YABS getting stuck at GB6
Every time I run YABS it always halts at this step, why?
Running GB6 benchmark test... cue elevator music
Is the VPS so bad that it couldn't even finish the test properly?
  • AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
    how long did you wait? what are the VPS specifications?
    TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
  • I waited for an afternoon.. and about an hour next several times.
    The specs are:
    CPU: 2 cores
    RAM: 1 GB
    Disk: 20 GB
    Bought it from CloudCone.
  • check with top/htop while it is running, if you can see activity on the cpu?
    Thanked by (1)rvldev
    @rvldev said: I waited for an afternoon.. and about an hour next several times.
    The specs are:
    CPU: 2 cores
    RAM: 1 GB
    Disk: 20 GB
    'lscpu' output? if you somehow ended up with a qemu cpu badly configured for some reason (like you self installed via iso or something) you could have emulated instruction sets which means it will be so slow it never completes.
    Just a guess.
    you need swap.
  • @rvldev said: Is the VPS so bad that it couldn't even finish the test properly?
    Maybe.
    Hmm yes I can see geekbench running in there with 200% CPU.
  • @backtogeek said:
    qemu
    That could definitely be the case. But it says KVM so probably not that.
  • @cybertech said:
    you need swap.
    Ok I will try that, thanks.
  • Btw if I disable Geekbench 6 in the flags it can finish the test.
    Wed Dec 17 09:16:21 AM EST 2025
    Uptime     : 1 days, 3 hours, 43 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
    CPU cores  : 2 @ 2599.998 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 960.4 MiB
    Swap       : 1024.0 MiB
    Disk       : 19.6 GiB
    Kernel     : 6.1.0-31-amd64
    ISP        : CYBERCON, INC.
    ASN        : AS7393 CYBERCON, INC.
    Host       : ASSERTIVENET
    Country    : United States
    Read       | 117.57 MB/s  (29.3k) | 18.32 MB/s     (286)
    Write      | 117.88 MB/s  (29.4k) | 18.91 MB/s     (295)
    Total      | 235.46 MB/s  (58.8k) | 37.24 MB/s     (581)
    Read       | 369.35 MB/s    (721) | 92.86 MB/s      (90)
    Write      | 388.97 MB/s    (759) | 99.04 MB/s      (96)
    Total      | 758.32 MB/s   (1.4k) | 191.91 MB/s    (186)
    Clouvider       | London, UK (10G)          | 822 Mbits/sec   | 276 Mbits/sec   | 91.8 ms
    Eranium         | Amsterdam, NL (100G)      | 831 Mbits/sec   | 773 Mbits/sec   | 96.3 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 294 Mbits/sec   | 193 ms
    Leaseweb        | Singapore, SG (10G)       | busy            | 117 Mbits/sec   | 763 ms
    Clouvider       | Los Angeles, CA, US (10G) | 864 Mbits/sec   | 661 Mbits/sec   | 52.5 ms
    Leaseweb        | NYC, NY, US (10G)         | 902 Mbits/sec   | 813 Mbits/sec   | 22.8 ms
    Edgoo           | Sao Paulo, BR (1G)        | 704 Mbits/sec   | 264 Mbits/sec   | 182 ms
    Geekbench 4 Benchmark Test:
    Single Core     | 2579
    Multi Core      | 4773
    Full Test       | https://browser.geekbench.com/v4/cpu/19236268
    Geekbench 5 Benchmark Test:
    Single Core     | 572
    Multi Core      | 1093
    Full Test       | https://browser.geekbench.com/v5/cpu/23978677
    YABS completed in 11 min 55 sec
  • edited December 2025
    GB6 needs more than 1GB of RAM, I forget how much it needs. Adding swap will let it finish but the score will be garbage.
  • Ok this time I watched it closely in top, and geekbench disappeared about half an hour. But my ssh session still shows the same. So I guess my ssh client somehow froze after not receiving new buffer. Then I made it pipe to a file and I finally got the result.
    Wed Dec 17 10:08:00 AM EST 2025
    Uptime     : 1 days, 4 hours, 35 minutes
    RAM        : 960.4 MiB
    Swap       : 1024.0 MiB
    Disk       : 19.6 GiB
    Host       : ASSERTIVENET
    Read       | 118.11 MB/s  (29.5k) | 56.49 MB/s     (882)
    Write      | 118.42 MB/s  (29.6k) | 57.04 MB/s     (891)
    Total      | 236.53 MB/s  (59.1k) | 113.54 MB/s   (1.7k)
    Read       | 240.84 MB/s    (470) | 65.22 MB/s      (63)
    Write      | 253.64 MB/s    (495) | 69.50 MB/s      (67)
    Total      | 494.49 MB/s    (965) | 134.72 MB/s    (130)
    Clouvider       | London, UK (10G)          | 735 Mbits/sec   | 391 Mbits/sec   | 91.9 ms
    Eranium         | Amsterdam, NL (100G)      | 764 Mbits/sec   | 774 Mbits/sec   | 96.4 ms
    Uztelecom       | Tashkent, UZ (10G)        | 609 Mbits/sec   | 229 Mbits/sec   | 193 ms
    Leaseweb        | Singapore, SG (10G)       | 445 Mbits/sec   | 287 Mbits/sec   | 220 ms
    Clouvider       | Los Angeles, CA, US (10G) | 758 Mbits/sec   | 605 Mbits/sec   | 52.9 ms
    Leaseweb        | NYC, NY, US (10G)         | 847 Mbits/sec   | 770 Mbits/sec   | 23.0 ms
    Edgoo           | Sao Paulo, BR (1G)        | 639 Mbits/sec   | 210 Mbits/sec   | 184 ms
    Single Core     | 402
    Multi Core      | 527
    Full Test       | https://browser.geekbench.com/v6/cpu/15624441
    YABS completed in 28 min 36 sec
