Post some YABS bench here
14243454748145
  • @zxrlha said:
    Racknerd. Today I observed high steal, so I decided to run YABS:
    #                     v2021-12-03                    #
    Tue 14 Dec 2021 09:05:11 PM UTC
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 1 @ 3792.874 MHz
    RAM        : 978.8 MiB
    Swap       : 978.8 MiB
    Disk       : 14.7 GiB
    Read       | 140.40 MB/s  (35.1k) | 972.85 MB/s  (15.2k)
    Write      | 140.77 MB/s  (35.1k) | 977.97 MB/s  (15.2k)
    Total      | 281.17 MB/s  (70.2k) | 1.95 GB/s    (30.4k)
    Read       | 1.28 GB/s     (2.5k) | 1.62 GB/s     (1.5k)
    Write      | 1.34 GB/s     (2.6k) | 1.73 GB/s     (1.6k)
    Total      | 2.62 GB/s     (5.1k) | 3.36 GB/s     (3.2k)
    Clouvider       | London, UK (10G)          | 131 Mbits/sec   | 251 Mbits/sec
    Online.net      | Paris, FR (10G)           | 422 Mbits/sec   | 217 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 415 Mbits/sec   | 265 Mbits/sec
    WebHorizon      | Singapore (1G)            | busy            | busy
    Clouvider       | NYC, NY, US (10G)         | 748 Mbits/sec   | 525 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 489 Mbits/sec   | 361 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 563 Mbits/sec   | 321 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 111 Mbits/sec   | 189 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 709
    Multi Core      | 728
    Full Test       | https://browser.geekbench.com/v5/cpu/11610699
    if you contact support they will move you
    but since they have no stock it is likely that all nodes are pretty full
    Thanked by (1)zxrlha
  • vyasvyas OGSenpai
    edited December 2021
    Raspberry Pi4 - 4 GB with M.2 SATA Boot
    Manjaro 21. Delighted to see ARM support (experimental as the note says!)
    Wednesday 15 December 2021 10:00:10 PM IST
    Processor  : Cortex-A72
    CPU cores  : 4 @ 1500.0000 MHz
    AES-NI     : ❌ Disabled
    VM-x/AMD-V : ❌ Disabled
    RAM        : 3.7 GiB
    Swap       : 5.5 GiB
    Disk       : 234.7 GiB
    Read       | 51.50 MB/s   (12.8k) | 145.19 MB/s   (2.2k)
    Write      | 51.47 MB/s   (12.8k) | 149.51 MB/s   (2.3k)
    Total      | 102.98 MB/s  (25.7k) | 294.70 MB/s   (4.6k)
    Read       | 162.08 MB/s    (316) | 155.07 MB/s    (151)
    Write      | 175.94 MB/s    (343) | 173.01 MB/s    (168)
    Total      | 338.03 MB/s    (659) | 328.08 MB/s    (319)
    ARM architecture not supported by Geekbench 4, use Geekbench 5.
    Geekbench 4 test failed. Run manually to determine cause.
    Single Core     | 216
    Multi Core      | 550
    Full Test       | https://browser.geekbench.com/v5/cpu/11626169
     .@cybertech is that too much swap? (default chosen by the OS)
  • @11111jfkdd said:
    #                     v2021-12-03                    #
    RAM        : 978.8 MiB
    Swap       : 978.8 MiB
    Disk       : 14.7 GiB
    Single Core     | 709
    Multi Core      | 728
    Probably they are pretty full.
    I'd like to wait a few day to see whether it becomes better.
    i think it's fine given that its dedicated I/O, perhaps set swappiness to 1?
