If you're from AU or NZ, you can use -au or -nz curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -au curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -nz
India is under development curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -in
HostHatch 1 Gb/s 1TB/m for $27/y
OS : Debian GNU/Linux 10 (64 Bit)
Virt/Kernel : KVM / 4.19.0-13-amd64
CPU Model : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
CPU Cores : 2 @ 3000.000 MHz x86_64 16384 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Disabled
Load Average : 0.00, 0.00, 0.00
Total Space : 39G (2.7G ~8% used)
Total RAM : 7978 MB (313 MB + 1803 MB Buff in use)
Total SWAP : 1023 MB (0 MB in use)
Uptime : 1 days 1:2
ASN & ISP : AS63473, HostHatch
Organization : HostHatch, LLC
Region : New South Wales
## Geekbench v4 CPU Benchmark:
Single Core : 2932 (GOOD)
Multi Core : 5540
## IO Test
CPU Speed:
bzip2 : 107 MB/s
sha256 : 188 MB/s
md5sum : 486 MB/s
RAM Speed:
Avg. write : 2491.7 MB/s
Avg. read : 6280.5 MB/s
Disk Speed:
1st run : 994 MB/s
2nd run : 983 MB/s
3rd run : 904 MB/s
Average : 960.3 MB/s
## Australia & New Zealand Speedtest.net
Location Upload Download Ping
Nearby 928.25 Mbit/s 931.40 Mbit/s 2.774 ms
Australia, Sydney (Optus) 924.65 Mbit/s 925.61 Mbit/s 1.398 ms
Australia, Melbourne (Telstra) 728.49 Mbit/s 771.84 Mbit/s 11.810 ms
Australia, Brisbane (Telstra) 684.49 Mbit/s 736.52 Mbit/s 15.475 ms
Australia, Adelaide (AARNet) 570.53 Mbit/s 403.54 Mbit/s 18.767 ms
Australia, Hobart (Optus) 714.02 Mbit/s 791.39 Mbit/s 12.773 ms
Australia, Darwin (AARNet) 191.05 Mbit/s 241.82 Mbit/s 58.152 ms
Australia, Perth (Telstra) 272.60 Mbit/s 316.28 Mbit/s 50.890 ms
NZ, Auckland (MyRepublic) 271.19 Mbit/s 350.51 Mbit/s 50.901 ms
NZ, Wellington (Spark) 407.58 Mbit/s 433.75 Mbit/s 34.470 ms
NZ, Christchurch (Vodafone) 329.00 Mbit/s 543.16 Mbit/s 39.123 ms
Finished in : 6 min 36 sec
Timestamp : 2020-12-10 21:36:19 GMT
Saved in : /root/speedtest.log
Share results:
- https://www.speedtest.net/result/10568020115.png
- https://browser.geekbench.com/v4/cpu/15931962
- https://clbin.com/iB828
OVH 100 Mb/s (an old VPS promo plan for $2.5/m)
Region: AU-NZ https://bench.monster v.1.5.5 2020-12-10
Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -AU-NZ
OS : CentOS 7.9.2009 (64 Bit)
Virt/Kernel : KVM / 3.10.0-1160.6.1.el7.x86_64
CPU Model : Intel Core Processor (Haswell, no TSX)
CPU Cores : 1 @ 3504.000 MHz x86_64 16384 KB Cache
CPU Flags : AES-NI Enabled & VM-x/AMD-V Enabled
Load Average : 0.26, 0.12, 0.08
Total Space : 30G (5.4G ~20% used)
Total RAM : 966 MB (349 MB + 451 MB Buff in use)
Total SWAP : 1023 MB (391 MB in use)
Uptime : 20 days 2:27
ASN & ISP : AS16276, OVH SAS
Organization : OVH Australia PTY LTD
Single Core : 4378 (EXCELLENT)
Multi Core : 4137
## IO Test
CPU Speed:
bzip2 : 126 MB/s
