More NetBSD-current fun at Linveo!
124»
    Yet another successful rebuild of NetBSD-current! :star:
    chronos@penguin:~/2026/linveo$ `head -n 1 login`
    Last login: Fri Feb 20 21:44:58 2026 from xxx.xxx.xxx.xxx
    NetBSD 11.99.5 (GENERIC) #2: Fri Feb 20 07:07:27 UTC 2026
    linveo# uptime
    10:21PM  up 3 mins, 1 user, load averages: 0.00, 0.00, 0.00
    linveo#
    Wow, that
    `head -n 1 login`
    got me confused for a bit. Had never thought you could use it in that context.
    Hi @cmeerw!
    In my Chromebook's Linux container's servers directory, each provider has its own subdirectory, inside of which each server has its own directory.
    The individual server directories each have a file named login. The first line of each login file (output by head -n 1) is the IPv4 ssh login command and the last line of each login file (output by tail -n 1) is the IPv6 ssh login command.
    As long as I am in the right directory, and using sh or bash, I almost always can log in by ssh to any server with the same two keystrokes: Ctrl+r (reverse search through previous commands) and then backtick (`).
    As you know, the backticks tell sh and bash to run as a command the output of what is between the backticks.
    Of course, as you know, ssh has it's own built-in shortcut procedure that can be set up in a configuration file.
    Thanks!
    Tom
    Thanked by (2)cmeerw Crab
  • Hopefully cmeerw's fix gets into NetBSD 11 so I could finally see a login prompt on my Linveo Intel VM :disappointed:
    It is working amazingly on FreeBSD though and the uptime has been impeccable.
    There seems to be a new version of the venerable pcc compiler available on Github at https://github.com/PortableCC.
    The new pcc seems to bootstrap successfully on NetBSD-current. The Github pcc sources were compiled first using NetBSD's native gcc, and then compiled again using the gcc-built pcc as the compiler to get a pcc-compiled, bootstrapped pcc.
    netbsd$ date
    Sun Apr  5 16:33:42 UTC 2026
    netbsd$ pwd
    /home/tom/PortableCC-compiles-itself/bin
    netbsd$ ls
    hello.c     p++     pcc     pcpp
    netbsd$ cat hello.c
    #include <stdio.h>
    int main() {
        printf("Hello from bootstrapped PCC!\n");
        return 0;
    netbsd$ ./pcc -o hello hello.c
    netbsd$ ./hello
    netbsd$ ./pcc -v
    Portable C Compiler 1.2.0.DEVEL 20231021 for x86_64-unknown-netbsd11.99
    error: no input files
    netbsd$
    Thanks to Anders Magnusson, the recent main pcc developer! <3 Thanks to Linveo for sponsoring my NetBSD-current VPS! <3
