[MaxKVM] Network Updates with Christmas and New Year Offers (2020)!
24
  • @yoursunny said: Hmm, NAUGHTYLIST works on 256MB as well. $12.6/year with IPv4.
    Yup. Not anymore. The 256M, 2G-2CPU, and 4G-4CPU are all excluded because they're already on promotion. =)
    Everyone seems to be waiting for Singapore to be back in stock.
    Existing customers can also migrate to Singapore DC?
  • Damn! I had the 12-24-2020 promo in cart but lost the voucher race when I was about to pay (got the regular price in PayPal)!
    @MaxKVM How many vouchers where for this?
    Thanked by (1)MaxKVM
    75% is a huge bite, and I think there are only a few. When used, it's gone. I guess there could be no exception for today, but there are more lucrative codes for tomorrow and the days after.
    There were only 5 and they sold out in 13 minutes. :joy:
    One of the orders has not competed checkout though. We'll see if more can be released today. :)
    Thanked by (1)jeroen
  • edited December 2020
    Already waiting for 12-25-2020 (but still so many hours to go). Where is my 95% discount? :)
    Thanked by (2)jeroen yoursunny
  • What is the time the new code takes effect everyday?
    Should be 00:00 PST
    Thanked by (2)jeroen MaxKVM
  • @Iroshan464 said:
    75% recurring discount today.
    Aaaand it's gone.
    @Freek said:
    Aaaand it's gone.
    With limited quantity, the coupon code mostly claimed within 10 minutes or so.. You still have a chance tomorrow..
  • @chocolateshirt said:
    @Freek said:
    Aaaand it's gone.
    I managed to get one :) I had my alarm clock at 8:58AM, on Christmas day!
  • What timezone? (I've not been able to apply any coupons and have it actually work with any product I might be interested in ... Except the ADD35 ... :p I guess I'm too old/lazy to retry a lot and set timer to maybe catch a deal.) :#
    I believe 00:00 PST
    I don't use an alarm clock unless I'm going to the airport. This improves sleep quality.
    I make my own deal: several of the special MaxKVM coupons are my suggestion, so I'm tagged when it drops.
    No hostname left!
    You are so lucky.
    I waited and waited and time and again, and the only package I obtained is that 4G, leading S, instead of P.
    When will be the magic code appear and I bump into a new plan, even bigger than the SKVM4g?
    MaxKVM's plan is different from lot of other providers', EPYC server chip, and ECC RAM.
  • I'll be watching this thread incase any new promo :D
    I haven't been able to understand what's the fundamental difference between S and P. The ratio between CPU:RAM:disk is the same.
    I don't feel the need for bigger machines. I write and optimize all the programs myself, so I usually go for the smallest machine. I'm canceling my 2GB and 4GB machines in favor of 512MB and 1GB. My current minimum is 384MB for KVM, and 256MB for container.
    I have high performance software as well, but it uses 100% CPU persistently and needs 100Gbps Ethernet ports (point-to-point VLAN with guaranteed bandwidth, non IP traffic). The network connection alone would cost $3000 per month, so I can only run this in the basement using a direct attach cable.
    Yes EPYC is true enterprise hardware designed for data centers. Ryzens, despite all the hype, are desktop hardware.
    No hostname left!
  • @yoursunny said: I haven't been able to understand what's the fundamental difference between S and P. The ratio between CPU:RAM:disk is the same.
    There was going to be a difference in Processor/RAM/SSD (and there are still plans to split it up) but it was more important to keep performance consistent worldwide so one plan/spec was adopted. Currently looking at RYZEN 3900X/3950X 5900X/5950x with PCIe 4.0 NVMe for the S or P Line to duplicate the 256M-16G lineup in each spec.
    Or maybe a storage lineup using the 3900X with a few HDDs and SSD cache?
    Technically, the Ryzens (or Threadripper, which is almost exactly a desktop EPYC) is not much different from the EPYC. The Ryzen still supports ECC RAM but it is limited to 4 sticks totaling "only" 128GB in dual channel. (This is actually a huge limitation for a processor with as many cores as the 3900/3950/5900/5950X). One (or a few) of those 7H12 "unofficial" EPYC processors would be a nice Christmas present. Looking forward to Zen3 EPYCs in Q1 2021.
    Thanked by (1)chocolateshirt
  • CHRISTMAS MORNING FLASH SALE
    12-25-2020-V0WS2QLW6N
    12-25-2020-7EF4ZB0QDQ
    12-25-2020-8G13YPYQDY
    12-25-2020-8IUFPNF8X1
    12-25-2020-AO538JHB0Y
    12-25-2020-FY8EFWS83T
    12-25-2020-H4L7W1LW2H
    12-25-2020-MYO38YJF94
    12-25-2020-O08TQB5EBX
    12-25-2020-QLVU27F6Y6
    The codes are for random discounts on a random selection of plans and billing cycles. Limited to one use per order/customer.
    SG temporarily in stock while there are active promo codes.
    Good luck! B)
    Good luck! B)
  • seems the biggest one is 50%
    The 75% were found and purchased almost immediately. There is still a 35% and 50% left. :)
    Thanked by (1)verd
  • vyasvyas OGSenpai
    Nice! (or as @smallweb says... Noice! )
  • Very impractical trying to figure these out on mobile ... :s
    Must on the desktop to quick switch tab
  • I've given up on getting any of the (non ADD35) MaxKVM coupons to apply, it's either expired or doesn't apply to product ... And I often only have my cell phone available ... ?‍♂️ B)
    Besides their flash deals, SKVM-4G-4CPU is also a great deal tho. currently I'm using it, you can read my review on other green forum :D
    and if you are a student or they give you sweet 50% off too
    Try HOSTLOC50. It's a 50% coupon and works on most products.
    You don't have to be a student. You just need an .edu inbox. Teachers, postdocs, and alumni have those in addition to students.
    ID.me can do student identity verification, but it'll cost more to the seller/provider.
    No hostname left!
  • @yoursunny said: You don't have to be a student. You just need an .edu inbox. Teachers, postdocs, and alumni have those in addition to students.
    oh, I don't know that, it can be abused then :open_mouth:
