LES BSD Thread!
13468919
    edited September 2024
    @linveo Wow, that was easy!
    root@linveo:~ # date -u
    Tue Sep 24 01:31:47 UTC 2024
    root@linveo:~ # freebsd-version
    14.1-RELEASE
    root@linveo:~ # sysctl hw.model hw.machine hw.ncpu hw.clockrate
    hw.model: AMD Ryzen 9 7950X 16-Core Processor
    hw.machine: amd64
    hw.ncpu: 2
    hw.clockrate: 4491
    root@linveo:~ #
    Thank you so much! <3
    Thanked by (1)linveo
  • Does VirtFusion have CPU topology settings hidden somewhere? When I look at the server creation API (https://docs.virtfusion.com/api/#api-Servers-Build), it mentions cpuCores in the hypervisor section, but I don't see API to manipulate them.
    "cpuCores": { "units": "#", "max": 0, "allocated": 4, "free": -4, "percent": null }
    I was also trying to find some settings for the CPU model. BuyVM's panel for example allows to change CPU model between "AMD/Intel" and "QEMU".
    @cmeerw is doing excellent investigation work at the kernel level, but I was just wondering whether the issue could actually be in the virtualization settings rather than in the kernel itself.
    Just throwing some ideas into the air.
    Thanked by (2)Not_Oles AlwaysSkint
  • linveolinveo Hosting ProviderOG
    Yes, CPU topology is available by VM and also by package to assign the resources.
    For CPU model, I don't believe this is user facing. I typically have this as host passthrough, but I am happy to change it for anyone that wants to try another setting such as QEMU.
  • @linveo said: I am happy to change it for anyone that wants to try another setting such as QEMU.
    Yes please change my VM's settings, let's give it a try!
    I have changed yours over to QEMU 64bit.
    It seems to be no-go. Powered the VM off and it doesn't even boot anymore. Control panel just says FAILED after trying for 49 seconds.
    Changed it back. I wonder if it needs to be from scratch and this can't be changed mid install.
  • @linveo said: I wonder if it needs to be from scratch and this can't be changed mid install.
    If you want to setup another VM with those settings, I can give it a try too.
  • @Crab said: @cmeerw is doing excellent investigation work at the kernel level, but I was just wondering whether the issue could actually be in the virtualization settings rather than in the kernel itself.
    As I said here earlier
    But it looks like something is not being reported correctly (by the CPU/virtualised CPU) here.
    but NetBSD should probably be able to handle this situation better (by continuing with sensible settings instead of asserting), particularly if it's a somewhat common issue in virtualised environments (and other OSes like Linux and FreeBSD a happy with it).
    Now on Ryzen - yahoo! :dizzy: Thanks @linveo (I thought it might have been a more lowly AMD.)
    I booted from a manually mounted NetBSD ISO, setup partitions and tried autoconfigure/DHCP. DHCP wouldn't assign the public IP etc., so needed to manually add the network configuration (IPv4) in /etc/rc.conf, within the console.
    I really like how compact NetBSD is - the VF backup only consumes 799MB. I wonder if I can make something useful out of this *nix. ;) A great opportunity!
    Thanks again Linveo.
    Thanked by (3)linveo Not_Oles kiwidave
    There doesn't appear to be a NetBSD package for qemu-guest-agent - seeing if I can build one from source - don't hold yer breath! :anguished: :astonished:
    1st stumbling block: the basics!
    On NetBSD, you need to install the “comp” and the “text” distribution sets.
    Though one needs to guess the procedure, other than starting from the boot installation!
  • ^ Figured just to wget then untar from online binary/sets
  • @linveo said: If anyone wants to change their VM type from Intel to AMD let me know and I can switch it for you.
    Could you maybe switch me over to AMD as well?
    I have now created a bug report for the Intel issue https://gnats.netbsd.org/cgi-bin/query-pr-single.pl?number=58693 so it doesn't get lost, but not sure when/if that might get applied to the kernel sources.
    I think it will be a lot easier not having to worry about having to use a patched kernel.
    I have already started looking at the build scripts for the NetBSD images from https://bsd-cloud-image.org/
    to build updated NetBSD 10.0 images: https://github.com/virt-lightning/netbsd-cloud-images/ (haven't looked at the cloud-init integration yet)
    BTW, https://www.etallen.com/cpuid.html is a very useful tool to get all that detailed CPU information - just sent the author a patch to make it compile under NetBSD.
  • Not sure how many of you have seen https://cybersecuritynews.com/critical-unauthenticated-rce-flaw/amp/ but appears to be a pretty bad vulnerability in Linux on the horizon (isn't there always). No operating system is immune from vulnerabilities, even all of the BSDs have had their share in the past. But with Windows having market share of all desktops when there is a major exploit it is a big problem for the world and with Linux having a big chunk of the server market something like this could also become a huge deal. Those of us on BSD can hopefully breathe easy for this one.