sha256 : 394 MB/s
md5sum : 564 MB/s
RAM Speed:
Avg. write : 3925.3 MB/s
Avg. read : 7714.1 MB/s
Disk Speed:
1st run : 368 MB/s
2nd run : 365 MB/s
3rd run : 356 MB/s
Average : 363.0 MB/s
Nearby 98.45 Mbit/s 97.59 Mbit/s 2.965 ms
Australia, Sydney (Optus) 99.59 Mbit/s 97.36 Mbit/s 1.223 ms
Australia, Melbourne (Telstra) 98.26 Mbit/s 97.27 Mbit/s 11.807 ms
Australia, Brisbane (Telstra) 99.30 Mbit/s 96.86 Mbit/s 14.998 ms
Australia, Adelaide (AARNet) 98.96 Mbit/s 96.82 Mbit/s 18.514 ms
Australia, Hobart (Optus) 98.80 Mbit/s 97.08 Mbit/s 12.297 ms
Australia, Darwin (AARNet) 87.48 Mbit/s 90.69 Mbit/s 59.915 ms
Australia, Perth (Telstra) 92.00 Mbit/s 86.99 Mbit/s 50.855 ms
NZ, Auckland (MyRepublic) 90.34 Mbit/s 90.99 Mbit/s 50.727 ms
NZ, Wellington (Spark) 96.41 Mbit/s 95.65 Mbit/s 34.934 ms
NZ, Christchurch (Vodafone) 93.00 Mbit/s 95.25 Mbit/s 39.298 ms
Finished in : 8 min 18 sec
Timestamp : 2020-12-10 22:18:30 GMT
Share results:
- https://www.speedtest.net/result/10568175619.png
- https://browser.geekbench.com/v4/cpu/15932019
- https://clbin.com/M8hSX
Singapore 1 Gb/s (inferno.name $2.5/m)
OS : CentOS 8.3.2011 (64 Bit)
Virt/Kernel : KVM / 4.18.0-193.28.1.el8_2.x86_64
CPU Model : Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz
CPU Cores : 1 @ 2199.906 MHz x86_64 16384 KB Cache
Load Average : 0.13, 0.32, 0.17
Total Space : 20G (6.2G ~33% used)
Total RAM : 979 MB (182 MB + 186 MB Buff in use)
Total SWAP : 2048 MB (162 MB in use)
Uptime : 10 days 11:25
ASN & ISP : AS9009, ISPIRIA Networks Ltd
Organization : ISPIRIA Networks Ltd
Region :
Single Core : 3688 (VERY GOOD)
Multi Core : 3275
## IO Test
CPU Speed:
bzip2 : 99.7 MB/s
sha256 : 296 MB/s
md5sum : 454 MB/s
RAM Speed:
Avg. write : 1774.9 MB/s
Avg. read : 4232.5 MB/s
Disk Speed:
1st run : 1.1 GB/s
2nd run : 1.1 GB/s
3rd run : 1.2 GB/s
Average : 1160.5 MB/s
Nearby 872.03 Mbit/s 918.48 Mbit/s 2.161 ms
Australia, Sydney (Optus) 148.54 Mbit/s 430.12 Mbit/s 119.909 ms
Australia, Melbourne (Telstra) 19.81 Mbit/s 85.74 Mbit/s 276.653 ms
Australia, Brisbane (Telstra) 19.73 Mbit/s 80.34 Mbit/s 276.130 ms
Australia, Adelaide (AARNet) 179.92 Mbit/s 510.35 Mbit/s 91.128 ms
Australia, Hobart (Optus) 129.63 Mbit/s 394.05 Mbit/s 132.014 ms
Australia, Darwin (AARNet) 137.34 Mbit/s 344.05 Mbit/s 153.140 ms
Australia, Perth (Telstra) 17.36 Mbit/s 52.69 Mbit/s 315.717 ms
NZ, Auckland (MyRepublic) 16.91 Mbit/s 53.00 Mbit/s 315.878 ms
NZ, Wellington (Spark) 67.17 Mbit/s 159.06 Mbit/s 215.844 ms
NZ, Christchurch (Vodafone) 58.55 Mbit/s 147.74 Mbit/s 227.401 ms
Finished in : 7 min 56 sec
Timestamp : 2020-12-10 22:24:35 GMT
Share results:
- https://www.speedtest.net/result/10568197720.png
- https://browser.geekbench.com/v4/cpu/15932028
- https://clbin.com/34tG2
Racknerd 11.11 Special with additional 1 core upgrade.
