Installing OpenBSD on a KVM VPS via ipxe/VNC console, no template required. (128mb ram, 1GB Disk)
AnthonySmith
ModeratorHosting ProviderOGSenpai
Ok, I know, I said last time I would not do any more for a while, but a few things that were said in response to the other ones got me thinking more down the OpenBSD route.
So again, armed with a 128mb TierHive VPS with 1GB disk, I got to work.
This should work on any host that provides an HTML5 VNC console in theory, as long as they have enabled the ability for you to drop into boot options, I think that's pretty standard now?
It's really going to help if your host also supports a clipboard for the html5 console, but not the end of the world if not.
First off, just install any OS to get the VPS set up with the package and specs you want, let it finish setup, I just used the Alpine template as its the only one that allows 128mb and 1GB disk, its a good idea to let this fully finish if you are on other hosts, I know from experience not everyone sets the default disk drivers etc until you actually install an os and you dont wantto be using the ide driver (solusvm)
Then get ready to catch the reboot aand start pressing escape in the html5 vnc console:
You will need to catch the ctrl+b option to drop you into the IPXE shell, like the above image shows, if you have DHCP enabled, just type dhcp and press enter; otherwise, you will need to configure your network at this stage, for example:
set net0/ip 192.168.1.123
set net0/netmask 255.255.255.0
set net0/gateway 192.168.1.1
set dns 8.8.8.8
ifopen net0
The ipxe shell should now have internet access, so we can pull the cd78.iso
sanboot http://cdn.openbsd.org/pub/OpenBSD/7.8/amd64/cd78.iso
Let that run for a bit, if you dont have dhcp you will need to enter the network details again otherise dhcp will sort that out for you, and you will eventually get to the install options:
Now select (I)nstall and run through the obvious options for ssh, user password etc, in most cases the defaults are fine but I will assume you have some clue about them if you are even attempting this, I used an auto disk layout for speed.
Select [http] (also the default) for sets.
And when it prompts for an HTTP Server, use cdn.openbsd.org
Select the sets for a minimal install, deselect everything that is not needed:
-comp78.tgz -man78.tgz -game78.tgz -xbase78.tgz -xserv78.tgz -xshare78.tgz -xfont78.tgz -bsd.rd
You will see a prompt about the prefetch area; the default is no, type yes
Now its going to pull the sets and then ask you if you want any more sets, the default [done] option is fine.
The install will finish up, you will see a load of warnings about /mnt file system is full, it's fine, just run syspatch after first boot a few times, you can now reboot, and enjoy ![]()
Welcome to OpenBSD: The proactively secure Unix-like operating system.
Please use the sendbug(1) utility to report bugs in the system.
Before reporting a bug, please try to reproduce it with the latest
version of the code. With bug reports, please try to ensure that
enough information to reproduce the problem is enclosed, and if a
known fix for it exists, include that as well.
testbsd# syspatch
Get/Verify syspatch78-001_syspatc... 100% |***************************************************************************************************| 8538 00:00
Installing patch 001_syspatch
syspatch: updated itself, run it again to install missing patches
testbsd# syspatch
Get/Verify syspatch78-003_unbound... 100% |***************************************************************************************************| 2952 KB 00:00
Installing patch 003_unbound
Get/Verify syspatch78-004_libssl.tgz 100% |***************************************************************************************************| 2553 KB 00:00
Installing patch 004_libssl
Get/Verify syspatch78-005_smtpd.tgz 100% |****************************************************************************************************| 218 KB 00:00
Installing patch 005_smtpd
Get/Verify syspatch78-006_libunwi... 100% |***************************************************************************************************| 1669 KB 00:00
Installing patch 006_libunwind
Get/Verify syspatch78-010_unbound... 100% |***************************************************************************************************| 2953 KB 00:00
Installing patch 010_unbound
Get/Verify syspatch78-012_rpki.tgz 100% |*****************************************************************************************************| 141 KB 00:00
Installing patch 012_rpki
Get/Verify syspatch78-013_httpd.tgz 100% |****************************************************************************************************| 79409 00:00
Installing patch 013_httpd
Get/Verify syspatch78-014_expat.tgz 100% |****************************************************************************************************| 685 KB 00:00
Installing patch 014_expat
Get/Verify syspatch78-015_tmppath... 100% |***************************************************************************************************| 1135 KB 00:00
Installing patch 015_tmppath
Get/Verify syspatch78-017_tmppath... 100% |***************************************************************************************************| 79182 00:00
Installing patch 017_tmppath
Get/Verify syspatch78-021_calenda... 100% |***************************************************************************************************| 14278 00:00
Installing patch 021_calendar
Get/Verify syspatch78-023_calenda... 100% |***************************************************************************************************| 14646 00:00
Installing patch 023_calendar
Get/Verify syspatch78-024_expat.tgz 100% |****************************************************************************************************| 683 KB 00:00
Installing patch 024_expat
Get/Verify syspatch78-026_smtpd.tgz 100% |****************************************************************************************************| 310 KB 00:00
Installing patch 026_smtpd
Errata can be reviewed under /var/syspatch
Fresh install, nothing changed yet.
