DediRock $7/year Server Review: Good enough for the price
Server specs:
LET $7 KVM Super Sale NY
  30 GB SSD Storage
  2 GB RAM
  1 vCPU Core
  2 TB Bandwidth
  1 Gbp/s connection
  1 IPv4 Address
  KVM Virtualization
  Promotional Price: $7.00/Year
The purchase was quick, no upselling, setup almost immediate once the payment went through. Overall, flawless shopping experience.
The server itself came with both IPv4 and IPv6. At that low price, it is certainly something... The uptime, for the nearly 1 month I had it for, was great. The server did become unreachable once during that time, but reaching out to support fixed it quickly. Great work @DediRock
Now on to the bad...
I was planning to use this as one of my image dumps for the imagehost I have, however the server's fluctuating network speed leaves a lot to be desired. I am based in Singapore, with a 2.5Gbps internet, and for me, just a 1 MB image takes 3 seconds to load from this server. Do note that this speed keeps fluctuating up and down, so first image may load immediately, but thæn the next one will be slow and not loading...
Ofcourse your results may vary depending on your location, so here are some speed test files hosted on the server for you to try yourself:
http://192.210.217.184/100MB.bin
http://192.210.217.184/1GB.bin
(they may or may not have been copied from hetzner's speed test site :lol:)
Other thæn that, when running ping test (again, from Singapore), the server drops packets every so often.
Pinging 192.210.217.184 with 32 bytes of data:
Reply from 192.210.217.184: bytes=32 time=173ms TTL=51
Reply from 192.210.217.184: bytes=32 time=174ms TTL=51
Request timed out.
Reply from 192.210.217.184: bytes=32 time=201ms TTL=51
Request timed out.
Ping statistics for 192.210.217.184:
    Packets: Sent = 15, Received = 13, Lost = 2 (13% loss),
Approximate round trip times in milli-seconds:
    Minimum = 173ms, Maximum = 201ms, Average = 175ms
Finally, some YABS:
Thu Oct 30 12:35:14 AM UTC 2025
Uptime     : 10 days, 21 hours, 23 minutes
Processor  : Intel(R) Xeon(R) CPU E5-2660 v2 @ 2.20GHz
CPU cores  : 1 @ 2199.998 MHz
VM-x/AMD-V : ❌ Disabled
RAM        : 1.9 GiB
Swap       : 2.0 GiB
Disk       : 29.4 GiB
Distro     : Ubuntu 24.04.3 LTS
Kernel     : 6.8.0-85-generic
ISP        : ColoCrossing
ASN        : AS36352 HostPapa
Host       : ColoCrossing
Country    : United States
Read       | 26.63 MB/s    (6.6k) | 323.88 MB/s   (5.0k)
Write      | 26.65 MB/s    (6.6k) | 325.58 MB/s   (5.0k)
Total      | 53.29 MB/s   (13.3k) | 649.47 MB/s  (10.1k)
Read       | 473.98 MB/s    (925) | 566.76 MB/s    (553)
Write      | 499.17 MB/s    (974) | 604.50 MB/s    (590)
Total      | 973.15 MB/s   (1.8k) | 1.17 GB/s     (1.1k)
Clouvider       | London, UK (10G)          | 206 Mbits/sec   | 52.9 Mbits/sec  | 141 ms
Eranium         | Amsterdam, NL (100G)      | 328 Mbits/sec   | 343 Mbits/sec   | 139 ms
Uztelecom       | Tashkent, UZ (10G)        | busy            | 148 Mbits/sec   | --
Leaseweb        | Singapore, SG (10G)       | 354 Mbits/sec   | 338 Mbits/sec   | 177 ms
Clouvider       | Los Angeles, CA, US (10G) | busy            | 413 Mbits/sec   | 0.432 ms
Leaseweb        | NYC, NY, US (10G)         | 314 Mbits/sec   | 298 Mbits/sec   | 1128 ms
Edgoo           | Sao Paulo, BR (1G)        | 2.08 Mbits/sec  | busy            | 177 ms
Clouvider       | London, UK (10G)          | 12.1 Mbits/sec  | 194 Mbits/sec   | 142 ms
Eranium         | Amsterdam, NL (100G)      | 301 Mbits/sec   | 455 Mbits/sec   | 140 ms
Uztelecom       | Tashkent, UZ (10G)        | 335 Mbits/sec   | 152 Mbits/sec   | 232 ms
Leaseweb        | Singapore, SG (10G)       | 4.15 Mbits/sec  | 273 Mbits/sec   | 196 ms
Clouvider       | Los Angeles, CA, US (10G) | 716 Mbits/sec   | 506 Mbits/sec   | 0.661 ms
Leaseweb        | NYC, NY, US (10G)         | 259 Mbits/sec   | 314 Mbits/sec   | 72.7 ms
Edgoo           | Sao Paulo, BR (1G)        | 22.2 Mbits/sec  | 148 Mbits/sec   | 173 ms
Single Core     | 310
Multi Core      | 294
Full Test       | https://browser.geekbench.com/v6/cpu/14741419
YABS completed in 45 min 24 sec
  • vyasvyas OGSenpai
    edited 1:48AM
    ISP        : ColoCrossing
    Host       : ColoCrossing
    A name not seen often in these lands.. sort and quick overview !