    Thanked by (2)GeekWanderer Not_Oles
    Absolutely, you have been a huge help. I have migrated your VM over to Ryzen.
    Thanked by (2)Not_Oles cmeerw
    Thanks so much.
    So looking at the CPU information on AMD, the CPUs show up as:
    [ 1.000004] cpu0 at mainbus0 apid 0
    [ 1.000004] cpu0: Use mfence to serialize rdtsc
    [ 1.000004] cpu0: AMD Ryzen 9 7950X 16-Core Processor , id 0xa60f12
    [ 1.000004] cpu0: node 0, package 0, core 0, smt 0
    [ 1.000004] cpu1 at mainbus0 apid 1
    [ 1.000004] cpu1: AMD Ryzen 9 7950X 16-Core Processor , id 0xa60f12
    [ 1.000004] cpu1: node 0, package 1, core 0, smt 0
    which probably isn't really ideal either. I think they should show up as core 0 and core 1 (with both being package 0).
    But looking at the information I get from cpuid, there isn't much else the code could do here:
    hyper-threading / multi-core supported = false
    number of threads = 0x1 (1)
    Other OSes probably do the same here, and as long as it works, nobody cares, I guess.
  • Used pfsense for ~3 years on my homelab until the whole drama with netgate started affecting the platform (cough, wireguard, cough), opnsense and haven't looked back.
  • @cmeerw said: Just as a little experiment, I thought I'd give Haiku a try (as Beta 5 has just been released), and that also doesn't boot.
    Haiku does actually work in the VM, I think I was just a bit too impatient last time as it needs quite a bit time to boot from the ISO image (as I believe VirtFusion is streaming the image data on demand via HTTP from the remote server).
  • @linveo have the cloud-init settings changed on the VM with the move to AMD?
    I used to see a small hard disk with the VM meta data on the Intel VM:
    Sep 24 15:51:37 linveo /netbsd: [ 2.2808864] sd0 at scsibus3 target 0 lun 2: <QEMU, QEMU HARDDISK, 2.5+> disk fixed
    Sep 24 15:51:37 linveo /netbsd: [ 2.2909223] sd0: 368 KB, 2 cyl, 16 head, 23 sec, 512 bytes/sect x 736 sectors
    Sep 24 15:51:37 linveo /netbsd: [ 2.2909223] sd0: async, 8-bit transfers, tagged queueing
    But I no longer see that disk now on the AMD VM.
  • I have put together a first NetBSD 10.0 image (somewhat based on the script from bsd-cloud-image.org, but without any cloud-init so far, so will need manual network configuration via VNC). @linveo do you want to add that as an installation image (it should boot on the AMD VMs)?
    Thanked by (3)AlwaysSkint Not_Oles Crab
  • ^ interesting; even I got it to boot under Proxmox but unfortunately I can't seem to emulate a 64-bit Intel on my lowend AMD FX.. ;)
    Seems that I got NetBSD installed inside Qemu running on Debian 12 with a Ryzen processor.
    This is not on my Linveo VPS, which is happily running FreeBSD. But I will try NetBSD on the Linveo VPS soon. Probably I also should try an Intel processor. And I should try OpenBSD.
    I like installig with the NetBSD boot-com.iso because I don't have to use a graphical install environment.
    Thu Sep 26 03:08:00 UTC 2024
    NetBSD/amd64 (netbsd.metalvps.com) (constty)
    login: root
    Password:
    Sep 26 03:08:10 netbsd login: ROOT LOGIN (root) on tty constty
    Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003,
        2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013,
        2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023,
        2024
        The NetBSD Foundation, Inc.  All rights reserved.
    Copyright (c) 1982, 1986, 1989, 1991, 1993
        The Regents of the University of California.  All rights reserved.
    NetBSD 10.99.12 (GENERIC) #0: Mon Sep 23 07:35:44 UTC 2024
    Welcome to NetBSD!
    This is a development snapshot of NetBSD for testing -- user beware!
    Bug reports: https://www.NetBSD.org/support/send-pr.html
    Donations to the NetBSD Foundation: https://www.NetBSD.org/donations/
    We recommend that you create a non-root account and use su(1) for root access.
    netbsd#
    Here are some of the steps I followed:
    root@Ryzen-2-vCore-VPS:~/netbsd# cat commands
      182  wget https://nycdn.netbsd.org/pub/NetBSD-daily/HEAD/202409061600Z/amd64/installation/cdrom/boot-com.iso
      183  wget https://nycdn.netbsd.org/pub/NetBSD-daily/HEAD/202409061600Z/amd64/installation/cdrom/SHA512
      184  cat SHA512
      185  ed SHA512SUM
      186  sha512sum -c SHA512SUM
      187  ls -lh
      188  mv SHA512 SHA512-unix
      189  mv SHA512SUM  SHA512SUM-linux
      192  qemu-img create -f qcow2 netbsd.qcow2 50G
    Run the following two commands inside tmux or else kill the qemu process after shutdown of NetBSD.
    root@Ryzen-2-vCore-VPS:~/netbsd# cat install-netbsd
    qemu-system-x86_64 \
    -nographic \
    -cpu host \
    -enable-kvm \
    -m 2048 \
    -drive file=netbsd.qcow2 \
    -cdrom boot-com.iso \
    -boot d
    root@Ryzen-2-vCore-VPS:~/netbsd# cat boot-installed-netbsd
    -nographic \
    -cpu host \
    -enable-kvm \
    -m 2048 \
    -boot c
    I copied the above described NetBSD files previously installed on the Ryzen VPS to another VPS which is running on an Intel processor. Beyond copying the files, all I did on the second VPS was apt-get install qemu-system and bash boot-installed-netbsd.
    SeaBIOS (version 1.16.2-debian-1.16.2-1)
    iPXE (http://ipxe.org) 00:03.0 CA00 PCI2.10 PnP PMM+7EFCF060+7EF0F060 CA00
    Booting from Hard Disk...
    NetBSD MBR boot
    NetBSD/x86 ffsv2 Primary Bootstrap
      \\-__,------,___.
       \\        __,---`  NetBSD/x86 BIOS Boot
        \\       `---,_.  Revision 5.11 (Thu Sep  5 19:12:04 UTC 2024)
         \\-,_____,.---`
         1. Boot normally
         2. Boot single user
         3. Drop to boot prompt
    Choose an option; RETURN for default; SPACE to stop countdown.
    Option 1 will be chosen in 0 seconds.
    21687216+795904+1301248 [947522+1418328+1040172]=0x1b403c8
    Loading /var/db/entropy-file
    [   1.0000000] WARNING: system needs entropy for security; see entropy(7)
    [   1.0000000] cpu_rng: rdrand/rdseed
    [   1.0000000] entropy: ready
    [   1.0000000] entropy: entering seed from bootloader with 256 bits of entropy
    [   1.0000000] Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003,
    [   1.0000000]     2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013,
    [   1.0000000]     2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023,
    [   1.0000000]     2024
    [   1.0000000]     The NetBSD Foundation, Inc.  All rights reserved.
    [   1.0000000] Copyright (c) 1982, 1986, 1989, 1991, 1993
    [   1.0000000]     The Regents of the University of California.  All rights reserved.
    [   1.0000000] NetBSD 10.99.12 (GENERIC) #0: Mon Sep 23 07:35:44 UTC 2024
    [   1.0000000]  [email protected]:/usr/src/sys/arch/amd64/compile/GENERIC
    [   1.0000000] total memory = 2047 MB
    [   1.0000000] avail memory = 1953 MB
    [   1.0000040] mainbus0 (root)
    [   1.0000040] ACPI: RSDP 0x00000000000F59D0 000014 (v00 BOCHS )
    [   1.0000040] ACPI: RSDT 0x000000007FFE1AC6 000034 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: FACP 0x000000007FFE197A 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: DSDT 0x000000007FFE0040 00193A (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: FACS 0x000000007FFE0000 000040
    [   1.0000040] ACPI: APIC 0x000000007FFE19EE 000078 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: HPET 0x000000007FFE1A66 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: WAET 0x000000007FFE1A9E 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: 1 ACPI AML tables successfully acquired and loaded
    [   1.0000040] ioapic0 at mainbus0 apid 0
    [   1.0000040] cpu0 at mainbus0 apid 0
    [   1.0000040] cpu0: Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz, id 0x406f1
    [   1.0000040] cpu0: node 0, package 0, core 0, smt 0
    [   1.0000040] acpi0 at mainbus0: Intel ACPICA 20240827
    [   1.0000040] acpi0: fixed power button present
    [   1.0260721] hpet0 at acpi0: high precision event timer (mem 0xfed00000-0xfed00400)
    [   1.0413615] qemufwcfg0 at acpi0 (FWCF, QEMU0002): io 0x510-0x51b
    [   1.0413615] pckbc1 at acpi0 (KBD, PNP0303) (kbd port): io 0x60,0x64 irq 1
    [   1.0413615] pckbc2 at acpi0 (MOU, PNP0F13) (aux port): irq 12
    [   1.0413615] fdc0 at acpi0 (FDC0, PNP0700): io 0x3f2-0x3f5,0x3f7 irq 6 drq 2
    [   1.0413615] lpt0 at acpi0 (LPT1, PNP0400-1): io 0x378-0x37f irq 7
    [   1.0413615] com0 at acpi0 (COM1, PNP0501-1): io 0x3f8-0x3ff irq 4
    [   1.0413615] com0: ns16550a, 16-byte FIFO
    [   1.0413615] com0: console
    [   1.0413615] ACPI: Enabled 2 GPEs in block 00 to 0F
    [   1.0413615] pckbd0 at pckbc1 (kbd slot)
    [   1.0413615] pckbc1: using irq 1 for kbd slot
    [   1.0413615] wskbd0 at pckbd0 mux 1
    [   1.0413615] pms0 at pckbc1 (aux slot)
    [   1.0413615] pckbc1: using irq 12 for aux slot
    [   1.0413615] wsmouse0 at pms0 mux 0
    [   1.0413615] pci0 at mainbus0 bus 0: configuration mode 1
    [   1.0413615] pchb0 at pci0 dev 0 function 0: Intel 82441FX (PMC) PCI and Memory Controller (rev. 0x02)
    [   1.0413615] pcib0 at pci0 dev 1 function 0: Intel 82371SB (PIIX3) PCI-ISA Bridge (rev. 0x00)
    [   1.0413615] piixide0 at pci0 dev 1 function 1: Intel 82371SB IDE Interface (PIIX3) (rev. 0x00)
    [   1.0413615] piixide0: primary channel interrupting at ioapic0 pin 14
    [   1.0413615] atabus0 at piixide0 channel 0
    [   1.0413615] piixide0: secondary channel interrupting at ioapic0 pin 15
    [   1.0413615] atabus1 at piixide0 channel 1
    [   1.0413615] piixpm0 at pci0 dev 1 function 3: Intel 82371AB (PIIX4) Power Management Controller (rev. 0x03)
    [   1.0413615] piixpm0: 24-bit timer
    [   1.0413615] piixpm0: interrupting at ioapic0 pin 9
    [   1.0413615] iic0 at piixpm0 port 0: I2C bus
    [   1.0413615] vga0 at pci0 dev 2 function 0: vendor 1234 product 1111 (rev. 0x02)
    [   1.0413615] wsdisplay0 at vga0 kbdmux 1
    [   1.0413615] drm at vga0 not configured
    [   1.0413615] wm0 at pci0 dev 3 function 0: Intel i82540EM 1000BASE-T Ethernet (rev. 0x03)
    [   1.0413615] wm0: interrupting at ioapic0 pin 11
    [   1.0413615] wm0: Ethernet address 52:54:00:12:34:56
    [   1.0413615] makphy0 at wm0 phy 1: Marvell 88E1011 Gigabit PHY, rev. 0
    [   1.0413615] makphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
    [   1.0413615] isa0 at pcib0
    [   1.0413615] attimer0 at isa0 port 0x40-0x43
    [   1.0413615] pcppi0 at isa0 port 0x61
    [   1.0413615] spkr0 at pcppi0: PC Speaker
    [   1.0413615] wsbell at spkr0 not configured
    [   1.0413615] midi0 at pcppi0: PC speaker
    [   1.0413615] sysbeep0 at pcppi0
    [   1.0413615] attimer0: attached to pcppi0
    [   1.0413615] acpicpu0 at cpu0: ACPI CPU
    [   1.0413615] vmt0 at cpu0
    [   1.0413615] vmware: open failed, eax=0xffffffff, ecx=0x1e, edx=0x5658
    [   1.0413615] vmt0: failed to open backdoor RPC channel (TCLO protocol)
    [   1.5900700] fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
    [   4.6008251] wd0 at atabus0 drive 0
    [   4.6117617] wd0: <QEMU HARDDISK>
    [   4.6231547] wd0: 51200 MB, 104025 cyl, 16 head, 63 sec, 512 bytes/sect x 104857600 sectors
    [   4.6608406] atapibus0 at atabus1: 2 targets
    [   4.6807660] cd0 at atapibus0 drive 0: <QEMU DVD-ROM, QM00003, 2.5+> cdrom removable
    [   4.6931056] swwdog0: software watchdog initialized
    [   4.7208087] WARNING: 1 error while detecting hardware; check system log.
    [   4.7371525] boot device: wd0
    [   4.7412069] root on wd0a dumps on wd0b
    [   4.7507688] root file system type: ffs
    [   4.7649995] kern.module.path=/stand/amd64/10.99.12/modules
    Thu Sep 26 05:25:30 UTC 2024
    Starting root file system check:
    /dev/rwd0a: file system is clean; not checking
    Setting sysctl variables:
    ddb.onpanic: 1 -> 0
    swapctl: setting dump device to /dev/wd0b
    swapctl: adding /dev/wd0b as swap device at priority 0
    Starting file system checks:
    Loaded entropy from /var/db/entropy-file.
    Waiting for entropy...done
    Setting tty flags.
    Starting network.
    Hostname: netbsd.metalvps.com
    IPv6 mode: host
    Configuring network interfaces: wm0.
    Adding interface aliases:.
    Waiting for duplicate address detection to finish...
    Starting dhcpcd.
