Anyone tried CasaOS?
The question is in the title. Do you like it?
url: https://casaos.zimaspace.com/
Are there any alternatives?
I like their self-hosted app store:
Thanked by (1)seenu
Was tempted to, but never did
I found https://umbrel.com/, but per Reddit that's a commercial version and it's not open-source.
I'm running Casa on a Rock5C at the moment, main reason was the for the AppStore/docker-compose environment - I like to have an easy to use interface for quickly testing out or trying docker applications prior to deploying them in a production or standalone environment and it makes it a bit simpler to do so.
Plus it has a pretty nice dashboard bundled in and you can also also add 3rd party repositories to the AppStore which broadens the selection way more.
lex.st - Free Shared Hosting in 4 Locations. fk ipv6.
I did not test CasaOS yet, will do when I will find the time.
Possible open-source alternatives:
More complete list from Cloudron's forum: https://forum.cloudron.io/topic/10000/a-list-of-cloudron-like-services-competitors
Seems like their umbrelOS is open source according to the site and they also link to their github
https://github.com/getumbrel/umbrel
"umbrelOS is licensed under the PolyForm Noncommercial 1.0.0 license. TL;DR — You're free to use, fork, modify, and redistribute Umbrel for personal and nonprofit use under the same license"
I remember umbrel being really popular among people hosting their own crypto nodes and other privacy software. Should be good.
From what I remember its just a fancy frontend to Docker containers.
Another one to consider is Cosmos-Cloud. You can integrate the CasaOS apps and others into the cosmos app store (market, whatever) by just adding it as a source. Pretty legit and fairly new considering some of the alternatives. The only thing behind a paywall is some VPN setup that allows you to tunnel to the server, but there are apps that offer that already. I haven't delved that deeply into it, but it's worth taking a look at.
https://cosmos-cloud.io/
https://github.com/azukaar/Cosmos-Server
comparison table on the github:
@slownedstark this looks much better, thx
Happy to use CasaOS (more than 1 year) for my Jellyfin server (3 vCPU, 4.5 GB RAM, 125 GB SSD), running with SSL subdomain (Cloudflared) and connected to another storage server (1 TB HDD) with Samba and MyVestaCP ✔
@Amadex
hows it going? why u look like the terminator in this pic ? i am used to see you in porn or smiling
@TheDP and his raw cocaine straight from 🇧🇴 is guilty!
hahahha @TheDP continues to surprise us
I haven't tried it yet, but it looks like I have to now!
You can't unsee it now.
CasaOS is so niceee, been using for 1 years +++, it is nice that you can run your own container normal way with YAML not limited to their stores apps
Say no to drugs, Gen Zs
✅ CasaOS easy 1-line installation
✅ Easy and intuitive control panel
✅ Simple control panel update
✅ Simple app (Jellyfin) update
use casaOS on android stb (hg680p).
docker pihole, torrent downloader and samba share (nas) usb hdd
easy to use and noob friendly
thanks for this,
i am planning to use home (or any alternative) for a long time, this looks more easy...will try.
ThemeForest Profile
I never knew about this. Will give it a try. Thank you op
It's a nice way to use your idlers 🫶🏻😆
just found accidentally...if you install aapnel...you get almost all of these images in their docker section too.
i thought of installing this in a vps where i have aapanel already
and installed this using installation script but IP:81 is not opening so i opened aapanel docker section to see if docker is running or not...but found similar apps...i thought may be aapanel auto imported casaos so showing all those...
but now installed aapnel in another vps and went to docker section and it has all those scripts too.
nice finding actually...
ThemeForest Profile
@TheDP someone say drugs?
Free Hosting at YetiNode | MicroNode | Cryptid Security | URL Shortener | LaunchVPS | ExtraVM | Host-C | In the Node, or Out of the Loop?
i started using this and worked well for 3-4days
now for last couple of days, it refuse to open casa dashboard
all other docker images working fine.
but if i want to stop/restart those docker images, i need casa dashboard.
best feature i like are file manager and terminal access within dashboard.
ThemeForest Profile
I am using Unraid and I am really happy with it.
I use caprover.
does it have docker images option?
i think this is an alternate to coolify
ThemeForest Profile
How easy is casa to set up? Tempted to use it to explore apps fast...and then deploy them on k3s/docker
It's a one-liner
wget -qO- https://get.casaos.io | sudo bash
very easy and usage is also breeze
but look at my issue i said above.
after few days, its panel is not opening...i changed ports, restarted casa service, even server...same issue.
on good side, since it is seperated from launched docker images, they run properly without any problems.
ThemeForest Profile
