178101213277
  • @Cyzzc1290 said:
    Hello, please help me with it
    Invoice 1413470
    order #560309
    Thank you!
    hello, ip can't connect. Unable to boot after reinstalling the system. Please fix. Thanks!
    service order#837558
    Invoice 1413470
  • edited April 2022
    @VirMach
    Order #560836
    OrderNumber 8477795567
    Invoice #1415112
    Thanks.
  • Can only CentOS 7 be installed on this machine?
    I tried installing Ubuntu 20.04, Ubuntu 18.04, Debian 11, Centos 8, and Windows Server 2022(evaluation mode). Only Centos 7 is successfully powered on. Is that normal?
    And after the boot I did not operate anything, broadband traffic in inexplicable consumption.
    I want to install Ubuntu 20.04 on my machine
  • edited April 2022
    Templates are broken. I'd suggest you to install AlmaLinux 8 (to enable CPU passthrough/AES-NI), then use the netboot.xyz ISO to reinstall with your desired OS.
    Thanked by (2)FrankZ fan
    谢谢,我明天白天进行一下尝试。
  • @JeDaYoshi said: (to enable CPU passthrough/AES-NI)
    Saw this and found my old Intel VM doesn't have AES-NI, and reinstalling with template enabled that. Thanks for the hint!
    edited April 2022
    @caodaye said: 谢谢,我明天白天进行一下尝试。
    Piss off with this shit! It's an English forum not Hostloc. Don't make this into another LET !
    Thanked by (1)opelnic
  • mikhomikho AdministratorOG
    No need to use strong language.
    I will make an update to the rules in a minute.
    You may (may not?) notice that I don't revert to strong language very often. Usually only to make a strong point.
    Thats why I so gently remind you to find your inner peace and be one with the universe.
    Ice cream??
  • @mikho said: Ice cream
    I scream frequently (inside). ;)
    Thanked by (4)mikho skorous Mason ehab
    edited April 2022
    managed to install debian 11 via netboot.
    TYOC040 seems faster now hitting 200mbps.
    However kernel panic still can happen when running YABS.
    #                     v2022-02-18                    #
    Sat 09 Apr 2022 07:27:05 AM +08
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 2 @ 3693.062 MHz
    RAM        : 2.4 GiB
    Swap       : 30.0 MiB
    Disk       : 49.9 GiB
    Read       | 284.37 MB/s  (71.0k) | 565.46 MB/s   (8.8k)
    Write      | 285.12 MB/s  (71.2k) | 568.43 MB/s   (8.8k)
    Total      | 569.49 MB/s (142.3k) | 1.13 GB/s    (17.7k)
    Read       | 541.01 MB/s   (1.0k) | 531.02 MB/s    (518)
    Write      | 569.76 MB/s   (1.1k) | 566.38 MB/s    (553)
    Total      | 1.11 GB/s     (2.1k) | 1.09 GB/s     (1.0k)
    Geekbench 4 Benchmark Test:
    Single Core     | 5692
    Multi Core      | 9390
    Full Test       | https://browser.geekbench.com/v4/cpu/16528036
    root@cybertech:~# curl -LsO bench.monster/speedtest.sh; bash speedtest.sh -io
     ## IO Test
     CPU Speed:
        bzip2     : 176 MB/s
       sha256     : 297 MB/s
       md5sum     : 706 MB/s
     RAM Speed:
       Avg. write : 4505.6 MB/s
       Avg. read  : 11093.3 MB/s
     Disk Speed:
       1st run    : 641 MB/s
       2nd run    : 678 MB/s
       3rd run    : 668 MB/s
       Average    : 662.3 MB/s
  • MasonMason AdministratorOG
  • ^ must be the coder's fault! :p
    Thanked by (3)Mason vyas mikho
    TYOC039 network is still not in perfect condition, but I hope it will stabilize in time!
    @Mason said:
    yes i get anxiety when no YABS runs well in a day.