    Building databases: dev, utmp, utmpx.
    Starting syslogd.
    Setting date via ntp.
    Mounting all file systems...
    Clearing temporary files.
    Checking quotas: done.
    Starting virecover.
    Checking for core dump...
    savecore: no core dump
    Starting local daemons:.
    Updating motd.
    Starting powerd.
    Starting postfix.
    postfix/postlog: starting the Postfix mail system
    Starting inetd.
    Starting cron.
    Thu Sep 26 05:25:59 UTC 2024
    login: root
    Password:
    Sep 26 05:26:11 netbsd login: ROOT LOGIN (root) on tty constty
    Last login: Thu Sep 26 04:17:44 2024 on constty
        2024
    Welcome to NetBSD!
    netbsd#
    Just for fun, here are, from the Intel machine, the boot messages from the previous boot on the Ryzen machine.
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003,
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]     2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013,
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]     2014, 2015, 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023,
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]     2024
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]     The NetBSD Foundation, Inc.  All rights reserved.
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] Copyright (c) 1982, 1986, 1989, 1991, 1993
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]     The Regents of the University of California.  All rights r.
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] NetBSD 10.99.12 (GENERIC) #0: Mon Sep 23 07:35:44 UTC 2024
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000]  [email protected]:/usr/src/sys/arch/amd64/compile/GEC
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] total memory = 2047 MB
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] avail memory = 1953 MB
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] timecounter: Timecounters tick every 10.000 msec
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] Kernelized RAIDframe activated
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000000] timecounter: Timecounter "i8254" frequency 1193182 Hz quality 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] mainbus0 (root)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: RSDP 0x00000000000F59D0 000014 (v00 BOCHS )
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: RSDT 0x000000007FFE1AC6 000034 (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: FACP 0x000000007FFE197A 000074 (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: DSDT 0x000000007FFE0040 00193A (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: FACS 0x000000007FFE0000 000040
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: APIC 0x000000007FFE19EE 000078 (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: HPET 0x000000007FFE1A66 000038 (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: WAET 0x000000007FFE1A9E 000028 (v01 BOCHS  BXPC     0000)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ACPI: 1 ACPI AML tables successfully acquired and loaded
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] ioapic0 at mainbus0 apid 0: pa 0xfec00000, version 0x11, 24 pis
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] cpu0 at mainbus0 apid 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] cpu0: Use mfence to serialize rdtsc
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] cpu0: AMD Ryzen 9 7950X 16-Core Processor            , id 0xa62
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] cpu0: node 0, package 0, core 0, smt 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] acpi0 at mainbus0: Intel ACPICA 20240827
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] acpi0: X/RSDT: OemId <BOCHS ,BXPC    ,00000001>, AslId <BXPC,0>
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] LNKS: ACPI: Found matching pin for 0.1.INTA at func 3: 9
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] LNKC: ACPI: Found matching pin for 0.3.INTA at func 0: 11
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] acpi0: SCI interrupting at int 9
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] acpi0: fixed power button present
    Sep 26 04:17:27 netbsd /netbsd: [   1.0000040] timecounter: Timecounter "ACPI-Fast" frequency 3579545 Hz qual0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0506526] hpet0 at acpi0: high precision event timer (mem 0xfed00000-0xf)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0506526] timecounter: Timecounter "hpet0" frequency 100000000 Hz qualit0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] qemufwcfg0 at acpi0 (FWCF, QEMU0002): io 0x510-0x51b
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] qemufwcfg0: <QEMU>
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pckbc1 at acpi0 (KBD, PNP0303) (kbd port): io 0x60,0x64 irq 1
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pckbc2 at acpi0 (MOU, PNP0F13) (aux port): irq 12
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] fdc0 at acpi0 (FDC0, PNP0700): io 0x3f2-0x3f5,0x3f7 irq 6 drq 2
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] lpt0 at acpi0 (LPT1, PNP0400-1): io 0x378-0x37f irq 7
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] com0 at acpi0 (COM1, PNP0501-1): io 0x3f8-0x3ff irq 4
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] com0: ns16550a, 16-byte FIFO
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] com0: console
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] ACPI: Enabled 2 GPEs in block 00 to 0F
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pckbd0 at pckbc1 (kbd slot)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pckbc1: using irq 1 for kbd slot
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wskbd0 at pckbd0 mux 1
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pms0 at pckbc1 (aux slot)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pckbc1: using irq 12 for aux slot
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wsmouse0 at pms0 mux 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pci0 at mainbus0 bus 0: configuration mode 1
