@nullnothere said: @VirMach that was a class act by @Wonder_Woman and I think you should release a code in hono(u)r of the achievement exclusively for him/her.
Of course for the rest of us clapping here, it'll be nice to have something - we are happy to clap more for you as well.
Alright, here's a coupon code. It's hidden in between 8 other coupon codes, and it's using the SHA256 cipher (am I pronouncing that right?) Anyway it should be really easy.
@Wonder_Woman said: Turns out the SHA256 "cipher" bit was all a red herring.
i just googled sha256 decode and tried to decode it which turned no results. now it seemed so easy
I wrote a couple scripts to try a couple different methods of running all the codes from the cipher in every permutation to SHA256 and trying to compare with what he posted. I'm not sure what made me realize it was just right there.
Alright, this one is going to be hard but it has 50 x 50% off recurring coupons inside it, so I recommend you guys create some type of community task force and crack it together since there should be plenty of codes for everyone once it's cracked. You'll see that one of you might not be in the positionto figure it out, but maybe three or five might ringa bell or two
You only have about eight ten hours to solve this, as all coupons will expire midnight PST on Cyber Monday. If it's solved, coupons can be extended to work later into the sale. There is no consolation prize, so waste your time at your own risk.
I might be doing some custom sales for Cyber Monday later tonight (I'd say at sunset but the sun's setting way too early) so solve it earlier if you want to be able to use the codes on those.
@VirMach said: You only have about eight ten hours to solve this, as all coupons will expire midnight PST on Cyber Monday. If it's solved, coupons can be extended to work later into the sale. There is no consolation prize, so waste your time at your own risk.
Welp, seems I have less than those eight hours.
Thanks Mr VirMach, I am now a PDF :-D
What did I miss?
No big disk, don't worry. Well big, not insanely big.
If my idling makes no difference to you, then please move my SJCZ012 and NYCB020 servers to CHIZ030. CHIZ030 is excellent.
SHA256 = 32 byte hash
32 bytes = 64 character
64 / 8 (length of coupons) = 8 coupons
ba575953
0af4c7c1
55113141
da135bcf
f8f5609e
1c81ae35
b89680f3
30990180
and f8f5609e was a recurring 60% off coupon for plan 255
I should have a 50% OFF coupon for the first year
So what specs did you get?
big herring
"switching soon" eclipse again!
@Wonder_Woman I always thought that you were smart, but you are seriously impressing me lately.
Atlanta
12GB RAM
6 Cores
240GB NVMe
20TB Bandwidth
8 IPv4
I'm honored
Nice. And what are you planing to do with it?
Idle
deserted in what way
Well... no plan at the moment. It's a premium idler for my collection. It's got plenty of juice to maybe run Proxmox and pretend I've got use cases?
This one looks good too, but it's too much money.
proxmox and a windows rdp thats all i do, windows shut when not needed
Everybody's happy with their 2TB NVME for $7 super deals that I have missed or are we still waiting for those?
I wouldn't mind getting a 2TB NVME to idle for $7/year.
Alright, this one is going to be hard but it has 50 x 50% off recurring coupons inside it, so I recommend you guys create some type of community task force and crack it together since there should be plenty of codes for everyone once it's cracked. You'll see that one of you might not be in the position to figure it out, but maybe three or five might ring a bell or two
Instructions:
qlorm calwe aiyvf tdcqm ofvqf ieiqm ydoek phmbx poquf cgwgy fbibm lvgps cbpqa ooshf vimrk awpti qwfmn oddyk xaywg gunjo niwdm sqaem mhgaq isnwz xqabu xuxmg sbmqt uapyf tfrpu yzlqv mffkd zqyvg eksnb tvyih bglzv pjyvt zdmjo kletq rgnal wgmdl axwfd gcyfp lucye vfsjz
Coupon Cipher Block:
QXUOKBTGGBHQHVOLVPYQCIBUWIGFDKOQKMNJFRQQSQVJALWOQPDGFKWIQLYDOLEZMAQOZRFCDQYFGDLCOLBPQHSDJNQHABGDWFOQUCNSCNOFQTKEJUZQTJHRYQVJJUUZQEFPVTNBMCYHSKOQQZELUFALJPQCOFCKFQMEEEUFCIEQSGJNQNSEAGKIZYQJYZLBYNQYZEOLIAJOGMQXQHCJXIGDQESDHNNFMYQOIMIPGQPTBMIFYQFUCNXGZNQHFXHSCQAZGWRICBNRXIQYQBLCLNCFQXZCIUFKNSRQRZGJYTYQBIPXCMQBLYOYLGQAZEODAXPDGQGLAOQNATGSQJZDAWNIDQLDSTLZBFZLQAFCTXCLQPAMCIIQMXMBLQTFEOHUALOUGQXZ
ok we are grouping guys work hard everybody and dont forget me your group friend to tell the code
this enigma things is way over my head
I am willing to support and tag team to get dem virbot coupons. Lemme know how can I help (except cracking thr code and spitting the coupons)
$7 for the coupon code that I can retro-actively use for all the purchases I have already done.
