HostBilby - DingoEdge - 2 vCPU, 4 GB RAM, 40 GB SSD (I got a slight disk bump due to unintentionally debugging a MaxMind issue), 7 TB @ 5 Gbps for $4.25/m
# Yet-Another-Bench-Script #
# v2025-01-01 #
Sun Mar 30 02:57:56 PM CEST 2025
Uptime : 0 days, 0 hours, 19 minutes
Processor : Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
CPU cores : 2 @ 2095.078 MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 59.9 GiB
Kernel : 6.1.0-9-amd64
VM Type : KVM
ISP : BilbyCorp
ASN : AS401619 BilbyCorp
Host : BilbyCorp
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Read | 138.35 MB/s (34.5k) | 1.50 GB/s (23.4k)
Write | 138.71 MB/s (34.6k) | 1.51 GB/s (23.6k)
Total | 277.07 MB/s (69.2k) | 3.01 GB/s (47.0k)
Read | 1.79 GB/s (3.4k) | 13.17 GB/s (12.8k)
Write | 1.88 GB/s (3.6k) | 14.05 GB/s (13.7k)
Total | 3.67 GB/s (7.1k) | 27.23 GB/s (26.5k)
Clouvider | London, UK (10G) | 1.15 Gbits/sec | 918 Mbits/sec | 141 ms
Eranium | Amsterdam, NL (100G) | 1.38 Gbits/sec | 1.23 Gbits/sec | 164 ms
Uztelecom | Tashkent, UZ (10G) | busy | 700 Mbits/sec | 222 ms
Leaseweb | Singapore, SG (10G) | 1.15 Gbits/sec | 1.05 Gbits/sec | 163 ms
Clouvider | Los Angeles, CA, US (10G) | 3.00 Gbits/sec | 2.37 Gbits/sec | 35.8 ms
Leaseweb | NYC, NY, US (10G) | 2.39 Gbits/sec | 2.59 Gbits/sec | 71.5 ms
Edgoo | Sao Paulo, BR (1G) | 1.09 Gbits/sec | 551 Mbits/sec | 191 ms
Clouvider | London, UK (10G) | 1.23 Gbits/sec | 1.13 Gbits/sec | 141 ms
Eranium | Amsterdam, NL (100G) | 1.25 Gbits/sec | 1.05 Gbits/sec | 164 ms
Uztelecom | Tashkent, UZ (10G) | 6.98 Mbits/sec | 653 Mbits/sec | 222 ms
Leaseweb | Singapore, SG (10G) | 1.02 Gbits/sec | 1.04 Gbits/sec | 163 ms
Clouvider | Los Angeles, CA, US (10G) | 3.08 Gbits/sec | 2.61 Gbits/sec | 35.8 ms
Leaseweb | NYC, NY, US (10G) | 2.80 Gbits/sec | 2.63 Gbits/sec | 71.4 ms
Edgoo | Sao Paulo, BR (1G) | 1.05 Gbits/sec | 579 Mbits/sec | 191 ms
Test | Value
Single Core | 1159
Multi Core | 2082
Full Test | https://browser.geekbench.com/v6/cpu/11284270
YABS completed in 15 min 43 sec
Got myself a new Hetzner box to consolidate porn storage from a few different servers into a single one (skipped network test since I'm transferring a bunch of stuff, but it's just your typical 1 Gbps Hetzner stuff network).
€159.70 + VAT. 2x960 GB NVMe in SW RAID1. 10x16 TB HDDs split into multiple YOL0RAIDs. YABS ran on the NVMes.
Prepaid-Host 5 euros/m
Their protection system may block your ip if you run yabs on vm as it did with mine. Need to contact support now..
ServerStatus , slackvpn
Recommended Providers: AlphaVPS(aff) | HostBRR(aff) | HostDare(aff) | KuroIT(aff)
CNFaster
HKL IPv6 Only
12.00HKD/year
1 vCPU / 256MB / 10GB / 1500GB @1000Mbps / Hong Kong
VirMach: Customer’s Service cannot use more than 10% of the monthly allocated bandwidth in under twenty-four (24) hours.