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pci0: i/o space, memory space enabled, rd/line, rd/mult, wr/ink
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pchb0 at pci0 dev 0 function 0: Intel 82441FX (PMC) PCI and Me)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pcib0 at pci0 dev 1 function 0: Intel 82371SB (PIIX3) PCI-ISA )
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0 at pci0 dev 1 function 1: Intel 82371SB IDE Interface)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0: bus-master DMA support present
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0: primary channel wired to compatibility mode
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0: primary channel interrupting at ioapic0 pin 14
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] atabus0 at piixide0 channel 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0: secondary channel wired to compatibility mode
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixide0: secondary channel interrupting at ioapic0 pin 15
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] atabus1 at piixide0 channel 1
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixpm0 at pci0 dev 1 function 3: Intel 82371AB (PIIX4) Power )
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] timecounter: Timecounter "piixpm0" frequency 3579545 Hz qualit0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixpm0: 24-bit timer
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] piixpm0: interrupting at ioapic0 pin 9
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] iic0 at piixpm0 port 0: I2C bus
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] vga0 at pci0 dev 2 function 0: vendor 1234 product 1111 (rev. )
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wsdisplay0 at vga0 kbdmux 1
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wsmux1: connecting to wsdisplay0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wskbd0: connecting to wsdisplay0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] drm at vga0 not configured
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0 at pci0 dev 3 function 0, 64-bit DMA: Intel i82540EM 1000B)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: interrupting at ioapic0 pin 11
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: 32-bit 33MHz PCI bus
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: 64 words (6 address bits) MicroWire EEPROM
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: RX packet buffer size: 48KB
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: Ethernet address 52:54:00:12:34:56
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wm0: 0x200002<LOCK_EECD,WOL>
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] makphy0 at wm0 phy 1: Marvell 88E1011 Gigabit PHY, rev. 0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] makphy0: Failed to access EADR. Are you an emulator?
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] makphy0: Failed to read EXTSR. Are you an emulator?. Regard as.
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] makphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000bo
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] isa0 at pcib0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] attimer0 at isa0 port 0x40-0x43
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] pcppi0 at isa0 port 0x61
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] spkr0 at pcppi0: PC Speaker
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] wsbell at spkr0 not configured
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] midi0 at pcppi0: PC speaker
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] sysbeep0 at pcppi0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] attimer0: attached to pcppi0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] acpicpu0 at cpu0: ACPI CPU
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] acpicpu0: C1: HLT, lat   0 us, pow     0 mW
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] vmt0 at cpu0
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] vmt0: UUID: 00000000-0000-0000-0000-000000000000
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] vmware: open failed, eax=0xffffffff, ecx=0x1e, edx=0x5658
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] vmt0: autoconfiguration error: failed to open backdoor RPC cha)
    Sep 26 04:17:27 netbsd /netbsd: [   1.0546551] timecounter: Timecounter "clockinterrupt" frequency 100 Hz qua0
    Sep 26 04:17:27 netbsd /netbsd: [   1.4394727] fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
    Sep 26 04:17:27 netbsd /netbsd: [   1.4394727] IPsec: Initialized Security Association Processing.
    Sep 26 04:17:27 netbsd /netbsd: [   4.4294970] wd0 at atabus0 drive 0
    Sep 26 04:17:27 netbsd /netbsd: [   4.4294970] wd0: <QEMU HARDDISK>
    Sep 26 04:17:27 netbsd /netbsd: [   4.4294970] wd0: drive supports 16-sector PIO transfers, LBA48 addressing
    Sep 26 04:17:27 netbsd /netbsd: [   4.4294970] wd0: 51200 MB, 104025 cyl, 16 head, 63 sec, 512 bytes/sect x 1s
    Sep 26 04:17:27 netbsd /netbsd: [   4.4397159] wd0: 32-bit data port
    Sep 26 04:17:27 netbsd /netbsd: [   4.4397159] wd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 5 ()
    Sep 26 04:17:27 netbsd /netbsd: [   4.4397159] wd0(piixide0:0:0): using PIO mode 4, DMA mode 2 (using DMA)
    Sep 26 04:17:27 netbsd /netbsd: [   4.4397159] atapibus0 at atabus1: 2 targets
    Sep 26 04:17:27 netbsd /netbsd: [   4.4498119] cd0 at atapibus0 drive 0: <QEMU DVD-ROM, QM00003, 2.5+> cdrom e
    Sep 26 04:17:27 netbsd /netbsd: [   4.4498119] cd0: 32-bit data port
    Sep 26 04:17:27 netbsd /netbsd: [   4.4498119] cd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 5 ()
    Sep 26 04:17:27 netbsd /netbsd: [   4.4498119] cd0(piixide0:1:0): using PIO mode 4, DMA mode 2 (using DMA)
    Sep 26 04:17:27 netbsd /netbsd: [   4.4498119] swwdog0: software watchdog initialized
    Sep 26 04:17:27 netbsd /netbsd: [   4.4602804] WARNING: 1 error while detecting hardware; check system log.
