@HostSlick said:
Please check your account and Email Inbox
Thank you for your kindness, I have misunderstood you with some prejudice based on some former bad information.
I would make an apology for my sudden impulse and immaturity causing this drama
Have a nice weekend
Have a nice weekend
If you contact us via Support, we will in most cases find a solution
Wish you same, also have fun with the VPS and any of your upcoming projects.
@InceptionHosting said:
And that is the problem with basing everything on a single point in time fully synthetic benchmark.
So, are you questioning about the reference value of YABS?
Why majority of the E5 vps I have bought can have a average score around 500 (and they run normal)
This vps scores 250 and it acutually running quiet slower than those scores 500 vps.
I am saying facts, the relevance between test score and the running speed is just there, anyone can check it if they don't believe there is a real relevance
What are you saying about, man?
I am saying 1 benchmark in total on a shared resource environment is not indicative of average performance.
I am also saying that posting about that 1 benchmark on a forum expressing disappointment before so much as running a second benchmark or opening a ticket is odd.
Nothing more than that.
Personally I would have ran a few over a few hours then contacted the host to see if that is expected performance and if that response was poor then I MIGHT publicly express my disappointment (but probably not if it cost less than a cheap frying pan)
Have a nice weekend
Performance of VPS fluctuate. Doesn't matter how isolated each accounts are. In the end it is shared.
Therefore, benchmark of a VPS is ultimately meaningless. Whatever number you get, it's not the result that will hold up.
That's why I only create drama thread when the server is totally and undeniably offline.
We scientists know that every experiment must be repeated 5 times!
No hostname available. affbrr
maybe ./thread closed , Sir?
Love the new thread title
It doesn't work, that way.
