Inception Hosting - We are off to Amsterdam! (Service migrations)
Copy of email sent to all customers in the Netherlands:
As some of you will have no doubt noticed the hardware and general services in the Netherlands from Inception Hosting is getting dated. This has in part been due to failure to reach a suitable long term contract with i3d (the upstream DC) as such what was once Inception Hosting’s largest market and where it all began back in 2011 is now by far the smallest in the Netherlands. I am happy to say that is about to change.
Since late 2020 options have been looked at to bring the Netherlands service back to life and former glory, I am pleased to say that Inception Hosting has found a new home with Clouvider Amsterdam.
All current services will soon be migrated to Clouvider Amsterdam and any new services will be provisioned there as standard from now on.
This is a giant service upgrade, services will now be based on pure NVMe raid disk arrays, 10gbit port speeds, and on Intel Xeon E-2278G processors, the difference in performance will be night and day.
What this means in practical terms for you:
- Migration from i3d Rotterdam to Clouvider Amsterdam, this work will begin today from 16:00 (UK/London time) and is planned to be complete by 17:00 on Friday 12th February.
- Your service will be unavailable during migration but it should not take much longer than 3 minutes per 1GB of data you have is the best estimate although this can vary.
- Your IPv4 and IPv6 address will change however we have put some work into making sure you have plenty of time to get switched onto your new IP addresses. After your service is migrated your current IP’s will still work.
- Once your service has been migrated you will see you have a new IPv4 and IPv6 subnet in addition to your old IP addresses, you will have further access to manage these within the VPS control panel.
- It is vital that you start using the new IP addresses by midnight 25th February 2021 as they will be removed from your VPS on the 26th February 2021.
- A great upgrade to your service!
- For Customers using the NAT containers in The Netherlands, you will be emailed separately with instructions for the new NAT IPv4 gateway addresses and haproxy IP’s, this is still a work in progress, you will benefit from the same upgrades.
If you have any questions or concerns or would like to volunteer to be migrated early then please pop a ticket in to support and we will get back to you as soon as possible
This is IP change done right.
Having a bit of overlapping time when both old and new IPs are attached would minimize downtime for a website published from a migrated server.
Even a 2-hour overlapping time would be beneficial, if the user shortens DNS TTL prior to migration window.
Checklist for users:
No hostname available. affbrr
I have a NAT there for close to two years, if not more. Now I should consider finally installing a OS on it to let him idle.
That is how I feel right now tbh.
allllllriggghttttttyyyyyyyy
silly me, forgot to mention the free DA licenses that will be available in NL too.
The KVM line up https://clients.inceptionhosting.com/cart.php?gid=33 (cant be purchased just yet)
storage NL ?
That's dope! Thanks @AnthonySmith for continuing to offer us great services
1 step at a time
luv ya
I can imagine given the other mail that just went out
Congrats! Good to see you remain onboard
Inception Hosting acquired by Clouvider Limited
ugh... Clouvider ...
All that matters
Any promos planned for NL nvme in near future?
My reliable providers : Ramnode : HostHatch : Serverica : InceptionHosting : AlphaVps : LittleCreekHosting : NexusBytes : Hostodo
Not in the immediate term, my concern is getting the migrations done first
My reaction to other networks usually is "ugh, not Clouvider", but to each his own I guess.
No, I see more and more centralization to a few providers, which sucks.
That's business. Everyone knows low end hosting has razor thin margins, consolidation leads to synergy so the margin gets a bit larger.
I'd rather have a provider that's part of a trusted larger business (emphasis on trusted) than a one man show that might fail any moment.
not to bad for a NAT vps
When can we expect deals in Amsterdam?
Might be a little while as the migration was the priority but if you check out the pricing it was set at a very competitive rate to begin with.
Ah, I missed those. I mean the ones on the InceptionHosting page now? Virtuozzo 7, correct?
KVM: https://clients.inceptionhosting.com/cart.php?gid=33
my little vz7 went down like 30min ago , anybody else with same issue ?
Amsterdam .200 IP
My god man, start a new thread.