    Sep 26 04:17:27 netbsd /netbsd: [   4.4602804] boot device: wd0
    Sep 26 04:17:27 netbsd /netbsd: [   4.4602804] root on wd0a dumps on wd0b
    Sep 26 04:17:27 netbsd /netbsd: [   4.4695287] root file system type: ffs
    Sep 26 04:17:27 netbsd /netbsd: [   4.4695287] kern.module.path=/stand/amd64/10.99.12/modules
    Sep 26 04:17:27 netbsd /netbsd: [  13.2395547] wsdisplay0: screen 1 added (80x25, vt100 emulation)
    Sep 26 04:17:27 netbsd /netbsd: [  13.2495518] wsdisplay0: screen 2 added (80x25, vt100 emulation)
    Sep 26 04:17:27 netbsd /netbsd: [  13.2495518] wsdisplay0: screen 3 added (80x25, vt100 emulation)
    Sep 26 04:17:27 netbsd /netbsd: [  13.2495518] wsdisplay0: screen 4 added (80x25, vt100 emulation)
    Sep 26 04:17:35 netbsd ntpdate[351]: step time server 50.205.57.38 offset -0.396531 sec
    Sep 26 04:17:35 netbsd savecore: no core dump
    Sep 26 04:19:11 netbsd syslogd[346]: Exiting on signal 15
    If I add -smp 2 \ to the boot-installed-netbsd command frrom the Ryzen VPS but now copied to the Intel VPS, the next Qemu boot produces the full output shown below, including the two cores:
    [   1.0000040] cpu1 at mainbus0 apid 1
    [   1.0000040] cpu1: Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz, id 0x406f1
    [   1.0000040] cpu1: node 0, package 0, core 1, smt 0
    Full output:
    NetBSD MBR boot
      \\-__,------,___.
         \\-,_____,.---`
         1. Boot normally
         2. Boot single user
    [   1.0000000]     2024
    [   1.0000040] ACPI: RSDT 0x000000007FFE1B21 000034 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: FACP 0x000000007FFE19CD 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: DSDT 0x000000007FFE0040 00198D (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: APIC 0x000000007FFE1A41 000080 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: HPET 0x000000007FFE1AC1 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0000040] ACPI: WAET 0x000000007FFE1AF9 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
    [   1.0199549] hpet0 at acpi0: high precision event timer (mem 0xfed00000-0xfed00400)
    [   1.0330006] qemufwcfg0 at acpi0 (FWCF, QEMU0002): io 0x510-0x51b
    [   1.0330006] pckbc1 at acpi0 (KBD, PNP0303) (kbd port): io 0x60,0x64 irq 1
    [   1.0330006] pckbc2 at acpi0 (MOU, PNP0F13) (aux port): irq 12
    [   1.0330006] fdc0 at acpi0 (FDC0, PNP0700): io 0x3f2-0x3f5,0x3f7 irq 6 drq 2
    [   1.0330006] lpt0 at acpi0 (LPT1, PNP0400-1): io 0x378-0x37f irq 7
    [   1.0330006] com0 at acpi0 (COM1, PNP0501-1): io 0x3f8-0x3ff irq 4
    [   1.0330006] com0: ns16550a, 16-byte FIFO
    [   1.0330006] com0: console
    [   1.0330006] ACPI: Enabled 2 GPEs in block 00 to 0F
    [   1.0330006] pckbd0 at pckbc1 (kbd slot)
    [   1.0330006] pckbc1: using irq 1 for kbd slot
    [   1.0330006] wskbd0 at pckbd0 mux 1
    [   1.0330006] pms0 at pckbc1 (aux slot)
    [   1.0330006] pckbc1: using irq 12 for aux slot
    [   1.0330006] wsmouse0 at pms0 mux 0
    [   1.0330006] pci0 at mainbus0 bus 0: configuration mode 1
    [   1.0330006] pchb0 at pci0 dev 0 function 0: Intel 82441FX (PMC) PCI and Memory Controller (rev. 0x02)
    [   1.0330006] pcib0 at pci0 dev 1 function 0: Intel 82371SB (PIIX3) PCI-ISA Bridge (rev. 0x00)
    [   1.0330006] piixide0 at pci0 dev 1 function 1: Intel 82371SB IDE Interface (PIIX3) (rev. 0x00)
    [   1.0330006] piixide0: primary channel interrupting at ioapic0 pin 14
    [   1.0330006] atabus0 at piixide0 channel 0
    [   1.0330006] piixide0: secondary channel interrupting at ioapic0 pin 15
    [   1.0330006] atabus1 at piixide0 channel 1
    [   1.0330006] piixpm0 at pci0 dev 1 function 3: Intel 82371AB (PIIX4) Power Management Controller (rev. 0x03)
    [   1.0330006] piixpm0: 24-bit timer
    [   1.0330006] piixpm0: interrupting at ioapic0 pin 9
    [   1.0330006] iic0 at piixpm0 port 0: I2C bus
    [   1.0330006] vga0 at pci0 dev 2 function 0: vendor 1234 product 1111 (rev. 0x02)
    [   1.0330006] wsdisplay0 at vga0 kbdmux 1
    [   1.0330006] drm at vga0 not configured
