VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
1104105107109110118
    @Kris said:
    BUY3AND1 - Buy VPS-BF-ORDER-3 and VPS-BF-ORDER-1 together to get 50% off one-time (non-recurring) on VPS-BF-ORDER-3 only. Must be purchased together.
    But...
    Please correct the following errors before continuing:
    Black Friday package quantities are limited. Please go back and remove one
    Did I buy too many? Didn't use this coupon before :o
    That's some old code we kept. I'm not sure how it works or what you had in your cart, if it prevents two separate ones from being in cart at once. Are you saying you had 1 quantity of 1 and 1 quantity of 3? I can manually generate this for you if you open a ticket if that was the case, and let me know so I can correct it.
    That's my guess without looking at it, that the code wasn't really properly changed to account for 3 unique plans.
    I added 2 qty for the same package #1875 and received the same message "Black Friday package quantities are limited. Please go back and remove one". Then I had to remove one and ordered one only.
  • @VirMach said: That's my guess without looking at it, that the code wasn't really properly changed to account for 3 unique plans.
    Yeah I had one of each, and it applied the 50% off and had a total of $21.79 but then told me to remove one due to limits.
    I removed and the promo became invalid. Still have one in my cart, #1874 which was BF-ORDER-3 at the time.
    I forget the other one, as I removed it from the cart trying to get it. Not sure if that's enough to trace the other. The pricing applied fine, but when I went to click complete order it denied due to black friday limits
  • @haynhat said: I added 2 qty for the same package #1875 and received the same message "Black Friday package quantities are limited. Please go back and remove one". Then I had to remove one and ordered one only.
    They were two different VMs. Not sure what happened. They were #1 and #3 at the time, wanted to use that coupon.
    Okay whoever wanted to use the buy one get one 50%, make a ticket and let me know which plan IDs, which one you wanted 50% applied to, and the prices when you intended to purchase and I'll manually handle it.
    Seems like it's definitely the thing I mentioned, I'll also try to fix it for future purchases.
  • Yo Virmach, can you price match my Virmach AMS VPS for SJC?
    We'll take price match requests once we split up our brands. VirmAche refugee deals.
    If you can do this manually, can you modify the offer to recurring? Thanks.
    I definitely can. I won't.
  • roseyysaroseyysa Retired
    edited December 2024
    Can I then get a refund for the other one?
    We've been starting to get a lot of fraudulent orders for specials. Usually this spillover doesn't occur but we also don't usually keep the sale running this long. This just means proper stolen credit cards/fraudsters or whoever you want to call them, criminals, are starting to purchase these specials because obviously it's easier for them to buy a 4GB plan for $20 per year or whatever instead of $20 per month.
    Unfortunately with the pricing for these plans we obviously can't afford that happening. So I'm going to be blocking people with accounts newer than created on at least black friday from ordering for now. Or some version of that. While I work on fixing this quantity issue (they use similar parts of the code, it's the cart validator.)
    Would that negatively affect anyone here?
    @msatt that's why the thing we spoke about occurred by the way. I had to apply stricter measures.
    Uhhh not sure what you mean, you tried using the coupon, and then you bought both the plans separately? You can make a ticket for that as well.
    Thanked by (1)localhost
    Okay both changes made...
    You must be at least 1 month old as a client to participate in the sale, and you should be able to add two different plans and check out, let me know if it still has issues as I haven't tested it fully yet. I'll try to work out another system later to allow exceptions where you can contact us here to get approval to participate maybe if you're new here.
    Eh, guess I'll wait for regular deals then. But SJC has been very rare so far :( (under $10)
  • Virmach testing whmcs limits since 2016 🤣
    Thanked by (3)yoursunny imok user123
    This doesn't matter, but
    88% OFF
    Offer #1503
    SKU: RYZEN SKU# V01-D3
    1 cores
    1024MB RAM
    20GB NVMe Storage
    1 IPv4
    5120GB Bandwidth
    AMSTERDAM, NL
    $7.61 per YEAR
    Subtotal               $7.61 USD
    39% Recurring Discount $2.97 USD
    Totals                 $4.64 USD Annually
    matters!
    Thanked by (1)sh97
    I think it shouldn't limit users who already have active services.
  • edited December 2024
    @roseyysa
    Did you get Offer 1876 yet?
    Seems like what you're looking for and been asking for a zillion times :p
    Amsterdam, NL
    1024MB RAM, 20GB ssd, 1 core, 2.5TB b/w, 1x IPv4
    = $7.58 at the moment
    If you have a 30% coupon left = $5.31
    If you have a 25% coupon left = $5.69
    If you have a 20% coupon left = $6.06
    If you have a 10% coupon left = $6.82
    Edit: You might have to hurry before there could be a price increase, (timer currently at: 2h20m left)
    Thanked by (2)admax roseyysa
  • @VirMach said: @msatt that's why the thing we spoke about occurred by the way. I had to apply stricter measures.
    I am sure you did not mean to imply that I was commiting fraud / using stolen cards etc - (although it did come across that way).
    All I did was buy one VM (making a total of 9).
    You need to protect yourself and obviously my 'workaround' solved the problem :)
  • @ZA_capetown said:
    @roseyysa
    Amsterdam, NL
    Thank you, I already have it, I just want to collect the most cost-effective one.
  • @roseyysa said: most cost-effective one
    this is the trap
    Thanked by (3)vyas roseyysa imok
  • Good morning.
    I can't see 1200GB NVMe in my account
    Thanked by (1)user123
    Good morning.
    that makes us two.
    @msatt said: I am sure you did not mean to imply that I was commiting fraud / using stolen cards etc - (although it did come across that way).
    Oh definitely not, just that we had to make our rules more strict = more false positives.
    Thanked by (2)localhost msatt
    I wonder whether @VirMach would allow combining my 480GB instance in Chicago and 800GB in Atlanta into a single 1200GB instance in LAX/SJC. I could even give some IPs back.
    Thanked by (2)localhost imok
    800 gb in ATL? How much was it ? What was the spec?
    It was available at the same time as 1200GB with the same price, but 800GB had a coupon available. That took 4 Core 8GB RAM 20TB BW down to $58.
    M sure it was posted when I was away for 2 mins ans was picked up by everyone else
    Thanked by (4)FrankZ Crab Kris imok
  • @VirMach said: Okay both changes made...
    Coupon worked this time no problem. Thought VirBot had cut me off - much appreciated!
  • @sh97 How did you implement https://t.me/virmach_flash? Is there any related open source project? I'd like to deploy one myself.