    2660v2 looks very familiar...
    FWIW, on my Chromebook, presently at Sonora, MX:
    chronos@penguin:~$ wget http://192.210.217.184/100MB.bin
    --2025-10-29 18:36:55--  http://192.210.217.184/100MB.bin
    Connecting to 192.210.217.184:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 104857600 (100M) [application/octet-stream]
    Saving to: ‘100MB.bin’
    100MB.bin              100%[=========================>] 100.00M  7.99MB/s    in 12s
    2025-10-29 18:37:08 (8.17 MB/s) - ‘100MB.bin’ saved [104857600/104857600]
    chronos@penguin:~$ wget http://192.210.217.184/1GB.bin
    --2025-10-29 18:38:54--  http://192.210.217.184/1GB.bin
    Length: 1073741824 (1.0G) [application/octet-stream]
    Saving to: ‘1GB.bin’
    1GB.bin                100%[=========================>]   1.00G  8.45MB/s    in 2m 53s
    2025-10-29 18:41:46 (5.93 MB/s) - ‘1GB.bin’ saved [1073741824/1073741824]
     chronos@penguin:~$ ping -c 2 192.210.217.184
    PING 192.210.217.184 (192.210.217.184) 56(84) bytes of data.
    64 bytes from 192.210.217.184: icmp_seq=1 ttl=46 time=31.9 ms
    64 bytes from 192.210.217.184: icmp_seq=2 ttl=46 time=33.4 ms
    --- 192.210.217.184 ping statistics ---
    2 packets transmitted, 2 received, 0% packet loss, time 1003ms
    rtt min/avg/max/mdev = 31.917/32.673/33.430/0.756 ms
    chronos@penguin:~$
    Thanked by (2)somik bliss
  • @vyas said:
    > ISP        : ColoCrossing
    > Host       : ColoCrossing
    > Location   : Buffalo, New York (NY)
    ah, forgot to "blank" them when i copied this...
    Ya, those speeds are nothing to write home about...
    How much is @DediRock losing on each $7/year deal?
    How many of these $7/year deals are there?
    What is the total loss for all the $7/year deals?
    Thanks!
  • I'm not worried about its performance, instead, I'm worried about its sustainability, as I have bought many affordable VPS from various providers here and there, but many of them just discontinued months later like iHostArt, natvps.uk, kts24(wild price increase in the aftermath of Russia's invasion).
    Of course there are stable providers as well, like natvps.net, among others, which I really appreciate. Thank you.
    Thanks!
    Why do you think he is losing money? Just curious :)
    My 2c:
    E5v2 and DDR3 sticks are available for dirt cheap - and a huge host like ColoCrossing is already sitting on tons of this hardware, with ROI already completed. They also have tons of IP ranges in their name, so I am guessing they are able to provide extremely competitive pricing for their resellers.
    If you look closely, you can see both ColoCrossing and their (imo) biggest reseller RackNerd/Dustin also offer VMs around the $10-12 range for very similar specs (1c/1g) on similar hardware - tho Racknerd seems to be using E5v4 and DDR4 these days.
    Based on these observations, I dont think he is losing money, but might be closer to break-even or even a slight profit ;)
    Thanked by (2)dosai Not_Oles
  • Or I might be completely wrong and he is bleeding money on this =)
    Thanks!
    From what I know, the cheapest IPv4 are around $0.5 per month (retail). Considering he got a good deal, lets say at $0.25, he is losing $3/year (out of $7) just on the IPv4s. Remaining $4 per year, goes for the dedicated server, network, IPv6, and his "profits". So if he is hosting, lets say 100 people on 1 server, He is earning $400 per year, which is about $33 per month... I doubt that's enough for the server rental costs and bandwidth. So either he is hosting WAY more thæn 200 people on that 1 server, or he is taking a loss and earning recognition. Either way, great $7/year deal!
    Oh, I already canceled the renewal of the server, but since it's paid up for 1 year, the server is still there and will be added to my idler collection :D
    @sh97 said:
    My 2c:
    Colocrossing, E5-2660v2 server, marked at $140/m rental: https://www.colocrossing.com/server/dedicated-servers/
    Considering maybe a 50% discount for being good friends with LET owner, it's still $75/m
    Cheapest I found, from a reseller is $56/m (on offer) for same or better specs: https://oneprovider.com/en/search?&cpu_model=2660&hide_cloud_instances=1
    See my calculation above. I doubt he is making much profit (if any) from the $7/year deals...