    Thanked by (1)vyas
  • @zxrlha said:
    @11111jfkdd said:
    #                     v2021-12-03                    #
    RAM        : 978.8 MiB
    Swap       : 978.8 MiB
    Disk       : 14.7 GiB
    Single Core     | 709
    Multi Core      | 728
    I doubt it will improve much with time
    If you ask support they are usually quick and fairly helpful, much better than average for a LE host, maybe they can still help
    Hostcram
    Confidential: Ryzen Two (LXC)
    2 vCPU Core (Ryzen 9 5950X)
    2 GB DDR4 RAM (Samsung)
    20 GB NVMe SSD Storage (Samsung)
    2 TB Bandwidth @ 1 Gbps Port
    1 Dedicated IPv4 (IPv6 on request)
    This plan comes with Limited Support and our brand new Cloud Portal access with self OS Rebuild, Start, Stop, Restart, TUN/TAP, Console, etc. management options.
    1 Year @ $25.00 USD
    2 Year @ $40.00 USD
    root@cyber:~# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-03                    #
    Thu Dec 16 08:57:46 UTC 2021
    CPU cores  : 2 @ 3400.000 MHz
    RAM        : 2.0 GiB
    Swap       : 2.5 GiB
    Disk       : 19.5 GiB
    Read       | 510.20 MB/s (127.5k) | 1.03 GB/s    (16.1k)
    Write      | 511.55 MB/s (127.8k) | 1.03 GB/s    (16.2k)
    Total      | 1.02 GB/s   (255.4k) | 2.06 GB/s    (32.3k)
    Read       | 1.24 GB/s     (2.4k) | 1.34 GB/s     (1.3k)
    Write      | 1.31 GB/s     (2.5k) | 1.42 GB/s     (1.3k)
    Total      | 2.55 GB/s     (4.9k) | 2.77 GB/s     (2.7k)
    Clouvider       | London, UK (10G)          | 874 Mbits/sec   | 461 Mbits/sec
    Online.net      | Paris, FR (10G)           | 874 Mbits/sec   | 376 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 859 Mbits/sec   | 863 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 930 Mbits/sec   | 922 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 922 Mbits/sec   | 929 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 933 Mbits/sec   | 928 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 829 Mbits/sec   | 473 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 6579
    Multi Core      | 11756
    Full Test       | https://browser.geekbench.com/v4/cpu/16440449
    Single Core     | 1497
    Multi Core      | 2801
    Full Test       | https://browser.geekbench.com/v5/cpu/11637031
  • Just grabbed another Hetzner box!
    #                     v2021-12-03                    #
    Thu 16 Dec 2021 11:40:13 AM CST
    Processor  : Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
    CPU cores  : 8 @ 3913.288 MHz
    RAM        : 62.6 GiB
    Swap       : 0.0 KiB
    Disk       : 14.4 TiB
    Read       | 1.59 MB/s      (399) | 24.83 MB/s     (388)
    Write      | 1.62 MB/s      (407) | 25.29 MB/s     (395)
    Total      | 3.22 MB/s      (806) | 50.13 MB/s     (783)
    Read       | 123.02 MB/s    (240) | 119.56 MB/s    (116)
    Write      | 129.56 MB/s    (253) | 127.53 MB/s    (124)
    Total      | 252.59 MB/s    (493) | 247.10 MB/s    (240)
    Clouvider       | London, UK (10G)          | 832 Mbits/sec   | 924 Mbits/sec
    Online.net      | Paris, FR (10G)           | 830 Mbits/sec   | 935 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 875 Mbits/sec   | 926 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 791 Mbits/sec   | 374 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 739 Mbits/sec   | 482 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 729 Mbits/sec   | 305 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 219 Mbits/sec   | 275 Mbits/sec
    Single Core     | 1213
    Multi Core      | 4695
    Full Test       | https://browser.geekbench.com/v5/cpu/11644912
  • SYS-2-SAT-32 FRANCE :
    Processor  : Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz
    CPU cores  : 16 @ 800.881 MHz
    RAM        : 31.3 GiB
    Swap       : 9.5 GiB
