Post some YABS bench here
16465676970120
    @ooopooo said:
    @ooopooo said:
    deinserverhost root server 17.4 euro
    #                     v2022-06-11                    #
    Fr 8. Jul 04:37:03 CEST 2022
    Uptime     : 0 days, 17 hours, 32 minutes
    Processor  : Common KVM processor
    CPU cores  : 8 @ 2849.998 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 15.6 GiB
    Swap       : 768.0 MiB
    Disk       : 196.8 GiB
    Kernel     : 5.10.0-15-amd64
    Read       | 84.60 MB/s   (21.1k) | 733.39 MB/s  (11.4k)
    Write      | 84.82 MB/s   (21.2k) | 737.25 MB/s  (11.5k)
    Total      | 169.43 MB/s  (42.3k) | 1.47 GB/s    (22.9k)
    Read       | 772.06 MB/s   (1.5k) | 707.41 MB/s    (690)
    Write      | 813.08 MB/s   (1.5k) | 754.52 MB/s    (736)
    Total      | 1.58 GB/s     (3.0k) | 1.46 GB/s     (1.4k)
    Clouvider       | London, UK (10G)          | 2.01 Gbits/sec  | 1.57 Gbits/sec
    Online.net      | Paris, FR (10G)           | 1.67 Gbits/sec  | busy
    Hybula          | The Netherlands (40G)     | 1.63 Gbits/sec  | 699 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 742 Mbits/sec   | 1.38 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 420 Mbits/sec   | 857 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 189 Mbits/sec   | 430 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 251 Mbits/sec   | 676 Mbits/sec
    #                     v2022-06-11                    #
    RAM        : 15.6 GiB
    Swap       : 768.0 MiB
    Disk       : 196.8 GiB
    ran geekbench 5 separately
    https://browser.geekbench.com/v5/cpu/15886709
    Holy shit that CPU steal is high af
    Contact me at: +1 (347) 518-1661 or [email protected]
  • edited July 2022
    @ralf said:
    @ofit said:
    Hello @ralf, can you please test wireguard and openvpn performance (speed) on pfsense and openwrt in promox on your new box n5105 please. Thanks
    I do have a wireguard proxy set up to another VM at OVH which seems to be working well, but not much use for a test as OVH is capped at 100Mbps.
    So, initial tests using that (as it was already set up) seem pretty good for up to 100Mbps.
    My direct setup is:
    (unecrypted) laptop -> wifi -> 192.168.1.1 (pfsense) -> WAN -> internet -> gra.proof.ovh.net
    My test set up using the tunnel is:
    (unecrypted) laptop -> wifi -> 192.168.1.1 (pfsense) -> 192.168.3.2 (wireguard VM)
    (encrypted) -> 192.168.3.1 (pfSense) -> WAN -> network -> vm on KS-LE-1
    (unencrypted)  -> masquerade -> KS-LE-1 -> masquerade -> gra.proof.ovh.net
    Doing a direct test first shows the wifi doesn't really limit bandwidth:
    % iperf3 -P 10 -p 5201-5209 -c gra.proof.ovh.net |tee gra.direct.1.txt
    % iperf3 -P 10 -p 5201-5209 -c gra.proof.ovh.net -R |tee gra.direct.1r.txt
    % grep SUM *direct* |grep 'er'
    gra.direct.1.txt:[SUM]   0.00-10.00  sec   606 MBytes   508 Mbits/sec                  sender
    gra.direct.1.txt:[SUM]   0.00-10.04  sec   599 MBytes   501 Mbits/sec                  receiver
    gra.direct.1r.txt:[SUM]   0.00-10.03  sec   653 MBytes   546 Mbits/sec  725             sender
    gra.direct.1r.txt:[SUM]   0.00-10.00  sec   626 MBytes   525 Mbits/sec                  receiver
    And multiple runs via the tunnel pretty much hit my usual speeds with OVH:
    % iperf3 -P 10 -p 5201-5209 -c gra.proof.ovh.net |tee gra.wg.3.txt
    % iperf3 -P 10 -p 5201-5209 -c gra.proof.ovh.net -R |tee gra.wg.3r.txt
    % grep SUM *wg* |grep 'er'
    gra.wg.1.txt:[SUM]   0.00-10.00  sec  95.2 MBytes  79.8 Mbits/sec                  sender
    gra.wg.1.txt:[SUM]   0.00-10.03  sec  94.0 MBytes  78.6 Mbits/sec                  receiver
    gra.wg.1r.txt:[SUM]   0.00-10.04  sec  95.1 MBytes  79.5 Mbits/sec  526             sender
    gra.wg.1r.txt:[SUM]   0.00-10.00  sec  93.4 MBytes  78.3 Mbits/sec                  receiver
    gra.wg.2.txt:[SUM]   0.00-10.00  sec   108 MBytes  90.6 Mbits/sec                  sender
    gra.wg.2.txt:[SUM]   0.00-10.04  sec   107 MBytes  89.6 Mbits/sec                  receiver
    gra.wg.2r.txt:[SUM]   0.00-10.04  sec  81.0 MBytes  67.7 Mbits/sec  496             sender
    gra.wg.2r.txt:[SUM]   0.00-10.00  sec  78.2 MBytes  65.6 Mbits/sec                  receiver
    gra.wg.3.txt:[SUM]   0.00-10.00  sec   107 MBytes  90.0 Mbits/sec                  sender
    gra.wg.3.txt:[SUM]   0.00-10.03  sec   107 MBytes  89.0 Mbits/sec                  receiver
    gra.wg.3r.txt:[SUM]   0.00-10.04  sec  81.5 MBytes  68.1 Mbits/sec  504             sender
    gra.wg.3r.txt:[SUM]   0.00-10.00  sec  78.8 MBytes  66.1 Mbits/sec                  receiver
    I guess -R is slower because the ports on KS-LE-1 are 100 up, 1000 down.
