More NetBSD-current fun at Linveo!
13
    Since @Crab is here maybe I should try FreeBSD again? Since @AuroraZero is here, maybe I should try Slackware again?
    My friend you cannot pass FreeBSD 15!
  • Someone mention Slackware????
    How to understand and fix this error, "type mismatch: specfile link, tree file"?
    Thanks for any hints and help! :)
    Sun Dec 14 22:17:17 UTC 2025
    /usr/src
    root
    ===> build.sh command:    ./build.sh -j 2 -O ../obj -T ../tools -U install=/
    ===> build.sh started:    Sun Dec 14 22:17:18 UTC 2025
    ===> NetBSD version:      11.99.4
    ===> MACHINE:             amd64
    ===> MACHINE_ARCH:        x86_64
    ===> Build platform:      NetBSD 11.99.4 amd64
    ===> HOST_SH:             /bin/sh
    ===> share/mk MAKECONF:   /etc/mk.conf
    ===> MAKECONF file:       /etc/mk.conf
    ===> TOOLDIR path:        /usr/src/../tools
    ===> DESTDIR path:        /usr/src/../obj/destdir.amd64
    ===> RELEASEDIR path:     /usr/src/../obj/releasedir
    ===> Updated makewrapper: /usr/src/../tools/bin/nbmake-amd64
    installsets ===> distrib/sets   (with: INSTALLDIR=/ INSTALLSETS=)
    #   execute  maketars for installsets
    cd /usr/src/distrib/sets &&  DESTDIR=/usr/src/../obj/destdir.amd64  MACHINE=amd64  MACHIN
    E_ARCH=x86_64  AWK=/usr/src/../tools/bin/nbawk  CKSUM=/usr/src/../tools/bin/nbcksum  DB=/
    usr/src/../tools/bin/nbdb  EGREP=/usr/src/../tools/bin/nbgrep\ -E  HOST_SH=/bin/sh  MAKE=
    /usr/src/../tools/bin/nbmake  MKTEMP=/usr/src/../tools/bin/nbmktemp  MTREE=/usr/src/../to
    ols/bin/nbmtree  PAX=/usr/src/../tools/bin/nbpax  COMPRESS_PROGRAM=/usr/src/../tools/bin/
    nbxz  GZIP=-n  XZ_OPT=-9  TAR_SUFF=tar.xz  PKG_CREATE=/usr/src/../tools/bin/nbpkg_create
     SED=/usr/src/../tools/bin/nbsed  TSORT=/usr/src/../tools/bin/nbtsort\ -q  /bin/sh ./make
    tars -d /usr/src/../obj/destdir.amd64   -M /usr/src/../obj/destdir.amd64/METALOG.sanitise
    d -N /usr/src/etc  -L base -i /
    Creating flist.base
    Creating set.base
    Creating flist.base32
    Creating set.base32
    Creating flist.comp
    Creating set.comp
    Creating flist.games
    Creating set.games
    Creating flist.gpufw
    Creating set.gpufw
    Creating flist.man
    Creating set.man
    Creating flist.manhtml
    Creating set.manhtml
    Creating flist.misc
    Creating set.misc
    Creating flist.modules
    Creating set.modules
    Creating flist.rescue
    Creating set.rescue
    Creating flist.tests
    Creating set.tests
    Creating flist.text
    Creating set.text
    Copying set base
    Copying set base32
    Copying set comp
    pax: line 110: ./usr/include/elf.h: type mismatch: specfile link, tree file
    Copying set games
    Copying set gpufw
    Copying set man
    Copying set manhtml
    Copying set misc
    Copying set modules
    Copying set rescue
    Copying set tests
    Copying set text
    *** Failed target:  installsets
  • edited December 2025
    I might be wrong, but I think it is complaining about elf.h being a file and not a sym link as it apparently is expecting. Since you have been having so much fun with NetBSD and building stuff, perhaps there are some old files that need to be cleaned up.
    In NetBSD‑current, usr/include/elf.h is a symlink to ../sys/elf.h. Modify that and see if it helps. Alternatively you could just remove everything under destination directory and build it from the scratch.
    Hey, hey, hey @Crab! :)
    FWIW, I haven't changed anything yet.
    linveo# cd /usr/include/
    linveo# ls -l elf.h
    lrwxr-xr-x  1 root  wheel  14 Oct 17 01:12 elf.h -> sys/exec_elf.h
    linveo#
    Hmm . . . October.
    Do you think sys/exec_elf.h is now wrong as the target object?
    Do you mean that the target should be /usr/include/../sys/elf.h? There doesn't seem to be a /usr/sys directory.
    Thank you, as always!
  • See the path has a dot in front so it is a relative path to your current path at /usr/src and not pointing to /, right?