Region: USA https://bench.monster v.1.5.5 2020-12-10
Usage : curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -USA
CPU Model : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
CPU Cores : 4 @ 2799.998 MHz x86_64 16384 KB Cache
Load Average : 0.04, 0.04, 0.05
Total Space : 55G (23G ~44% used)
Total RAM : 2845 MB (561 MB + 1492 MB Buff in use)
Total SWAP : 2047 MB (0 MB in use)
Uptime : 0 days 23:59
ASN & ISP : AS36352, ColoCrossing
Organization : NYC Metro
Region : District of Columbia
Single Core : 2215 (FAIR)
Multi Core : 5731
## IO Test
CPU Speed:
bzip2 : 59.4 MB/s
sha256 : 133 MB/s
md5sum : 349 MB/s
RAM Speed:
Avg. write : 1051.3 MB/s
Avg. read : 2867.2 MB/s
Disk Speed:
1st run : 665 MB/s
2nd run : 505 MB/s
3rd run : 544 MB/s
Average : 571.3 MB/s
## USA Speedtest.net
Nearby 279.60 Mbit/s 364.93 Mbit/s 43.052 ms
USA, New York (Optimum) 417.28 Mbit/s 755.45 Mbit/s 7.512 ms
USA, Boston (Starry, Inc.) 469.17 Mbit/s 647.34 Mbit/s 12.500 ms
USA, Washington, DC (Sprint) 603.12 Mbit/s 791.53 Mbit/s 1.890 ms
USA, Charlotte, NC (Windstream) 404.33 Mbit/s 540.53 Mbit/s 14.991 ms
USA, Atlanta (Frontier) 204.95 Mbit/s 648.75 Mbit/s 31.872 ms
USA, Miami (Frontier) 149.33 Mbit/s 635.74 Mbit/s 50.819 ms
USA, Nashville (Sprint) 360.73 Mbit/s 584.19 Mbit/s 16.774 ms
USA, Indianapolis (Metronet) 113.48 Mbit/s 470.39 Mbit/s 31.883 ms
USA, Cleveland (CenturyLink) 374.71 Mbit/s 619.87 Mbit/s 20.612 ms
USA, Chicago (Windstream) 263.94 Mbit/s 598.29 Mbit/s 23.170 ms
USA, St. Louis (Elite Fiber) 359.28 Mbit/s 381.70 Mbit/s 29.117 ms
USA, Minneapolis (US Internet) 376.42 Mbit/s 727.76 Mbit/s 24.279 ms
USA, Kansas City (UPNfiber) 276.76 Mbit/s 525.16 Mbit/s 39.291 ms
USA, Oklahoma City (OneNet) 150.39 Mbit/s 365.01 Mbit/s 34.610 ms
USA, Dallas (Windstream) 230.07 Mbit/s 434.64 Mbit/s 29.248 ms
USA, San Antonio, TX (Sprint) 212.89 Mbit/s 470.58 Mbit/s 33.502 ms
USA, Denver (Vistabeam) 109.38 Mbit/s 146.14 Mbit/s 59.639 ms
USA, Albuquerque (Plateau Tel) 149.31 Mbit/s 490.05 Mbit/s 58.392 ms
USA, Phoenix (Cox) 224.65 Mbit/s 287.64 Mbit/s 71.475 ms
USA, Salt Lake City (UTOPIA) 217.79 Mbit/s 225.53 Mbit/s 69.603 ms
USA, Helena, MT (The Fusion) 212.85 Mbit/s 420.58 Mbit/s 48.273 ms
USA, Las Vegas (LV.Net) 179.04 Mbit/s 239.32 Mbit/s 66.194 ms
USA, Seattle (Bluespan) 146.12 Mbit/s 440.43 Mbit/s 75.077 ms
USA, San Francisco (Wiline) 196.15 Mbit/s 252.33 Mbit/s 67.784 ms
USA, Los Angeles (Windstream) 154.73 Mbit/s 314.94 Mbit/s 66.622 ms
USA, Anchorage (Alaska Com) 148.91 Mbit/s 371.42 Mbit/s 115.077 ms
USA, Honolulu (Hawaiian Telcom) 150.08 Mbit/s 121.29 Mbit/s 130.923 ms