    CPU on proxmox hit about 6.5% on the first test and about 7.5% on the second, so not much impact. From the graph that shows all cores, running top -t 0.25 shows CPU getting up to about 30% (max 400%)
    For comparison, iperf direct from the KS-LE-1:
    gra.ksle1.1.txt:[SUM]   0.00-10.00  sec   116 MBytes  97.2 Mbits/sec  7261             sender
    gra.ksle1.1.txt:[SUM]   0.00-10.01  sec   114 MBytes  95.5 Mbits/sec                  receiver
    gra.ksle1.1r.txt:[SUM]   0.00-10.01  sec  1.08 GBytes   928 Mbits/sec  14333             sender
    gra.ksle1.1r.txt:[SUM]   0.00-10.00  sec  1.08 GBytes   926 Mbits/sec                  receiver
  • Just fresh Delivered
    10€/y Miami W24
    #                     v2022-06-11                    #
    Sat Jul  9 09:03:28 EDT 2022
    Uptime     : 0 days, 0 hours, 0 minutes
    CPU cores  : 1 @ 3393.624 MHz
    RAM        : 976.4 MiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Kernel     : 5.10.0-16-amd64
    Read       | 383.30 MB/s  (95.8k) | 1.80 GB/s    (28.1k)
    Write      | 384.31 MB/s  (96.0k) | 1.81 GB/s    (28.2k)
    Total      | 767.62 MB/s (191.9k) | 3.61 GB/s    (56.4k)
    Read       | 1.82 GB/s     (3.5k) | 1.78 GB/s     (1.7k)
    Write      | 1.92 GB/s     (3.7k) | 1.90 GB/s     (1.8k)
    Total      | 3.75 GB/s     (7.3k) | 3.68 GB/s     (3.5k)
    Clouvider       | London, UK (10G)          | 118 Mbits/sec   | 187 Mbits/sec
    Online.net      | Paris, FR (10G)           | 327 Mbits/sec   | 369 Mbits/sec
    Hybula          | The Netherlands (40G)     | 199 Mbits/sec   | 748 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 29.8 Mbits/sec  | 298 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 650 Mbits/sec   | 947 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 110 Mbits/sec   | 247 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 272 Mbits/sec   | 913 Mbits/sec
    Clouvider       | London, UK (10G)          | 347 Mbits/sec   | 752 Mbits/sec
    Online.net      | Paris, FR (10G)           | 159 Mbits/sec   | 197 Mbits/sec
    Hybula          | The Netherlands (40G)     | 192 Mbits/sec   | 744 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | busy
    Clouvider       | NYC, NY, US (10G)         | 735 Mbits/sec   | 921 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 425 Mbits/sec   | 921 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 331 Mbits/sec   | 707 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 1469
    Multi Core      | 1450
    Full Test       | https://browser.geekbench.com/v5/cpu/15912630
  • AdvinAdvin Hosting Provider
    edited July 2022
    Steam Deck 256GB NVMe (not plugged in)
    #                     v2022-06-11                    #
    Mon Jul 11 02:19:08 AM EDT 2022
    Uptime     : 14 days, 13 hours, 24 minutes
    Processor  : AMD Custom APU 0405
    CPU cores  : 8 @ 1700.000 MHz
    RAM        : 14.5 GiB
    Swap       : 1024.0 MiB
    Disk       : 232.0 GiB
    Distro     : SteamOS
    Kernel     : 5.13.0-valve15-1-neptune-02197-gf6ec7ad3762a
    Read       | 136.12 MB/s  (34.0k) | 209.60 MB/s   (3.2k)
    Write      | 136.48 MB/s  (34.1k) | 210.70 MB/s   (3.2k)
    Total      | 272.60 MB/s  (68.1k) | 420.31 MB/s   (6.5k)
    Read       | 122.18 MB/s    (238) | 64.87 MB/s      (63)
    Write      | 128.68 MB/s    (251) | 69.26 MB/s      (67)
    Total      | 250.87 MB/s    (489) | 134.13 MB/s    (130)
    Clouvider       | London, UK (10G)          | 39.2 Mbits/sec  | 85.0 Mbits/sec
    Online.net      | Paris, FR (10G)           | 36.9 Mbits/sec  | 82.3 Mbits/sec
    Hybula          | The Netherlands (40G)     | 39.6 Mbits/sec  | 83.5 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 37.6 Mbits/sec  | 39.6 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 41.1 Mbits/sec  | 84.7 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 35.4 Mbits/sec  | 28.0 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 40.2 Mbits/sec  | 82.1 Mbits/sec
    Clouvider       | London, UK (10G)          | 39.0 Mbits/sec  | 54.4 Mbits/sec
    Online.net      | Paris, FR (10G)           | 38.6 Mbits/sec  | busy
    Hybula          | The Netherlands (40G)     | 33.5 Mbits/sec  | 87.6 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 32.3 Mbits/sec  | 74.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 36.9 Mbits/sec  | 83.9 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 40.1 Mbits/sec  | 86.3 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 40.0 Mbits/sec  | 83.4 Mbits/sec
    Single Core     | 821
    Multi Core      | 3819
    Full Test       | https://browser.geekbench.com/v5/cpu/15943815
    edited July 2022
    Steam Deck 256GB NVMe (plugged in)
    Uptime     : 0 days, 0 hours, 3 minutes
    CPU cores  : 8 @ 2800.000 MHz
    RAM        : 14.5 GiB
    Swap       : 1024.0 MiB
    Disk       : 232.1 GiB
    Distro     : SteamOS
    Read       | 132.74 MB/s  (33.1k) | 214.68 MB/s   (3.3k)
    Write      | 133.09 MB/s  (33.2k) | 215.81 MB/s   (3.3k)
    Total      | 265.84 MB/s  (66.4k) | 430.49 MB/s   (6.7k)
    Read       | 287.77 MB/s    (562) | 318.51 MB/s    (311)
    Write      | 303.06 MB/s    (591) | 339.72 MB/s    (331)
    Total      | 590.83 MB/s   (1.1k) | 658.23 MB/s    (642)
    Clouvider       | London, UK (10G)          | 39.9 Mbits/sec  | 39.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 31.8 Mbits/sec  | 46.3 Mbits/sec
    Hybula          | The Netherlands (40G)     | 38.1 Mbits/sec  | 119 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 38.7 Mbits/sec  | 97.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 41.5 Mbits/sec  | 140 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 28.3 Mbits/sec  | 126 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 40.2 Mbits/sec  | 109 Mbits/sec
    Clouvider       | London, UK (10G)          | 38.3 Mbits/sec  | 87.6 Mbits/sec
    Online.net      | Paris, FR (10G)           | 38.4 Mbits/sec  | 56.6 Mbits/sec
