@fr99ths said: Is there a law to protect customers in case of the issue above happened?
Yes.
@fr99ths said: If the host lied, what could the customer do?
Chargeback and sue.
That is the trick on which the provider relies their whole business model on. Chargebacks are not worth the time spent for justification of €10; suing ain't worth the effort for a €10 loss.
In my opinion not even the stress itself is worth €10, even though the time waiting for an "apt update" command to complete is worth more than that. The stress appears when one thinks of all the people who fall for this kind of offers, while the provider oversells even further, then suspends accounts to oversell even more.
Some form of unity between people is always needed, because when they're divided they are being taken for granted and even conquered (as seen throughout history).
No trick or business model as some conspirators might think.
Simply the Client was reported for abuse from 4 of his 6 VPS, which was also causing him to be completely banned from accessing his servers... The whole thing was solved by reinstalling the VPS that apparently had been compromised (they were running ddos attacks to external IP addresses).
Thanks
Furthermore, we'd like to exceptionally mention that this customer opens also fraudulent PayPal cases, knowing well the website is available and their access IP is the problem and actively refuses to comply accordingly, in order to attempt to get their money back, also creating multiple tickets for a given issue as well. Similar connection issues also arose on our end as well for this customer, possibly for similar reasons.
We usually don't provide or talk about this information, but exceptionally we'll have to provide this detail as well: this is someone that knows what is doing (in terms of malicious action). Therefore, it can't be of much surprise that such termination occurred, as it also occurred on our side as well.
Otherwise, each provider's work is each provider's work, we just wanted to mention this one as well; and state that for this particular case, having abuse reports taking down 4 out of 6 VPSes is, unfortunately, not a coincidence.
We had to outright blacklist the customer today.
Okay I am going to weigh in here and this goes for everyone.
I personally run on facts, if you do not have or do not provide proof of what you say I will treat it as a baseless accusation.
I treat everyone the same host or user and I have been sick and tired of the baseless accusations that get thrown around. If you want me to take you seriously then provide proof, you can even PM it me if it makes it easier.
Naturally can't talk for C1VHosting nor their uptime questions, those are with them, but if you need specifically for this one on our end, I'll willingly send you a PM with these details. We have all the necessary evidence and facts archived and on our servers as well (we had to, really).
Yes.
Chargeback and sue.
Thanks
Appreciate the offer but, this is more of a general note. If someone has a rblem with your actions we will take it up at the that time, until then I do not require anything.
Yes.
Chargeback and sue.
Thanks
A good popcorn drama appears when there are facts and complaints are backed by proof (such as screenshots). A simple baseless accusation does not usually turn into a popcorn drama, unless there are many people complaining at the same time and emotion takes over.
It is like in court where you see yourself as judge; strong proof, many complaints or many witnesses gives you a case to moderate.
I honestly think you expect too much from a service that is VERY cheap and whose goal is to make Cloud services accessible even to the smallest wallets .........
c1vhosting IPv6 website is now UP
Downtime: 19 hr 16 min
This is fun. IPv4 went down for 18 hours and few hours later IPv6 went down for 19 hours.
I guess there are dedicated routers for IPv4 and another for IPv6 and it just took little longer to replace it
/s
I don't know if anyone else has encountered too but my VPS was stopped on 07:16 am UTC, Sept 13, which I thought another outage at first, later I realised it was not because nobody complained here after 2 days. So I just logged into the control panel then started the VPS manually.
This is quite normal. It starts with abnormal high CPU steal and then suddenly your VPS is gone. It then seems to have been shutdown, and manual intervention (of you, the customer) is needed. Ofcourse most other hostsers won't even get to the point that a VPS is shut down automatically, but (although it happens regularly) this sh*tshow doesn't do anything about it.
And why nobody complains? You're getting numb for it I guess. At least I got the same thing around the same time and restarted the thing to idle again.
The offer is oversold so much that even idling is using too much CPU from the host.
I reserve the right to license all of my content under: CC BY-NC-ND. What happens on this forum should stay on this forum.
then STOP idling it!
In my defense: I only idle it for about 90% of the time. The remaining 10% the VPS is either down or unreachable.
My $0.92 / month NetCup vps is 100x more stable
An example that low cost should not mean low quality.
@hostmonit said:
My server is down. Please check it out.
What do you expect @c1vhosting to do with this kind of information? Without any ID, IP, login, anything? Like... he should manually check all the virtual servers and then he guess which one offline is yours?
Your VPS most likely is just running (try IPv6 - o wait, that can also respond when the server is really off... then just look in the Client Area in your NoVNC), but the IPv4 address isn't responding - it even seems that the BGP is f*cked up. Ofcourse with the mail of Tuesday that IP ranges would get changed and we'd get a 2 weeks "grace period", it could very well be that people changed their mind and the grace period is over after 4 days...
Thank you, I successfully connected to my VPS via IPv6
Performance Advisory: This provider is designed for basic tasks and is not suitable for high-performance ticket responses.
Clarifications are needed because it is all quite confusing:
Make it a fill in form:
A - services
B - tickets
C - Quality of the responses
D - All of the above
D - D then.
I don't know what to say when IPv6 network is down after IPv4 being down and up.
Daily core router replacement! It will be better from now on.
Refer to this
https://lowendspirit.com/discussion/comment/182477/#Comment_182477
/s
Great, it is back online for now.
C1VHOSTING: more customers, more problems.
Now also Poor Speeds on POM4 never was an issue before
network is down again
what a joke
What is down sorry?
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
So far so good.
autoboot needed
1000x you mean
wait that didnt sound right either
Open a ticket. https://osticket-bbvyvxqybd17b1mnd.c1vhosting.it/upload/index.php
VPS returned (on IPv4) again. Downtime: 17 hours.
You're luck, my IPv4 is still down.
Edit:
Yes the IPv4 is actually up now, but with heavy packet losses:
While 1.0.0.1 is totally inaccessible.
