I wanted to update the design of NanoKVM first, however I am still not done and I suck at it.
Afterwards updating it to PHP 8 before doing any feature changes.
Given the code already exists in microLXC its just copy & paste.
I will check if I can add it to microLXC soon, then ^
A planned maintenance window will be occurring in our Auckland (New Zealand) facility on Wednesday, March 2nd between 3AM - 4AM NZDT. This will make some of our VPS and dedicated servers unreachable for a maximum period of 30mins throughout the maintenance window.
I don't really like this decision, but the way LET is going right now, I am not willing to Support this anymore.
Means, Accounts created after the 14th of March, will be rejected by the System when you apply, for now. I don't know if things will change so, could be that this is gone in a week again.
This does not affect accounts created before on LET in any way.
If you wanna try microLXC after the 14th of March, I suggest you try the OGF.
South Africa is still down, since this is an older VM, I don't have Panel access, neither VNC access.
The Support replied suggested an OOM issue, which I can't confirm but this does not help to solve the issue either.
The VM has been rebooted but no luck so far, plus the Support seems to be very slow in replying to tickets.
No ETA when this gets fixed.
JP is currently offline because the traffic limit was exceeded of the instance.
I am currently asking for a reset/upgrade of the limit, so the instance should be back online shortly.
Traffic usage is tracked at all times, but was never enforced, since most people behaved nicely.
A Patch will follow shortly to address this issue.
Just wanted to give a try to one of these NAT LXC instances...... but it fell here: Your request got rejected for the following reason: Lowendspirit account not found
Tried with lowercase only, same result!
Someone could help?
Someone could help?
Someone could help?
Sorry for the Delay, this should now be fixed, please try again.
Regarding the container issues with LXC, so far KVM support has been added and works well.
The Plan would be, to switch all Locations to KVM in the longrun.
The new NL Location is already ready and will be Online this week, the Packages will be KVM only.
Hong Kong should be available by next week, same here, KVM only, still waiting for IPv6 allocation.
The other locations will follow.
VNC is not added yet, will be added as soon I get it working.
Packages on Norway have been switched to KVM, except the Storage Package.
Devuan is not available currently for KVM Packages, its disabled on the Reinstall Menu however, not yet disabled if you make a new Deployment.
Which will result in a Deployment error if you still choose it.
Is it possible to migrate current norway lxc to kvm?
Nvm i just backed up, terminated and re-made instance
Groningen (NL) is now Available, Dronten (NL) has been disabled for new Deployments, it will be terminated in the next months.
Please move your Instance in the next weeks to a different Location.
Patch Notes
KVM Packages have been deployed in MB instead of MiB, which resulted in less Memory allocation as they should get.
Fixed.
Network Stats did not work for KVM Instances.
Fixed.
No, I forgot it, sorry.
IPv6 died on SG partially (Virtualizor), reboot fixed it.
e007-7944-14b5-9db8
Maintenance Announcement
76af-c46d-2f05-c98a
I didn't know microLXC has dedicated servers now.
HostBrr aff best VPS.
Copy & Paste, the only dedi microLXC has is Norway.
1105-9e88-4c22-9710
Syuh - sftp, rsync & rclone accessible storage from 50GB to TBs.
Maintenance should be done.
Thank you.
Why?
I am aware of the current outage in South Africa, waiting for Ticket reply.
Wow, that's truly a nice offer
JP is back online, sadly it took them 24 hours ish to reply to the Ticket.
Someone could help?
Must be a bug in the LES Plugin, will check.
Thanks again @Neoon, and here we are: 23d7-c418-79f0-2e8a
No, Termination is the way to go.
Thanks to Bakker IT for providing this Location.
Patch Notes
Fixed.
Fixed.
Anything else I should do?
Follow the instructions, if you close the browser window just to post the code here, the system will mark your request as incomplete and delete it.
You expect folks to read the instructions? I mean.. READ??
Squats are the new Push-ups