    Disk       : 14.4 TiB
    Read       | 6.29 MB/s     (1.5k) | 69.64 MB/s    (1.0k)
    Write      | 6.29 MB/s     (1.5k) | 70.00 MB/s    (1.0k)
    Total      | 12.59 MB/s    (3.1k) | 139.65 MB/s   (2.1k)
    Read       | 264.27 MB/s    (516) | 253.66 MB/s    (247)
    Write      | 278.32 MB/s    (543) | 270.55 MB/s    (264)
    Total      | 542.60 MB/s   (1.0k) | 524.22 MB/s    (511)
    Clouvider       | London, UK (10G)          | 243 Mbits/sec   | 7.47 Gbits/sec
    Online.net      | Paris, FR (10G)           | 243 Mbits/sec   | 8.33 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 243 Mbits/sec   | 9.36 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 231 Mbits/sec   | 2.28 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 223 Mbits/sec   | 1.64 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 221 Mbits/sec   | 1.24 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 200 Mbits/sec   | 759 Mbits/sec
    Single Core     | 766
    Multi Core      | 5369
    Full Test       | https://browser.geekbench.com/v5/cpu/11642937
  • stardust NL:
    #                     v2021-12-03                    #
    Mon Dec 20 10:33:09 UTC 2021
    Processor  : AMD EPYC 7281 16-Core Processor
    CPU cores  : 1 @ 2096.040 MHz
    RAM        : 975.6 MiB
    Swap       : 0.0 KiB
    Disk       : 9.1 GiB
    Read       | 138.81 MB/s  (34.7k) | 982.45 MB/s  (15.3k)
    Write      | 139.17 MB/s  (34.7k) | 987.62 MB/s  (15.4k)
    Total      | 277.98 MB/s  (69.4k) | 1.97 GB/s    (30.7k)
    Read       | 1.26 GB/s     (2.4k) | 1.34 GB/s     (1.3k)
    Write      | 1.33 GB/s     (2.6k) | 1.43 GB/s     (1.3k)
    Total      | 2.60 GB/s     (5.0k) | 2.77 GB/s     (2.7k)
    Clouvider       | London, UK (10G)          | 245 Mbits/sec   | 3.85 Gbits/sec
    Online.net      | Paris, FR (10G)           | 208 Mbits/sec   | 4.42 Gbits/sec
    WorldStream     | The Netherlands (10G)     | 208 Mbits/sec   | 4.72 Gbits/sec
    WebHorizon      | Singapore (1G)            | 131 Mbits/sec   | 356 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 356 Mbits/sec   | 2.16 Gbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 244 Mbits/sec   | 1.15 Gbits/sec
    Single Core     | 551
    Multi Core      | 596
    Full Test       | https://browser.geekbench.com/v5/cpu/11710203
    Greencloudvps
    Ryzen10GbpsHK-3
    NVMe 4.0
    look at that network, can't believe it's in Asia
    [root@cybertech ~]# curl -sL yabs.sh | bash -s -- -9
    #                     v2021-12-03                    #
    Thu Dec 23 12:14:42 +08 2021
    Processor  : AMD Ryzen Threadripper 3960X 24-Core Processor
    CPU cores  : 2 @ 3799.956 MHz
    RAM        : 2.9 GiB
    Swap       : 32.0 MiB
    Disk       : 35.0 GiB
    Read       | 370.09 MB/s  (92.5k) | 2.16 GB/s    (33.8k)
    Write      | 371.07 MB/s  (92.7k) | 2.17 GB/s    (34.0k)
    Total      | 741.17 MB/s (185.2k) | 4.34 GB/s    (67.9k)
    Read       | 2.37 GB/s     (4.6k) | 2.46 GB/s     (2.4k)
    Write      | 2.50 GB/s     (4.8k) | 2.62 GB/s     (2.5k)
    Total      | 4.87 GB/s     (9.5k) | 5.09 GB/s     (4.9k)
    Clouvider       | London, UK (10G)          | 933 Mbits/sec   | 789 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.08 Gbits/sec  | 989 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 666 Mbits/sec   | 649 Mbits/sec
    WebHorizon      | Singapore (1G)            | 308 Mbits/sec   | 237 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 832 Mbits/sec   | 800 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 403 Mbits/sec   | 844 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.04 Gbits/sec  | 1.00 Gbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 503 Mbits/sec