    ./usr/include/elf.h
  • What's the point of using NetBSD instead of FreeBSD?
    ./usr/include/elf.h
    Yes, but if I am in /usr/src, then ./usr/include/elf.h would refer to /usr/usr/include/elf.h.
    But /usr/src has no /usr/src/usr subdirectory. There are /usr/src/usr.bin and /usr/src/usr.sbin.
    I am still confused. . . . :)
    Back in the 1990s I started using NetBSD because, with some help, I managed to run it on the x86, MIPS, and Power machines I had at that time.
    @Crab :star: recently helped me try FreeBSD, which is equally great.
    For me it's very fun to try different OSes. :) My suggestion is that you try NetBSD, OpenBSD, and FreeBSD in addition to Linux, and see which one you like best for your equipment and workflow. :)
    Thanked by (1)Neat321
    Can you check what's under cd /usr/src/distrib/sets? I am not super familiar with NetBSD, but I don't believe that leading dot is there for no reason making it a relative directory to some other location than root (/). Can you check with find command if there's another elf.h somewhere else under /usr/src?
    I checked the /usr/src/UPDATING file, which says nothing about the issue on the table here.
    Previously in this thread I listed what's currently installed:
    linveo# ls -l elf.h
    linveo#
    What's in $DESTDIR is different. It seems now a real file instead of a symlink.
    linveo# pwd
    /usr/obj/destdir.amd64/usr/include
    linveo# ls -l elf.h
    -r--r--r--  1 tom  wheel  1723 Dec 14 00:27 elf.h
    linveo#
    Here is the file pointed to by the symlink:
    linveo# pwd
    /usr/include/sys
    linveo# ls -l elf.h
    ls: elf.h: No such file or directory
    linveo# ls -l exec_elf.h
    -r--r--r--  1 root  wheel  55842 Dec 11 01:14 exec_elf.h
    linveo#
    Maybe I could replace the present symlink with the present pointed-to file? Then the new file would not be a different type of file but would have different content.
    I am missing out on understanding how the difference is detected by pax(1).
    The error refers to "line 110:"
    But line 110 of what?
    @Crab said: Can you check what's under cd /usr/src/distrib/sets?
    linveo# cd /usr/src/distrib/sets
    linveo# ls
    CVS           checkflist    fmt-list      makeflist     maketars      sets.subr
    Makefile      comments      getdirs.awk   makeobsolete  metalog.subr  sort-list
    README        culldeps      join.awk      makeplist     mkvars.mk     syspkgdeps
    TODO          deps          listpkgs      makesrctars   regpkg        versions
    attrs         descrs        lists         makesums      regpkgset
    linveo#
    @Crab said: Can you check with find command if there's another elf.h somewhere else under /usr/src?
    linveo# find /usr/src -name "elf.h"
    /usr/src/external/cddl/osnet/sys/elf.h
    /usr/src/external/cddl/osnet/sys/sys/elf.h
    /usr/src/external/gpl3/binutils/dist/libctf/elf.h
    /usr/src/external/gpl3/binutils.old/dist/libctf/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/arc/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/arm/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/alpha/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/avr/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/bfin/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/c6x/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/h8300/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/ia64/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/loongarch/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/mips/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/nds32/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/nios2/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/or1k/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/pa/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/riscv/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/sh/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/vax/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/visium/elf.h
    /usr/src/external/gpl3/gcc/dist/gcc/config/xtensa/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/arc/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/arm/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/alpha/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/avr/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/bfin/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/c6x/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/h8300/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/ia64/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/mips/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/nds32/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/nios2/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/pa/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/riscv/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/sh/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/vax/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/visium/elf.h
    /usr/src/external/gpl3/gcc.old/dist/gcc/config/xtensa/elf.h
    /usr/src/external/gpl3/gdb/dist/libctf/elf.h
    /usr/src/external/gpl3/gdb.old/dist/libctf/elf.h
    /usr/src/include/elf.h
    /usr/src/sys/arch/epoc32/stand/e32boot/include/elf.h
    /usr/src/sys/arch/mipsco/include/elf.h
    linveo#
    I gave this to Co-pilot and this is what it says.
    Here’s what’s happening in your NetBSD build:
    🔎 What the error means
    • During installsets, the build system uses pax together with the METALOG spec file to copy files into the DESTDIR.
    • The spec file says that ./usr/include/elf.sh should be a symlink (usually pointing to ../sys/elf.h).
    • In your actual DESTREE tree, elf.h is a regular file instead of a symlink.
    • pax detects this mismatch and aborts with:
    ⚙️ Why this happens
    • Stale DESTDIR: If you’ve run builds before, leftover files in may not match the current source tree’s expectations.
