Inception Hosting - The sales strike back - Part II (Triple BW + double disk) [NL+UK]
2
  • edited March 2021
    @InceptionHosting
    Well, I think you should add it into the Notes that Chinese are not allowed to buy any product
  • @brunuh said:
    @InceptionHosting
    Yes I should start adding that, but then I have to respond to 30 identical questions asking why with every post :), either way that situation is under review.
  • Does anyone have a benchmark from last week's UK offer?
    2GB in London:
    #                     v2020-12-29                    #
    fr. 19. mars 07:20:39 +0000 2021
    Processor  : Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz
    CPU cores  : 2 @ 3600.030 MHz
    RAM        : 1.9 GiB
    Swap       : 4.0 GiB
    Disk       : 49.1 GiB
    Read       | 49.88 MB/s   (12.4k) | 373.64 MB/s   (5.8k)
    Write      | 49.96 MB/s   (12.4k) | 375.60 MB/s   (5.8k)
    Total      | 99.84 MB/s   (24.9k) | 749.25 MB/s  (11.7k)
    Read       | 598.38 MB/s   (1.1k) | 667.18 MB/s    (651)
    Write      | 630.17 MB/s   (1.2k) | 711.61 MB/s    (694)
    Total      | 1.22 GB/s     (2.3k) | 1.37 GB/s     (1.3k)
    Clouvider       | London, UK (10G)          | 944 Mbits/sec   | 871 Mbits/sec
    Online.net      | Paris, FR (10G)           | 937 Mbits/sec   | 785 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 933 Mbits/sec   | 835 Mbits/sec
    Biznet          | Jakarta, Indonesia (1G)   | 764 Mbits/sec   | 184 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 895 Mbits/sec   | 228 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 871 Mbits/sec   | 139 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 834 Mbits/sec   | 177 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | busy
    Clouvider       | London, UK (10G)          | 880 Mbits/sec   | 798 Mbits/sec
    Online.net      | Paris, FR (10G)           | 838 Mbits/sec   | busy
    WorldStream     | The Netherlands (10G)     | 841 Mbits/sec   | 448 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 771 Mbits/sec   | 133 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 644 Mbits/sec   | 107 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 694
    Multi Core      | 1045
    Full Test       | https://browser.geekbench.com/v5/cpu/7019479
    Thanked by (1)andreipoe
  • I just opened up the last London node with available space on it this morning which is a sign that this sale may be coming to a close fairly soon based on the current daily order volume.
  • @InceptionHosting said: this sale may be coming to a close fairly soon
    Thanked by (3)angstrom ehab AaronSS
  • edited March 2021
    @daffy said:
    2GB in London:
    I've also been put on the lone E3-1270 v5 node, but my disk speeds are much lower than yours. I'm going to give it a few days to see if things settle, although there doesn't seem to be much CPU steal to begin with.
  • @InceptionHosting in the future, are there any plans to open new locations in USA or Germany with Clouvider network?
  • @andreipoe said:
    @daffy said:
    2GB in London:
    Due to a provisioning issue to many people got put on 1 particular node, I believe it was a v5 (there are 3 of them now actually) I am actively working to resolve it but if it is not at acceptable speeds in a few days please feel freer to open a ticket for help/migration, you might end up on another E3-1270v5 node but it will be must less densely populated (good old SolusVM)
    The real-world difference between a v5 and v6 is near nothing.
    Still in discussion, too soon to say.
    Thanked by (3)Pasweb andreipoe bsh
  • salakissalakis OG
    edited March 2021
    Got one in NL, haven't had any active service with @InceptionHosting for years, but this just confirms the reputation. The performance is absolutely stellar.
    However, latency to some ISPs could be a bit lower, routing isn't quite ideal. One example is T-Mobile NL (AS13127), I'm getting around 36ms to T-Mobile ADSL2 and I would expect around 22ms instead.
     1  185.193.158.1 (185.193.158.1)  10.487 ms  11.270 ms  11.272 ms
     2  194.127.172.7 (194.127.172.7)  2.794 ms  2.800 ms  2.827 ms
     3  194.127.172.4 (194.127.172.4)  0.315 ms  0.321 ms  0.308 ms
     4  et-0-0-41.cr4-ams2.ip4.gtt.net (154.14.30.81)  0.458 ms  0.454 ms  0.434 ms
     5  ae6.cr0-cph5.ip4.gtt.net (89.149.182.101)  17.704 ms  15.687 ms  17.694 ms
     6  ip4.gtt.net (87.119.98.86)  15.065 ms  14.971 ms  14.952 ms
     7  ams-core-2.bundle-ether1.tele2.net (130.244.205.179)  18.748 ms  18.717 ms  19.114 ms
     8  gbg-core-1.bundle-ether14.tele2.net (130.244.75.183)  18.172 ms  18.474 ms  18.435 ms
     9  ams-core-2.bundle-ether1.tele2.net (130.244.205.179)  18.356 ms  18.744 ms  18.711 ms
    10  130.244.21.86 (130.244.21.86)  21.617 ms  18.512 ms  18.557 ms
    11  212.53.19.130 (212.53.19.130)  18.683 ms  18.665 ms 212.53.19.134 (212.53.19.134)  21.764 ms
    12  ipx-14x-173-82.adsl2.static.versatel.nl (82.173.14x.x)  37.740 ms  38.687 ms  40.087 ms
    Similar results to the AS13127 IP used by OVH smokeping (62.58.50.4), 19ms compared to 3ms from Dronten. O2 DE (AS6805) could also be a tad lower (+5ms compared to Dronten).
