Is netim.com reliable?
i want to take two domains (.nu / .se) away from loopia.se and am looking for a new registrar that has both .nu and .se in their program (so i don't need another provider).
currently i pay with loopia per year
12,00 euro for the dns module
16,25 eurp for the .se domain
17,50 eurp for the .nu doamin
all incl. taxes
i noticed netim.com. they offer both of the above mentioned domain extensions. is there any experience with this provider? is it recommendable? are there any other providers that would also come into question?
Domeneshop seems to have both extensions at a lower price at least.
I have several domains with them, no issues apart from their panel being a bit outdated.
https://domene.shop
FreeVPS.org - Grab a free VPS!
Yes, netim is reliable. Support is stellar.
copy/pasta'ing my reply from OGF, lol
Yeah, they're good/legit. Their panel can be a bit clunky, although it just got an update so it's a bit better.
If you're looking for other options you can check TLD-list:
https://tld-list.com/tld/nu
https://tld-list.com/tld/se
double holds better is what they say here 😁
Netim is quite reliable from my experience with it. It has a very old panel to manage domains, which is quite confusing sometimes. My biggest problem it that customers don't get to choose a login username (this is given by Netim), but overall I never had any problems with them.
During all the current west sanctions against Russia, I can't seem to find any information of them blocking Russian citizens, therefore this is a big plus for Netim as respect for it's own customers.
How are you... online?
Used them since 2013 and have not had any issues as far as I can recall.
Support was fine and responsive too when I needed them.
fsdata.se also works.
+1 for netim.
Can't say anything about their support because I never needed it...
Can't comment on their .nu/.se pricing, but they are reliable. Got a domain with them for a few years now.
