1269270272274275277
  • @taizi said: hentai@home
    Virmach now allows running hentai@home? I remember it was discussed earlier in this thread, and it was causing some problems on Tokyo storage.
    LIMITED OFFER
    $47.45 /yr
    KVM – 1 GIGABIT
    3669MB DDR4 RAM
    4 vCORE (RYZEN 3.4GHz+)
    160GB SSD (NVMe)
    16384GB MONTHLY DATA
    NYC METRO, NJ LOCATION
    3 DEDICATED IPv4
  • edited December 2022
    the main problem is, it will abuse the disk io. Virmach asked will it improve if add SSD cache(Tokyo storage is HDD)
    But I am using NVME to run it(Ryzen Special 2536), because in my "tech stack", the local disk is for the cache, my actual file is encrypted and stored at another place.
  • @taizi said: But I am using NVME to run it(Ryzen Special 2536), because in my "tech stack", the local disk is for the cache, my actual file is encrypted and stored at another place.
    This is interesting, I see Ryzen Special 2536 only has 50gb of storage, how much is your h@h cache size?
    521 static ranges assigned(hitrate 57.9 / min)
    actual size:67G
    my cache size:9.5G
    approximate cache hit:50%-75%
    my client quality is bad, but it works.
    LIMITED OFFER
    $33.85 /yr
    KVM – 1 GIGABIT
    3242MB DDR4 RAM
    50GB SSD (NVMe)
    5120GB MONTHLY DATA
    ATLANTA, GA LOCATION
    1 DEDICATED IPv4
  • @taizi said: it works.
    That hitrate is impressive, my client has ~600gb cache and 3200 static ranges, but only has 72.8 / min hitrate.
    I bet your client isn't in Asia, only Asia has so much traffic.
    I used to have a client host in pulsedmedia,5000 ranges but only 60 hitrate, because it is in Europe, so the hitrate is low.
  • FrankZFrankZ ModeratorOG
    @sdsbirdman said:
    You ran Proxmox on a KVM? how is the performance?
    I thought it is supposed to be on bare metal only.
    I run nested KVM on some bigger KVM to isolate some stuff that needs to run on older O/S that I don't want exposed to the world.
    Runs almost as fast as the base KVM if you set it up correctly.
    I really thought H@H was against VirMach's TOS. Now I am going to have to go and double check.
    I would guess if it did not set off the abuse scripts you could get away with it on NVMe, but I expect you are living dangerously.
    I'll be back in ~ an hour after reading the whole TOS again.
  • @taizi said:
    actually, I can't use so much bandwidth, but the problem is, I can't estimate the usage of my hentai@home service in the future.
    If there is a strict rate limitation to network port instead of suspending after bandwidth runs out, I can only need 4T full-speed bandwidth(to be honest,20M network is enough for 99% of my work), but unfortunately virmach does not provide this option atm...
    if your service like hentai@home doesnt support bandwidth limitations, then you could limit your server bandwidth with wondershaper or similar
    @VirMach Now which areas cannot be turned on immediately, Or which areas can be turned on immediately after buying?
    Always pending status, which hinders my purchase
    @VirMach
    For some unpleasant reasons, my virmach tracking channel will be closed after this flash sale.
    I would like to consult your opinion, should it be kept or destroyed?
    Thanked by (1)lemoncube
  • @j0rmo said:
    @VirMach
    your channel helpful for me,thanks your work
  • @j0rmo said:
    @VirMach
    Is that you I know?
  • @j0rmo said:
    @VirMach
    I like your work on the rating. I doubt virmach would even care, though.
    it support, I just don't want to limit it and serve more request
  • @FrankZ said: I really thought H@H was against VirMach's TOS. Now I am going to have to go and double check.
    some critical issue
    i. infringes on any third party’s intellectual property or publicity/privacy rights;
    e-hentai is a user-shared gallery but it obeys copyright laws and DMCA
    E-Hentai Galleries complies with applicable copyright law. Unfortunately, due to sheer volume it is impossible for us to verify the copyright status of every single gallery uploaded to our site, nor are we legally complied to do so. If you find that your copyright has been infringed by one of our members, please report this using the DMCA Report Form found by clicking the Report Gallery button on the gallery in question, or by emailing a list of links to the galleries in question to reports (a) e-hentai period org.
    and I didn't hear any user receive any copyright strike because of running this so far.
    (even some Chinese guy host their own h@h client in China mainland, wtf?? I afraid it will make Winnie the Pooh's naughty list longer)
    xi. involves mass public file storage of any kind (image hosting site, video hosting site, torrents, etc);
    not for the public, only works for e-hentai. but since e-hentai is a public website, it is walk on the edge...
    High I/O: Customer’s Service cannot average more than 80 IOPS within any two (2) hour period, cannot burst above 300MB/s disk write average for more than ten (10) minutes, cannot average more than 300 write operations per second for more than 1 hour, and cannot be above 20% average utilization within any six (6) hour period.
    I use NVME not HDD.currently the IO usage is low.
    @taizi said: e-hentai is a user-shared gallery but it obeys copyright laws and DMCA
    Ya knew e-hentai servers are at Romania for a reason
    Screw T&S, Flying Chinaman runs TOR, game server, torrent and whatever pentest script in a 7x24h manner
    Ontario Dildo Inspector
    no,it host at Moldova now
  • I wish I can utilize such a beast.
    LIMITED OFFER
    $64.38 /yr
    KVM – 1 GIGABIT
    7712MB DDR4 RAM
    205GB SSD (NVMe)
    20992GB MONTHLY DATA
    LOS ANGELES, CA LOCATION
    1 DEDICATED IPv4
    MJJ rating 60% worthy, ya'd butter pass
  • Crazy deals Jan 1 at 12:01am
    YEAH
    Thanked by (2)localhost FrankZ
  • FAT32FAT32 OGSenpai
    What have I seen...
    Thanked by (2)ehab FrankZ
  • @ehab said:
    YEAH
    Oh my holy tits
    Thanked by (1)ehab
  • its one way of saying to @risturiz - u wish -
  • VirMach [699] 64% - $46.34 /yr
    4 vCores CPU
    3328MB RAM
    160GB Disk
    16384GB Transfer
    NYC METRO, NJ
    3 IP, 1 GIGABIT
    this is good for those looking for US location
    4 vCores CPU
    3328MB RAM
    160GB Disk
    16384GB Transfer
    NYC METRO, NJ
    3 IP, 1 GIGABIT
    Won't bite the bait unless more than 95% worthy (75% for Tokyo)
  • @sdsbirdman said:
    I checked out 2 of them for 0.5 bucks. Lol another great find to match with the rest of the idlers.
    oh,looks nice! but why mine was still pending?it is my first get in virmach,as is its low price. how about their reputation and service?good boy or bad girl?
  • @mbk said:
    Bought 2 deals so far and both deployed in under 5 minutes.
    Damn... I jinxed myself :#
    $21 deal has been pending for more than 18 hours.