    Hybula          | The Netherlands (40G)     | 37.7 Mbits/sec  | 90.1 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 30.0 Mbits/sec  | 52.0 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 40.9 Mbits/sec  | 83.7 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 39.3 Mbits/sec  | 82.9 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 39.9 Mbits/sec  | 83.0 Mbits/sec
    Single Core     | 829
    Multi Core      | 3789
    Full Test       | https://browser.geekbench.com/v5/cpu/15944316****
  • NeoonNeoon OG
    edited July 2022
    Aliababa Cloud Offer 2GB KVM for 2.50$ 6Mbit Cap, 1.5TB Hong Kong
    #                     v2022-06-11                    #
    Tue Jul 12 08:57:30 CST 2022
    Processor  : Intel(R) Xeon(R) Platinum 8269CY CPU @ 2.50GHz
    CPU cores  : 1 @ 2500.002 MHz
    RAM        : 1.9 GiB
    Swap       : 0.0 KiB
    Disk       : 39.2 GiB
    Distro     : Debian GNU/Linux 10 (buster)
    Kernel     : 4.19.0-10-amd64
    Read       | 6.27 MB/s     (1.5k) | 74.27 MB/s    (1.1k)
    Write      | 6.27 MB/s     (1.5k) | 74.67 MB/s    (1.1k)
    Total      | 12.55 MB/s    (3.1k) | 148.94 MB/s   (2.3k)
    Read       | 71.66 MB/s     (139) | 71.25 MB/s      (69)
    Write      | 75.47 MB/s     (147) | 76.00 MB/s      (74)
    Total      | 147.14 MB/s    (286) | 147.25 MB/s    (143)
    Clouvider       | London, UK (10G)          | 7.15 Mbits/sec  | 10.9 Mbits/sec
    Online.net      | Paris, FR (10G)           | 7.05 Mbits/sec  | 9.40 Mbits/sec
    Hybula          | The Netherlands (40G)     | 7.17 Mbits/sec  | 8.77 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 7.18 Mbits/sec  | 8.80 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 7.23 Mbits/sec  | 10.7 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 7.07 Mbits/sec  | 9.36 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 7.27 Mbits/sec  | 10.8 Mbits/sec
    Single Core     | 730
    Multi Core      | 699
    Full Test       | https://browser.geekbench.com/v5/cpu/15959515
    Thanked by (1)ralf
  • 15$/y AMS GreenCloud from 4th April Sale, still in Stock.
    root@GreenCloud:~# curl -sL yabs.sh | bash
    #                     v2022-06-11                    #
    Tue Jul 12 16:49:35 EDT 2022
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz
    CPU cores  : 1 @ 2594.400 MHz
    RAM        : 1.9 GiB
    Swap       : 1024.0 MiB
    Disk       : 18.6 GiB
    Read       | 202.74 MB/s  (50.6k) | 571.02 MB/s   (8.9k)
    Write      | 203.28 MB/s  (50.8k) | 574.02 MB/s   (8.9k)
    Total      | 406.03 MB/s (101.5k) | 1.14 GB/s    (17.8k)
    Read       | 553.77 MB/s   (1.0k) | 581.03 MB/s    (567)
    Write      | 583.19 MB/s   (1.1k) | 619.73 MB/s    (605)
    Total      | 1.13 GB/s     (2.2k) | 1.20 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 2.43 Gbits/sec  | 4.10 Gbits/sec
    Online.net      | Paris, FR (10G)           | 7.80 Gbits/sec  | 8.84 Gbits/sec
    Hybula          | The Netherlands (40G)     | 9.08 Gbits/sec  | 8.14 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.80 Gbits/sec  | 2.44 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.61 Gbits/sec  | 1.42 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 306 Mbits/sec   | 673 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.01 Gbits/sec  | 1.22 Gbits/sec
    Single Core     | 763
    Multi Core      | 759
    Full Test       | https://browser.geekbench.com/v5/cpu/15976820
  • OneProvider.com
    Product/Service: Dedicated Server +
    Server location: Paris - FR
    HARDWARE SPECIFICATIONS:
    CPU: Intel Xeon E3-1220 v2 or better - 3.1 GHz - 4 core(s)
    RAM: 32GB - DDR3
    Hard Drive(s): 2x 1TB (SSD SATA)
    Bandwidth: Unmetered @ 1Gbps (1 Gbps Guaranteed)
    Price: €24.99 / 1 month
    I got 2x SA530 3D NAND SATA SSD drives from Western Digital with Power On Hours: 120 , Intel Xeon E3-1230 V2 CPU and Dell Multi-bit ECC 4x 8GiB bus 1600 MT/s RAM.
    Yabs is here:
    root@dtt:/home/ubuntu# curl -sL yabs.sh | bash
    #                     v2022-06-11                    #
    Wed 13 Jul 2022 12:50:01 AM UTC
    Uptime     : 0 days, 0 hours, 53 minutes
    Processor  : Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
    CPU cores  : 8 @ 1801.250 MHz
    RAM        : 31.3 GiB
    Swap       : 9.0 GiB
    Disk       : 915.2 GiB
    Distro     : Ubuntu 20.04.4 LTS
    Kernel     : 5.4.0-122-generic
    Read       | 89.54 MB/s   (22.3k) | 162.19 MB/s   (2.5k)
    Write      | 89.77 MB/s   (22.4k) | 163.04 MB/s   (2.5k)
    Total      | 179.32 MB/s  (44.8k) | 325.24 MB/s   (5.0k)
    Read       | 146.07 MB/s    (285) | 146.58 MB/s    (143)
    Write      | 153.83 MB/s    (300) | 156.34 MB/s    (152)
    Total      | 299.91 MB/s    (585) | 302.92 MB/s    (295)
    Clouvider       | London, UK (10G)          | 938 Mbits/sec   | 939 Mbits/sec
    Online.net      | Paris, FR (10G)           | 942 Mbits/sec   | 941 Mbits/sec
    Hybula          | The Netherlands (40G)     | 937 Mbits/sec   | 938 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 850 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 895 Mbits/sec   | 891 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 572 Mbits/sec   | 625 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 844 Mbits/sec   | 857 Mbits/sec
    Clouvider       | London, UK (10G)          | 926 Mbits/sec   | 927 Mbits/sec
    Online.net      | Paris, FR (10G)           | 929 Mbits/sec   | 928 Mbits/sec
    Hybula          | The Netherlands (40G)     | busy            | busy
    Uztelecom       | Tashkent, UZ (10G)        | 876 Mbits/sec   | 850 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 877 Mbits/sec   | 884 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 856 Mbits/sec   | 851 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 840 Mbits/sec   | 850 Mbits/sec
    Single Core     | 854
    Multi Core      | 3312
    Full Test       | https://browser.geekbench.com/v5/cpu/15979276
    Thanked by (2)cybertech chimichurri
    https://dttech.net - Personal Site.