    • Header reorganization: NetBSD’s source tree sometimes changes headers from files to symlinks (or vice versa). If your tree is mid‑upgrade, you can get mismatches.
    • Partial rebuild: Running "build.sh install=/" without a clean DESTDIR can leave behind old files.
    🛠 How to fix
    1. Clean DESTDIR completely
    rm -rf ../obj/destdir.amd64
    1. Then rerun your build.sh command. This ensures no stale headers remain.
    2. Rebuild includes explicitly
      From /usr/src :
    ./build.sh -O ../obj -T ../tools -U -D ../obj/destdir.amd64 includes
    1. This regenerates symlinks like usr/include/elf.h.
    2. Check expected state
      In NetBSD‑current, usr/include/elf.h is a symlink to ../sys/elf.h. Verify in your source tree:
    ls -l /usr/src/include/elf.h
    1. It should show elf.h -> ../sys/elf.h.
    ✅ Summary
    Your build failed because elf.h in DESTDIR is a file, but the spec expects a symlink. The cure is to wipe DESTDIR and rebuild includes so the symlink is created correctly.
    Co-pilot said
    @Crab's Co-pilot said:
    🛠 How to fix
    It seemed like a good idea to clean DESTDIR.amd64, which is inside /obj. So, I moved /usr/obj to /usr/obj-broken and made a new, empty /usr/obj directory:
    linveo# pwd
    /usr
    linveo# ls -l | grep obj
    drwxr-xr-x  23 tom   wheel    512 Dec 16 00:11 obj
    drwxr-xr-x  23 tom   wheel    512 Dec 15 20:02 obj-broken
    linveo#
    I started a new CVS update and build.sh. We will see what happens. . . .
    To begin checking on what Co-pilot said, as the new build proceeds:
    @Crab's Co-pilot said: • During installsets, the build system uses pax together with the METALOG spec file to copy files into the DESTDIR.
     linveo# pwd
    /usr/obj-broken/destdir.amd64
    linveo# cat -n METALOG.sanitised | grep "elf.h " | head -n 1
      3927  ./usr/include/elf.h type=link mode=0755 link=sys/exec_elf.h
    linveo#
    What is the "line 110" in the error that started all this? It's not line 3827 in METALOG.sanitized. . . .
    @Crab's Co-pilot said: • In your actual DESTREE tree, elf.h is a regular file instead of a symlink.
    linveo# cd obj-broken/destdir.amd64/usr/include/
    linveo# ls -l elf.h
    linveo# file elf.h
    elf.h: C source, ASCII text
    linveo#
    Let's see what happens when the new build is done. Thanks! :)
    Extra thanks to @Crab! <3
    @Crab
    Hey! The build and installs of NetBSD-current kernel and userland plus reboots completed without apparent issue. Thanks to Linveo for a fast VPS! <3 Thanks to @cmeerw for the NetBSD image that got me started! <3
    Looks like completely cleaning the /usr/obj directory worked okay! :star: Thanks to your Co-pilot for the hint about cleaning! <3
    As time goes on, maybe I can understand more about exactly what happened and how and why. Maybe I need to incorporate more cleaning?
    In other news, I have been doing a few OpenBSD builds from source. Maybe I am going to try FreeBSD builds too. . . .
    Thanks again for helping @Crab! <3
    Thanked by (1)Crab
    Thank you for your reply!
    Excellent! I thanked my Co-pilot and got a response:
    That’s fantastic news! 🎉. I’m glad the cleanup and header rebuild sorted out the mismatch — those lingering DESTDIR artifacts can be sneaky. It’s always satisfying when a stubborn build error finally gives way to a clean run.
    Going back to your original problem, I think it is a good habit to clean your env before doing any recompilation. You never know what type of clutter is left behind and potentially throwing you off just like what happened here now.
    About compiling FreeBSD, years ago I used to manage multiple production FreeBSD systems using ports which meant that every single update had to be compiled from the sources including the kernel. Yes it took a while, but it was working great and depending on your software needs could provide much more compact and tighter installation than you'd get with pkg. Definitely give it a try!
    How many make targets does NetBSD offer?
