HOST-C General Downtime 21-SEPT-2024
2»
    @AuroraZero said: Unsuspeticle I am losing Milllions!!!!!!
    I swear, the first time I read this, it was: I am loosing minions. =) =)
    Unless it is Billions, don't open a ticket. B) <3
    Thanked by (1)skorous
    edited September 2024
    > @Amadex said: Geekbench 6 Benchmark Test:
    Test | Value
    Single Core | 799
    Multi Core | 3321
    Full Test | https://browser.geekbench.com/v6/cpu/7903421
    YABS completed in 15 min 7 sec
    Hmmm, wished for a 850-900 Single Score on this, but hey, the node is pretty bashed to the wall for the moment.
    At 6 cores it does scale better then a V4.
    We will see what the users say, AVX-512 extensions and the increased memory Bandwidth should translate to better overall performance compared to a V4.
    THX for the test!
    Hey GiB me my Minions backs!!!!
    Thanked by (1)host_c
    Don't make me do the summoning!!! :tongue:
    MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
  • @host_c Now that the storage wall has been built, can we get some more of them BIG fucking offers, pretty please!? :smiley:
    Thanked by (1)benz
  • edited September 2024
    Running windows server 2019 OS on storage server VPS
    As promised, here are some details on the move.
    We started out with this:
    and we had to go to here:
    during this time we also decided to upgrade a few stuff:
    As usually, we are very organized =) =)
    by the 7th hour things started to look a little better:
    And in the end, we ended up like this.
    It almost went perfectly B)
    1-old-rack
    2-new-rack
    cpu-swap-1
    cpu-swap-2
    Server-to-be-upgrated
    the-cart
    things-flying-arround
    things-flying-arround-2
    from-the-back
    front-view
    Hmm. None of the images show up
    @localhost said: Hmm. None of the images show up
    How about now?
    Thanked by (1)localhost
    Porn
  • @host_c gpt email about cpu upgrade, if you could share yabs it would be more helpful for people to decide
    Don't expect miracles purely CPU-wise, a few percents maybe. The benefit might come from the greater memory bandwidth and new cpu instructions... if your software make use of it.
    root@serv4:~# curl -sL yabs.sh | bash
    #                     v2024-06-09                    #
    Tue Sep 24 16:55:03 UTC 2024
    Uptime     : 3 days, 2 hours, 37 minutes
    Processor  : Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz
    CPU cores  : 2 @ 2394.374 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Kernel     : 6.1.0-25-cloud-amd64
    ISP        : Andrei Tiberiu Holt
    ASN        : AS211462 Andrei Tiberiu Holt
    Host       : Andrei Tiberiu Holt
    Country    : Romania
    Read       | 171.02 MB/s  (42.7k) | 919.40 MB/s  (14.3k)
    Write      | 171.47 MB/s  (42.8k) | 924.24 MB/s  (14.4k)
    Total      | 342.50 MB/s  (85.6k) | 1.84 GB/s    (28.8k)
    Read       | 946.21 MB/s   (1.8k) | 930.56 MB/s    (908)
    Write      | 996.49 MB/s   (1.9k) | 992.54 MB/s    (969)