    Clouvider       | London, UK (10G)          | 849 Mbits/sec   | 641 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.06 Gbits/sec  | 895 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 555 Mbits/sec
    WebHorizon      | Singapore (1G)            | 413 Mbits/sec   | 690 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 798 Mbits/sec   | 628 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.04 Gbits/sec  | 990 Mbits/sec
    Single Core     | 5343
    Multi Core      | 9492
    Full Test       | https://browser.geekbench.com/v4/cpu/16446267
    Single Core     | 1198
    Multi Core      | 2337
    Full Test       | https://browser.geekbench.com/v5/cpu/11761931
    hosthatch HK revisit
    #                     v2021-12-03                    #
    Thu Dec 23 16:19:50 +08 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
    CPU cores  : 1 @ 3000.006 MHz
    RAM        : 1.9 GiB
    Swap       : 32.0 MiB
    Disk       : 19.9 GiB
    Read       | 78.20 MB/s   (19.5k) | 1.06 GB/s    (16.6k)
    Write      | 78.41 MB/s   (19.6k) | 1.06 GB/s    (16.7k)
    Total      | 156.62 MB/s  (39.1k) | 2.13 GB/s    (33.3k)
    Read       | 2.52 GB/s     (4.9k) | 2.20 GB/s     (2.1k)
    Write      | 2.65 GB/s     (5.1k) | 2.35 GB/s     (2.2k)
    Total      | 5.17 GB/s    (10.1k) | 4.55 GB/s     (4.4k)
    Clouvider       | London, UK (10G)          | 351 Mbits/sec   | 372 Mbits/sec
    Online.net      | Paris, FR (10G)           | 516 Mbits/sec   | 334 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | busy
    WebHorizon      | Singapore (1G)            | 413 Mbits/sec   | 598 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 594 Mbits/sec   | 338 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 372 Mbits/sec   | 339 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 618 Mbits/sec   | 386 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 430 Mbits/sec   | 176 Mbits/sec
    Clouvider       | London, UK (10G)          | 555 Mbits/sec   | 420 Mbits/sec
    Online.net      | Paris, FR (10G)           | 608 Mbits/sec   | 475 Mbits/sec
    WebHorizon      | Singapore (1G)            | 476 Mbits/sec   | 589 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 572 Mbits/sec   | 379 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 559 Mbits/sec   | 366 Mbits/sec
    Single Core     | 2559
    Multi Core      | 2414
    Full Test       | https://browser.geekbench.com/v4/cpu/16446413
    Single Core     | 519
    Multi Core      | 512
    Full Test       | https://browser.geekbench.com/v5/cpu/11764692
    Thanked by (1)chocolateshirt
    RAM        : 31.3 GiB
    Swap       : 9.5 GiB
    Disk       : 14.4 TiB
    Single Core     | 766
    Multi Core      | 5369
    Crazy IOPS. Assuming Raid0? I have less than 10K hours disk but my IO is
    io Disk Speed Tests (Mixed R/W 50/50):
    Read 3.93 MB/s (982) 48.42 MB/s (756)
    Write 3.95 MB/s (987) 48.73 MB/s (761)
    Total 7.88 MB/s (1.9k) 97.15 MB/s (1.5k)
    Read 174.23 MB/s (340) 182.63 MB/s (178)
    Write 183.49 MB/s (358) 194.79 MB/s (190)
    Total 357.72 MB/s (698) 377.42 MB/s (368)
    Team push-ups!
    RAM        : 31.3 GiB
    Swap       : 9.5 GiB
    Disk       : 14.4 TiB
    Single Core     | 766
    Multi Core      | 5369
    Yep Raid0 - IOPS settled a bit now :+1:
    Thu 23 Dec 15:36:19 UTC 2021
    CPU cores  : 16 @ 800.914 MHz
    RAM        : 31.3 GiB
    Swap       : 9.5 GiB
    Disk       : 14.4 TiB
    Read       | 6.37 MB/s     (1.5k) | 59.48 MB/s     (929)
    Write      | 6.38 MB/s     (1.5k) | 59.98 MB/s     (937)
    Total      | 12.75 MB/s    (3.1k) | 119.46 MB/s   (1.8k)
    Read       | 213.75 MB/s    (417) | 224.63 MB/s    (219)
    Write      | 225.11 MB/s    (439) | 239.59 MB/s    (233)
    Total      | 438.87 MB/s    (856) | 464.22 MB/s    (452)
    Any benchmark for the OVH Advance-LE ?