    linveo$ cd /usr/src/sys/arch/amd64
    linveo$ ls
    CVS      Makefile acpi     amd64    compile  conf     include  stand
    linveo$ make -V .ALLTARGETS | tr ' ' '\n' | cat -n
         1
         2  tags
         3  links
         4  /usr/src/params
         5  check_DESTDIR
         6  check_RELEASEDIR
         7  all
         8  clean
         9  cleandir
        10  depend
        11  dependall
        12  distclean
        13  includes
        14  install
        15  lint
        16  obj
        17  regress
        18  beforedepend
        19  afterdepend
        20  beforeinstall
        21  afterinstall
        22  realinstall
        23  realdepend
        24  realall
        25  html
        26  subdir-all
        27  subdir-install
        28  subdir-depend
        29  analyze
        30  describe
        31  rumpdescribe
        32  .WAIT_1
        33  .WAIT_2
        34  __makeverbose_dummy_target__
        35  __recurse
        36  all-compile
        37  all-include
        38  all-../x86/include
        39  all-../xen/include
        40  all-../i386/include
        41  all-../i386/stand
        42  all-stand
        43  clean-compile
        44  clean-include
        45  clean-../x86/include
        46  clean-../xen/include
        47  clean-../i386/include
        48  clean-../i386/stand
        49  clean-stand
        50  subdir-clean
        51  cleandir-compile
        52  cleandir-include
        53  cleandir-../x86/include
        54  cleandir-../xen/include
        55  cleandir-../i386/include
        56  cleandir-../i386/stand
        57  cleandir-stand
        58  subdir-cleandir
        59  depend-compile
        60  depend-include
        61  depend-../x86/include
        62  depend-../xen/include
        63  depend-../i386/include
        64  depend-../i386/stand
        65  depend-stand
        66  dependall-compile
        67  dependall-include
        68  dependall-../x86/include
        69  dependall-../xen/include
        70  dependall-../i386/include
        71  dependall-../i386/stand
        72  dependall-stand
        73  subdir-dependall
        74  includes-compile
        75  includes-include
        76  includes-../x86/include
        77  includes-../xen/include
        78  includes-../i386/include
        79  includes-../i386/stand
        80  includes-stand
        81  subdir-includes
        82  install-compile
        83  install-include
        84  install-../x86/include
        85  install-../xen/include
        86  install-../i386/include
        87  install-../i386/stand
        88  install-stand
        89  lint-compile
        90  lint-include
        91  lint-../x86/include
        92  lint-../xen/include
        93  lint-../i386/include
        94  lint-../i386/stand
        95  lint-stand
        96  subdir-lint
        97  obj-compile
        98  obj-include
        99  obj-../x86/include
       100  obj-../xen/include
       101  obj-../i386/include
       102  obj-../i386/stand
       103  obj-stand
       104  subdir-obj
       105  regress-compile
       106  regress-include
       107  regress-../x86/include
       108  regress-../xen/include
       109  regress-../i386/include
       110  regress-../i386/stand
       111  regress-stand
       112  subdir-regress
       113  tags-compile
       114  tags-include
       115  tags-../x86/include
       116  tags-../xen/include
       117  tags-../i386/include
       118  tags-../i386/stand
       119  tags-stand
       120  subdir-tags
       121  html-compile
       122  html-include
       123  html-../x86/include
       124  html-../xen/include
       125  html-../i386/include
       126  html-../i386/stand
       127  html-stand
       128  subdir-html
       129  analyze-compile
       130  analyze-include
       131  analyze-../x86/include
       132  analyze-../xen/include
       133  analyze-../i386/include
       134  analyze-../i386/stand
       135  analyze-stand
       136  subdir-analyze
       137  describe-compile
       138  describe-include
       139  describe-../x86/include
       140  describe-../xen/include
       141  describe-../i386/include
       142  describe-../i386/stand
       143  describe-stand
       144  subdir-describe
       145  rumpdescribe-compile
       146  rumpdescribe-include
       147  rumpdescribe-../x86/include
       148  rumpdescribe-../xen/include
       149  rumpdescribe-../i386/include
       150  rumpdescribe-../i386/stand
       151  rumpdescribe-stand
       152  subdir-rumpdescribe
       153  lintmanpages-compile
       154  lintmanpages-include
       155  lintmanpages-../x86/include
       156  lintmanpages-../xen/include
       157  lintmanpages-../i386/include
       158  lintmanpages-../i386/stand
       159  lintmanpages-stand
       160  subdir-lintmanpages
       161  lintmanpages
    linveo$
    Here are this morning's results from the NetBSD-current build while I was sleeping. This is with a new, empty /use/obj directory. Maybe I will start replacing /usr/tools as well.
