@codelock said: @host_c gpt email about cpu upgrade, if you could share yabs it would be more helpful for people to decide
Don't expect miracles purely CPU-wise, a few percents maybe. The benefit might come from the greater memory bandwidth and new cpu instructions... if your software make use of it.
Single Core | 783
Multi Core | 1386
Full Test | https://browser.geekbench.com/v6/cpu/7958331
Xeon E5-2687W V4 @ 3.0 GHz
Single Core | 992
Multi Core | 1708
Full Test | https://browser.geekbench.com/v6/cpu/7961122
Xeon CPU E5-2690 v4 @ 2.60GHz
Single Core | 818
Multi Core | 1477
Full Test | https://browser.geekbench.com/v6/cpu/7961353
So higher CPU Clock beats Newer Gen with lower CPU Clock in Synthetic Benchmark.
Synthetic tests show only one part of the a performance aspect. The newer the CPU, the newer the Chipset, more modern storage controllers, lower latencies, and so on.
Even if each of those brings 1%, all added up the final product should be better.
Now, if I run something that will make no use of the newer features, then yes, an upgrade like this makes no sense.
For me personally, when I moved my PLEX server from Xeon E5-2687W V4 @ 3.0 GHz to a Xeon Gold 6130 @ 2.1 GHz I saw better performance trans-coding 4K and the over-all VPS worked much faster. SQL Database on the other hand was slower due to the lower CPU Clock.
I swear, the first time I read this, it was: I am loosing minions.
Unless it is Billions, don't open a ticket.
> @Amadex said: Geekbench 6 Benchmark Test:
Test | Value
Single Core | 799
Multi Core | 3321
Full Test | https://browser.geekbench.com/v6/cpu/7903421
YABS completed in 15 min 7 sec
Hmmm, wished for a 850-900 Single Score on this, but hey, the node is pretty bashed to the wall for the moment.
At 6 cores it does scale better then a V4.
We will see what the users say, AVX-512 extensions and the increased memory Bandwidth should translate to better overall performance compared to a V4.
THX for the test!
Hey GiB me my Minions backs!!!!
Don't make me do the summoning!!!
MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
@host_c Now that the storage wall has been built, can we get some more of them BIG fucking offers, pretty please!?
Running windows server 2019 OS on storage server VPS
As promised, here are some details on the move.
We started out with this:
and we had to go to here:
during this time we also decided to upgrade a few stuff:
As usually, we are very organized
by the 7th hour things started to look a little better:
And in the end, we ended up like this.
It almost went perfectly
Hmm. None of the images show up
How about now?
Porn
Amadex • Hosting Forums
True, so here it is:
From @mikewazar
Xeon Gold 6148 @ 2.4 GHz
The two Xeon V4 yabs test I used:
YABS - Xeon E5-2687W V4 @ 3.0 GHz
YABS - Xeon CPU E5-2690 v4 @ 2.60GHz
works for me rn
With or without www?
I see we have a redirect issue from host-c.com to www.host-c.com.
I will put someone to look into it.
NVM