    It is currently on sale
    My new VM in Amsterdam.
    root@cloud01:~# curl -sL yabs.sh | bash -s -- -r
    #                     v2021-12-03                    #
    Thu 23 Dec 2021 04:22:00 PM EST
    Processor  : AMD EPYC 7H12 64-Core Processor
    CPU cores  : 4 @ 2599.998 MHz
    RAM        : 3.8 GiB
    Swap       : 255.0 MiB
    Disk       : 79.5 GiB
    Read       | 367.95 MB/s  (91.9k) | 5.62 GB/s    (87.8k)
    Write      | 368.92 MB/s  (92.2k) | 5.65 GB/s    (88.3k)
    Total      | 736.87 MB/s (184.2k) | 11.27 GB/s  (176.1k)
    Read       | 8.20 GB/s    (16.0k) | 8.56 GB/s     (8.3k)
    Write      | 8.64 GB/s    (16.8k) | 9.13 GB/s     (8.9k)
    Total      | 16.84 GB/s   (32.8k) | 17.69 GB/s   (17.2k)
    Clouvider       | London, UK (10G)          | 936 Mbits/sec   | 900 Mbits/sec
    Online.net      | Paris, FR (10G)           | 935 Mbits/sec   | 809 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 785 Mbits/sec   | 310 Mbits/sec
    Clouvider       | London, UK (10G)          | 924 Mbits/sec   | 913 Mbits/sec
    Online.net      | Paris, FR (10G)           | 922 Mbits/sec   | 903 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 866 Mbits/sec   | 293 Mbits/sec
    Single Core     | 984
    Multi Core      | 3905
    Full Test       | https://browser.geekbench.com/v5/cpu/11775669
  • hey @Mason , sorry for bothering you here at that time - no need to respond ;-)
    just wanted to let you know that it seems GB changed something to the output or so. the numbers won't get displayed in yabs anymore (obviously they are there, because the link works just fine...
    as said, no need to rush anything, a Merry Christmas to you and your family!
    nonononono this cant be happening no scores what? no
    no
    nooooooooooooooo
    no
    nooooooooooooooo
    stay strong mate! you will live through it. it's gonna be though, but you can do it!
    Thanked by (1)cybertech
  • MasonMason AdministratorOG
    Perhaps whatever it was got fixed? Just ran a GB4 and GB5 test and the numbers populated just fine, let me know if you're still having the issue. If you still are having issues, then the only thing that I can possibly think of would be that your host isn't able to connect to the geekbench url (browser.geekbench.com) to retrieve the results after the tests are done.
    mrowe@cerberus:~$ curl -sL yabs.sh | bash -s -- -di
    #                     v2021-12-03                    #
    Fri Dec 24 17:49:17 UTC 2021
    Processor  : Intel(R) Core(TM) i5-10400 CPU @ 2.90GHz
    CPU cores  : 12 @ 1433.902 MHz
    RAM        : 31.2 GiB
    Swap       : 40.0 GiB
    Disk       : 43.9 TiB
    Single Core     | 1202
    Multi Core      | 6176
    Full Test       | https://browser.geekbench.com/v5/cpu/11790573
    mrowe@cerberus:~$ curl -sL yabs.sh | bash -s -- -di4
    #                     v2021-12-03                    #
    Fri Dec 24 17:52:14 UTC 2021
    CPU cores  : 12 @ 800.029 MHz
    RAM        : 31.2 GiB
    Swap       : 40.0 GiB
    Disk       : 43.9 TiB
    Single Core     | 5546
    Multi Core      | 25075
    Full Test       | https://browser.geekbench.com/v4/cpu/16447531
    Thanked by (1)Falzo
  • FalzoFalzo Senpai
    @Mason said: If you still are having issues, then the only thing that I can possibly think of would be that your host isn't able to connect to the geekbench url (browser.geekbench.com) to retrieve the results after the tests are done.