    Kernel
    ===> Summary of results:
             build.sh command:    /usr/src/build.sh -j 2 -O ../obj -T ../tools -U kernel=GENERIC
             build.sh started:    Sat Dec 27 07:00:57 UTC 2025
             MACHINE:             amd64
             HOST_SH:             /bin/sh
             Building kernel without building new tools
             Building kernel:     GENERIC
             Build directory:     /usr/src/../obj/sys/arch/amd64/compile/GENERIC
             Kernels built from GENERIC:
              /usr/src/../obj/sys/arch/amd64/compile/GENERIC/netbsd
             build.sh ended:      Sat Dec 27 07:07:04 UTC 2025
    Build Tools and Userland Distribution
    ===> Successful make distribution
    ===> build.sh ended:      Sat Dec 27 07:00:57 UTC 2025
             build.sh command:    /usr/src/build.sh -j 2 -O ../obj -T ../tools -U distribution
             build.sh started:    Sat Dec 27 05:34:33 UTC 2025
             MACHINE:             amd64
             HOST_SH:             /bin/sh
    After installing new kernel, rebooting, installing new userland, and rebooting again
    NetBSD 11.99.4 (GENERIC) #0: Sat Dec 27 07:06:47 UTC 2025
    linveo# uname -r
    11.99.4
    linveo# uptime
     7:04PM  up 1 min, 1 user, load averages: 0.02, 0.01, 0.00
    linveo# ls -l /bin | head
    total 1942
    -r-xr-xr-x  2 root  wheel   22056 Dec 27 07:00 [
    -r-xr-xr-x  1 root  wheel   22024 Dec 27 07:00 cat
    lrwxr-xr-x  1 root  wheel      11 Dec 27 07:00 chgrp -> /sbin/chown
    -r-xr-xr-x  1 root  wheel   22240 Dec 27 07:00 chio
    -r-xr-xr-x  1 root  wheel   17584 Dec 27 07:00 chmod
    -r-xr-xr-x  1 root  wheel   33528 Dec 27 07:00 cp
    -r-xr-xr-x  1 root  wheel   57720 Dec 27 06:59 cpio
    -r-xr-xr-x  1 root  wheel  194992 Dec 27 07:00 csh
    -r-xr-xr-x  1 root  wheel   27272 Dec 27 07:00 date
    linveo#
    Next, pkgsrc is updated with pkg-rolling_replace and a full backup is made.
    Until recently, this build was running redundantly on two separate servers at separate providers. But right now there is only one server, at Linveo. Is there another server out there? :) Thanks @linveo! <3
    edited January 1
    Thanks @linveo! Happy New Year 2026!
    ===> build.sh ended:      Thu Jan  1 20:30:16 UTC 2026
             build.sh started:    Thu Jan  1 19:03:01 UTC 2026
             MACHINE:             amd64
             HOST_SH:             /bin/sh
             No $TOOLDIR/bin/nbmake, needs building.
             Bootstrapping nbmake
             Created /usr/src/../tools/bin/nbmake
         5234.75 real      7614.10 user      1527.33 sys
    ===> Kernels built from GENERIC:
    ===> build.sh ended:      Thu Jan  1 20:36:48 UTC 2026
             build.sh started:    Thu Jan  1 20:30:16 UTC 2026
             MACHINE:             amd64
             HOST_SH:             /bin/sh
          392.03 real       561.91 user       115.55 sys
    NetBSD 11.99.4 (GENERIC) #0: Thu Jan  1 20:36:29 UTC 2026
    linveo# uptime
     9:00PM  up 1 min, 1 user, load averages: 0.00, 0.00, 0.00
    total 1942
    -r-xr-xr-x  2 root  wheel   22056 Jan  1 20:29 [
    -r-xr-xr-x  1 root  wheel   22024 Jan  1 20:29 cat
    lrwxr-xr-x  1 root  wheel      11 Jan  1 20:29 chgrp -> /sbin/chown
    -r-xr-xr-x  1 root  wheel   22240 Jan  1 20:29 chio
    -r-xr-xr-x  1 root  wheel   17584 Jan  1 20:29 chmod
    -r-xr-xr-x  1 root  wheel   33528 Jan  1 20:29 cp
    -r-xr-xr-x  1 root  wheel   57720 Jan  1 20:29 cpio
    -r-xr-xr-x  1 root  wheel  194992 Jan  1 20:29 csh
    -r-xr-xr-x  1 root  wheel   27272 Jan  1 20:29 date
    linveo#
    This morning's NetBSD-current compile completed successfully following a NetBSD source code commit which seemed to fix a compile error first seen yesterday evening.
    Both this morning's commit and yesterday evening's error transcript are below.
    • Is this the commit which fixed the error?
    • How does the fix work?
    • Why did the compile error transcript show several compiler flags being repeated within a single command?
    Thanks to @linveo for the test VPS! <3 Thanks in advance for any help understanding this error and its fix! <3
    Commit
    To: source-changes%NetBSD.org@localhost
    Subject: CVS commit: src/tools/compat
    Date: Sun, 11 Jan 2026 10:37:46 +0000
    Module Name:    src
    Committed By:   nia
    Date:           Sun Jan 11 10:37:46 UTC 2026
    Modified Files:
            src/tools/compat: compat_defs.h configure configure.ac
    Log Message:
    tools build fixes for <sys/endian.h> changes, from skrll
    To generate a diff of this commit:
    cvs rdiff -u -r1.130 -r1.131 src/tools/compat/compat_defs.h
    cvs rdiff -u -r1.110 -r1.111 src/tools/compat/configure
    cvs rdiff -u -r1.112 -r1.113 src/tools/compat/configure.ac
    Please note that diffs are not public domain; they are subject to the
    copyright notices on the relevant files.