Finished in : 12 min 34 sec
Timestamp : 2021-03-25 02:24:21 GMT
Share results:
- https://www.speedtest.net/result/11151722443.png
- https://browser.geekbench.com/v4/cpu/16098770
- https://clbin.com/sKGzK
CPU Model : AMD Ryzen 5 3600 6-Core Processor
CPU Cores : 2 @ 3593.236 MHz x86_64 512 KB Cache
Load Average : 0.00, 0.05, 0.03
Total Space : 15G (13G ~90% used)
Total RAM : 1995 MB (1090 MB + 714 MB Buff in use)
Total SWAP : 2047 MB (259 MB in use)
Uptime : 35 days 3:46
ASN & ISP : AS24940, Hetzner Online GmbH
Organization :
Region : Saxony
Single Core : 4297 (EXCELLENT)
Multi Core : 7450
## IO Test
CPU Speed:
bzip2 : 113 MB/s
sha256 : 173 MB/s
md5sum : 578 MB/s
RAM Speed:
Avg. write : 2150.4 MB/s
Avg. read : 5300.1 MB/s
Disk Speed:
1st run : 235 MB/s
2nd run : 789 MB/s
3rd run : 1.3 GB/s
Average : 785.1 MB/s
Nearby 230.54 Mbit/s 283.69 Mbit/s 30.065 ms
USA, New York (Optimum) 122.68 Mbit/s 268.31 Mbit/s 84.820 ms
USA, Boston (Starry, Inc.) 58.78 Mbit/s 315.07 Mbit/s 87.205 ms
USA, Washington, DC (Sprint) 161.73 Mbit/s 262.60 Mbit/s 97.454 ms
USA, Charlotte, NC (Windstream) 156.34 Mbit/s 88.89 Mbit/s 107.683 ms
USA, Atlanta (Frontier) 157.52 Mbit/s 138.71 Mbit/s 118.348 ms
USA, Miami (Frontier) 145.10 Mbit/s 105.84 Mbit/s 135.292 ms
USA, Nashville (Sprint) 159.66 Mbit/s 153.97 Mbit/s 104.614 ms
USA, Indianapolis (Metronet) 155.77 Mbit/s 193.19 Mbit/s 107.108 ms
USA, Cleveland (CenturyLink) 110.14 Mbit/s 73.12 Mbit/s 112.057 ms
USA, Chicago (Windstream) 131.91 Mbit/s 88.25 Mbit/s 102.218 ms
USA, St. Louis (Elite Fiber) 160.76 Mbit/s 179.15 Mbit/s 120.207 ms
USA, Minneapolis (US Internet) 138.79 Mbit/s 88.70 Mbit/s 113.492 ms
USA, Kansas City (UPNfiber) 150.96 Mbit/s 191.37 Mbit/s 118.172 ms
USA, Oklahoma City (OneNet) 147.36 Mbit/s 150.18 Mbit/s 125.113 ms
USA, Dallas (Windstream) 150.58 Mbit/s 151.51 Mbit/s 124.258 ms
USA, San Antonio, TX (Sprint) 145.73 Mbit/s 178.03 Mbit/s 119.815 ms
USA, Denver (Vistabeam) 117.68 Mbit/s 225.02 Mbit/s 134.287 ms
USA, Albuquerque (Plateau Tel) 67.15 Mbit/s 93.83 Mbit/s 148.393 ms
USA, Phoenix (Cox) 70.30 Mbit/s 147.79 Mbit/s 152.221 ms
USA, Salt Lake City (UTOPIA) 141.05 Mbit/s 116.83 Mbit/s 137.310 ms
USA, Helena, MT (The Fusion) 117.68 Mbit/s 227.75 Mbit/s 144.078 ms
USA, Las Vegas (LV.Net) 132.95 Mbit/s 63.18 Mbit/s 152.947 ms
USA, Seattle (Bluespan) 97.89 Mbit/s 245.85 Mbit/s 176.596 ms
USA, San Francisco (Wiline) 86.95 Mbit/s 36.29 Mbit/s 155.805 ms
USA, Los Angeles (Windstream) 137.79 Mbit/s 132.24 Mbit/s 145.827 ms
USA, Anchorage (Alaska Com) 110.01 Mbit/s 159.40 Mbit/s 174.505 ms