    [   1.0330006] wm0 at pci0 dev 3 function 0: Intel i82540EM 1000BASE-T Ethernet (rev. 0x03)
    [   1.0330006] wm0: interrupting at ioapic0 pin 11
    [   1.0330006] wm0: Ethernet address 52:54:00:12:34:56
    [   1.0330006] makphy0 at wm0 phy 1: Marvell 88E1011 Gigabit PHY, rev. 0
    [   1.0330006] makphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
    [   1.0330006] isa0 at pcib0
    [   1.0330006] attimer0 at isa0 port 0x40-0x43
    [   1.0330006] pcppi0 at isa0 port 0x61
    [   1.0330006] spkr0 at pcppi0: PC Speaker
    [   1.0330006] wsbell at spkr0 not configured
    [   1.0330006] midi0 at pcppi0: PC speaker
    [   1.0330006] sysbeep0 at pcppi0
    [   1.0330006] attimer0: attached to pcppi0
    [   1.0330006] acpicpu0 at cpu0: ACPI CPU
    [   1.0330006] vmt0 at cpu0
    [   1.0330006] vmware: open failed, eax=0xffffffff, ecx=0x1e, edx=0x5658
    [   1.0330006] vmt0: failed to open backdoor RPC channel (TCLO protocol)
    [   1.0330006] acpicpu1 at cpu1: ACPI CPU
    [   1.0330006] fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
    [   4.8446253] wd0 at atabus0 drive 0
    [   4.8662180] wd0: <QEMU HARDDISK>
    [   4.8810130] wd0: 51200 MB, 104025 cyl, 16 head, 63 sec, 512 bytes/sect x 104857600 sectors
    [   4.9298941] atapibus0 at atabus1: 2 targets
    [   4.9512939] cd0 at atapibus0 drive 0: <QEMU DVD-ROM, QM00003, 2.5+> cdrom removable
    [   4.9833706] swwdog0: software watchdog initialized
    [   5.0260930] WARNING: 1 error while detecting hardware; check system log.
    [   5.0497957] boot device: wd0
    [   5.0497957] root on wd0a dumps on wd0b
    [   5.0687481] root file system type: ffs
    [   5.0794291] kern.module.path=/stand/amd64/10.99.12/modules
    Thu Sep 26 06:09:21 UTC 2024
    ddb.onpanic: 1 -> 0
    Setting tty flags.
    Starting network.
    IPv6 mode: host
    Starting dhcpcd.
    Starting syslogd.
    Starting virecover.
    Updating motd.
    Starting powerd.
    Starting postfix.
    Starting inetd.
    Starting cron.
    Thu Sep 26 06:09:51 UTC 2024
    login: root
    Password:
    Sep 26 06:10:02 netbsd login: ROOT LOGIN (root) on tty constty
    Last login: Thu Sep 26 05:26:11 2024 on constty
        2024
    Welcome to NetBSD!
    netbsd#
    Thanked by (1)AlwaysSkint
  • @Not_Oles said: If I add -smp 2 \ to the boot-installed-netbsd command frrom the Ryzen VPS but now copied to the Intel VPS, the next Qemu boot produces the full output shown below, including the two cores:
    I wonder if it could be an old qemu or Linux kernel version running at linveo that could be responsible for the inconsistent cpuid information provided in their Intel VMs?
    Apologies for marketing, but what @cmeerw said just above is a great example of the itch that MetalVPS was born to scratch. No one-click MetalVPS installs as yet, but MetalVPS neighbors can see what's going on inside the Node, including, as @cmeerw mentioned, the Node's kernel and Qemu versions.
    From https://metalvps.com (emphasis added):
    Hello from MetalVPS! :)
    Traditional shell accounts!
    Super fast bare metal performance!
    See what's happening on your Node!
    Make your own VPSes from the command line!
    Thanks to YetiNode Free for hosting MetalVPS.com! <3
  • @linveo Just having a quick look around the installation options on the VM dashboard. From the FreeBSDs only FreeBSD 13.2 seems to install (but only shows a single CPU core), with the other FreeBSDs I get an error at the "Creating configuration." stage.
  • ^ Thought it was just me: I ended up template installing Debian, then restoring my FreeBSD backup. I did intend to start FreeBSD from scratch, using ext4 rather than ZFS 'cos one can shrink/resize ext4.
  • @linveo I would like to surrender my BSD VPS as I am not able to spend enough time into it, please consider my request and let someone else have it if needed.
    Thanked by (3)Not_Oles cmeerw linveo
    BTW, the script to build the image is here: https://bitbucket.org/cmeerw/netbsd-cloud-image/src/main/