  • edited July 2022
    Hetzner CPX21
    Thu Jul 14 05:31:20 AM UTC 2022
    Processor : AMD EPYC Processor
    CPU cores : 3 @ 2445.406 MHz
    AES-NI : ✔ Enabled
    RAM : 3.7 GiB
    Swap : 0.0 KiB
    Disk : 75.1 GiB
    Distro : Ubuntu 22.04 LTS
    Kernel : 5.15.0-40-generic
    Read 144.65 MB/s (36.1k) 1.45 GB/s (22.7k)
    Write 145.03 MB/s (36.2k) 1.46 GB/s (22.8k)
    Total 289.68 MB/s (72.4k) 2.91 GB/s (45.5k)
    Read 2.44 GB/s (4.7k) 2.85 GB/s (2.7k)
    Write 2.57 GB/s (5.0k) 3.04 GB/s (2.9k)
    Total 5.02 GB/s (9.8k) 5.89 GB/s (5.7k)
    Test | Value
    Single Core | 909
    Multi Core | 2580
    Full Test | https://browser.geekbench.com/v5/cpu/16001884
  • Oracle Cloud Ashburn, Virginia
    #                     v2022-06-11                    #
    Thu Jul 14 16:18:41 UTC 2022
    Processor  : Neoverse-N1
    CPU cores  : 4 @ ??? MHz
    RAM        : 23.4 GiB
    Swap       : 0.0 KiB
    Disk       : 101.7 GiB
    Kernel     : 5.15.0-1013-oracle
    Read       | 13.11 MB/s    (3.2k) | 26.88 MB/s     (420)
    Write      | 13.11 MB/s    (3.2k) | 27.68 MB/s     (432)
    Total      | 26.23 MB/s    (6.5k) | 54.56 MB/s     (852)
    Read       | 24.43 MB/s      (47) | 24.12 MB/s      (23)
    Write      | 26.52 MB/s      (51) | 26.91 MB/s      (26)
    Total      | 50.96 MB/s      (98) | 51.03 MB/s      (49)
    Clouvider       | London, UK (10G)          | 675 Mbits/sec   | 702 Mbits/sec
    Online.net      | Paris, FR (10G)           | 435 Mbits/sec   | 832 Mbits/sec
    Hybula          | The Netherlands (40G)     | 857 Mbits/sec   | busy
    Uztelecom       | Tashkent, UZ (10G)        | 627 Mbits/sec   | 326 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 3.40 Gbits/sec  | 3.17 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 493 Mbits/sec   | 318 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.21 Gbits/sec  | 766 Mbits/sec
    Single Core     | 853
    Multi Core      | 3296
    Full Test       | https://browser.geekbench.com/v5/cpu/16011718
    Thanked by (1)cybertech
  • edited July 2022
    Apologies for not adding more info. I did a similar proxy to a US VPS with Racknerd in LA and run iperf directly on that machine. I was getting about 300Mbps direct but for some reason the forwarding to a VM that did wireguard and forwarded on to the RN machine seemed to top out at about 130Mbps. Not sure why yet why it was much lower throughput than unwrapped, as CPU usage seemed pretty low everywhere.
  • edited July 2022
    FiberVM - Linux Cloud VPS S - Singapore
    #                     v2022-06-11                    #
    Fri Jul 15 16:03:06 UTC 2022
    Uptime     : 0 days, 0 hours, 19 minutes
    Processor  : Intel(R) Xeon(R) E-2236 CPU @ 3.40GHz
    CPU cores  : 4 @ 3400.000 MHz
    RAM        : 8.0 GiB
    Swap       : 2.0 GiB
    Disk       : 62.4 GiB
    Kernel     : 5.15.35-1-pve
    Read       | 766.61 MB/s (191.6k) | 2.46 GB/s    (38.5k)
    Write      | 768.63 MB/s (192.1k) | 2.48 GB/s    (38.7k)
    Total      | 1.53 GB/s   (383.8k) | 4.95 GB/s    (77.3k)
    Read       | 2.49 GB/s     (4.8k) | 2.49 GB/s     (2.4k)
    Write      | 2.62 GB/s     (5.1k) | 2.66 GB/s     (2.6k)
    Total      | 5.12 GB/s    (10.0k) | 5.15 GB/s     (5.0k)
    Clouvider       | London, UK (10G)          | 670 Mbits/sec   | 343 Mbits/sec
    Online.net      | Paris, FR (10G)           | 711 Mbits/sec   | 253 Mbits/sec
    Hybula          | The Netherlands (40G)     | 826 Mbits/sec   | busy
    Uztelecom       | Tashkent, UZ (10G)        | 659 Mbits/sec   | 668 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | busy            | 636 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | busy            | 326 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 812 Mbits/sec   | 497 Mbits/sec
    Clouvider       | London, UK (10G)          | busy            | 136 Mbits/sec
    Online.net      | Paris, FR (10G)           | 745 Mbits/sec   | 453 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 635 Mbits/sec   | 620 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | busy            | 184 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | busy            | 474 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | busy            | 306 Mbits/sec
    Single Core     | 1171
    Multi Core      | 3814
    Full Test       | https://browser.geekbench.com/v5/cpu/16030676
    Thanked by (2)CloudV cybertech
  • edited July 2022
    Virmach $6/yr plan from 2017 that was migrated (Dallas):
    #                     v2022-06-11                    #
    Fri Jul 15 13:42:00 EDT 2022
    Uptime     : 0 days, 3 hours, 59 minutes
    CPU cores  : 2 @ 3493.436 MHz
    RAM        : 460.4 MiB
    Swap       : 32.0 MiB
    Disk       : 4.8 GiB
    Distro     : CentOS Stream 8
    Kernel     : 4.18.0-394.el8.x86_64
    Read       | 273.13 MB/s  (68.2k) | 141.43 MB/s   (2.2k)
    Write      | 273.85 MB/s  (68.4k) | 142.17 MB/s   (2.2k)
    Total      | 546.98 MB/s (136.7k) | 283.60 MB/s   (4.4k)
    Read       | 699.85 MB/s   (1.3k) | 841.44 MB/s    (821)
    Write      | 737.04 MB/s   (1.4k) | 897.48 MB/s    (876)
    Total      | 1.43 GB/s     (2.8k) | 1.73 GB/s     (1.6k)
    Clouvider       | London, UK (10G)          | 794 Mbits/sec   | 181 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 201 Mbits/sec
    Hybula          | The Netherlands (40G)     | 757 Mbits/sec   | 677 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 495 Mbits/sec   | 178 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 866 Mbits/sec   | 220 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 798 Mbits/sec   | 177 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 781 Mbits/sec   | 296 Mbits/sec
    Virmach $6/yr plan from 2017 that was migrated (New York):
    #                     v2022-06-11                    #
    Fri 15 Jul 2022 01:44:13 PM EDT
    Uptime     : 2 days, 45 hours, 0 minutes
    Processor  : AMD EPYC-Rome Processor
    CPU cores  : 2 @ 3799.998 MHz
    RAM        : 472.9 MiB
    Swap       : 32.0 MiB
    Disk       : 4.8 GiB
    Kernel     : 5.10.0-8-amd64
    Read       | 95.32 MB/s   (23.8k) | 330.85 MB/s   (5.1k)
    Write      | 95.58 MB/s   (23.8k) | 332.59 MB/s   (5.1k)
    Total      | 190.91 MB/s  (47.7k) | 663.44 MB/s  (10.3k)
    Read       | 397.13 MB/s    (775) | 807.30 MB/s    (788)
    Write      | 418.23 MB/s    (816) | 861.07 MB/s    (840)
    Total      | 815.37 MB/s   (1.5k) | 1.66 GB/s     (1.6k)
    Clouvider       | London, UK (10G)          | 596 Mbits/sec   | 73.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 526 Mbits/sec   | 106 Mbits/sec
    Hybula          | The Netherlands (40G)     | 758 Mbits/sec   | 571 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 696 Mbits/sec   | 76.1 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 862 Mbits/sec   | 486 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 697 Mbits/sec   | 24.1 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 694 Mbits/sec   | 89.3 Mbits/sec
  • vyasvyas OG
    edited July 2022
    New / sub brand of Cloud V?