https://virmach.com/terms-conditions/#aup
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 41 minutes Processor : AMD EPYC-Rome Processor CPU cores : 1 @ 3493.414 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 937.7 MiB Swap : 256.0 MiB Disk : 24.5 GiB Distro : Ubuntu 24.04.1 LTS Kernel : 6.8.0-31-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Iomart Hosting Ltd ASN : AS20860 IOMART CLOUD SERVICES LIMITED Host : Iomart Managed Services Limited Location : Glasgow, Scotland (SCT) Country : United Kingdom fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 42.76 MB/s (10.6k) | 542.01 MB/s (8.4k) Write | 42.84 MB/s (10.7k) | 544.87 MB/s (8.5k) Total | 85.60 MB/s (21.4k) | 1.08 GB/s (16.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.81 GB/s (3.5k) | 2.03 GB/s (1.9k) Write | 1.91 GB/s (3.7k) | 2.16 GB/s (2.1k) Total | 3.72 GB/s (7.2k) | 4.19 GB/s (4.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.99 Gbits/sec | 1.66 Gbits/sec | 2.87 ms Eranium | Amsterdam, NL (100G) | 1.76 Gbits/sec | 1.82 Gbits/sec | 8.18 ms Uztelecom | Tashkent, UZ (10G) | 542 Mbits/sec | 432 Mbits/sec | 99.0 ms Leaseweb | Singapore, SG (10G) | 511 Mbits/sec | 1.29 Gbits/sec | 168 ms Clouvider | Los Angeles, CA, US (10G) | 442 Mbits/sec | 618 Mbits/sec | 141 ms Leaseweb | NYC, NY, US (10G) | 549 Mbits/sec | 1.49 Gbits/sec | 70.2 ms Edgoo | Sao Paulo, BR (1G) | 321 Mbits/sec | 379 Mbits/sec | 196 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.99 Gbits/sec | 1.64 Gbits/sec | 2.88 ms Eranium | Amsterdam, NL (100G) | 1.63 Gbits/sec | 1.79 Gbits/sec | 8.20 ms Uztelecom | Tashkent, UZ (10G) | 546 Mbits/sec | 250 Mbits/sec | 97.3 ms Leaseweb | Singapore, SG (10G) | 328 Mbits/sec | 1.34 Gbits/sec | 168 ms Clouvider | Los Angeles, CA, US (10G) | 480 Mbits/sec | 634 Mbits/sec | 138 ms Leaseweb | NYC, NY, US (10G) | 453 Mbits/sec | 1.41 Gbits/sec | 70.2 ms Edgoo | Sao Paulo, BR (1G) | 369 Mbits/sec | 394 Mbits/sec | 194 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4486 Multi Core | 4291 Full Test | https://browser.geekbench.com/v4/cpu/18508627 YABS completed in 9 min 30 secOur 2 Core AMD Ryzen 9950x plan
GreenCloudVPS EPYC JP IIJ 🇯🇵
GreenCloudVPS EPYC SG DC 1 🇸🇬
GreenCloudVPS EPYC NL 🇳🇱
GreenCloudVPS EPYC DE 🇩🇪
GreenCloudVPS Ryzen LA 🇺🇸
GreenCloudVPS SGSTorage 0.5T 🇸🇬
HostBRR 15€/yr:
LTstats resource monitoring system | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
Advin Kansas
onidel AU 1C2G20GB 2T
@kuroit 2C4G25GB 2T in XinJiapo
New Machine Testing
Sun Mar 23 06:28:11 PM CET 2025
Uptime : 2 days, 21 hours, 13 minutes
Processor : AMD EPYC-Milan Processor
CPU cores : 1 @ 2399.998 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 957.4 MiB
Swap : 957.0 MiB
Disk : 11.6 GiB
Distro : Ubuntu 22.04.5 LTS
Kernel : 5.15.0-134-generic
VM Type : KVM
ISP :
ASN
Host :
Country :
Running GB4 benchmark test... cue elevator music
Test | Value
Single Core | 3484
Multi Core | 2909
Full Test | https://browser.geekbench.com/v4/cpu/18621967
YABS completed in 7 min 12 sec
Hetzner CPX11, 2 vCPU, 2 GB RAM, 40 GB Disk, 20 TB, €3.85 /mo
onidel Xinjiapo 1C2G20G 2T
Tubbo's Server host (play.hosting) free Pterodactyl (container)
datalix's aff #1 fan
Website: thomassen.sh
KS-MYSTERY Memory and additional diks (2x2TB) upgrade
KS-MYSTERY Memory and NVMe upgrade (Raid zero)
HostBilby - VPS offer: DingoEdge
Bullethost - Eygelshoven, Netherlands - €120 Annually.
HighEndSpirit
Yet still cheaper than the Hetzner boxes I am migrating from
OVH Mystery Box (€22.99/month)
OVH KS-LE-1 ($11.99/month)
OVH MYSTERY
@hostiko Aeza Refugee 66.66 UAH in Ukrayina
Anyone want yabs on Reliablesite ryzen 9 9950x dedicated?
One does not ask such a question.. just post yabs here
GreenCloudVPS JPSTorage 0.5T 🇯🇵
Which SSD Model is in your server?
