microLXC Public Test
11415161719
    Restocked Vilnius.
    Thanked by (1)zgato
    IPv6 connectivity issue in Milan has been fixed.
    edited July 2024
    No info about Chile though, the prefixes disappeared from the routing table entirely.
    Will post here when I know more.
    Here's the email Zappie sent yesterday:
    At about 5:50am 29th June NZST (About 3 hours prior from this notification being sent) we have noticed that there has been network distributions in our Chile facility.
    We are in communication with a datacenter tech (our upstreams) who are investigating the fault. So far we have been told that there has been power related failures in the facility
    We are hoping and expect things to come back online within the next hour or so, and will continue to get updates from the upstream datacenter
    Yea he send out an email correct, I didn't noticed it because my monitoring was going off and the email went under.
    Thanks for posting though.
    Restocked Milan.
    Thanked by (2)Wonder_Woman ehab
  • 35e7-cea6-f41d-600b
  • I really want a New Zealand VPS test, but unfortunately my account does not meet the requirements. Thank you anyway
    Bratislava is now available thanks to @Hosteroid
    Groningen is not longer available and will be discontinued in a few weeks, replacement Node in Meppel should be up by end of the week.
  • HosteroidHosteroid Hosting Provider
    Good luck with it! o:)
    nice services 🤝🏽
    edited August 2024
    Restocked Bratislava.
    Thanked by (2)carlin0 Wonder_Woman
  • Hi @Neoon
    Can we upgrade the container (Memory / Disk) without terminate it?
    or at least by re-install it.
    @Fritz said:
    Hi @Neoon
    Not as of right now.
    Meppel is now available as replacement for Groningen, same packages as before.
    Everyone that still has a container or virtual-machine on Groningen will be notified, in a bit, to give them enough time to migrate.
    @Fritz said:
    Hi @Neoon
    Should be available in a bit.
    Thanked by (1)Ganonk
    edited August 2024
    Recently there has been made a change to Incus, which requires an additional device.
    That by default isn't added, hence some virtual machines refuse to boot.
    So far as of my knowledge, it only affects CentOS Stream on Meppel, which is our first Incus kvm node.
    If you run into issues, please choose a different OS for now, until a fix is available.
    edited August 2024
    Patchnotes
    • Fixed an issue which would prevent some os templates from booting up successfully when deployed as KVM
      There is still an issue though, with the Shell on these os templates, will resolve this later.
    • Added an option to reconfigure the network
      If an IPv6 Prefix is changed or IPv6 connectivity is added, this will update the network configuration on the fly
    • Restocked Meppel
    Thanked by (1)Wonder_Woman
    edited August 2024
    Mumbai is now available, Thanks to https://webhorizon.net / @Abdullah
    Node was already ready on Monday, however since I had stuff to do a bit delayed.
    Node YABS: https://lowendspirit.com/discussion/comment/183825#Comment_183825
    Currently 6 Packages are available.
    • 1x Core (25%), 64MB, 1.3GB, 250GB @ 100Mbit
    • 1x Core (50%), 128MB, 2.5GB, 400GB @ 100Mbit
    • 1x Core (50%), 192MB, 2.5GB, 400GB @ 100Mbit
    • 1x Core (50%), 256MB, 3.0GB, 400GB @ 100Mbit
    • 1x Core (50%), 384MB, 3.5GB, 500GB @ 200Mbit
    • 1x Core (50%), 512MB, 4.0GB, 500GB @ 200Mbit
    Any suggestions regarding the packages? lemme know.
    edited August 2024
    Patchnotes
    • Upgrades are now available for LXC containers @Fritz
      Downgrades will follow (LXC only), same for upgrades for KVM.
    • Containers that exceed the 50% usage cpu cap for more than 2 hours, will be rebooted automatically, this wasn't enabled before
      You will get a bunch of emails as before, if your usage is below 50% its considered fine for now, however keep it reasonable.
    Thanked by (2)Wonder_Woman ElonBezos
  • edited August 2024
    @Neoon said:
    Patchnotes
    Nice!!
    One problem, does upgrade mean get a higher plan?
    Can I just upgrade a small portion of Memory or disk?
    @Fritz said:
    Nice!!
    Yeah, No that would be way to much work.
    However if you got a suggestion for a Package, lemme know.
    Patchnotes
    - Renamed Upgrade to Resize
    - Fixed a bug that won't list all packages when up/downgrading
    - Added Support for Downgrades on LXC containers
    As long you have enough free disk space you can downgrade you container all the way to 64MB.
    Maintenance Announcement for Helsinki
    There will be electrical maintenance today through 23:30 to 06:00 CET.
    There will be 2 complete blackouts, and partial or most servers might be down for the period depending upon how much load the diesel generator can take.
    Will post here, when the maintenance is done.
    Done, roughly 10 minutes of downtime.
    edited August 2024
    There was a Raid failure on the Italy node, which made the file system read only.
    I will post here when I know more.
    edit: Resolved.
    NZ is back online, Ticket pending.
  • Your average CPU usage for your container lxcdcea9534 in the last 30 minutes was higher than 50%
    and it got rebooted by the system,
    how do i know which of my vm's this is? i'd like to check it further.
    for now I'm just using it as a personal vpn (web browsing)
    India, yea you exceeded 50% cpu usage on a shared system for a few hours.
    I will see what I can do to better reflect hostnames in the interface.
    omg sorry for that.
    actually the cpu usage is quite strange as i don't use the india vm yet, for anything.
    i have temporary shut it down to prevent anything worse