    #                     v2022-06-11                    #
    RAM        : 8.0 GiB
    Swap       : 2.0 GiB
    Disk       : 62.4 GiB
    Single Core     | 1171
    Multi Core      | 3814
    Squats are the new Push-ups
  • Was able to access my Hostcram VPS after a long time (long story, too). So, posting a YABS - 6 months later.
    Sun Jul 17 00:14:15 UTC 2022
    Uptime     : 17 days, 12 hours, 26 minutes
    Processor  : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz
    CPU cores  : 1 @ 3500.000 MHz
    RAM        : 1.0 GiB
    Swap       : 1.5 GiB
    Disk       : 9.7 GiB
    Distro     : Ubuntu 18.04.6 LTS
    Kernel     : 5.13.19-6-pve
    Read       | 1.25 GB/s   (313.7k) | 3.01 GB/s    (47.1k)
    Write      | 1.25 GB/s   (314.5k) | 3.03 GB/s    (47.4k)
    Total      | 2.51 GB/s   (628.2k) | 6.05 GB/s    (94.5k)
    Read       | 2.61 GB/s     (5.1k) | 1.25 MB/s        (1)
    Write      | 2.75 GB/s     (5.3k) | 1.58 MB/s        (1)
    Total      | 5.37 GB/s    (10.4k) | 2.84 MB/s        (2)
    Clouvider       | London, UK (10G)          | 86.6 Mbits/sec  | 71.6 Mbits/sec
    Online.net      | Paris, FR (10G)           | 85.6 Mbits/sec  | 69.6 Mbits/sec
    Hybula          | The Netherlands (40G)     | 86.6 Mbits/sec  | 85.8 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 82.5 Mbits/sec  | 53.7 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 89.4 Mbits/sec  | 85.6 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 85.8 Mbits/sec  | 63.6 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 89.6 Mbits/sec  | 86.8 Mbits/sec
    Geekbench 4 Benchmark Test:
    Single Core     | 6803
    Multi Core      | 6836
    Full Test       | https://browser.geekbench.com/v4/cpu/16586715
    Single Core     | 1590
    Multi Core      | 1561
    Full Test       | https://browser.geekbench.com/v5/cpu/16057115
    Thanked by (2)lapua Shakib
    > Basic System Information:
    > AES-NI     : ✔ Enabled
    > VM-x/AMD-V : ✔ Enabled
    > RAM        : 1.0 GiB
    > Swap       : 1.5 GiB
    > Disk       : 9.7 GiB
    > fio Disk Speed Tests (Mixed R/W 50/50):
    > Block Size | 4k            (IOPS) | 64k           (IOPS)
    > Block Size | 512k          (IOPS) | 1m            (IOPS)
    > iperf3 Network Speed Tests (IPv4):
    > Test            | Value
    > Single Core     | 6803
    > Multi Core      | 6836
    > Test            | Value
    > Single Core     | 1590
    > Multi Core      | 1561
    Hi @vyas ,
    Do you know why the Network speed is limited to less than 90 Mbits/sec?
