@vyas maybe you could use code for formatting.. I am interested in those spec. How much bandwidth they provide?
I don't normally do these. But since @chocolateshirt requested it... ?
Liteserver.nl 's base-model Storage KVM-HDD-1G .
(1-2% overhead from LUKS full disk encryption)
They actually do deliver 500Gigs usable.
How did you set that up on a VPS?
Seems like you're able to boot a OS ISO with liteserver, so just using the default installer of your distribution I guess.
> Geekbench 5 Benchmark Test:
> Test | Value
> Single Core | 1257
> Multi Core | 1254
> Full Test | https://browser.geekbench.com/v5/cpu/3364455
Browser issues while formatting. Deleted
Squats are the new Push-ups
I wish I could. In Vivaldi/chrome, the page keeps refreshing every time I format. Tried three times. Bot going to waste time again.
Yes, I think this bug happened when we do some post edit and trying to apply code format.
Code format used as below
< p r e >
< / p r e >
@chocolateshirt @vyas
On a test VPS in Bucharest, RO:
Manchester, UK
Nice CPU!
Just debian-installer. (d-I)
MaxKVM
SKVM-4G
$12/mth
Singapore
EPYC 7302P
AES
Nested Virtualization
Those disk speeds are madness. How?
Absolute madness. Looks like a Nexusbytes benchmark to me
AMD EPYC powered Performance NVMe VPS - Los Angeles, Dallas, New York, Amsterdam, Singapore | Support | Status
True. But I’ve got a decent collection of Nexusbytes VM’s and this has by far the highest disk speeds.
This is a Nexusbytes bench? @seriesn must be running a few Samsungs in RAID10 now. Nice!
That and
I try experimenting here and there so that kinda makes sense lol . End of the day, numbers are just numbers. As long as the performance adds up to it
It looks good on benchmarks, I test some things on my VMs that prosper with fast disks. But I won’t notice the difference between 70K and 160K IOPS.
?. Spoken like a true human.
2K iops used to be real good, and 10K was the gold standards.
Guess this just means enough iops for every one and no longer the bottleneck in a shared server it used to be.
Will we ever be a happy family again?
i'm sure there will come one day boss
i came to Singapore for you, but yet you weren't there. Oh baby, only if you knew, how badly I want you
YABS thread needs a “comment cleanup in Aisle 9”...
So that we can get back to yabbing
Nexus Bites Singapore
@seriesn no Green Goblin stuff with the disk speeds
@MaxKVM Singapore..
geekbench 5 numbers are several dozen points lower than the YABS I had run a couple of weeks ago. (link)
Sir, that number don't add up. Can you please power your VPS off and on again from the managementpanel?
What is this green goblin gobledegook stuff?
Also
This is Premium KVM VPS "VPS-1G" right??
