@nahaoba said: It looks like I'm not lucky. TYOC027 has been down for 22 days since the 19 Feb.How long will it take to repair?
Sorry, I guess I should just go for it. I'm really dreading this situation because if I take action in this particular case, there is a small chance it could go terribly wrong. But you're right, it's been too long and I haven't been able to find a better solution. The main issue is that if it does go bad, it will require a lot more time to be spent on it. Let's see if we're lucky.
If the failure takes a long time to process, why not migrate to another node first?
Tokyo-exclusive issue. We can't move people to nearby location as we normally would (we'd get 95% complaints) and can't move everyone to another Tokyo node either because it'll likely cause problems on the other node after a mass migration. Also this would only be possible for the ones that are online.
What I can offer is to move anyone who contacts us to get recreated on another node if they want to abandon their data.
As for what I said I'd do the other day, I did. It didn't result in it going terribly wrong but it also didn't go terribly right. Closer to wrong than right. There's a lot more that could be said but it's not helpful.
I can abandon my data,can you help me to move another Tokyo node?
That one started being weird a day or two ago. None of this is a coincidence though, I just haven't had time to play detective while dealing with LAXA004S. Such a PITA, I had to basically piece together the host operating system because it decided to die mid-patch.
I blame @msatt his disease on AMSD018 is spreading over the node to other VPS on that node
and it's dead after reboot.
No bootable device.
And AMSD018 has just gone offline again for me so no, I blame you.
Getting no response when using VNC so can't even say the disk has gone.
Not going to do a reboot, will just be patient.
@tommy1412 said: @VirMach Have you looked at Invoice #1678842 yet? It is now Cancelled while my money is gone, what's your problem ?
This is on a renewal or a new service purchase ?
New purchase, my card was charged but Invoice is not paid then Cancelled, zero notices from them
More than likely if the purchase was denied for whatever reason, and it does not show as account credit, the money will be returned to your card. Sometimes it takes the bank a bit to process the reversal. VirMach is not known for keeping peoples money without providing the service purchased. Virmach will probably drop by later to answer this definitively, in the mean time don't worry that you got scammed for your $$.
Ok... thought I got a good flash deal but it turned out to be terrible...
Thank you
Thank you
P.S. Welcome to LES
Hello Sir, how to get ipv6 on Virmach services?
is Virmach allowed tunnelbroker?
@tommy1412 said: New purchase, my card was charged but Invoice is not paid then Cancelled, zero notices from them
Sounds like your payment wasn't accepted. How did you open your ticket by the way? Whichever way you did it means it gets delayed in the queue, I want to make sure we patch that so others don't do it.
I've located your payment, make a ticket using the contact us button and select billing. Confirm you want us to attempt to capture the payment manually.
VirMach has some nodes in Amsterdam and Tokyo that have unsupported native IPv6. Otherwise VirMach does not offer native IPv6. From my experience tunnelbroker can be used in all VirMach locations expect for where VirMach uses QuadraNet. Chicago and Miami as example. Tunnelbroker has blocked QuadraNet not VirMach.
is LAX also included in those blocked by tunnelbroker?
VirMach uses Equinix LA3 in El Segundo now for his Los Angeles location now. He recently moved out of QuadraNet Los Angeles. So tunnelbroker should work with VirMach Los Angeles.
There's no 'Billing' department on select list, I choosed 'Sale' dept. and [Ticket ID: 390345] was closed for improper use... this makes new customer like me don't know what to do, I found only way to get in touch with you via LES
VirMach uses Equinix LA3 in El Segundo now for his Los Angeles location now. He recently moved out of QuadraNet Los Angeles. So tunnelbroker should work with @VirMach Los Angeles.
my node : LAX-A026
ip : 104.234.61.0/23
but Geo on Canada with isp QuadraNet
Just waiting for a moment that Virmach AI would deem this idler using too much CPU and ban me (-:
min 1.8 ms, avg 150 :-D
AMSD014 coincidentally started to sweat up
https://imgur.com/a/HSiaKeb
OFFER #3212 is good ~ 2 IPv4's
, but I am waiting for the $8 8 IPv4s
This is by far my "idlest" server. Hope they won't look only at that chart like that...
Shutting down my VM on AMSD014 due to high [70%+] steal.
I've got extras so no worries.
If this is your preferred solution I'll contact you, otherwise I'll just wait it out.
Should be OK now. Monitoring further.
@VirMach Please check Invoice #1678842, my card was charged but invoice still Unpaid
We back to idling!
Eh.
No bootable device.
WE BACK @msatt
Aware. They'll be moved off at this point or to another disk. There's also still abuse, I need to wrap up LAXA004S first.
TYO027 node how is it going, I saw your lastest update on 5 March @VirMach
Did you see this comment on March 14th ?
P.S. Welcome to LES
Thank you
What was it?
RYZEN SKU# V01-00
RAM 1024MB DDR4 RAM
CPU 1 Core
30GB SSD (NVMe)
2048GB BANDWIDTH
2 IPv4
$7.25 USD annually
my node : LAX-A026