    #                     v2022-06-11                    #
    Sun 17 Jul 2022 03:17:08 PM CEST
    Uptime     : 13 days, 7 hours, 18 minutes
    CPU cores  : 4 @ 3393.624 MHz
    RAM        : 7.8 GiB
    Swap       : 0.0 KiB
    Disk       : 155.5 GiB
    Kernel     : 5.18.4-xanmod1
    Read       | 468.01 MB/s (117.0k) | 2.12 GB/s    (33.2k)
    Write      | 469.25 MB/s (117.3k) | 2.13 GB/s    (33.4k)
    Total      | 937.27 MB/s (234.3k) | 4.26 GB/s    (66.6k)
    Read       | 2.24 GB/s     (4.3k) | 2.18 GB/s     (2.1k)
    Write      | 2.35 GB/s     (4.6k) | 2.32 GB/s     (2.2k)
    Total      | 4.59 GB/s     (8.9k) | 4.51 GB/s     (4.4k)
    Clouvider       | London, UK (10G)          | 2.93 Gbits/sec  | 4.02 Gbits/sec
    Online.net      | Paris, FR (10G)           | 6.16 Gbits/sec  | 6.05 Gbits/sec
    Hybula          | The Netherlands (40G)     | 6.73 Gbits/sec  | 5.59 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 4.67 Gbits/sec  | 851 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.78 Gbits/sec  | 1.40 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 479 Mbits/sec   | 458 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.10 Gbits/sec  | 1.05 Gbits/sec
    Clouvider       | London, UK (10G)          | 6.89 Gbits/sec  | 3.83 Gbits/sec
    Online.net      | Paris, FR (10G)           | 6.05 Gbits/sec  | 5.88 Gbits/sec
    Hybula          | The Netherlands (40G)     | 6.82 Gbits/sec  | 5.04 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 5.01 Gbits/sec  | 3.62 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 2.04 Gbits/sec  | 909 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 1.33 Gbits/sec  | 985 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 1.14 Gbits/sec  | 476 Mbits/sec
    Single Core     | 6063
    Multi Core      | 17497
    Full Test       | https://browser.geekbench.com/v4/cpu/16586996
    Single Core     | 1375
    Multi Core      | 3826
    Full Test       | https://browser.geekbench.com/v5/cpu/16067574
    edited July 2022
    virmach after fixing their network in tokyo
    root@cybertech:~# curl -sL yabs.sh | bash -s -- -4
    #                     v2022-06-11                    #
    Mon 18 Jul 2022 05:23:47 PM +08
    Uptime     : 0 days, 0 hours, 16 minutes
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 2 @ 3693.018 MHz
    RAM        : 2.4 GiB
    Swap       : 30.0 MiB
    Disk       : 49.9 GiB
    Kernel     : 5.18.0-2-amd64
    Read       | 314.14 MB/s  (78.5k) | 908.22 MB/s  (14.1k)
    Write      | 314.97 MB/s  (78.7k) | 913.00 MB/s  (14.2k)
    Total      | 629.11 MB/s (157.2k) | 1.82 GB/s    (28.4k)
    Read       | 1.22 GB/s     (2.3k) | 2.30 GB/s     (2.2k)
    Write      | 1.28 GB/s     (2.5k) | 2.45 GB/s     (2.4k)
    Total      | 2.50 GB/s     (4.8k) | 4.76 GB/s     (4.6k)
    Clouvider       | London, UK (10G)          | 499 Mbits/sec   | 142 Mbits/sec
    Online.net      | Paris, FR (10G)           | 611 Mbits/sec   | 162 Mbits/sec
    Hybula          | The Netherlands (40G)     | 626 Mbits/sec   | 491 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 689 Mbits/sec   | 150 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 586 Mbits/sec   | 137 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 506 Mbits/sec   | 84.9 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 695 Mbits/sec   | 129 Mbits/sec
    Single Core     | 5297
    Multi Core      | 9050
    Full Test       | https://browser.geekbench.com/v4/cpu/16587401
    Thanked by (2)henix chimichurri
  • edited July 2022
    iHostART VPS FluxNode
    #                     v2022-06-11                    #
    Tue 19 Jul 2022 02:53:01 AM CEST
    Processor  : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
    CPU cores  : 8 @ 2499.998 MHz
    RAM        : 7.9 GiB
    Swap       : 1016.0 KiB
    Disk       : 218.4 GiB
    Read       | 39.63 MB/s    (9.9k) | 461.32 MB/s   (7.2k)
    Write      | 39.72 MB/s    (9.9k) | 463.75 MB/s   (7.2k)
    Total      | 79.36 MB/s   (19.8k) | 925.07 MB/s  (14.4k)
    Read       | 666.30 MB/s   (1.3k) | 667.40 MB/s    (651)
    Write      | 701.70 MB/s   (1.3k) | 711.85 MB/s    (695)
    Total      | 1.36 GB/s     (2.6k) | 1.37 GB/s     (1.3k)
    Clouvider       | London, UK (10G)          | 675 Mbits/sec   | 854 Mbits/sec
    Online.net      | Paris, FR (10G)           | 628 Mbits/sec   | 708 Mbits/sec
    Hybula          | The Netherlands (40G)     | 700 Mbits/sec   | 838 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 565 Mbits/sec   | 693 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 553 Mbits/sec   | 617 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 221 Mbits/sec   | 304 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 464 Mbits/sec   | 525 Mbits/sec
    Single Core     | 601
    Multi Core      | 4014
    Full Test       | https://browser.geekbench.com/v5/cpu/16095841
    Thanked by (3)cybertech thagoat Abdullah
    HostBrr aff best VPS.
  • edited July 2022
    NexusBytes $16/y vps
    #                     v2022-06-11                    #
    Mon 18 Jul 2022 09:37:53 PM EDT
    Uptime     : 85 days, 10 hours, 18 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz
    CPU cores  : 1 @ 2095.146 MHz
    RAM        : 976.4 MiB
    Swap       : 0.0 KiB
    Disk       : 9.8 GiB
    Read       | 136.90 MB/s  (34.2k) | 1.74 GB/s    (27.2k)
    Write      | 137.26 MB/s  (34.3k) | 1.75 GB/s    (27.3k)
    Total      | 274.17 MB/s  (68.5k) | 3.49 GB/s    (54.6k)
    Read       | 2.18 GB/s     (4.2k) | 2.09 GB/s     (2.0k)
    Write      | 2.29 GB/s     (4.4k) | 2.23 GB/s     (2.1k)
    Total      | 4.47 GB/s     (8.7k) | 4.33 GB/s     (4.2k)
    Clouvider       | London, UK (10G)          | 987 Mbits/sec   | 953 Mbits/sec
    Online.net      | Paris, FR (10G)           | 956 Mbits/sec   | 949 Mbits/sec
    Hybula          | The Netherlands (40G)     | 996 Mbits/sec   | 954 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 377 Mbits/sec   | 861 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 456 Mbits/sec   | 900 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 97.1 Mbits/sec  | 101 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 224 Mbits/sec   | 584 Mbits/sec
  • virtono KVM1G - 2.5 e
    #                     v2022-06-11                    #
    Mon 18 Jul 2022 09:37:29 PM EDT
    Uptime     : 0 days, 23 hours, 20 minutes
    Processor  : Intel Xeon Processor (Skylake, IBRS)
    CPU cores  : 1 @ 2300.000 MHz
    RAM        : 976.4 MiB
    Swap       : 1023.0 MiB
    Disk       : 28.8 GiB
    Read       | 87.75 MB/s   (21.9k) | 310.10 MB/s   (4.8k)
    Write      | 87.98 MB/s   (21.9k) | 311.73 MB/s   (4.8k)
    Total      | 175.74 MB/s  (43.9k) | 621.83 MB/s   (9.7k)
    Read       | 296.11 MB/s    (578) | 292.31 MB/s    (285)
