed.
oh nOo! my uptime
Thank you so much. I feel bad, you deployed it so fast and I haven't had a chance to stop by and say thanks yet.
Can I apply
Can you read?
Token
325fc5088885918829ed58d5f4146368d1b53152
Fremont had network issues about an hour ago.
IPv6 still dead, waiting for fix.
IPv6 is back up since roughly 1 hour.
If you still have issues, lemme know.
Still not working for me. I can ping the default gateway on
eth1
but nothing beyond (Google, for example)dnscry.pt - Public DNSCrypt resolvers hosted by LowEnd providers • Need a free NAT LXC? -> https://microlxc.net/
Yikes, they fixed it last time now it broke again.
Ticket is out, I suggested a permanent fix, will see, I report back.
Thank you, it just came back online
Yes but its not a permanent fix though.
There will be another network maintenance.
Then we should have a permanent fix.