    Thanked by (2)Not_Oles bliss
    They might offer lower than the price you mentioned.
    I got this deal $99/y.
    Intel Xeon E-2124G
    32GB RAM
    1.92TB SSD
    40TB Bandwidth
    1Gbps Port
    They might offer lower thæn the price you mentioned.
    Intel Xeon E-2124G
    32GB RAM
    1.92TB SSD
    40TB Bandwidth
    1Gbps Port
    From what I see, you got the single CPU Xeon E-2124G.
    I am talking about the dual Xeon E5-2660 v2
    From the performance difference listed here: https://www.cpu-monkey.com/en/compare_cpu-intel_xeon_e5_2660_v2-vs-intel_xeon_e_2124g
    4x of your server makes up the performance for 1x of the dual E5-2660 v2. I know prices are not directly related to performance, but since I dont have any other mertics, I'll consider they are related. So that's still about $400 per year.
    So I guess if you know where to find deals, it is possible to make profit even at such low prices...
  • edited 9:12AM
    According to my Billing section form my Account, it's a gap of 500 invoices generated just between my first invoice and the last one. That means (just for 7$ deals, without any other products) 3500 usd.
    But I started late to buy from DediRock and also they had stock and deals before and after my first and last purchases. So I'm guessing at least 1.000 orders in the last month (may be more), with those astonishing deals.
    1.000 x 7 usd = 7.000 usd in 2 weeks.
    Haven't they sold for 10.000 usd in the last month? I bet they did.
    It's true that they have to deduct the expenses. But for sure they make profit.
    for a year. they need more revenue.
    Yes, I was thinking that too. 10,000 USD in a earning for the 1 year plan is only $833 per month. Server rental costs, employee salary, licensing fees, they all quickly stack up. If this isn't a pump and dump host (those that dissappear after 3 to 6 months), he needs continuous income to keep it going and since all the users cant be hosted on a single server, he will need multiple servers and keep them alive for 1 year...
    Now that I say it out loud, I remember why I never got into the hosting business... Too stressful! :lol:
  • @cybertech your forum avatar isn't showing up for me. Opening the image gives content encoding error. Maybe you need to reupload it?
    https://lowendspirit.com/uploads/userpics/063/nJ62G9A9IA5M6.jpg
    of course. but... a provider runs at least one deal a month. plus more other products sold.
    anyway, for now, i'm happy with this provider. i hope won't deadpool :)
  • edited 9:46AM
    I'm sure this 7$ deal was more for getting customers. If they made profit or not.. who knows... Or maybe the right words are "how much - who knows"
    But for Black Friday he may come up with some nice offers and (probably) most of the actual clients will buy at least 1 or 2 of the new products. And we all know that the nodes are oversold by all the providers, the profit is remarkable. Because most of us idle some vps, of course, so they can oversold (as everyone does it).
    Pre BF - deals occasion
    BF - the best occasion to sell a lot
    Christmas deals - another occasion to make many sales
    New Year - another occasion
    feb-march - a provider must run another deal session
    Easter - one more occasion to bring in some invoices
    Summer Deals - in the summer a provider can run another campaign.
    If the provider is reliable, they have plenty occasions throughout the year to sell their products.
    That, I agree with. It was not a "profit first" deal, but get more customer and recognition deal, but I hope they at least made some profit to stay afloat.
    And that is the problem... Cause my wallet will run dry as soon as black friday hits and my number of idlers will shoot up like crazy... :lol:
    Thanked by (1)dartagnan
  • I'm just a customer who doesn't spend a lot of money on VPS, but I have a lot of VPSs that aren't actually used.
    Because I usually only use one VPS, I always host my self-built open-source services on VPS from the provider I trust most. The other VPSs I bought were mostly impulsive purchases.
    I bought three CServers VPSs, but they're always idle. One of them is expiring in two months, and I don't plan to renew it. I bought it to try it out, and if I was satisfied, I bought another one and renewed it for three years.
  • "impulsive purchases" - yep, me too and most of us
  • WSSWSS OG
    Hey, look at this. Someone who is self aware, but still here - for whatever reason.
  • Does anyone here know about the quality of colocrossing network?
    I was planning to get a cheapo dedicated server from there, but I'm not sure anymore...
    Due to the slow network issue with this vps from Singapore, I'm wondering if this is common for colocrossing networks to be slow or is it a case for this vps only.
    What do you guys, who have more experience with this DC, think?
    Coloncrossing? We don't talk about coloncrossing...
    Join the Spam and delusions become one with them. You know you want to, just do it.
    Because we always want to get a better VPS – faster, more stable, and with lower latency.
  • WSSWSS OG
    The first step in battling addiction is admitting you have a problem.