    Write      | 311.84 MB/s    (609) | 311.78 MB/s    (304)
    Total      | 607.95 MB/s   (1.1k) | 604.10 MB/s    (589)
    Clouvider       | London, UK (10G)          | 439 Mbits/sec   | 651 Mbits/sec
    Online.net      | Paris, FR (10G)           | 466 Mbits/sec   | 523 Mbits/sec
    Hybula          | The Netherlands (40G)     | 427 Mbits/sec   | 862 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 372 Mbits/sec   | 515 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 240 Mbits/sec   | 148 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 79.3 Mbits/sec  | 139 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 173 Mbits/sec   | 81.6 Mbits/sec
    Clouvider       | London, UK (10G)          | 562 Mbits/sec   | 512 Mbits/sec
    Online.net      | Paris, FR (10G)           | 472 Mbits/sec   | 523 Mbits/sec
    Hybula          | The Netherlands (40G)     | 511 Mbits/sec   | 869 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 369 Mbits/sec   | 592 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 287 Mbits/sec   | 370 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 169 Mbits/sec   | 131 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 303 Mbits/sec   | 347 Mbits/sec
    Single Core     | 562
    Multi Core      | 562
    Full Test       | https://browser.geekbench.com/v5/cpu/16096368
  • VirMach BF plan after ryzen migration to frankfurt
    #                     v2022-06-11                    #
    Mon Jul 18 21:38:21 EDT 2022
    Uptime     : 8 days, 12 hours, 5 minutes
    CPU cores  : 1 @ 3693.062 MHz
    RAM        : 2.6 GiB
    Swap       : 256.0 MiB
    Disk       : 34.2 GiB
    Distro     : AlmaLinux 8.6 (Sky Tiger)
    Kernel     : 4.18.0-372.13.1.el8_6.x86_64
    Read       | 290.96 MB/s  (72.7k) | 1.07 GB/s    (16.7k)
    Write      | 291.73 MB/s  (72.9k) | 1.07 GB/s    (16.8k)
    Total      | 582.70 MB/s (145.6k) | 2.15 GB/s    (33.6k)
    Read       | 2.40 GB/s     (4.7k) | 4.20 GB/s     (4.1k)
    Write      | 2.53 GB/s     (4.9k) | 4.48 GB/s     (4.3k)
    Total      | 4.94 GB/s     (9.6k) | 8.68 GB/s     (8.4k)
    Clouvider       | London, UK (10G)          | 929 Mbits/sec   | 933 Mbits/sec
    Online.net      | Paris, FR (10G)           | 929 Mbits/sec   | 906 Mbits/sec
    Hybula          | The Netherlands (40G)     | 933 Mbits/sec   | 938 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 868 Mbits/sec   | 751 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 866 Mbits/sec   | 751 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 452 Mbits/sec   | 254 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 757 Mbits/sec   | 544 Mbits/sec
    Clouvider       | London, UK (10G)          | 908 Mbits/sec   | 922 Mbits/sec
    Online.net      | Paris, FR (10G)           | 913 Mbits/sec   | 923 Mbits/sec
    Hybula          | The Netherlands (40G)     | 910 Mbits/sec   | 924 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 826 Mbits/sec   | 776 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 864 Mbits/sec   | 807 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 756 Mbits/sec   | 488 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 757 Mbits/sec   | 730 Mbits/sec
    Single Core     | 1151
    Multi Core      | 1173
    Full Test       | https://browser.geekbench.com/v5/cpu/16096355
  • server-factory epyc XS
    #                     v2022-06-11                    #
    Tue Jul 19 03:39:02 CEST 2022
    Uptime     : 5 days, 9 hours, 16 minutes
    Processor  : AMD EPYC 7702P 64-Core Processor
    CPU cores  : 1 @ 1999.999 MHz
    RAM        : 3.6 GiB
    Swap       : 0.0 KiB
    Disk       : 50.0 GiB
    Kernel     : 4.18.0-348.7.1.el8_5.x86_64
    Read       | 21.09 MB/s    (5.2k) | 338.39 MB/s   (5.2k)
    Write      | 21.11 MB/s    (5.2k) | 340.18 MB/s   (5.3k)
    Total      | 42.20 MB/s   (10.5k) | 678.57 MB/s  (10.6k)
    Read       | 1.37 GB/s     (2.6k) | 1.77 GB/s     (1.7k)
    Write      | 1.45 GB/s     (2.8k) | 1.89 GB/s     (1.8k)
    Total      | 2.82 GB/s     (5.5k) | 3.66 GB/s     (3.5k)
    Clouvider       | London, UK (10G)          | 1.03 Gbits/sec  | 950 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.02 Gbits/sec  | 807 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.04 Gbits/sec  | 994 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 427 Mbits/sec   | 646 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 280 Mbits/sec   | 812 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 119 Mbits/sec   | 436 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 315 Mbits/sec   | 813 Mbits/sec
    Clouvider       | London, UK (10G)          | 1.03 Gbits/sec  | 979 Mbits/sec
    Online.net      | Paris, FR (10G)           | 1.02 Gbits/sec  | 784 Mbits/sec
    Hybula          | The Netherlands (40G)     | 1.04 Gbits/sec  | 983 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 379 Mbits/sec   | 622 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 373 Mbits/sec   | 896 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 309 Mbits/sec   | 898 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 316 Mbits/sec   | 843 Mbits/sec
  • racknerd NY flash sale $6.79/y
    #                     v2022-06-11                    #
    Mon 18 Jul 2022 09:40:12 PM EDT
    Uptime     : 7 days, 11 hours, 10 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    CPU cores  : 1 @ 2799.998 MHz
    RAM        : 598.4 MiB
    Swap       : 640.0 MiB
    Disk       : 9.1 GiB
    Read       | 75.22 MB/s   (18.8k) | 489.73 MB/s   (7.6k)
    Write      | 75.42 MB/s   (18.8k) | 492.30 MB/s   (7.6k)
    Total      | 150.65 MB/s  (37.6k) | 982.04 MB/s  (15.3k)
    Read       | 714.29 MB/s   (1.3k) | 582.37 MB/s    (568)
    Write      | 752.24 MB/s   (1.4k) | 621.15 MB/s    (606)
    Total      | 1.46 GB/s     (2.8k) | 1.20 GB/s     (1.1k)
    Clouvider       | London, UK (10G)          | 781 Mbits/sec   | 336 Mbits/sec
    Online.net      | Paris, FR (10G)           | 551 Mbits/sec   | 243 Mbits/sec
    Hybula          | The Netherlands (40G)     | 718 Mbits/sec   | 630 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 550 Mbits/sec   | 276 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 855 Mbits/sec   | 793 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 375 Mbits/sec   | 185 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 655 Mbits/sec   | 404 Mbits/sec
    Single Core     | 498
    Multi Core      | 499
    Full Test       | https://browser.geekbench.com/v5/cpu/16096369
    #                     v2022-06-11                    #
    RAM        : 8.0 GiB
    Swap       : 2.0 GiB
    Disk       : 62.4 GiB
    Single Core     | 1171
    Multi Core      | 3814
    IDK, the control panel is indeed Cloud V though
    Also note that the VPS doesn't allow TIOCSTI.
