Z+ 512MB LXC 5GB Solid State - $2.50/m
2
  • skorupionskorupion Hosting Provider
    @ZizzyDizzyMC said:
    @skorupion said:
    Would be happy to try and run yabs, anyone wanna share their instance for an hour?
    My testing account has a reserved node on it if you'd like to try it using that node - I can push the services to your account through the billing panel so you can have a go at it if you want?
    I was not at all expecting to sell out of this meme, though to be fair there's only one node up. I'll set up a couple more over the weekend - these are great learning tools and when they work, they're actually functional despite the meme.
    Hell yeah lemme create an account
    Contact me at: +1 (509) 606-3569 or [email protected]
    I'll dm you my email
  • edited October 2022
    On which ASN is that compute stick, considering a dedicated v4 for every container? =)
    Might be something for @jtk
    Edit: Ah, I see.
    https://bgp.he.net/AS399266
    @jtk only takes KVM.
    His write-up is easy to understand:
    https://dataplane.org/jtk/publications/login2018-dataplane.pdf
    No hostname available. affbrr
    Should be set, good test of my transfer system. You'll have to rebuild the container as I already forgot the temporary pass I set on it when I made it for myself.
    alr
    edited October 2022
    alr
    Rebuilded and now cant get to billing.zd.do
    nvm
    If you add 1 GB of SWAP to that LXC, then I can get geek bench 5 results
  • Do you have plans to use Starlink? =) It would make this offer better xD
    I'm on the Starlink waitlist, I had gotten it before but couldn't afford it by the time I got through.
    I've manually added swap, good luck.
    alr thanks, will do when I come back from school
  • AdvinAdvin Hosting Provider
    Out of stock?
    edited October 2022
    GOT ITTT
    Tue Oct 25 16:52:28 UTC 2022
    Uptime     : 0 days, 1 hours, 9 minutes
    Processor  : Intel(R) Atom(TM) x5-Z8330  CPU @ 1.44GHz
    CPU cores  : 2 @ 1920.000 MHz
    RAM        : 512.0 MiB
    Swap       : 1.0 GiB
    Disk       : 4.8 GiB
    Distro     : Ubuntu 20.04 LTS
    Kernel     : 5.15.39-3-pve
    Read       | 364.00 KB/s     (91) | 42.00 KB/s       (0)
    Write      | 386.00 KB/s     (96) | 55.00 KB/s       (0)
    Total      | 750.00 KB/s    (187) | 97.00 KB/s       (0)
    Read       | 303.00 KB/s      (0) | 0.00 KB/s        (0)
    Write      | 656.00 KB/s      (1) | 0.00 KB/s        (0)
    Total      | 959.00 KB/s      (1) | 0.00 KB/s        (0)
    Clouvider       | London, UK (10G)          | 15.6 Mbits/sec  | 11.8 Mbits/sec
    Online.net      | Paris, FR (10G)           | busy            | busy
    Hybula          | The Netherlands (40G)     | 16.1 Mbits/sec  | 15.5 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 13.3 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 16.1 Mbits/sec  | 14.2 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 17.0 Mbits/sec  | 14.8 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 16.8 Mbits/sec  | 15.9 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 189
    Multi Core      | 326
    Full Test       | https://browser.geekbench.com/v5/cpu/18207319
    Edit: You need swap, you need to manually install fio, and iperf3 & you need to download YABS from another source (GitHub didn't want to work, so I uploaded it to my own webserver)
    Edit: Got the 1M fio test working
    Tue Oct 25 18:44:16 UTC 2022
    RAM        : 512.0 MiB
    Swap       : 1.0 GiB
    Disk       : 4.8 GiB
    Read       | 1.09 MB/s      (272) | 170.00 KB/s      (2)
    Write      | 1.12 MB/s      (281) | 200.00 KB/s      (3)
    Total      | 2.21 MB/s      (553) | 370.00 KB/s      (5)
    Read       | 1.65 MB/s        (3) | 935.00 KB/s      (0)
    Write      | 2.02 MB/s        (3) | 1.32 MB/s        (1)
    Total      | 3.68 MB/s        (6) | 2.26 MB/s        (1)
    Clouvider       | London, UK (10G)          | 15.7 Mbits/sec  | 12.2 Mbits/sec
    Online.net      | Paris, FR (10G)           | 15.5 Mbits/sec  | 12.4 Mbits/sec
    Hybula          | The Netherlands (40G)     | 15.2 Mbits/sec  | 14.7 Mbits/sec
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 6.84 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 16.1 Mbits/sec  | 11.6 Mbits/sec
    Clouvider       | Dallas, TX, US (10G)      | 16.6 Mbits/sec  | 14.6 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 16.8 Mbits/sec  | 15.7 Mbits/sec
    Single Core     | 190
    Multi Core      | 347
    Full Test       | https://browser.geekbench.com/v5/cpu/18209515
    I'm absolutely rolling, I can't believe you've managed that lol.
