18910111214»
  • @Neoon said:
    Maintenance Announcement
    Most of the Nodes are still running Proxmox 7, which is EOL end of this month.
    So they need to be upgraded, you can expect up to 30 minutes of downtime per Node.
    I will start upgrading the Nodes next Friday (26.07) at around 20:00 CET, one by one.
    Once its done, I will post here again.
    Will be done on Sunday instead, same time though.
    Thanked by (3)carlin0 tuc Wonder_Woman
  • havochavoc OGContent Writer
    edited July 26
    41a033760922ee59773dc33631410d4d85859cef
    Usage will be searx and a http proxy. Low usage & will be secured so that it's not open - just me
    Will process your request shortly, currently migrating the website over to another server.
    Thanks! No rush on mine
    Deployed.
    All nodes have been upgraded.
    If you notice any issues, please lemme know.
  • jqrjqr OG
    edited July 28
    My Valdivia node is not accessible. The Dashboard shows it's online, but clicking on Manage gives me an error: "Failed to contact Node, please try again later."
    Just thought I'd led you know as you asked. No rush. Thank you for offering the service.
    edit: Oops, wrong service. My bad.
    It's pronounced hacker.
    Could you check if there's any issue with IPv6 in Fremont? Gateway is reachable but nothing beyond.
    default via fe80::4a8:e8ff:fe78:754d dev eth1 proto ra metric 1024 expires 1600sec hoplimit 64 pref medium
    [root@vps129 ~]# ping6 fe80::4a8:e8ff:fe78:754d%eth1
    PING fe80::4a8:e8ff:fe78:754d%eth1(fe80::4a8:e8ff:fe78:754d%eth1) 56 data bytes
    64 bytes from fe80::4a8:e8ff:fe78:754d%eth1: icmp_seq=1 ttl=64 time=0.166 ms
    64 bytes from fe80::4a8:e8ff:fe78:754d%eth1: icmp_seq=2 ttl=64 time=0.167 ms
    64 bytes from fe80::4a8:e8ff:fe78:754d%eth1: icmp_seq=3 ttl=64 time=0.169 ms
    64 bytes from fe80::4a8:e8ff:fe78:754d%eth1: icmp_seq=4 ttl=64 time=0.158 ms
    ^C
    --- fe80::4a8:e8ff:fe78:754d%eth1 ping statistics ---
    4 packets transmitted, 4 received, 0% packet loss, time 2999ms
    rtt min/avg/max/mdev = 0.158/0.165/0.169/0.004 ms
    [root@vps129 ~]# ping6 2a09::
    PING 2a09::(2a09::) 56 data bytes
    ^C
    --- 2a09:: ping statistics ---
    9 packets transmitted, 0 received, 100% packet loss, time 8000ms
    ^C
    ^C
    Fixed, sorry for that.
    Thanked by (1)Brueggus
  • 89d000a72288b04a2a5fd73522f42fff8f580fff
    Hoping for a basic VPS for monitoring and some small services that is a bit out of band from what I currently have...
    Deployed.
    oh nOo! my uptime :grimace:
    Deployed.
    Thank you so much. I feel bad, you deployed it so fast and I haven't had a chance to stop by and say thanks yet.
  • Can I apply
  • @abyssvpn said:
    Can I apply
    Can you read?
    Thanked by (2)bliss ElonBezos
  • Returning to work with Information Technology and networks, leaving a job as a rescuer in the public service of health, I believe that a vps like this already helps to do the tests and learning I need.
    Token
    325fc5088885918829ed58d5f4146368d1b53152
  • Fremont had network issues about an hour ago.
    IPv6 still dead, waiting for fix.
    Thanked by (1)Wonder_Woman
    IPv6 is back up since roughly 1 hour.
    If you still have issues, lemme know.
    Thanked by (2)Wonder_Woman ElonBezos
    Still not working for me. I can ping the default gateway on eth1 but nothing beyond (Google, for example)
    Yikes, they fixed it last time now it broke again.
    Ticket is out, I suggested a permanent fix, will see, I report back.
    Thank you, it just came back online
    Yes but its not a permanent fix though.
    There will be another network maintenance.
    Then we should have a permanent fix.
