VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
15758606263118
  • Any more hints? greedy search is not really helpful.
  • I don't really need any more servers, but I feel like I'm letting you guys down! I've been plugging away at the hints into the Enigma Machine...
    After this I'm going on a ....
  • Anyone got tunnelbroker working in LAX?
    I tired, and I am being told the network is not allowed. Seems like a limit based on the DC?
    edited December 2024
    I have it working on nodes LAXA031 & LAXA022
    IP ranges are 104.234.36.xx & 141.11.209.xxx
  • too starving, i quit :(
  • Yep, tried again and got This network is restricted
    What IP range ?
  • 141.11.93.xxx
  • I'm still not getting anywhere with this. Damn it, @VirMach!
    @CMunroe said:
    141.11.93.xxx
    That's odd because both mine and yours are AS8100 with the same Prefix Registrant.
    Maybe try a different HE server and see if it works.
  • @FrankZ said:
    @CMunroe said:
    141.11.93.xxx
    Negative Captain, none worked.
    @CMunroe said:
    @CMunroe said:
    141.11.93.xxx
    Give me a minute and I'll try to make a new tunnel and see what happens.
    EDIT: You are correct. I tried to add a new HE IPv6 tunnel to a new VPS in QuadraNet Los Angeles and it gave me the same message that you received. "This network is restricted"
  • Im wondering if maybe someone has a tunnel on the same IP under a different account.
    I don't think it has to do with your IP as I got the same message on a new VPS. Old tunnels still work fine.
    Thanks for the heads up, I know now not to delete any of the old tunnels.
  • Weird!
    Maybe too many people putting in tunnels, so rate limited?
  • edited December 2024
    @FrankZ said: EDIT: Ok, Wonder_Woman said this better a hour ago. So I am well behind the leader.
    I'm ahead, I'm finishing up my era-accurate Bombe machine in Python while I eat dinner. Well okay that's also unfair taking all the credit since ChatGPT is doing most (all) the work. Have no idea how long it'll take though, it's probably better if the clues are used.
    Edit -- wait a minute this isn't even correct. I think I'm missing my rings or maybe it's just not being displayed. Hmmm...
    It would be nice to at least have cuteness as a redeeming factor. :'(
    Thanked by (2)localhost FrankZ
  • vyasvyas OGSenpai
    Where I live, the word Bombe means a Toy Doll or a small figurine. Quite the opposite of the machine or its size. That image is haunting..
  • I give up on the quest to crack the virbot enigma.
    Good luck to whose who.van cracked and enjoy the coupons...
    Save some foe me too
    See you all layer.
    Thanked by (2)imok Wonder_Woman
  • Right after my post as i make my way to get some rest @VirMach will post the codes or additional clues
    And I will 💯 miss some great ones.
    Enjoy and thanks everyone
    Thanked by (3)user123 FrankZ FAT32
  • @feeed said:
    Looking at enigma:
    There are some configuration options for the decoder:
    Rotors ⚙ (from left to right) (Walzenlage)
    Reflector ⇄ (UmKehrWalze)
    Positions of rings ∘ (Ringstellung)
    Positions of rotors ⌖ (Grundstellung)
    Connections pairs (Steckerverbindungen)
    Trying various combinations, and guessing stuff, but it's really a stretch
    see one position to three five ring a two
    Rotors: "see" = C?
    Positions of rotors: "position to" = 5, 5, 5? 2, 3, 5?
    Position of rings: "ring a" = A?
    We're running out of time so yes, "see" = C
    The C is the UKW reflector. The rotors are I through V. Positions are 1 (A) through 26 (Z) and rings are 1 (A) through 26 (Z) so these are a lot more important to solve than the reflector (since there's 26 of them per rotor.) This is for Enigma I which corresponds to the Bombe machine photo I showed (that one cracked Enigma I, it's the one made by Alan Turing.)
    My bruteforcer is pretty much useless unless you know more details from the clues, otherwise it'll take forever to run. I'm going to add settings for it just in case you guys have most of the stuff but not all of it and share the code if you're interested. If you have all of it then you can pretty much decrypt it in a second.
  • I'm suffering
  • every time i revisit this thread, there's some new level of insanity going on with these codes
    Cool, that takes away a bit of the guesswork, although technically I had already guessed at all of that. Just nice to know I was right.
    Also important to know that for the position and rings, you can either use letters or numbers. A = 1, and so on. That knowledge is important for the clues to work.
    What do I win if I get it? :p
    Yep, I'm on board. I am expecting actual words to come out of this though, there's not like another encoding after this... right?
    I guess I'm still stuck here:
    Italicized letters/words: see [UKW C] / one [enigma ver#] / position to [20 15] / three [C] / five [E] / ring a [1] / two [20 23 15]
    Plus, @VirMach said it's rotors I-IV, meaning it's the 4-rotor version.
    Using T, O, C, E as the position of rotors, and A, T, W, O as the position of the rings...still gets me gibberish for deciphering the instructions. This also assumes the instructions are encrypted with the same cipher as the codes.
