@c1vhosting said: I have updated your old IPv4 as you pasted it here
and after clicking reconfigure network I had to fix stuff manually. Fun stuff.
HINT: If you give someone IP from 5.59.249.[129-255] don't set network mask to 25 if default route is via 5.59.249.1. It's different network.
No idea how you managed to broke autoconfigure to even do this.
# This file is generated from information provided by the datasource. Changes
# to it will not persist across an instance reboot. To disable cloud-init's
# network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
ethernets:
eth0:
accept-ra: false
addresses:
- 5.59.249.1XX/25
dhcp4: false
nameservers:
addresses:
- 1.1.1.1
- 8.8.8.8
routes:
- metric: 100
to: 0.0.0.0/0
via: 5.59.249.1
version: 2
Dear Customer,
We are writing to inform you of scheduled maintenance on our equipment.
Scheduled Maintenance Notification Description: We will be performing a software update on our systems to improve the performance and stability of your services.
Start Time: October 25, 2024, 21:00 CET
End Time: October 26, 2024, 00:00 CET
Maintenance Window Estimated: Up to 3 hours
Affected Services (Full Outage): ID 2720 - PADUA
We apologize for any inconvenience this may cause and appreciate your understanding.
A wild Scheduled Maintenance appeared.
Again.
This time with 3 days notice, progreeeeeeeessssssssss.
And this time it's not n+1 power! Can you imagine?
If anyone wanna place bets when it will start and end please do, but we need someone to report when it actually started as my
the old IP address is no longer operational. The new IP has been activated only for those who have requested it.
this
It's simple: for some reason our kid can't have that original IP range anymore and asked his mom for a new one. But he has to migrate all current users to the new range. Every descent provider would allocate new IPs to users and communicate with the customers that they'd have a grace period in which both are available. Not Luca. His "AI" came up with another solution: let the users ask for it with a grace period. Trouble is: almost nobody asks. So AI came up with a solution: mess up connectivity to the old range so people are more willing to ask. And AI also mentioned that that would be a very good scheme, because every user not being able to use the service is potential money to be made.
this
in summary
scam
i dont give a fuck what he asks his mom or anyone for
@cochon said: the old IP address is no longer operational. The new IP has been activated only for those who have requested it.
This sounds like: I sold hosting services to you, but at some point, I decided to sell your IPs to someone else to cover garage DC rent. If you really want a new IP, please request it - otherwise, you won't have one.
That’s exactly the strategy in my opinion
And since its services are unstable, very few people were motivated to apply. I didn't.
For me at this stage it becomes a scam. I'm not going to be tolerant again.
I'm sorry to bother but after the latest upgrade or maintenance, the network got high packet loss both inbound and outbound:
user@c1v:~$ ping -6 dns.google -qc 80
PING dns.google (2001:4860:4860::8888) 56 data bytes
--- dns.google ping statistics ---
80 packets transmitted, 75 received, 6.25% packet loss, time 79157ms
rtt min/avg/max/mdev = 10.130/10.204/10.366/0.041 ms
Hello,
Thanks for reporting. I will continue to monitor reachability from our monitors, as soon as a packet is lost I will be there to track down the problem.
Hello,
Are you sure you monitor every packet? I get bad results too.
Thanks for recommending, but the provider account was registered in this May and has only 16 comments so far, with no discussions.
I'm not 100% or even 80% sure, but C1V has joined this forum for more than 2 years. I will leave your recommendation untouched, wait until at least 2026 to see if that account is still active then.
That is entirely your choice.
As long as you are happy with your c1v vps, no need to look for any alternatives.
