This plan comes with Limited Support and our brand new Cloud Portal access with self OS Rebuild, Start, Stop, Restart, TUN/TAP, Console, etc. management options.
hey @Mason , sorry for bothering you here at that time - no need to respond ;-)
just wanted to let you know that it seems GB changed something to the output or so. the numbers won't get displayed in yabs anymore (obviously they are there, because the link works just fine...
as said, no need to rush anything, a Merry Christmas to you and your family!
nonononono this cant be happening no scores what? no
no
nooooooooooooooo
stay strong mate! you will live through it. it's gonna be though, but you can do it!
Perhaps whatever it was got fixed? Just ran a GB4 and GB5 test and the numbers populated just fine, let me know if you're still having the issue. If you still are having issues, then the only thing that I can possibly think of would be that your host isn't able to connect to the geekbench url (browser.geekbench.com) to retrieve the results after the tests are done.
@Mason said: If you still are having issues, then the only thing that I can possibly think of would be that your host isn't able to connect to the geekbench url (browser.geekbench.com) to retrieve the results after the tests are done.
thanks a lot for checking and pointing into the right direction:
as this is a very old host, it's possible that just my ca-certificates needs and update... I'll investigate ;-)
sorry for the possible false alarm.
edit: just to mention, I only wrote here, because I saw another yabs missing those number over on OGF - hence I probably jumped to a conclusion to quickly. again sorry for waking you up ;-)
edit 2: indeed they (GB) are using LE and my old vps still had their old rootcs in store. combined with a bug in a somewhat older openssl version this seem to break validation. removing the single old DST root from ca-certificate brought me numbers back:
@giang said:
LowHosting Final Bench before I let it expire.
Not enjoying it? I think it's one of the best value with 50% off
It seems pretty solid. What is the monthly/yearly price?
Nexus says my VPS is getting migrated (DE>>NL) so dropping a before here & after to follow a bit later.
Big gotcha though - not representative of migration overall. It's a grandfathered once off clearance special with nine lives and a lot of luck that @seriesn very honourably rolled 1:1 specs wise last migration when really the platforms were not 1:1 comparable at all. So regardless of before/after results I won't be complaining
if you contact support they will move you
but since they have no stock it is likely that all nodes are pretty full
Raspberry Pi4 - 4 GB with M.2 SATA Boot
Manjaro 21. Delighted to see ARM support (experimental as the note says!)
Wednesday 15 December 2021 10:00:10 PM IST ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Processor : Cortex-A72 CPU cores : 4 @ 1500.0000 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.7 GiB Swap : 5.5 GiB Disk : 234.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 51.50 MB/s (12.8k) | 145.19 MB/s (2.2k) Write | 51.47 MB/s (12.8k) | 149.51 MB/s (2.3k) Total | 102.98 MB/s (25.7k) | 294.70 MB/s (4.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 162.08 MB/s (316) | 155.07 MB/s (151) Write | 175.94 MB/s (343) | 173.01 MB/s (168) Total | 338.03 MB/s (659) | 328.08 MB/s (319) ARM architecture not supported by Geekbench 4, use Geekbench 5. Geekbench 4 test failed. Run manually to determine cause. Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 216 Multi Core | 550 Full Test | https://browser.geekbench.com/v5/cpu/11626169blog | exploring visually |
Probably they are pretty full.
I'd like to wait a few day to see whether it becomes better.
i think it's fine given that its dedicated I/O, perhaps set swappiness to 1?
I doubt it will improve much with time
If you ask support they are usually quick and fairly helpful, much better than average for a LE host, maybe they can still help
Hostcram
Confidential: Ryzen Two (LXC)
2 vCPU Core (Ryzen 9 5950X)
2 GB DDR4 RAM (Samsung)
20 GB NVMe SSD Storage (Samsung)
2 TB Bandwidth @ 1 Gbps Port
1 Dedicated IPv4 (IPv6 on request)
1 Year @ $25.00 USD
2 Year @ $40.00 USD
Just grabbed another Hetzner box!
SYS-2-SAT-32 FRANCE :
stardust NL:
Greencloudvps
Ryzen10GbpsHK-3
NVMe 4.0
look at that network, can't believe it's in Asia
hosthatch HK revisit
Crazy IOPS. Assuming Raid0? I have less than 10K hours disk but my IO is
Team push-ups!
Yep Raid0 - IOPS settled a bit now
Any benchmark for the OVH Advance-LE ?
It is currently on sale
https://webhorizon.net
My new VM in Amsterdam.
Amadex • Hosting Forums • root.hr
no
nooooooooooooooo
On my Laptop - 2018 (or 2017) Huawei - WSL:
Its a 1TB Samsung 860 - Beats me why it shows 250GiB...
boomer.host final bench
Team push-ups!
Periodic YABS for InceptionHosting Storage (PHX). Pretty solid for almost one year uptime.
€12 a month with the deal. Unlimited bandwidth!
Team push-ups!
still in use https://browser.geekbench.com/v5/cpu/11848688 √
This is the free dedi MetalVPS got for BF from Shock Hosting. Newly reinstalled with Debian 11. RAID 1. Please note that, since we got it for free, we are not charging for accounts on it. Thanks @ShockHosting!