    Thanked by (1)vyas
  • GreenCloud LET 5555 RO
    Uptime     : 0 days, 0 hours, 2 minutes
    Processor  : Intel(R) Xeon(R) CPU E5-2698 v3 @ 2.30GHz
    CPU cores  : 5 @ 2299.996 MHz
    RAM        : 4.8 GiB
    Swap       : 2.0 GiB
    Disk       : 52.9 GiB
    Read       | 177.59 MB/s  (44.3k) | 1.29 GB/s    (20.2k)
    Write      | 178.06 MB/s  (44.5k) | 1.30 GB/s    (20.4k)
    Total      | 355.65 MB/s  (88.9k) | 2.60 GB/s    (40.7k)
    Read       | 1.19 GB/s     (2.3k) | 1.17 GB/s     (1.1k)
    Write      | 1.25 GB/s     (2.4k) | 1.25 GB/s     (1.2k)
    Total      | 2.44 GB/s     (4.7k) | 2.43 GB/s     (2.3k)
    Clouvider       | London, UK (10G)          | 856 Mbits/sec   | 2.16 Gbits/sec
    Online.net      | Paris, FR (10G)           | busy            | 4.41 Gbits/sec
    Hybula          | The Netherlands (40G)     | 6.37 Gbits/sec  | 5.18 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.94 Gbits/sec  | 1.61 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 1.26 Gbits/sec  | 1.62 Gbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 353 Mbits/sec   | 504 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 839 Mbits/sec   | busy
    Single Core     | 575
    Multi Core      | 2687
    Full Test       | https://browser.geekbench.com/v5/cpu/16124595
  • Brazil, G-Core
    #                     v2022-06-11                    #
    Thu Jul 21 21:41:24 UTC 2022
    CPU cores  : 1 @ 2394.374 MHz
    AES-NI     : ❌ Disabled
    RAM        : 483.3 MiB
    Swap       : 0.0 KiB
    Disk       : 19.6 GiB
    Kernel     : 4.19.0-5-amd64
    Read       | 265.75 MB/s  (66.4k) | 1.92 GB/s    (30.0k)
    Write      | 266.45 MB/s  (66.6k) | 1.93 GB/s    (30.2k)
    Total      | 532.20 MB/s (133.0k) | 3.86 GB/s    (60.3k)
    Read       | 1.96 GB/s     (3.8k) | 2.02 GB/s     (1.9k)
    Write      | 2.07 GB/s     (4.0k) | 2.16 GB/s     (2.1k)
    Total      | 4.04 GB/s     (7.8k) | 4.18 GB/s     (4.0k)
    Clouvider       | London, UK (10G)          | 98.5 Mbits/sec  | 92.0 Mbits/sec
    Online.net      | Paris, FR (10G)           | 104 Mbits/sec   | 91.2 Mbits/sec
    Hybula          | The Netherlands (40G)     | 103 Mbits/sec   | 91.1 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 98.7 Mbits/sec  | busy
    Clouvider       | NYC, NY, US (10G)         | 107 Mbits/sec   | 95.9 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 98.8 Mbits/sec  | 63.6 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 106 Mbits/sec   | 91.0 Mbits/sec
    Clouvider       | London, UK (10G)          | 104 Mbits/sec   | 91.7 Mbits/sec
    Online.net      | Paris, FR (10G)           | 105 Mbits/sec   | 90.9 Mbits/sec
    Hybula          | The Netherlands (40G)     | 103 Mbits/sec   | 88.9 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 98.4 Mbits/sec  | 76.4 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 108 Mbits/sec   | 94.8 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 106 Mbits/sec   | 94.2 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 105 Mbits/sec   | 92.6 Mbits/sec
  • Hosthatch - Singapore - 32gb VPS
    #                     v2022-06-11                    #
    Fri Jul 22 10:21:33 UTC 2022
    Uptime     : 0 days, 0 hours, 7 minutes
    Processor  : AMD EPYC 7443 24-Core Processor
    CPU cores  : 8 @ 2844.652 MHz
    RAM        : 31.4 GiB
    Swap       : 0.0 KiB
    Disk       : 112.7 GiB
    Kernel     : 5.15.0-1013-kvm
    Read       | 237.89 MB/s  (59.4k) | 2.79 GB/s    (43.6k)
    Write      | 238.51 MB/s  (59.6k) | 2.80 GB/s    (43.8k)
    Total      | 476.40 MB/s (119.1k) | 5.59 GB/s    (87.4k)
    Read       | 9.54 GB/s    (18.6k) | 9.90 GB/s     (9.6k)
    Write      | 10.05 GB/s   (19.6k) | 10.55 GB/s   (10.3k)
    Total      | 19.59 GB/s   (38.2k) | 20.46 GB/s   (19.9k)
    Clouvider       | London, UK (10G)          | 511 Mbits/sec   | 774 Mbits/sec
    Online.net      | Paris, FR (10G)           | 810 Mbits/sec   | 676 Mbits/sec
    Hybula          | The Netherlands (40G)     | 704 Mbits/sec   | 1.00 Gbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 1.18 Gbits/sec  | 1.15 Gbits/sec
    Clouvider       | NYC, NY, US (10G)         | 489 Mbits/sec   | 580 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | busy            | 378 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 502 Mbits/sec   | 579 Mbits/sec
    Clouvider       | London, UK (10G)          | 532 Mbits/sec   | 752 Mbits/sec
    Online.net      | Paris, FR (10G)           | 912 Mbits/sec   | 983 Mbits/sec
    Hybula          | The Netherlands (40G)     | 503 Mbits/sec   | 578 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | 504 Mbits/sec   | busy
    Clouvider       | NYC, NY, US (10G)         | 562 Mbits/sec   | 555 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 564 Mbits/sec   | 496 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 460 Mbits/sec   | 599 Mbits/sec
    Single Core     | 1083
    Multi Core      | 6499
    Full Test       | https://browser.geekbench.com/v5/cpu/16165754
    #                     v2022-06-11                    #
    RAM        : 31.4 GiB
    Swap       : 0.0 KiB
    Disk       : 112.7 GiB
    Single Core     | 1083
    Multi Core      | 6499
    How much do you pay for this?
  • vyasvyas OG
    edited July 2022
    Short answer : A LOT
    More than LES limits allow.
    Edit: regular price isn’t too bad considering the specs and location
    https://hosthatch.com/ssd-vps