USA, Honolulu (Hawaiian Telcom) 65.79 Mbit/s 79.98 Mbit/s 225.087 ms
Finished in : 14 min 37 sec
Timestamp : 2021-03-25 03:03:41 GMT
Share results:
- https://www.speedtest.net/result/11151833149.png
- https://browser.geekbench.com/v4/cpu/16098817
- https://clbin.com/Wr8b8
root@ger:~#
OS : Ubuntu 20.04.2 LTS (64 Bit)
Virt/Kernel : KVM / 5.4.0-70-generic
CPU Model : AMD Ryzen 9 3900X 12-Core Processor
CPU Cores : 1 @ 3792.874 MHz x86_64 512 KB Cache
Load Average : 0.10, 0.04, 0.01
Total Space : 19G (3.1G ~18% used)
Total RAM : 1483 MB (240 MB + 1049 MB Buff in use)
Total SWAP : 1535 MB (0 MB in use)
Uptime : 1 days 3:15
Organization : RackNerd LLC
Region : New York
Single Core : 4860 (EXCELLENT)
Multi Core : 4699
## IO Test
CPU Speed:
bzip2 : 127 MB/s
sha256 : 240 MB/s
md5sum : 555 MB/s
RAM Speed:
Avg. write : 2184.5 MB/s
Avg. read : 7782.4 MB/s
Disk Speed:
1st run : 1.2 GB/s
2nd run : 1.2 GB/s
3rd run : 1.2 GB/s
Average : 1228.8 MB/s
Nearby 342.58 Mbit/s 125.29 Mbit/s * 82.838 ms
USA, New York (Optimum) 597.37 Mbit/s 381.84 Mbit/s 11.352 ms
USA, Boston (Starry, Inc.) 335.63 Mbit/s 428.04 Mbit/s 15.995 ms
USA, Washington, DC (Sprint) 455.90 Mbit/s 602.22 Mbit/s 17.548 ms
USA, Charlotte, NC (Windstream) 434.81 Mbit/s 320.28 Mbit/s 27.219 ms
USA, Atlanta (Frontier) 332.23 Mbit/s 281.06 Mbit/s 36.765 ms
USA, Miami (Frontier) 188.95 Mbit/s 351.63 Mbit/s 41.692 ms
USA, Nashville (Sprint) 247.70 Mbit/s 436.73 Mbit/s 29.891 ms
USA, Indianapolis (Metronet) 490.59 Mbit/s 574.79 Mbit/s 17.647 ms
USA, Cleveland (CenturyLink) 432.98 Mbit/s 320.84 Mbit/s 22.064 ms
USA, Chicago (Windstream) 571.09 Mbit/s 617.87 Mbit/s 10.625 ms
USA, St. Louis (Elite Fiber) 475.77 Mbit/s 604.67 Mbit/s 19.793 ms
USA, Minneapolis (US Internet) 468.76 Mbit/s 368.04 Mbit/s 22.184 ms
USA, Kansas City (UPNfiber) 204.79 Mbit/s 140.89 Mbit/s 24.626 ms
USA, Oklahoma City (OneNet) 237.13 Mbit/s 320.32 Mbit/s 36.224 ms
USA, Dallas (Windstream) 304.45 Mbit/s 329.96 Mbit/s 36.103 ms
USA, San Antonio, TX (Sprint) 180.90 Mbit/s 404.20 Mbit/s 40.841 ms
USA, Denver (Vistabeam) 325.56 Mbit/s 272.08 Mbit/s 35.555 ms
USA, Albuquerque (Plateau Tel) 242.76 Mbit/s 226.12 Mbit/s 43.417 ms
USA, Phoenix (Cox) 171.06 Mbit/s 231.80 Mbit/s 80.111 ms
USA, Salt Lake City (UTOPIA) 144.25 Mbit/s 99.05 Mbit/s 50.526 ms
USA, Helena, MT (The Fusion) 220.76 Mbit/s 330.58 Mbit/s 42.031 ms
USA, Las Vegas (LV.Net) 168.44 Mbit/s 212.91 Mbit/s 75.821 ms
USA, Seattle (Bluespan) 153.05 Mbit/s 500.05 Mbit/s 65.382 ms
USA, San Francisco (Wiline) 184.88 Mbit/s 223.73 Mbit/s 70.749 ms
USA, Los Angeles (Windstream) 207.45 Mbit/s 313.78 Mbit/s 55.833 ms
