Looking for hourly-based NAT IPv4 VPS with at least 3 TCP & UDP forwarded ports (Check details)
edited March 1 in General
Hourly-based NAT IPv4 with root access:
  • KVM or OVZ (KVM is preferred)
  • At least 3 public forwarded TCP & UDP ports (including SSH)
  • At least 200 Mbps network speed
  • 1 vCPU
  • 512 MB RAM (256 MB should work too)
  • No monthly/daily/weekly contract, only hourly
  • Locations, any of: US, DE, NL
  • Can delete and recreate with no limits, different IPs and/or multiple locations would be a plus
  • Would be a plus if I can choose my own resources
Use case:
  • VPN (OpenVPN & WireGuard)
  • Proxies (Dynamic SSH port forward - ssh -C -N -D options & ShadowSocks)
And to be clear from the beginning, if your service requires specific minimum for adding balance, I won't deposit +$2.
If you require any more info, please let me know (I can send an example of a service too).
Thanks.
    edited March 1
    MicroNode/YetiNode may be useful. Alternatively have a look if TierHive matches your requirements.
  • AnthonySmithAnthonySmith ModeratorHosting ProviderOGSenpai
    o your budget is $2 maximum?
    @MichaelCee said: Alternatively have a look if TierHive matches your requirements.
    There is free credit without a credit card on sign up, but minimum top up os $3 also you get 2 ports (technically, you get around 500 ports, as you get a /24 but if you don't know how to port forward or use socat, then maybe it's confusing)
    I was going to comment on this last night, but it almost reads like someone who tried TierHive and decided it was not right for them haha.
    TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
  • edited March 2
    @MichaelCee said: MicroNode/YetiNode may be useful. Alternatively have a look if TierHive matches your requirements.
    MicroNode keeps giving me this error: "Error: It looks like you are using invalid details. Please ensure that all details are correct. Signups from a VPN or Proxy are not allowed." every time I try to register, and not sure why it's saying "VPN or Proxy are not allowed", because I'm not using any. In addition to that it asks a lot of personal information, especially phone number, why?
    @AnthonySmith said: I was going to comment on this last night, but it almost reads like someone who tried TierHive and decided it was not right for them haha.
    Yes, I do use TierHive at the moment, it has almost everything I want, except the number of allowed ports and the minimum top up. But these aren't really a big problem if it's my only option, that's why I'm looking for additional alternatives, also because if they ran out of business or closed, I can have an alternative ready.
    edited March 2
    Just in case you don't know you can spin up a micro instance for more ports and just forward internally on your /24 and they only cost around $0.10 p/month.
    One of the improvements we are looking into is adding more ports as an option though, still figuring out the best way to do an it.
  • @AnthonySmith said: Just in case you don't know you can spin up a micro instance for more ports and just forward internally on your /24 and they only cost around $0.10 p/month.
    I think I understand what you mean.
    Do you mean create an additional smaller machine and forward a port from the first machine to a public forwarded port on this new machine, correct?