    Error Transcript
         1  --- dependall ---
         2  --- atoll.lo ---
         3  --- basename.lo ---
         4  --- atoll.lo ---
         5  #   compile  compat/atoll.lo
         6  cc -O   -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys  -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D__DBINTERFACE_PRIVATE -c -o atoll.lo.o    /usr/src/tools/compat/../../lib/libc/stdlib/atoll.c
         7  --- basename.lo ---
         8  #   compile  compat/basename.lo
         9  cc -O   -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys  -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D__DBINTERFACE_PRIVATE -c -o basename.lo.o    /usr/src/tools/compat/../../lib/libc/gen/basename.c
        10  --- atoll.lo ---
        11  In file included from ./nbtool_config.h:987,
        12                   from /usr/src/tools/compat/../../lib/libc/stdlib/atoll.c:33:
        13  /usr/src/tools/compat/compat_defs.h: In function 'be16enc':
        14  /usr/src/tools/compat/compat_defs.h:1138:25: error: implicit declaration of function 'bswap16' [-Wimplicit-function-declaration]
        15   1138 | #define htobe16(x)      bswap16((u_int16_t)(x))
        16        |                         ^~~~~~~
        17  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe16'
        18   1179 |         u = hto ## endian ## bits (u); \
        19        |             ^~~
        20  /usr/src/tools/compat/compat_defs.h:1183:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        21   1183 | __GEN_ENDIAN_ENC(16, be)
        22        | ^~~~~~~~~~~~~~~~
        23  /usr/src/tools/compat/compat_defs.h: In function 'be32enc':
        24  /usr/src/tools/compat/compat_defs.h:1141:25: error: implicit declaration of function 'bswap32' [-Wimplicit-function-declaration]
        25   1141 | #define htobe32(x)      bswap32((u_int32_t)(x))
        26        |                         ^~~~~~~
        27  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe32'
        28   1179 |         u = hto ## endian ## bits (u); \
        29        |             ^~~
        30  /usr/src/tools/compat/compat_defs.h:1186:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        31   1186 | __GEN_ENDIAN_ENC(32, be)
        32        | ^~~~~~~~~~~~~~~~
        33  /usr/src/tools/compat/compat_defs.h: In function 'be64enc':
        34  /usr/src/tools/compat/compat_defs.h:1144:25: error: implicit declaration of function 'bswap64' [-Wimplicit-function-declaration]
        35   1144 | #define htobe64(x)      bswap64((u_int64_t)(x))
        36        |                         ^~~~~~~
        37  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe64'
        38   1179 |         u = hto ## endian ## bits (u); \
        39        |             ^~~
        40  /usr/src/tools/compat/compat_defs.h:1189:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        41   1189 | __GEN_ENDIAN_ENC(64, be)
        42        | ^~~~~~~~~~~~~~~~
        43
        44  *** Failed target: atoll.lo
        45  *** In directory: /usr/src/tools/compat
        46  *** Failed commands:
        47          ${_MKTARGET_COMPILE}
        48          => @echo '#  ' "compile " compat/atoll.lo
        49          ${HOST_COMPILE.c} -o ${.TARGET}.o ${COPTS.${.IMPSRC:T}} ${CPUFLAGS.${.IMPSRC:T}} ${CPPFLAGS.${.IMPSRC:T}} ${.IMPSRC}
        50          => cc -O   -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys  -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D__DBINTERFACE_PRIVATE -c -o atoll.lo.o    /usr/src/tools/compat/../../lib/libc/stdlib/atoll.c
        51          ${MV} ${.TARGET}.o ${.TARGET}
        52          => mv -f atoll.lo.o atoll.lo
        53  *** [atoll.lo] Error code 1
        54
        55  nbmake[6]: stopped making "realall" in /usr/src/tools/compat
        56  --- basename.lo ---
        57  In file included from ./nbtool_config.h:987,
        58                   from /usr/src/tools/compat/namespace.h:9,
        59                   from /usr/src/tools/compat/../../lib/libc/gen/basename.c:37:
        60  /usr/src/tools/compat/compat_defs.h: In function 'be16enc':
        61  /usr/src/tools/compat/compat_defs.h:1138:25: error: implicit declaration of function 'bswap16' [-Wimplicit-function-declaration]
        62   1138 | #define htobe16(x)      bswap16((u_int16_t)(x))
        63        |                         ^~~~~~~
        64  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe16'
        65   1179 |         u = hto ## endian ## bits (u); \
        66        |             ^~~
        67  /usr/src/tools/compat/compat_defs.h:1183:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        68   1183 | __GEN_ENDIAN_ENC(16, be)
        69        | ^~~~~~~~~~~~~~~~
        70  /usr/src/tools/compat/compat_defs.h: In function 'be32enc':
        71  /usr/src/tools/compat/compat_defs.h:1141:25: error: implicit declaration of function 'bswap32' [-Wimplicit-function-declaration]
        72   1141 | #define htobe32(x)      bswap32((u_int32_t)(x))
        73        |                         ^~~~~~~
        74  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe32'
        75   1179 |         u = hto ## endian ## bits (u); \
        76        |             ^~~
        77  /usr/src/tools/compat/compat_defs.h:1186:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        78   1186 | __GEN_ENDIAN_ENC(32, be)
        79        | ^~~~~~~~~~~~~~~~
        80  /usr/src/tools/compat/compat_defs.h: In function 'be64enc':
        81  /usr/src/tools/compat/compat_defs.h:1144:25: error: implicit declaration of function 'bswap64' [-Wimplicit-function-declaration]
        82   1144 | #define htobe64(x)      bswap64((u_int64_t)(x))
        83        |                         ^~~~~~~
        84  /usr/src/tools/compat/compat_defs.h:1179:13: note: in expansion of macro 'htobe64'
        85   1179 |         u = hto ## endian ## bits (u); \
        86        |             ^~~
        87  /usr/src/tools/compat/compat_defs.h:1189:1: note: in expansion of macro '__GEN_ENDIAN_ENC'
        88   1189 | __GEN_ENDIAN_ENC(64, be)
        89        | ^~~~~~~~~~~~~~~~
        90
        91  *** Failed target: basename.lo
        92  *** In directory: /usr/src/tools/compat
        93  *** Failed commands:
        94          ${_MKTARGET_COMPILE}
        95          => @echo '#  ' "compile " compat/basename.lo
        96          ${HOST_COMPILE.c} -o ${.TARGET}.o ${COPTS.${.IMPSRC:T}} ${CPUFLAGS.${.IMPSRC:T}} ${CPPFLAGS.${.IMPSRC:T}} ${.IMPSRC}
        97          => cc -O   -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys  -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -I. -I./include -I/usr/src/tools/compat -I/usr/src/tools/compat/sys -DHAVE_NBTOOL_CONFIG_H=1 -D_FILE_OFFSET_BITS=64 -D__DBINTERFACE_PRIVATE -c -o basename.lo.o    /usr/src/tools/compat/../../lib/libc/gen/basename.c
        98          ${MV} ${.TARGET}.o ${.TARGET}
        99          => mv -f basename.lo.o basename.lo
       100  *** [basename.lo] Error code 1
       101
       102  nbmake[6]: stopped making "realall" in /usr/src/tools/compat
       103  nbmake[6]: 2 errors
       104
       105  nbmake[6]: stopped making "realall" in /usr/src/tools/compat
       106
       107  nbmake[5]: stopped making "dependall" in /usr/src/tools/compat
       108
       109  nbmake[4]: stopped making "dependall-compat dependall-binstall dependall-host-mkdep" in /usr/src/tools
       110
       111  nbmake[3]: stopped making "build_install" in /usr/src/tools
       112
       113  nbmake[2]: stopped making "do-tools" in /usr/src
       114
       115  nbmake[1]: stopped making "build" in /usr/src
       116
       117  nbmake: stopped making "distribution" in /usr/src
       118
       119  ERROR: Failed to make distribution
       120
       121  *** BUILD ABORTED ***
       122         40.75 real        26.97 user        24.87 sys
       123
       124  ========
    NetBSD recompiled itself last night while I was sleeping! :)
    The new kernel install followed by reboot, the new userland install, and another reboot happened a few moments ago.