    Total      | 1.94 GB/s     (3.7k) | 1.92 GB/s     (1.8k)
    Clouvider       | London, UK (10G)          | 740 Mbits/sec   | 988 Mbits/sec   | 42.8 ms
    Eranium         | Amsterdam, NL (100G)      | 616 Mbits/sec   | 986 Mbits/sec   | 26.9 ms
    Uztelecom       | Tashkent, UZ (10G)        | 245 Mbits/sec   | 937 Mbits/sec   | 96.6 ms
    Leaseweb        | Singapore, SG (10G)       | 287 Mbits/sec   | 882 Mbits/sec   | 179 ms
    Clouvider       | Los Angeles, CA, US (10G) | 297 Mbits/sec   | 894 Mbits/sec   | 162 ms
    Leaseweb        | NYC, NY, US (10G)         | 394 Mbits/sec   | 935 Mbits/sec   | 113 ms
    Edgoo           | Sao Paulo, BR (1G)        | 216 Mbits/sec   | 732 Mbits/sec   | 226 ms
    Clouvider       | London, UK (10G)          | 656 Mbits/sec   | 973 Mbits/sec   | 42.8 ms
    Eranium         | Amsterdam, NL (100G)      | 701 Mbits/sec   | 974 Mbits/sec   | 26.2 ms
    Uztelecom       | Tashkent, UZ (10G)        | 262 Mbits/sec   | 928 Mbits/sec   | 96.3 ms
    Leaseweb        | Singapore, SG (10G)       | 290 Mbits/sec   | 866 Mbits/sec   | 179 ms
    Clouvider       | Los Angeles, CA, US (10G) | 351 Mbits/sec   | 867 Mbits/sec   | 161 ms
    Leaseweb        | NYC, NY, US (10G)         | 353 Mbits/sec   | 925 Mbits/sec   | 113 ms
    Edgoo           | Sao Paulo, BR (1G)        | 191 Mbits/sec   | 713 Mbits/sec   | 226 ms
    Single Core     | 783
    Multi Core      | 1386
    Full Test       | https://browser.geekbench.com/v6/cpu/7958331
    YABS completed in 17 min 17 sec
    @codelock said: @host_c gpt email about cpu upgrade, if you could share yabs it would be more helpful for people to decide
    True, so here it is:
    From @mikewazar
    Xeon Gold 6148 @ 2.4 GHz
    Single Core     | 783
    Multi Core      | 1386
    Xeon E5-2687W V4 @ 3.0 GHz
    Single Core     | 992
    Multi Core      | 1708
    Full Test       | https://browser.geekbench.com/v6/cpu/7961122
    Xeon CPU E5-2690 v4 @ 2.60GHz
    Single Core     | 818
    Multi Core      | 1477
    Full Test       | https://browser.geekbench.com/v6/cpu/7961353
    So higher CPU Clock beats Newer Gen with lower CPU Clock in Synthetic Benchmark.
    Synthetic tests show only one part of the a performance aspect. The newer the CPU, the newer the Chipset, more modern storage controllers, lower latencies, and so on.
    Even if each of those brings 1%, all added up the final product should be better.
    Now, if I run something that will make no use of the newer features, then yes, an upgrade like this makes no sense.
    For me personally, when I moved my PLEX server from Xeon E5-2687W V4 @ 3.0 GHz to a Xeon Gold 6130 @ 2.1 GHz I saw better performance trans-coding 4K and the over-all VPS worked much faster. SQL Database on the other hand was slower due to the lower CPU Clock.
    The two Xeon V4 yabs test I used:
    YABS - Xeon E5-2687W V4 @ 3.0 GHz
    root@test:~# curl -sL yabs.sh | bash
    #                     v2024-06-09                    #
    Tue Sep 24 20:29:37 UTC 2024