  • so where exactly is this located?
    Neither can I, so 2 months free LOL
    I'm away atm but I'll get you a voucher and ticket you with it.
  • Network and CPU actually look usable, I like the single 1M iop.
    I missed this post, in the original listing "May be located in a cornfield or backyard" It's single homed.
    I see that, but any info on the physical location?
    Like city, state/province, country?
    Oh, midwestern USA. Not sure how I didn't see this notification till now.
  • Address on the ASN registration:
    Network is single homed to FranTech Las Vegas.
    So we doxing people once again <3
    ASN registration is public information:
    IP address is visible on page 1 of this thread.
    As @yoursunny said, it's public info.
    I'd be more worried if you didn't do research into what you were getting.
    I'll add more nodes this weekend since, for some reason, people have made tickets asking for more.
    The compute sticks are just awful for this, and awful to work with. I'm actively looking for other low power alternates that are slightly more performant than 1 whole iop.
    well, that's the address you provided when registering for an ASN.
    it doesn't mean you have to physically have a host there, right?
    FWIW, you can host it in your aunt's house, your buddy's office, etc...
    so there is tunneling going on for sure.
    edited February 2023
    Because I don't like to leave clients hanging, an update is in order.
    1. Will there be more stock? Not until I fix this mess.
    2. The beta node was offline for what I could tell probably at least 2 weeks, but maybe less, maybe more.
    I did some investigating and the node locally was fine, nothing was wrong with the node itself, business as usual. I didn't dig into the logs, just make sure it's online and the proxmox page wasn't spewing kernel errors. Checks out.
    Router, the router that handles the wifi portion of connecting the node to the vlan that routes to the tunneled portion of the network... Well it had a bad day at some point. Logs were all corrupted so I'm guessing she's not happy with whatever I'm doing to her. Cue router abuse'
    I'm gonna own up to my mistake, the 4 clients on the machine will all get 2 months free for this, despite none of them actually submitting a ticket saying "it broke". Not many providers out there that'll own up like that unless questioned so definitely want to be an example.
    In addition to this, I've spent a few weeks locating low power nodes that have ethernet onboard and suitable performance specifications to replace the compute stick nodes. I've made 1 purchase of a node, but if anyone here has suggestions for meme nodes feel free if it doesn't break my wallet too hard considering I hand out credit code for these like candy. Would eventually like to earn a dollar back on these someday.
    Edit: Don't know how I forgot, but I also plan to give the 4 beta client's who've put up with this meme free upgrades to the new ultra low power nodes once I've determined a node I like. This will likely come with an increase in ram and disk space. Prices will remain the same for as long as they keep the plan on their account. Hurray for legacy!
    As part of an action remediation plan I am looking into proper uptime monitoring tools so I get service check alerts when devices or nodes don't respond for a set period of time. Suggestions are welcome.