Short YABS for ChunkServe VPS
CPU Model : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
CPU Cores : 2 @ 2397.223 MHz
CPU Cache : 35840 KB
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 822
Multi Core | 1621
Full Test | https://browser.geekbench.com/v5/cpu/23006846
Test | Value
Single Core | 1010
Multi Core | 1836
Full Test | https://browser.geekbench.com/v6/cpu/8533634
Location Latency Loss DL Speed UP Speed Server
Nearest 1.36 ms 0.0% 4621.39 Mbps 3069.40 Mbps PremierDC Verimerkezi A.S - Istanbul
Dallas, US 159.14 ms 0.7% 1896.47 Mbps 46.80 Mbps i3D.net - Dallas, TX
Houston, TX 152.34 ms 0.0% 2344.96 Mbps 480.04 Mbps Ezee Fiber - Houston, TX
Chicago, IL 145.71 ms 0.0% 1.42 Mbps 44.12 Mbps Enzu.com - Chicago, IL
Miami, FL 151.53 ms N/A 2062.96 Mbps 541.83 Mbps Dish Wireless - Miami, FL
Miami, FL 143.15 ms 0.0% 1652.94 Mbps 393.23 Mbps ReliableSite Hosting - Miami, FL
Spokane, WA 216.74 ms 0.0% 1957.78 Mbps 343.94 Mbps Crunchbits - Spokane, WA
Seattle, WA 187.99 ms 0.0% 1.87 Mbps 54.42 Mbps Misaka Network, Inc. - Seattle, WA
Los Angeles, US 172.71 ms 0.0% 2005.28 Mbps 361.19 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 196.18 ms 0.3% 1.66 Mbps 142.18 Mbps Misaka Network, Inc. - San Jose, CA
London, UK 49.15 ms 0.0% 4873.83 Mbps 688.50 Mbps VeloxServ Communications - London
Amsterdam, NL 46.66 ms 0.3% 4168.02 Mbps 108.72 Mbps 31173 Services AB - Amsterdam
Paris, FR 55.22 ms N/A 4795.03 Mbps 527.50 Mbps Axione - Paris
Frankfurt, DE 35.46 ms 0.0% 3226.96 Mbps 814.84 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 43.83 ms 0.0% 5092.54 Mbps 817.68 Mbps Play - Warszawa
Kyiv, UA 46.48 ms 0.0% 2970.81 Mbps 685.81 Mbps O3 - Kyiv
Bangalore, IN 193.88 ms 0.0% 64.64 Mbps 311.09 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 337.50 ms N/A 2.37 Mbps 27.71 Mbps Jio - Chennai
Mumbai, IN 172.27 ms 0.7% 1327.13 Mbps 41.26 Mbps i3D.net - Mumbai
Mumbai, MH 224.76 ms N/A 157.43 Mbps 122.27 Mbps Jio - Rajkot
Notification Description: Our upstreams are going to perform a software update on their systems to improve the performance and stability of your services.
Start Time: October 29, 2024, 01:00 CET
c1vhosting IPv4 website is now DOWN.
Noticed at: 2024-10-29 00:17:41 (UTC+01:00)
You sure you translated times correctly? Got hit by DST?
It seems to have started like 43 minutes too early.
he should quit hosting and explore alternative career in comedy.
I have just posted another YABS for another low price VPS (10 euro/year)
https://lowendspirit.com/discussion/comment/188442/#Comment_188442
Check OGF thread for DeluxHost.
Low Performance Advisory
lol fucking scammy bullshit
AI did it. It was trained wrong.
i have seen many but this c1vhosting IP shortage scam is definitely the first!
We received two Planned Maintenance Update notices this week.
We have no idea what's changed.
C1V scammer VPN is still working for us.
17 Mbps download, 48 Mbps upload.
vps9hostname is available. affbrrWhat do you mean by "IP shortage scam"?
this
this
in summary
scam
Hello,
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
502 Bad Gateway
@bliss
Another offer from OGF
Search ChunkServe
everything down now...
There was a planned maintenance
HAHAHAHAAHAAHABABAHAHAHABAABAAHAHAAB
My impression is that he is doing exactly that for quite a few months now... Both without real success though.
I chuckled reading this
https://www.c1vhosting.it/datacenter.php
Running Windows Server 2019 on $10/year VPS that is much better than c1v.
YABS -
https://lowendspirit.com/discussion/comment/188840/#Comment_188840
