lowendspirit solusvm NAT VPS api url ?
Hi
I generated API key and hash under solus vm console, however can't figure out what's the url to send the request to?
Thanks
  • Did you ask for access to post through SVM?
  • Hm, don't exactly understand what do you mean
  • Did you tell @AnthonySmith , @mikho , or whoever you bought an LES service from that you wanted to use the API? These aren't always directly accessible.
  • mikhomikho AdministratorOG
    @WSS me no use Solus ?
  • @mikho YOU.. YOU BASTARD!
    Thanked by (1)mikho
    @flesz said:
    Hi
    Thanks
    Add ”/api/client" after the solus url and you should be good to go. If the provider has the API accessible.
    You should probably read up on the Solus Docs on what you can do as a client.
    Ah, ok will ask Anthony about it, cheers
    I tried that, but getting permanently redirected response, so I think the URL is different or I am doing something wrong
    I will create a ticket
    Have you read this: https://documentation.solusvm.com/display/DOCS/Client ? and know how to test it?