    thanks a lot for checking and pointing into the right direction:
    # curl https://browser.geekbench.com/v5/cpu/11789272
    curl: (60) SSL certificate problem: certificate has expired
    More details here: http://curl.haxx.se/docs/sslcerts.html
    as this is a very old host, it's possible that just my ca-certificates needs and update... I'll investigate ;-)
    sorry for the possible false alarm.
    edit: just to mention, I only wrote here, because I saw another yabs missing those number over on OGF - hence I probably jumped to a conclusion to quickly. again sorry for waking you up ;-)
    edit 2: indeed they (GB) are using LE and my old vps still had their old rootcs in store. combined with a bug in a somewhat older openssl version this seem to break validation. removing the single old DST root from ca-certificate brought me numbers back:
    #                     v2021-12-03                    #
    Fr 24. Dez 19:17:58 CET 2021
    Processor  : Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
    CPU cores  : 6 @ 3399.998 MHz
    RAM        : 5.8 GiB
    Swap       : 2.0 GiB
    Disk       : 96.3 GiB
    Single Core     | 738
    Multi Core      | 2389
    Full Test       | https://browser.geekbench.com/v5/cpu/11791018
    Thanked by (1)Mason
  • edited December 2021
    On my Laptop - 2018 (or 2017) Huawei - WSL:
    Its a 1TB Samsung 860 - Beats me why it shows 250GiB...
    user@DESKTOP:~$ curl -sL yabs.sh | bash
    #                     v2021-12-03                    #
    Sat Dec 25 17:37:52 EST 2021
    Processor  : AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
    CPU cores  : 8 @ 1996.187 MHz
    RAM        : 5.3 GiB
    Swap       : 2.0 GiB
    Disk       : 251.0 GiB
    Read       | 73.18 MB/s   (18.2k) | 125.85 MB/s   (1.9k)
    Write      | 73.37 MB/s   (18.3k) | 126.51 MB/s   (1.9k)
    Total      | 146.55 MB/s  (36.6k) | 252.36 MB/s   (3.9k)
    Read       | 155.44 MB/s    (303) | 166.31 MB/s    (162)
    Write      | 163.70 MB/s    (319) | 177.39 MB/s    (173)
    Total      | 319.15 MB/s    (622) | 343.71 MB/s    (335)
    Clouvider       | London, UK (10G)          | 215 Mbits/sec   | 66.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 214 Mbits/sec   | 107 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 200 Mbits/sec   | 75.4 Mbits/sec
    WebHorizon      | Singapore (1G)            | 203 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 237 Mbits/sec   | 170 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 212 Mbits/sec   | 78.9 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 210 Mbits/sec   | 58.1 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 212 Mbits/sec   | 46.7 Mbits/sec
    Single Core     | 596
    Multi Core      | 2556
    Full Test       | https://browser.geekbench.com/v5/cpu/11812901
    boomer.host final bench
    root@cybertech:~# curl -sL yabs.sh | bash -s -- -4i
    #                     v2021-12-03                    #
    Mon Dec 27 03:12:29 UTC 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2640 v2 @ 2.00GHz
    CPU cores  : 1 @ 2299.926 MHz
    RAM        : 1000.0 MiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Read       | 14.51 MB/s    (3.6k) | 13.19 MB/s     (206)
    Write      | 14.52 MB/s    (3.6k) | 13.75 MB/s     (214)
    Total      | 29.03 MB/s    (7.2k) | 26.95 MB/s     (420)
    Read       | 11.71 MB/s      (22) | 30.59 MB/s      (29)
    Write      | 12.91 MB/s      (25) | 34.41 MB/s      (33)
    Total      | 24.62 MB/s      (47) | 65.00 MB/s      (62)
    Single Core     | 1682
    Multi Core      | 1758
    Full Test       | https://browser.geekbench.com/v4/cpu/16449443
  • LowHosting Final Bench before I let it expire.