USA, Anchorage (Alaska Com) 144.92 Mbit/s 102.36 Mbit/s 88.701 ms
USA, Honolulu (Hawaiian Telcom) 95.75 Mbit/s 98.65 Mbit/s 140.709 ms
Finished in : 11 min 28 sec
Timestamp : 2021-04-03 10:06:50 GMT
Share results:
- https://www.speedtest.net/result/11203306855.png
- https://browser.geekbench.com/v4/cpu/16111686
- https://clbin.com/baSab
Virmach BF special
refer to YABS thread for VPS description
Virmach BF special
anynode
product description in YAB thread
hosterlabs
racknerd
San Jose (premium Colon)
ServersGalore $16 AUD p/m Melbourne:
Hetzner AX101
https://pastebin.com/GRhvmWtD
Just moved to Singapore location
MaxKVM SKVM-4G
an old test from @cybertech https://talk.lowendspirit.com/discussion/comment/37100/#Comment_37100
hostsolutions @cociu
Hosthatch 8NVMe post re-installation of Debian 10
https://clbin.com/ZHWe3
Novos's EPYC
Novos - Ryzen 9 3900XT
https://dttech.net - Personal Site.
revisit to AlphaVPS after BF.
lookatdat ram speeeeeed.
My idling Letbox's 3TB Ryzen on BF
Dubai $5/m
drServer - Intel® Atom™ C2750 (4-Core, 2.4GHz) 8GB DDR3 1x 200GB SSD 13usd/m
Virt/Kernel : Dedicated / 5.4.0-65-generic
CPU Model : Intel(R) Atom(TM) CPU C2750 @ 2.41GHz
CPU Cores : 4 @ 2528.036 MHz x86_64 1024 KB Cache
Load Average : 0.25, 0.20, 0.21
Total Space : 182G (2.2G ~2% used)
Total RAM : 7918 MB (119 MB + 479 MB Buff in use)
Total SWAP : 976 MB (0 MB in use)
Uptime : 0 days 2:43
ASN & ISP : AS396881, drServer International
Organization : FranTech Solutions
Region : Delaware
Is the difference b/w Bench Monster and YABS basically Geekbench V4 vs V5 and iperf vs speedtest.net?
something like that. YABS can choose GB v4/v5 or both in the same test.
monster can choose either v4/v5 as well.
monster has RAM speed test.
Wiredblade. description in YABS thread.
https://talk.lowendspirit.com/discussion/comment/58378/#Comment_58378
naranjatech
KVM-NVME-2GB
2 GB RAM
1 CPU Core
30 GB NVMe
5 TB Traffic
1 Gbps port speed
1 IPv4
/64 IPv6
mindblown
https://microlxc.net/
Hosterlabs Germany AMD 5
Any Austrians here? Look at that (barely existing) latency towards Magenta/DTAG network!
Now, if only Magenta would finally improve the latency of their own last mile…
Contabo VPS L SSD
Hostsolutions 1TB Storage VPS
WEbhosting24- SIngapore 2 GB. Ran it witi -in flag for India specific network speeds.
For Asia:
Squats are the new Push-ups
Racknerd 1.5 GB Ryzen KVM VPS (USA Speedtest)
Webhosting24 - Munich
Click to view
(gif screencapture)
Edit: click to view. See comment below
mate I can't see the results I wonder if my internet is slow
The file is 81.6 MB in size. An 81.6 MB GIF.
