How to run wireguard in OpenVZ?
I have a bunch of old LES OpenVZ servers from Inception and wanted to run wireguard there (servers, although in wireguard everyone's a peer). However, when I try to run wireguard, I get
# wg-quick up wg0
[#] ip link add wg0 type wireguard
RTNETLINK answers: Operation not supported
Unable to access interface: Protocol not supported
[#] ip link delete dev wg0
Cannot find device "wg0"
Is it impossible to run wireguard in these containers or is it a PEBKAC issue? Do you recommend any of the userspace wireguard implementations and, if so, which?
IIRC enable TAP/TUN in SolusVM, wait for reboot, then run the script made by @Nyr ... π
Most likely the node doesn't have the WireGuard kernel module loaded, try asking if they can get it loaded?
If you just want plain WG, there's wireguard-go; if you want a bit more, there's Tailscale.
Hey, @InceptionHosting, is it ok to request for a LES offer?
I was smart enpough to enable TUN! And I installed wireguard plus I already have the config for it.
Do you mean this script?
Yes, that script. I doubt the OpenVZ kernel is new enough to include Wireguard support. The script will pull in the userspace version... (At least it did for my debian VM's.)
Yeah, it pulls BoringTun. Which is fine because it works.
For future reference, in addition to turning on tun, I had to do the inception magic to enable proper iptables by
touch /option.netfilterand waiting half an hour.Very cool script, @Nyr.