    #                     v2021-12-03                    #
    Mon 27 Dec 2021 03:16:14 PM +07
    CPU cores  : 6 @ 3393.622 MHz
    AES-NI     : ? Enabled
    VM-x/AMD-V : ? Enabled
    RAM        : 15.6 GiB
    Swap       : 256.0 MiB
    Disk       : 117.9 GiB
    Read       | 483.24 MB/s (120.8k) | 1.89 GB/s    (29.6k)
    Write      | 484.52 MB/s (121.1k) | 1.90 GB/s    (29.8k)
    Total      | 967.76 MB/s (241.9k) | 3.80 GB/s    (59.4k)
    Read       | 1.90 GB/s     (3.7k) | 2.07 GB/s     (2.0k)
    Write      | 2.00 GB/s     (3.9k) | 2.21 GB/s     (2.1k)
    Total      | 3.91 GB/s     (7.6k) | 4.29 GB/s     (4.1k)
    Clouvider       | London, UK (10G)          | 926 Mbits/sec   | 14.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 923 Mbits/sec   | 3.67 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 926 Mbits/sec   | 911 Mbits/sec
    WebHorizon      | Singapore (1G)            | 23.4 Mbits/sec  | 266 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 853 Mbits/sec   | 15.8 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 757 Mbits/sec   | 18.1 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 793 Mbits/sec   | 9.66 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 11.0 Mbits/sec  | 163 Mbits/sec
    Clouvider       | London, UK (10G)          | 861 Mbits/sec   | 732 Mbits/sec
    Online.net      | Paris, FR (10G)           | 884 Mbits/sec   | 516 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 889 Mbits/sec   | 665 Mbits/sec
    WebHorizon      | Singapore (1G)            | 242 Mbits/sec   | 225 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 806 Mbits/sec   | 189 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 669 Mbits/sec   | 107 Mbits/sec
    Single Core     | 1160
    Multi Core      | 4601
    Full Test       | https://browser.geekbench.com/v5/cpu/11837746
    #                     v2021-12-03                    #
    AES-NI     : ? Enabled
    RAM        : 15.6 GiB
    Swap       : 256.0 MiB
    Disk       : 117.9 GiB
    Single Core     | 1160
    Multi Core      | 4601
    Not enjoying it? I think it's one of the best value with 50% off
    Team push-ups!
    It seems pretty solid. What is the monthly/yearly price?
    Periodic YABS for InceptionHosting Storage (PHX). Pretty solid for almost one year uptime.
    choco@phx-01:~$ curl -sL yabs.sh | bash
    #                     v2021-12-03                    #
    Mon Dec 27 18:50:05 WIB 2021
    Processor  : Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
    CPU cores  : 1 @ 2199.998 MHz
    AES-NI     : � Enabled
    VM-x/AMD-V : � Enabled
    RAM        : 473.1 MiB
    Swap       : 510.0 MiB
    Disk       : 490.6 GiB
    Read       | 3.72 MB/s      (930) | 62.98 MB/s     (984)
    Write      | 3.74 MB/s      (935) | 63.32 MB/s     (989)
    Total      | 7.46 MB/s     (1.8k) | 126.31 MB/s   (1.9k)
    Read       | 81.57 MB/s     (159) | 109.53 MB/s    (106)
    Write      | 85.90 MB/s     (167) | 116.82 MB/s    (114)
    Total      | 167.48 MB/s    (326) | 226.36 MB/s    (220)
    Clouvider       | London, UK (10G)          | 852 Mbits/sec   | 230 Mbits/sec
    Online.net      | Paris, FR (10G)           | 842 Mbits/sec   | 264 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 827 Mbits/sec   | 204 Mbits/sec
    WebHorizon      | Singapore (1G)            | 326 Mbits/sec   | 313 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 903 Mbits/sec   | 426 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 901 Mbits/sec   | 523 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 935 Mbits/sec   | 884 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 786 Mbits/sec   | 330 Mbits/sec
    Single Core     | 502
    Multi Core      | 484
    Full Test       | https://browser.geekbench.com/v5/cpu/11840611
    €12 a month with the deal. Unlimited bandwidth!
