New homeserver is online - replacing the X99 misadventure. Pretty chuffed that the 4x4x4x4 bifurc worked straight away. That means 6 nvme and 8 satas. Not bad for consumer class motherboard <£100. And the 5700x score is landing a touch higher than GB database average so that's nice
Uptime : 0 days, 0 hours, 10 minutes
Processor : AMD Ryzen 7 5700X 8-Core Processor
CPU cores : 16 @ 3716.348 MHz
AES-NI : _ Enabled
VM-x/AMD-V : _ Enabled
RAM : 62.7 GiB
Swap : 0.0 KiB
Disk :
Kernel : 6.8.12-9-pve
VM Type : LXC
IPv4/IPv6 : _ Online / __ Offline
Test | Value
Single Core | 2170
Multi Core | 10392
Tried pushing proxmox from 6.8 kernel to 6.14 to see if it would improve performance (LXC). Figure it might given a handful of improvements in recent kernels
An intersting AMD Engineering Sample which I ordered in China. Using it as an own Proxmox Home Server... works actually great.
Is a Ryzen 9 7945HX (AMD Eng Sample: 100-000000870-24_Y 16 Cores, 32 Threads up to 5.4GHz) using only 55W.
# Yet-Another-Bench-Script #
# v2025-04-20 #
Wed Sep 24 12:33:16 AM CEST 2025
Uptime : 3 days, 8 hours, 2 minutes
Processor : AMD Eng Sample
CPU cores : 32 @ 400.000 MHz
AES-NI : ✔ Enabled
RAM : 29.1 GiB
Swap : 8.0 GiB
Disk : 10.9 TiB
Kernel : 6.8.12-14-pve
VM Type : NONE
ISP : SpaceX Starlink
ASN : AS14593 Space Exploration Technologies Corporation
Country : Germany
Warning: Could not parse free space format for /: ''
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/pve-root):
Read | 802.14 MB/s (200.5k) | 604.17 MB/s (9.4k)
Write | 804.25 MB/s (201.0k) | 607.35 MB/s (9.4k)
Total | 1.60 GB/s (401.5k) | 1.21 GB/s (18.9k)
Read | 1.27 GB/s (2.4k) | 1.61 GB/s (1.5k)
Write | 1.34 GB/s (2.6k) | 1.72 GB/s (1.6k)
Total | 2.61 GB/s (5.1k) | 3.33 GB/s (3.2k)
Clouvider | London, UK (10G) | 34.7 Mbits/sec | 202 Mbits/sec | 35.9 ms
Eranium | Amsterdam, NL (100G) | 33.3 Mbits/sec | 367 Mbits/sec | 31.9 ms
Uztelecom | Tashkent, UZ (10G) | 19.2 Mbits/sec | 144 Mbits/sec | 107 ms
Leaseweb | Singapore, SG (10G) | 13.2 Mbits/sec | 116 Mbits/sec | 267 ms
Clouvider | Los Angeles, CA, US (10G) | 11.5 Mbits/sec | 59.3 Mbits/sec | 170 ms
Leaseweb | NYC, NY, US (10G) | 11.0 Mbits/sec | 142 Mbits/sec | 105 ms
Edgoo | Sao Paulo, BR (1G) | 9.96 Mbits/sec | 67.5 Mbits/sec | 203 ms
Geekbench 4 Benchmark Test:
Test | Value
Single Core | 8558
Multi Core | 87538
Full Test | https://browser.geekbench.com/v4/cpu/19038107
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 2112
Multi Core | 20300
Full Test | https://browser.geekbench.com/v5/cpu/23805588
Test | Value
Single Core | 2802
Multi Core | 16327
Full Test | https://browser.geekbench.com/v6/cpu/14023761
YABS completed in 14 min 3 sec
Host-C 5TB LES special after upgrade (different CPU, +2GB RAM), $57/year
Original GB 946, 1690
Fixed IPv6 after I ran this, had to manually update
/etc/netplan/50-cloud-init.yamlRealToxMedia Dusseldorf 10€/y
ServerStatus , slackvpn
Recommended Providers: AlphaVPS(aff) | HostBRR(aff) | HostDare(aff) | KuroIT(aff)
HostSailor 12EUR/y
Not so much a yabs, but result.
Nope zilch diff
Debian 13 shows better Geekbench 6 results. Here is the benchmark for OVH KS-LE-E ($16/month).
Yet another OVH Frankfurt VPS-1
(Starlink at home for the win)
VDS-1 plan (capped at 500 Mbit/s)
orderlink please
I ordered it from taobao (like amazon but only accessible and ships in china)... you would need a reshipper for that. If you want it dm me.
https://lowendtalk.com/discussion/210084/firevps-new-jersey-kvm-vps-starting-9-99-yr-recurring-discount#latest
https://lowendtalk.com/discussion/203197/nuyek-1-year-anniversary-highland-il/p1
https://lowendtalk.com/discussion/208076/7-year-california-kvm-vps-free-bonuses-ram-vcpu-disk-ipv4#latest
ExtraVM Sydney Chicken
C-Servers CentralVPS-II 2560
3 vCPU / 2.5GB RAM / 60GB NVMe / unlimited BW / Finland / 22.99 USD triennially
https://www.hetzner.com/dedicated-rootserver/ex63/
AS200690 would like to thank ParadoxNetworks Limited for sponsoring VM to access Ontario Internet Exchange.
vps9hostname is available. affbrr
