pfsense wireguard outbound connection
Hello, does anyone know if it is possible to have wireguard client in pfsense always use one specific gateway for its connection to a wireguard server. I have a dual wan pfsense setup and I know that in openvpn there is the interface option but not sure what the equivalent in wireguard is.
You want the wg connection to go through one specific WAN interface? One way is to add a static route for the remote wg peer via the desired WAN gateway.
yes this is what I need and thanks for the suggest, I will try it later
You can install Wireguard as an experimental WireGuard package from the Package Manager. Navigate to System > Packages, Available Packages. You can setup the way you want to there.
me@ivlad.net | www.ivlad.net