Memory: Real: 21M/88M act/tot Free: 3936K Cache: 13M Swap: 3272K/17M
Filesystem Size Used Avail Capacity Mounted on
/dev/sd0a 975M 634M 292M 69% /
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 1 0.0 0.3 944 376 ?? I 2:03PM 0:00.01 /sbin/init
root 25349 0.0 0.0 1108 24 ?? Ip 2:03PM 0:00.01 /sbin/slaacd
_slaacd 29575 0.0 0.1 1116 112 ?? Ip 2:03PM 0:00.01 slaacd: engi
_slaacd 82864 0.0 0.1 1112 96 ?? IpU 2:03PM 0:00.02 slaacd: fron
root 99250 0.0 0.0 1120 24 ?? IU 2:03PM 0:00.00 /sbin/dhcple
_dhcp 56878 0.0 0.5 1132 596 ?? Ip 2:03PM 0:00.01 dhcpleased:
_dhcp 40899 0.0 0.6 1140 688 ?? IpU 2:03PM 0:00.01 dhcpleased:
root 33511 0.0 0.0 832 24 ?? IpU 2:03PM 0:00.01 /sbin/resolvd
root 18053 0.0 1.6 1048 1836 ?? IpU 2:04PM 0:00.01 syslogd: [pr
_syslogd 75114 0.0 1.4 1492 1632 ?? Spc 2:04PM 0:00.04 /usr/sbin/sy
root 13046 0.0 0.7 976 760 ?? IU 2:04PM 0:00.00 pflogd: [pri
_pflogd 85025 0.0 0.8 1016 904 ?? Ipc 2:04PM 0:00.00 pflogd: [run
_ntp 68896 0.0 2.0 1176 2324 ?? S<pc 2:04PM 0:00.16 ntpd: ntp en
_ntp 79900 0.0 1.6 1128 1856 ?? Ip 2:04PM 0:00.01 ntpd: dns en
root 89475 0.0 1.5 1756 1676 ?? I<pU 2:04PM 0:00.01 /usr/sbin/nt
root 4509 0.1 2.5 1100 2848 ?? S 2:04PM 0:00.07 sshd: /usr/s
root 3013 0.0 1.6 1816 1864 ?? Ip 2:04PM 0:00.01 /usr/sbin/sm
_smtpd 85973 0.0 2.0 1552 2240 ?? Ipc 2:04PM 0:00.00 smtpd: crypt
_smtpd 42320 0.0 2.2 1876 2516 ?? Ipc 2:04PM 0:00.01 smtpd: contr
_smtpd 39534 0.0 2.6 1652 2952 ?? Ip 2:04PM 0:00.01 smtpd: looku
_smtpd 39115 0.0 4.1 2384 4680 ?? Ipc 2:04PM 0:00.01 smtpd: dispa
_smtpq 64001 0.0 2.9 1776 3296 ?? Ipc 2:04PM 0:00.01 smtpd: queue
_smtpd 12214 0.0 2.8 1556 3164 ?? Ipc 2:04PM 0:00.01 smtpd: sched
_sndiop 81722 0.0 0.8 9060 932 ?? IpU 2:04PM 0:00.00 sndiod: help
_sndio 52312 0.0 0.7 9060 828 ?? I<pc 2:04PM 0:00.00 /usr/bin/snd
root 45289 0.0 1.2 1136 1400 ?? Ip 2:05PM 0:00.01 /usr/sbin/cr
Services enabled at boot:
check_quotas
cron
dhcpleased
library_aslr
ntpd
pf
pflogd
resolvd
slaacd
smtpd
sndiod
sshd
syslogd
I am sure someone that is more of a regular BSD user will probably know a few things that could improve this. I encourage you to comment.
And.... you can probably guess what is coming next....
AI Declaration: There was no AI involved in this; the work is my own. I did not even bother using it for formatting, as this was a speed run; you can just live with my shitty English spelling and grammar
Enjoy!
Spoiler:
TierHive - Hourly VPS - NAT Native - /24 per customer - Lab in the cloud - Free to try. | I am Anthony Smith
You can disable most of those daemons. I would also suggest installing a stripped-down kernel.
I put a link to this post HN, in Show HN:
Pointed it back here, maybe get some new blood in the community.
Did Christmas come early?! These guides are just fantastic!
We are glad to see IPv6 remains enabled.
best of "yoursunny lore" by Google AI 🤣 affbrr
