Who do you use for cold backup?
I am finally going to design my 3-2-1 backup plan, which is a step up from my current plan:
replace hard drives before they fail
So, wonder how is everyone's plan look like, what services do you use?
The obvious provider would be AWS... but any other contenders?
  • How much storage do you require? Also how cold is the storage? Maybe S3 Glacier could work for you or depending on the amount of storage I’m sure a provider would be able to do custom large storage deals.
  • I typically use Wasabi. But S3 glacier would be great considering the new 100GB free egress + 1TB free Cloudfront
    Thanked by (1)terrorgen
  • vyasvyas OGSenpai
    b2 (with or without Cloudflare depending on use)
  • Don't wasabi only have one price (i.e. hot storage)? Same for B2. AWS glacier deep storage is $1/TB/mo, but of course retrieval costs can kill you. Scaleway C14 is 2 Euro/TB/mo, but lower retrieval cost.
  • vyasvyas OGSenpai
    edited January 2022
    Cost comparison from backblaze. We are considering it for our use- once we start video podcasts. Not sure if these are reasonable prices
    (10 TB total backup, with 1 TB/ month data xfer -
    considering cold storage)
    Excellent questions by @natvps_uk btw
    Depending on storage requirements the 2 TB plan from sync.com (solo basic or the solo professional ) can also be an option.
    I like sync. Rather under rated in the space
    https://www.sync.com/pricing/
  • I probably have less than 1tb to back up unless I count those Linux ISOs I gathered the past decade and a half.
    Using onedrive - O365 fam comes with 6TB. And since I need office anyway....
    Be sure to encrypt those linux isos...cloud providers hashing copyright content is becoming more fashionable
    Thanked by (2)vyas dosai
    Hi @terrorgen! I have a 5 TB Seagate lifetime! :) It cost $95 last Christmas. :)
    I know this probably isn't what you want, but I can't resist joking around! ¡Saludos! 🤩
    Thanked by (2)terrorgen ehab
    Then uploaded to the cloud via IPoAC?
  • @terrorgen I'm curious how much are you willing to pay for say 2TB lifetime encrypted storage?
    Team push-ups!
    Definitely! How appropriate to mention clouds in the context of IPoAC!
    You win this round! ✨💖
  • AdvinAdvin Hosting Provider
    I just backup my personal files to my Gsuite Unlimited $12/month legacy plan :)
    @vyas if you proxy Cloudflare in front of B2, you don’t have to pay for any egress costs due to the bandwidth alliance right? Doesn’t that make it a no-brained? And $5/TB/mo without egress costs makes it cheaper than Wasabi… or do I not understand it correctly?
  • For a cold backup, I use my own server at home. It's just a simple 1U storage server that I built.
    Thanked by (2)Ganonk skorous
  • The ultimate cold backup: GitHub Archive Program.
    Arctic Code Vault Contributor
    Upload your files in a public repository on GitHub.
    Wait a few years.
    It will be printed as microfilm and store in a cold vault.
    Your files will last long past the humanity.
    Thanked by (4)terrorgen Mei Unixfy Kalipus
  • If you are using Wasabi, be aware that they have a minimum storage duration policy which affects pricing.
    https://wasabi-support.zendesk.com/hc/en-us/articles/360058734492-How-does-Wasabi-s-minimum-storage-duration-policy-work-
  • vyasvyas OGSenpai
    edited January 2022
    Wait a few years.
    Microsoft Putting azure to use for this?
  • vyasvyas OGSenpai
    That was the reason behind posting the link and screenshot.
    There are quite a few folks who loathe CF.
    So they get both pricing options to play with
    Thanked by (1)lentro
    can you use the s3 API with the proxied domain? last time I tested, there were errors when connecting via cloudflare-proxied domain, which makes it useless if your using most backup softwares. plus, wasabi has more locations available, which is a big plus too.