    Other than that, thank you for the amazing offer!
  • debaserdebaser OG
    edited March 2021
    The problem here is that Tele2 NL is singlehomed behind Tele2 Sweden. That’s no tier 1 network. So they don’t have peering in place with tier 1 networks at all of their pops. In this case, traffic routes through Copenhagen and Goteborg apparently.
    Don’t know if they peer with Telia or one of Clouviders other transits in NL. This is probably not the optimal route.
    The good news is that the old Tele2 NL network is being discountinued. T-Mobile has transit from CW and Level(3).
  • FreekFreek Senpai
    FOMO kicked in
    Thanked by (3)angstrom ehab vimalware
  • Thank you all for the orders, the sales have now come to an end, I will do an assessment to see if there is any more available space on the spare nodes for next week or when I get time (there is a lot more time involved in this that people probably realize) :)
    To pre-empt the inevitable question: I am sorry, I cannot do just 1 more.
    Thanked by (3)flips vuong Mustafamw3
  • Great offer :+1: , I guess the sales is over now.
  • @InceptionHosting So I placed an order, took a while to verify my order, wanted to pay today but seems my account ain't logging me in again, tried resetting the password but no mail comes in :/
    This offer has expired, orders that don't complete for 24 hours have the accounts closed.
    Oh my bad, any way to get it back? :)
  • Oh, missed this thread entirely, would have taken that 45 EUR plan for the 4GB ram. Currently considering just setting up my own DA panel for my personal sites instead of using cPanel at Hostmantis. Never mind. I do have another VPS with IH but not enough ram.
  • @daffy said: 2GB in London:
    What node is that?
    my vps does not have VM-x/AMD-V enabled.
    What node is that?
    Here are the instructions of IH on the LET:
    Tip: Install any OS via template first if you use a host that also uses the solusvm control panel.
    This (if the host has set things up correctly) will automatically enable CPU passthrough and optimal driver sets), you can then install via ISO and keep all the optimal settings perminantly.
    It is a limitation of SolusVM (reported long ago and many times) that it is not possible to set CPU passthrough as standard for ISO installations.
    I agree it is ridiculous but it is what it is, for the sake of clicking reinstall > centos 7 > confirm, then power off and install from ISO you can save yourself any time requesting it in the future for new servers.
    Once it is set, it is permanently set though.> >
    Thanked by (1)jam
  • @dinhvanlocitvn said: Here are the instructions of IH on the LET:
    Not work for me, tried 2 times.
    Thanks! anyways
  • I have a 1GB KVM in AMS for $1.50/month with another provider but apparently I'm too stupid to operate a virtual server on their platform.
    If you re-release the €15 next month, I'll switch to Inception in London.
    Thanked by (1)Decicus
    What node is that?
    I'm on KVM6 (or something like that).
    Didn't do anything special other than install the Debian template ??‍♂️
    Assuming it's the same VPS and the provider, I will be very much interested in it. Hopefully, there is an option of VPS transfer.
  • @daffy said:
    What node is that?
    Some nodes just don’t have it enabled and enabling it means shutting down all user VPS first so it’s quite disruptive.
    It gets enabled now during maintenance windows one nodes that don’t have it.
    Thanked by (1)xowxenxirix
  • jamjam
    edited March 2021
    @daffy said: I'm on KVM6 (or something like that).
    Yes, same for me but in Amsterdan location on KVM13ams node.
    @InceptionHosting said: Some nodes just don’t have it enabled and enabling it means shutting down all user VPS first so it’s quite disruptive.
    Is KVM5 node in London location, one of theses nodes that does not have the feature enabled?
    if you see the cpu model and it’s not enabled then yes, if you see qemu cpu as the model then you should open a ticket
  • Hi @InceptionHosting ,
    Long time no exclusive deals, could you please bring these offers back :D
  • edited May 2022
    i miss Ant
    after the merge he has been dating like crazy -- i guess all the time fixing vps's was doing he's catching up trying out all sorts of women or is it men now?
