Looking for hourly-based NAT IPv4 VPS with at least 3 TCP & UDP forwarded ports (Check details)
Hourly-based NAT IPv4 with root access:
- KVM or OVZ (KVM is preferred)
- At least 3 public forwarded TCP & UDP ports (including SSH)
- At least 200 Mbps network speed
- 1 vCPU
- 512 MB RAM (256 MB should work too)
- No monthly/daily/weekly contract, only hourly
- Locations, any of: US, DE, NL
- Can delete and recreate with no limits, different IPs and/or multiple locations would be a plus
- Would be a plus if I can choose my own resources
Use case:
- VPN (OpenVPN & WireGuard)
- Proxies (Dynamic SSH port forward -
ssh -C -N -Doptions & ShadowSocks)
And to be clear from the beginning, if your service requires specific minimum for adding balance, I won't deposit +$2.
If you require any more info, please let me know (I can send an example of a service too).
Thanks.
MicroNode/YetiNode may be useful. Alternatively have a look if TierHive matches your requirements.
o your budget is $2 maximum?
There is free credit without a credit card on sign up, but minimum top up os $3 also you get 2 ports (technically, you get around 500 ports, as you get a /24 but if you don't know how to port forward or use socat, then maybe it's confusing)
I was going to comment on this last night, but it almost reads like someone who tried TierHive and decided it was not right for them haha.
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
MicroNode keeps giving me this error: "Error: It looks like you are using invalid details. Please ensure that all details are correct. Signups from a VPN or Proxy are not allowed." every time I try to register, and not sure why it's saying "VPN or Proxy are not allowed", because I'm not using any. In addition to that it asks a lot of personal information, especially phone number, why?
Yes, I do use TierHive at the moment, it has almost everything I want, except the number of allowed ports and the minimum top up. But these aren't really a big problem if it's my only option, that's why I'm looking for additional alternatives, also because if they ran out of business or closed, I can have an alternative ready.
Just in case you don't know you can spin up a micro instance for more ports and just forward internally on your /24 and they only cost around $0.10 p/month.
One of the improvements we are looking into is adding more ports as an option though, still figuring out the best way to do an it.
I think I understand what you mean.
Do you mean create an additional smaller machine and forward a port from the first machine to a public forwarded port on this new machine, correct?
Tagging the yeti @AuroraZero
Most providers will ask for your phone number. No idea why. They never message or call
Also, if you are going to be signing up to a lot of services, get yourself a secondary no contract phone line for a few months. Use that number to sign up and thæn cancel the plan.