    Uptime     : 0 days, 0 hours, 2 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2687W v4 @ 3.00GHz
    CPU cores  : 2 @ 2999.996 MHz
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Host       : Host C
    Country    : Romania
    Read       | 212.88 MB/s  (53.2k) | 450.88 MB/s   (7.0k)
    Write      | 213.44 MB/s  (53.3k) | 453.25 MB/s   (7.0k)
    Total      | 426.33 MB/s (106.5k) | 904.13 MB/s  (14.1k)
    Read       | 763.97 MB/s   (1.4k) | 968.30 MB/s    (945)
    Write      | 804.57 MB/s   (1.5k) | 1.03 GB/s     (1.0k)
    Total      | 1.56 GB/s     (3.0k) | 2.00 GB/s     (1.9k)
    Clouvider       | London, UK (10G)          | 1.19 Gbits/sec  | 1.88 Gbits/sec  | 31.6 ms
    Eranium         | Amsterdam, NL (100G)      | 1.31 Gbits/sec  | 4.97 Gbits/sec  | 31.6 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.13 Gbits/sec  | 1.25 Gbits/sec  | 98.5 ms
    Leaseweb        | Singapore, SG (10G)       | 1.09 Gbits/sec  | 967 Mbits/sec   | 176 ms
    Clouvider       | Los Angeles, CA, US (10G) | 927 Mbits/sec   | 1.01 Gbits/sec  | 162 ms
    Leaseweb        | NYC, NY, US (10G)         | 1.81 Gbits/sec  | 1.11 Gbits/sec  | 108 ms
    Edgoo           | Sao Paulo, BR (1G)        | 748 Mbits/sec   | 731 Mbits/sec   | 220 ms
    Single Core     | 992
    Multi Core      | 1708
    YABS completed in 13 min 31 sec
    YABS - Xeon CPU E5-2690 v4 @ 2.60GHz
    #                     v2024-06-09                    #
    Tue Sep 24 20:48:09 UTC 2024
    Uptime     : 0 days, 0 hours, 0 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
    CPU cores  : 2 @ 2599.996 MHz
    RAM        : 3.8 GiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Host       : Host C
    Country    : Romania
    Read       | 98.99 MB/s   (24.7k) | 915.38 MB/s  (14.3k)
    Write      | 99.25 MB/s   (24.8k) | 920.19 MB/s  (14.3k)
    Total      | 198.25 MB/s  (49.5k) | 1.83 GB/s    (28.6k)
    Read       | 2.35 GB/s     (4.6k) | 810.53 MB/s    (791)
    Write      | 2.48 GB/s     (4.8k) | 864.51 MB/s    (844)
    Total      | 4.84 GB/s     (9.4k) | 1.67 GB/s     (1.6k)
    Clouvider       | London, UK (10G)          | 3.00 Gbits/sec  | 4.92 Gbits/sec  | 31.6 ms
    Eranium         | Amsterdam, NL (100G)      | 4.42 Gbits/sec  | 4.48 Gbits/sec  | 31.9 ms
    Uztelecom       | Tashkent, UZ (10G)        | 2.23 Gbits/sec  | 1.53 Gbits/sec  | 98.7 ms
    Leaseweb        | Singapore, SG (10G)       | 1.13 Gbits/sec  | 978 Mbits/sec   | 176 ms
    Clouvider       | Los Angeles, CA, US (10G) | 945 Mbits/sec   | 971 Mbits/sec   | 163 ms
    Leaseweb        | NYC, NY, US (10G)         | 1.75 Gbits/sec  | 1.63 Gbits/sec  | 108 ms
    Edgoo           | Sao Paulo, BR (1G)        | 868 Mbits/sec   | 747 Mbits/sec   | 220 ms
    Single Core     | 818
    Multi Core      | 1477
    YABS completed in 14 min 18 sec
    Thanked by (3)mikewazar Shot² lukast__
  • @tetech said:
    works for me rn
  • tetechtetech OG
    @mikewazar said:
    @tetech said:
    works for me rn
    With or without www?
