HDD or NVME VPS? We've got you covered! The plan you want most at €10/year.
1567911
  • @root said:
    @Jab said:
    @fr99ths said: Is there a law to protect customers in case of the issue above happened?
    Yes.
    @fr99ths said: If the host lied, what could the customer do?
    Chargeback and sue.
    That is the trick on which the provider relies their whole business model on. Chargebacks are not worth the time spent for justification of €10; suing ain't worth the effort for a €10 loss.
    In my opinion not even the stress itself is worth €10, even though the time waiting for an "apt update" command to complete is worth more than that. The stress appears when one thinks of all the people who fall for this kind of offers, while the provider oversells even further, then suspends accounts to oversell even more.
    Some form of unity between people is always needed, because when they're divided they are being taken for granted and even conquered (as seen throughout history).
    No trick or business model as some conspirators might think.
    Simply the Client was reported for abuse from 4 of his 6 VPS, which was also causing him to be completely banned from accessing his servers... The whole thing was solved by reinstalling the VPS that apparently had been compromised (they were running ddos ​​attacks to external IP addresses).
    Thanks
    C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
    i like how answers to questions are cherry picked
    Thanked by (2)Calypso dev_vps
  • rootroot OG
    edited September 2024
    @c1vhosting said:
    [...] VPS that apparently had been compromised (they were running ddos ​​attacks to external IP addresses).[...]
    Did you simply assume someone could actually run something (anything, even some DDoS application) within your VPS offer?
    Thanked by (2)cybertech dev_vps
    I reserve the right to license all of my content under: CC BY-NC-ND. What happens on this forum should stay on this forum.
  • Out of Stock. It's so pity.
    Trust me. I promise you did not lose anything. You're a winner for saving your money on this.
    Thanked by (2)Kris cybertech
  • edited September 2024
    @hostmonit said:
    HDD PLAN
    apt install python3 takes about 2 hours
    @c1vhosting
    Are you done with the fix or share ETA for the fix.
    @c1vhosting said:
    we are working on improving IO speeds on the HDD node.
    Thanks for your patience.
    https://lowendspirit.com/discussion/comment/182473/#Comment_182473
    @c1vhosting said:
    We specialize in providing low-cost services that, in relation to the price, guarantee a truly advantageous quality-price ratio.
    Due to the nature of this offering, we cannot guarantee minimum speed rates.
    of course, low performance advisory applies to this also.
    https://lowendspirit.com/discussion/comment/182477/#Comment_182477
    @c1vhosting said:
    I honestly think you expect too much from a service that is VERY cheap and whose goal is to make Cloud services accessible even to the smallest wallets .........
  • Basic System Information:
    Processor  : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz
    CPU cores  : 2 @ 2596.990 MHz
    RAM        : 7.6 GiB
    Disk       : 79.9 GiB
    Distro     : Oracle Linux Server 9.4
    Kernel     : 5.15.0-206.153.7.el9uek.x86_64
    ISP        : Cinzia Tocci trading as C1V
    ASN        : AS212271 Cinzia Tocci trading as C1V
    Host       : C1V Hosting
    Country    : Italy
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2):
    Read       | 75.86 MB/s   (18.9k) | 849.22 MB/s  (13.2k)
    Write      | 76.06 MB/s   (19.0k) | 853.69 MB/s  (13.3k)
    Total      | 151.93 MB/s  (37.9k) | 1.70 GB/s    (26.6k)
    Read       | 1.58 GB/s     (3.0k) | 1.53 GB/s     (1.5k)
    Write      | 1.66 GB/s     (3.2k) | 1.63 GB/s     (1.6k)
    Total      | 3.24 GB/s     (6.3k) | 3.17 GB/s     (3.1k)
    Clouvider       | London, UK (10G)          | 35.5 Mbits/sec  | 1.02 Gbits/sec  | 34.4 ms
    Eranium         | Amsterdam, NL (100G)      | 352 Mbits/sec   | 1.44 Gbits/sec  | 31.5 ms
    Uztelecom       | Tashkent, UZ (10G)        | 34.3 Mbits/sec  | busy            | 81.7 ms
    Leaseweb        | Singapore, SG (10G)       | 251 Mbits/sec   | 394 Mbits/sec   | 264 ms
    Clouvider       | Los Angeles, CA, US (10G) | 2.99 Mbits/sec  | 489 Mbits/sec   | 207 ms
    Leaseweb        | NYC, NY, US (10G)         | busy            | 291 Mbits/sec   | 143 ms
    Edgoo           | Sao Paulo, BR (1G)        | 227 Mbits/sec   | 152 Mbits/sec   | 213 ms
    Clouvider       | London, UK (10G)          | 453 Mbits/sec   | 950 Mbits/sec   | 33.6 ms
    Eranium         | Amsterdam, NL (100G)      | 448 Mbits/sec   | 1.27 Gbits/sec  | 31.9 ms
    Uztelecom       | Tashkent, UZ (10G)        | 280 Mbits/sec   | busy            | 81.7 ms
    Leaseweb        | Singapore, SG (10G)       | 171 Mbits/sec   | 362 Mbits/sec   | --
    Clouvider       | Los Angeles, CA, US (10G) | 2.71 Mbits/sec  | 118 Mbits/sec   | 206 ms
    Leaseweb        | NYC, NY, US (10G)         | 3.38 Mbits/sec  | 475 Mbits/sec   | 144 ms
    Edgoo           | Sao Paulo, BR (1G)        | 166 Mbits/sec   | 245 Mbits/sec   | 212 ms
    Geekbench 5 Benchmark Test:
    Single Core     | 228
    Multi Core      | 441
    Full Test       | https://browser.geekbench.com/v5/cpu/22846600
  • @dev_vps said:
    Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 228 Multi Core | 441 Full Test | https://browser.geekbench.com/v5/cpu/22846600 .
