Decent if the hard 100 mbit/s cap is acceptable. All resources are "dedicated", so that's nice, but the good disk and cpu bench here might just be because the nodes are vacant right now. I'll test again in a few weeks to see if the results are similar.
The best Block Size | 4kb speed I've ever seen
To be honest it was on a relatively quiet node with reasonably new drives.
Nexusbytes FSN, nice GeekBench score.
Naranjatech
Virmach (this one is free)
UltraVPS SAS Special, this one has been a lot better in the past. Noisy neighbors much?
Lunanode Toronto
VirMach BlackFriday
4GB/12GB Disk/4 IP adresses=12$
Can't complain...
Hotline servers, 512MB SSD
Oracle Cloud free instance in Frankfurt
SEO Software
Cheap SSD Hosting
Web Scraping API
https://ecosia.org Plant trees from your keyboard.
OVHCloud's new "Starter VPS" - 1 vCore/2 GB/20 GB SSD/unlim 100Mbps @ $3.50/mo in Vint Hill, VA, USA
Tetahost
Rare CPU in hetzner
Presumably empty node
--------------------------------- Processor : Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz CPU cores : 2 @ 3600.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.9Gi Swap : 2.0Gi Disk : 18G fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4kb (IOPS) | 64kb (IOPS) ------ | --- ---- | ---- ---- Read | 238.70 MB/s (59.6k) | 2.30 GB/s (36.0k) Write | 239.33 MB/s (59.8k) | 2.32 GB/s (36.2k) Total | 478.03 MB/s (119.5k) | 4.62 GB/s (72.3k) | | Block Size | 512kb (IOPS) | 1mb (IOPS) ------ | ----- ---- | --- ---- Read | 3.40 GB/s (6.6k) | 3.49 GB/s (3.4k) Write | 3.58 GB/s (7.0k) | 3.73 GB/s (3.6k) Total | 6.99 GB/s (13.6k) | 7.23 GB/s (7.0k) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4931 Multi Core | 8225 Full Test | https://browser.geekbench.com/v4/cpu/15512877I bench YABS 24/7/365 unless it's a leap year.
I too grabbed one. Seems very good. Most likely new yet. Well worth the price though.
@AnthonySmith possible to change category to "General" so its viewable by public?
Done, but in technical.
Readydedis 4GB Falkenstein
SSDNodes London Datacenter
Hostodo Miami
Khanwebhost LES KVM Plan 1 France
2 CPU Cores (Intel Xeon) Fair Usage
2 GB RAM
30 Gb SSD Disk Space
6 TB Bandwidth @500 MB/sec
1 IPV4
$3.50 / mo
@Freek Wht about geekbench v4 have u tested it ?
Err, yes, it's in my post? Just above the Geekbench 5 I pasted the Geekbench 4 test.
Ryzen from hotlineservers
Location?
blog | exploring visually |
I think they have it only on Miami
vServer.site special
Miami.
Server.it 2GB 0.99€ KVM
Decided to run this on a 4GB KVM plan on a new Ryzen 3700 Pro (OVH) system that clients will be moved to from E-2136's in Montreal.