    Team push-ups!
    This is the free dedi MetalVPS got for BF from Shock Hosting. Newly reinstalled with Debian 11. RAID 1. Please note that, since we got it for free, we are not charging for accounts on it. Thanks @ShockHosting!
    root@shock:~# curl -sL yabs.sh | bash
    #                     v2021-12-03                    #
    Mon 27 Dec 2021 08:07:30 PM PST
    Processor  : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz
    CPU cores  : 8 @ 2523.226 MHz
    RAM        : 31.4 GiB
    Swap       : 2.9 GiB
    Disk       : 1.8 TiB
    Read       | 1.14 MB/s      (285) | 15.43 MB/s     (241)
    Write      | 1.17 MB/s      (294) | 15.94 MB/s     (249)
    Total      | 2.31 MB/s      (579) | 31.37 MB/s     (490)
    Read       | 58.62 MB/s     (114) | 71.51 MB/s      (69)
    Write      | 61.85 MB/s     (120) | 76.27 MB/s      (74)
    Total      | 120.47 MB/s    (234) | 147.78 MB/s    (143)
    Clouvider       | London, UK (10G)          | 876 Mbits/sec   | 294 Mbits/sec
    Online.net      | Paris, FR (10G)           | 866 Mbits/sec   | 322 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 860 Mbits/sec   | 290 Mbits/sec
    WebHorizon      | Singapore (1G)            | 316 Mbits/sec   | 324 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 923 Mbits/sec   | 873 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 928 Mbits/sec   | 866 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 926 Mbits/sec   | 917 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 846 Mbits/sec   | 327 Mbits/sec
    Clouvider       | London, UK (10G)          | 864 Mbits/sec   | 431 Mbits/sec
    Online.net      | Paris, FR (10G)           | 863 Mbits/sec   | 544 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 850 Mbits/sec   | 524 Mbits/sec
    WebHorizon      | Singapore (1G)            | 324 Mbits/sec   | 339 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 911 Mbits/sec   | 873 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 902 Mbits/sec   | 899 Mbits/sec
    Single Core     | 1055
    Multi Core      | 3989
    Full Test       | https://browser.geekbench.com/v5/cpu/11853185
    root@shock:~#
    Nexus says my VPS is getting migrated (DE>>NL) so dropping a before here & after to follow a bit later.
    Big gotcha though - not representative of migration overall. It's a grandfathered once off clearance special with nine lives and a lot of luck that @seriesn very honourably rolled 1:1 specs wise last migration when really the platforms were not 1:1 comparable at all. So regardless of before/after results I won't be complaining
    Tue 28 Dec 2021 12:24:43 PM EST
    Processor  : AMD Ryzen 7 3700X 8-Core Processor
    CPU cores  : 4 @ 3593.248 MHz
    RAM        : 15.6 GiB
    Swap       : 0.0 KiB
    Disk       : 39.4 GiB
    Read       | 358.87 MB/s  (89.7k) | 3.31 GB/s    (51.7k)
    Write      | 359.82 MB/s  (89.9k) | 3.33 GB/s    (52.0k)
    Total      | 718.69 MB/s (179.6k) | 6.64 GB/s   (103.8k)
    Read       | 3.69 GB/s     (7.2k) | 3.83 GB/s     (3.7k)
    Write      | 3.89 GB/s     (7.5k) | 4.09 GB/s     (3.9k)
    Total      | 7.58 GB/s    (14.8k) | 7.92 GB/s     (7.7k)
    Clouvider       | London, UK (10G)          | 939 Mbits/sec   | 933 Mbits/sec
    Online.net      | Paris, FR (10G)           | 953 Mbits/sec   | 937 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 894 Mbits/sec   | 534 Mbits/sec
    Single Core     | 1252
    Multi Core      | 4008
    Full Test       | https://browser.geekbench.com/v5/cpu/11864054