    Thanked by (2)Mason FrankZ
    picking up now
    Clouvider       | London, UK (10G)          | 89.2 Mbits/sec  | 39.9 Mbits/sec
    Online.net      | Paris, FR (10G)           | 110 Mbits/sec   | 70.9 Mbits/sec
    WorldStream     | The Netherlands (10G)     | busy            | 83.0 Mbits/sec
    WebHorizon      | Singapore (400M)          | 81.7 Mbits/sec  | 129 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 124 Mbits/sec   | 120 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 114 Mbits/sec   | 115 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 89.2 Mbits/sec  | 127 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | 154 Mbits/sec
  • edited April 2022
    @cybertech said:
    picking up now
    Your bandwidth has doubled tripled 😉
    edited April 2022
    TYOC040 is Ryzennnnnnnn
    -------------------- A Bench.sh Script By Teddysun -------------------
    Version            : v2022-02-22
     Usage              : wget -qO- bench.sh | bash
     CPU Model          : AMD Ryzen 9 5900X 12-Core Processor
     CPU Cores          : 2 @ 3693.062 MHz
     CPU Cache          : 512 KB
     AES-NI             : Enabled
     VM-x/AMD-V         : Enabled
     Total Disk         : 49.9 GB (5.5 GB Used)
     Total Mem          : 2.4 GB (344.1 MB Used)
     Total Swap         : 30.0 MB (0 Used)
     System uptime      : 0 days, 4 hour 48 min
     Load average       : 0.00, 0.01, 0.00
     OS                 : Debian GNU/Linux 11
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.16.0-6-amd64
     TCP CC             : bbr
     Virtualization     : Dedicated
     Organization       : AS23959 Owl Limited
     Region             : Tokyo
     I/O Speed(1st run) : 613 MB/s
     I/O Speed(2nd run) : 657 MB/s
     I/O Speed(3rd run) : 637 MB/s
     I/O Speed(average) : 635.7 MB/s
     Node Name        Upload Speed      Download Speed      Latency
     Speedtest.net    637.46 Mbps       471.78 Mbps         1.03 ms
     Los Angeles, US  393.37 Mbps       484.80 Mbps         109.47 ms
     Dallas, US       333.14 Mbps       168.74 Mbps         130.20 ms
     Montreal, CA     216.19 Mbps       405.59 Mbps         171.07 ms
     Paris, FR        143.78 Mbps       26.75 Mbps          245.12 ms
     Amsterdam, NL    59.08 Mbps        91.73 Mbps          298.10 ms
     Shanghai, CN     62.73 Mbps        3.20 Mbps           135.43 ms
     Nanjing, CN      49.38 Mbps        53.01 Mbps          55.46 ms
     Guangzhou, CN    13.40 Mbps        41.25 Mbps          56.41 ms
     Hongkong, CN     20.40 Mbps        40.91 Mbps          140.94 ms
     Seoul, KR        28.58 Mbps        6.29 Mbps           177.38 ms
     Finished in        : 6 min 25 sec
     Timestamp          : 2022-04-09 16:13:55 +08
  • Got mine yesterday and has been using it ever since. There were some trouble when installing OS but all worked fine now.
    YABS :
    # Yet-Another-Bench-Script #
    # v2022-02-18 #
    Sat 09 Apr 2022 04:07:19 AM EDT
    CPU cores  : 1 @ 3693.060 MHz
    RAM        : 724.4 MiB
    Swap       : 256.0 MiB
    Disk       : 19.4 GiB
    Read       | 308.90 MB/s  (77.2k) | 639.25 MB/s   (9.9k)
    Write      | 309.72 MB/s  (77.4k) | 642.62 MB/s  (10.0k)
    Total      | 618.62 MB/s (154.6k) | 1.28 GB/s    (20.0k)
    Read       | 944.02 MB/s   (1.8k) | 1.05 GB/s     (1.0k)
    Write      | 994.18 MB/s   (1.9k) | 1.12 GB/s     (1.1k)
    Total      | 1.93 GB/s     (3.7k) | 2.18 GB/s     (2.1k)
    Clouvider       | London, UK (10G)          | 95.8 Mbits/sec  | 183 Mbits/sec
    Online.net      | Paris, FR (10G)           | 257 Mbits/sec   | 348 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 229 Mbits/sec   | 410 Mbits/sec
    WebHorizon      | Singapore (400M)          | 141 Mbits/sec   | 319 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 416 Mbits/sec   | 210 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 79.2 Mbits/sec  | 168 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 534 Mbits/sec   | 214 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | 189 Mbits/sec   | 205 Mbits/sec
  • @Virmach After the incidents on your recent sales thread on OGF, I was wondering if you would ever do a sale there.
  • vyasvyas OGSenpai
    What were the incidents ? (Response via pm okay, or in Cest Pit, thanks)
  • @VirMach Hello,please activate Invoice #1413533.
    Thanks.
    @elliotc said:
    TYOC039, server turn off when I try to reinstall from netboot, is it normal? :/
    What are you installing?
    @Jab said:
    @VirMach please double check those adjusted invoices dates - a lot of people reports it's set to 7.04.2022 (aka today, not 2023) and if your billing system gonna charge that you will have shit ton of new angry customers and chargebacks ^.-
    If your automagically billing is disabled just ignore me :)
    Is this still an issue?
    I have amnesia so I'm sure I will but I'll instantly start getting flashbacks and yell at myself when I realize the same thing happened again.
    Thanked by (3)AlwaysSkint pikachu FrankZ
  • TheDPTheDP OGSenpai
    Is the /64 IPv6 upon request?
    Just referring to NL.
    Also, would you be able to delegate the block's auth to a customer's NS?
    We'll add a button to add /64 IPv6 blocks later, or at least that's the current plan.
    We're refraining from offering any customizations or anything else, and limiting a lot of custom requests for some time until everyone is first migrated to Ryzen. We just wouldn't be able to handle the ticket load from all of our customers asking us all these things at once, I hope you understand and I wish it was possible.
    Tokyo is about to be put behind a pay wall, as in, there will be a setup fee for Tokyo as soon as our sale gets posted on OGF. So it's last call to order Tokyo without paying this setup fee.
  • Order #560658
    OrderNumber 7159836566
    Invoice #1414526
    Thanked by (1)Brueggus