    That is indeed low-end, but I believe C1Vhosting can go even lower. More overselling is needed.
    Refer to this comment from @c1vhosting
  • @dev_vps said:
    Yeah, and shortly after that he changed his signature on LES from "Premier Datacenter" to "Low cost Italian Cloud & Data Center Solutions".
    Basically what he did there is putting the middle finger up to all his previous older customers (if he has them, but hey, less then a year ago he was luring in customers with "Premier" "High Quality" etc for yearly subscriptions)...
    next year it will be gutter cloud for peanuts just to keep the lights on
  • @Calypso said:
    No more “Premier” or “Tier 3” marketing slogans.
    The only expectation customer should have is that VPS is up and running, GB5 score could be 50, 150, 250 … based on AI based luck system
  • And VPS is down again for quite some time. It's running allright, but no network connectivity.
  • @Calypso said: And VPS is down again for quite some time. It's running allright, but no network connectivity.
    It's weekly core router replacement, what else? :p
    How do you know it's alright?
    Is that not a case of 'If a tree falls in the forest and no one is there, does it still make a sound?'
    Can login to the mangement portal and through console can login to the VPS itself. So that way I know it's not shut down, hanging, or anything like that, just misses network connectivity.
    Thanked by (2)cochon bliss
  • @Calypso said: just misses network connectivity.
    some of the network connectivity.
    IPv6 working.
    and as this is IPv6 I am tagging @yoursunny so he can say something!
    Thanked by (2)AuroraZero yoursunny
    IPv6 working.
    Lucky you. Here IPv6 also not responding. Well... that's the randomness they call C1V right...
    IPv6 working.
    as per c1v, we are expecting too much. He has already mentioned Low Performance Advisory as well.
    quote source --
  • @dev_vps said:
    IPv6 working.
    quote source --
    Again, what I've mentioned before, that's not what I've signed up for/was promised when I signed up.
    "At C1V Hosting we understand the importance of providing you with the best hosting solutions"
    "Don't miss this incredible chance to elevate your hosting experience"
    "Tier 3"
    That he later lowers expectations and removes those kind of outings doesn't mean that he isn't a fraud and liar.
    Now I'll shut again, he won't react here anyway. But we can still warn people that it's better to donate your money to a charity - you will have the same on(off)line result but a better feeling for yourself.
  • c1vhosting IPv4 website is now UP
    Downtime: 18 hr 28 min
    Got connectivity again. Good, now at least I can see my VPS idling because it's unusable for real purposes.
    @xx7879 said:
    I have a VPS with them.
    It's offline days ago, they help me to bring it back, and ask me to leave a review to get one resource upgrade.
    The VPS died again after doing that, and nobody replys my tikect: #C1V_9960315_TCUSID.
    What can I say?
    I am going to investigate this further. @xx7879 we will talk in private.
    Any update?
    What can I say?
    Any update?
    Laissez faire =)
    Thanked by (1)sh97
    @Calypso said:
    @dev_vps said:
    IPv6 working.
    quote source --
    "Tier 3"
    i rather donate it for medical fees.
    or did i?
    now i feel better.
  • How long does it take before you respond to a ticket.
  • cserverscservers Hosting Provider
    @c1vhosting said:
    @root said:
    Yes.
    Chargeback and sue.
    Thanks
    Furthermore, we'd like to exceptionally mention that this customer opens also fraudulent PayPal cases, knowing well the website is available and their access IP is the problem and actively refuses to comply accordingly, in order to attempt to get their money back, also creating multiple tickets for a given issue as well. Similar connection issues also arose on our end as well for this customer, possibly for similar reasons.
    We usually don't provide or talk about this information, but exceptionally we'll have to provide this detail as well: this is someone that knows what is doing (in terms of malicious action). Therefore, it can't be of much surprise that such termination occurred, as it also occurred on our side as well.
    Otherwise, each provider's work is each provider's work, we just wanted to mention this one as well; and state that for this particular case, having abuse reports taking down 4 out of 6 VPSes is, unfortunately, not a coincidence.
    We had to outright blacklist the customer today.
    Thanked by (1)c1vhosting
    @cservers said:
    @c1vhosting said:
    @root said:
    Yes.
    Chargeback and sue.
    Thanks
    Okay I am going to weigh in here and this goes for everyone.
    I personally run on facts, if you do not have or do not provide proof of what you say I will treat it as a baseless accusation.
    I treat everyone the same host or user and I have been sick and tired of the baseless accusations that get thrown around. If you want me to take you seriously then provide proof, you can even PM it me if it makes it easier.
    We usually answer in 2-3 days, what is your ticket number?