    $ echo | openssl s_client -showcerts -servername host-c.com -connect host-c.com:443 2>/dev/null | openssl x509 -inform pem -noout -text
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number: 29421 (0x72ed)
            Signature Algorithm: sha256WithRSAEncryption
            Issuer: C = --, ST = SomeState, L = SomeCity, O = SomeOrganization, OU = SomeOrganizationalUnit, CN = localhost.localdomain, emailAddress = [email protected]
            Validity
                Not Before: Jan 17 11:40:32 2022 GMT
                Not After : Jan 17 11:40:32 2023 GMT
            Subject: C = --, ST = SomeState, L = SomeCity, O = SomeOrganization, OU = SomeOrganizationalUnit, CN = localhost.localdomain, emailAddress = [email protected]
            Subject Public Key Info:
                Public Key Algorithm: rsaEncryption
                    RSA Public-Key: (2048 bit)
                    Modulus:
                        00:bb:0d:dd:b4:10:be:fe:2a:f6:85:bd:4b:99:55:
                        14:e7:8d:cb:8d:d3:c8:cf:0f:05:3b:ab:9e:ce:c5:
                        58:2d:6b:24:14:f7:1a:51:09:dc:c9:ab:b0:c2:dc:
                        f9:d8:b4:72:60:e8:52:88:e6:54:23:34:1e:db:24:
                        b7:b0:b7:ae:39:8c:66:38:db:41:a3:fe:08:9f:7c:
                        15:32:94:ef:ab:01:f0:2a:8b:b1:db:ec:c2:cb:e6:
                        fc:72:a1:fc:2b:3d:f0:60:81:ef:73:37:62:d9:7b:
                        0e:35:3b:48:19:37:af:8f:a7:6a:eb:50:59:a7:22:
                        ad:a6:54:bb:80:6a:bd:7e:0a:ce:4a:5e:33:5f:7a:
                        4e:f8:8f:31:20:64:74:3e:a3:71:43:3e:24:ce:c6:
                        51:88:e8:7b:63:dd:14:ca:d7:75:b9:fa:e6:69:0d:
                        0c:c5:27:cf:2e:0b:4d:12:f9:3d:1e:dd:67:45:78:
                        1b:fe:56:a8:45:10:1b:59:1e:20:4f:86:61:ca:e8:
                        3c:e4:9e:ce:2f:cf:0a:74:88:45:49:14:65:35:70:
                        a0:22:2b:eb:9e:40:2a:ce:1a:10:17:22:6a:df:0e:
                        9e:05:aa:aa:18:9e:41:98:e9:e2:0f:e4:4b:04:d7:
                        3f:07:c7:0b:19:5e:f0:e9:92:4f:05:df:96:8b:3b:
                        ba:6b
                    Exponent: 65537 (0x10001)
            X509v3 extensions:
                X509v3 Basic Constraints:
                    CA:FALSE
                X509v3 Key Usage:
                    Digital Signature, Non Repudiation, Key Encipherment
             3e:6c:32:f8:30:ab:42:e8:89:3b:ec:41:9a:09:cf:9c:6a:ac:
             82:9f:8d:5e:5d:65:21:f1:39:3b:5a:3c:db:3f:57:83:3f:7e:
             97:64:50:f1:94:68:40:fe:6b:90:6c:4c:1a:d6:9b:01:73:cf:
             43:3b:57:66:ec:fc:a0:78:e7:38:85:f7:5d:27:e2:c9:dc:f0:
             79:dd:1a:a0:34:84:3f:35:77:54:0d:7a:ad:b5:79:c8:25:19:
             e0:4e:8a:05:66:57:c0:93:fc:64:1a:30:54:e9:2b:5e:84:e8:
             b2:2b:29:70:e5:a3:7d:ba:7b:10:f6:13:3e:01:68:25:6b:28:
             47:d4:71:8c:9e:74:38:bb:15:d5:8b:1c:63:75:49:85:8c:6b:
             1e:00:7b:d9:52:a4:87:26:d9:27:f4:a6:c5:d5:2d:f8:11:87:
             a3:14:c5:e0:38:2f:29:cf:cf:d0:c0:13:98:26:b3:2d:9a:e5:
             07:4c:fc:a3:79:81:88:48:2d:66:13:60:f2:9c:11:f0:a0:24:
             75:1f:e4:dd:20:7b:78:97:71:12:a2:9d:79:7f:0c:a2:3b:32:
             f4:90:6d:ad:16:bc:35:fc:14:39:3e:84:df:e7:71:61:00:98:
             0e:f2:7f:d8:85:82:c9:b6:73:7d:ee:30:9f:24:b4:0a:72:b9:
             18:14:2b:fa
    @tetech said: With or without www?
    I see we have a redirect issue from host-c.com to www.host-c.com.
    I will put someone to look into it.
    NVM