    chronos@penguin:~/2026/linveo$ `head -n 1 login`
    Last login: Sun Feb  1 18:31:10 2026 from 186.96.138.102
    NetBSD 11.99.5 (GENERIC) #0: Sun Feb  1 07:14:33 UTC 2026
    linveo# date; uptime
    Sun Feb  1 18:36:51 UTC 2026
     6:36PM  up 1 min, 1 user, load averages: 0.00, 0.00, 0.00
    total 1942
    -r-xr-xr-x  2 root  wheel   22056 Feb  1 07:07 [
    -r-xr-xr-x  1 root  wheel   22024 Feb  1 07:07 cat
    lrwxr-xr-x  1 root  wheel      11 Feb  1 07:07 chgrp -> /sbin/chown
    -r-xr-xr-x  1 root  wheel   22240 Feb  1 07:07 chio
    -r-xr-xr-x  1 root  wheel   17584 Feb  1 07:07 chmod
    -r-xr-xr-x  1 root  wheel   33528 Feb  1 07:07 cp
    -r-xr-xr-x  1 root  wheel   57728 Feb  1 07:07 cpio
    -r-xr-xr-x  1 root  wheel  194992 Feb  1 07:07 csh
    -r-xr-xr-x  1 root  wheel   27272 Feb  1 07:07 date
    linveo# ls -l /lib | head
    total 18640
    drwxr-xr-x  3 root  wheel      512 Feb  1 05:44 i386
    lrwxr-xr-x  1 root  wheel       13 Feb  1 07:07 libavl.so -> libavl.so.0.0
    lrwxr-xr-x  1 root  wheel       13 Feb  1 07:07 libavl.so.0 -> libavl.so.0.0
    -r--r--r--  1 root  wheel    16096 Feb  1 07:07 libavl.so.0.0
    lrwxr-xr-x  1 root  wheel       19 Feb  1 07:07 libblocklist.so -> libblocklist.so.0.1
    lrwxr-xr-x  1 root  wheel       19 Feb  1 07:07 libblocklist.so.0 -> libblocklist.so.0.1
    -r--r--r--  1 root  wheel    20792 Feb  1 07:07 libblocklist.so.0.1
    lrwxr-xr-x  1 root  wheel       14 Feb  1 05:47 libc.so -> libc.so.12.224
    lrwxr-xr-x  1 root  wheel       14 Feb  1 05:47 libc.so.12 -> libc.so.12.224
    linveo#
    Now all the packages were rebuilt by pkg_rolling-replace -rsuv :
    + asciidoc
    + git
    + git-perlscripts
    + libgcrypt
    + libgpg-error
    + libxslt
    + p5-Authen-SASL
    + xmlto
          175.07 real        74.63 user        28.86 sys
    Sun Feb  1 18:54:34 UTC 2026
    I recently was looking at the history of compilers (for example, pcc) and the make and bmake commands.
    According to its Wikipedia article make will be 50 years old next month!
    As mentioned in the OP,
    VPS Share
    Would anybody be interested in sharing my free Linveo AMD Ryzen 9 9950X NetBSD VPS in Arizona? It's open to friends who want to help me learn.
    The offer is still open! :)
    Thanks @Linveo! <3
    Thanked by (2)Crab tmntwitw
    I remember building a NetBSD 1.x kernel on my Vaxstation 3100. It recompiled itself over several nights of sleep.
    Today's rebuild of NetBSD-current is now running!
    As mentioned at https://lowendspirit.com/discussion/comment/228322/#Comment_228322 today's rebuild has a fix for a bug found by LES' esteemed @cmeerw!
    NetBSD 11.99.5 (GENERIC) #1: Sun Feb  8 00:33:15 UTC 2026
    Sun Feb  8 02:15:24 UTC 2026
     2:15AM  up 1 min, 1 user, load averages: 0.00, 0.00, 0.00
    total 1942
    -r-xr-xr-x  2 root  wheel   22056 Feb  8 00:26 [
    -r-xr-xr-x  1 root  wheel   22024 Feb  8 00:26 cat
    lrwxr-xr-x  1 root  wheel      11 Feb  8 00:26 chgrp -> /sbin/chown
    -r-xr-xr-x  1 root  wheel   22240 Feb  8 00:26 chio
    -r-xr-xr-x  1 root  wheel   17584 Feb  8 00:26 chmod
    -r-xr-xr-x  1 root  wheel   33528 Feb  8 00:26 cp
    -r-xr-xr-x  1 root  wheel   57728 Feb  8 00:26 cpio
    -r-xr-xr-x  1 root  wheel  194992 Feb  8 00:26 csh
    -r-xr-xr-x  1 root  wheel   27272 Feb  8 00:26 date
    linveo# ls -l /usr/bin/ftp
    -r-xr-xr-x  1 root  wheel  208968 Feb  8 00:26 /usr/bin/ftp
    linveo#
    Thanked by (1)cmeerw
    Yet another successful rebuild of NetBSD-current! :star:
    Last login: Fri Feb 20 21:44:58 2026 from xxx.xxx.xxx.xxx
    NetBSD 11.99.5 (GENERIC) #2: Fri Feb 20 07:07:27 UTC 2026
    linveo# uptime
    10:21PM  up 3 mins, 1 user, load averages: 0.00, 0.00, 0.00
    linveo#
    Thanks to @linveo for a whole year 🎂 of fast, free Ryzen 9 9950X VPS! <3
    As I said a year ago today in the OP:
    VPS Share
    Thanked by (1)linveo
    I put this offer up on Nodeseek.
