@AlwaysSkint said:
Some asshole is broadcasting from syncthing on the new PHX range. Why the hell does software get released with this default methodology? (Rhetorical.)
Just making sure I understand. Are you railing against the injustice or is it actually causing you a problem?
@skorous said: ..or is it actually causing you a problem?
Seen how often your syslog fills up, from your friendly neighbours?
dmesg
up 3:09
624K Jan 5 11:21 messages
I have to specifically deploy iptables rules, to limit the Load created by them, manually tailored per subnet etc.
dmesg
up 3:09
right on ... wasn't passing judgement or anything. Just wanted to know. My default is DROP without a log so they don't fill up but I get where you're coming from.
It looks like this person has enabled (it's by default), the localAnnounceEnabled option in Syncthing:
"Whether to send announcements to the local LAN, also use such announcements to find other devices."
their system just wants to find friends, friends who send dirty twisted packets .. maybe they want to share shell access with their newfound friends?
With iptables, this still logs activity whereas INVDROP doesn't.
For embitterment's sake/revenge, I should really use REJECT but would just pressure the LAN further.
Now, what was I actually going to do with that VPS, there?
Oh aye, too big for just a nameserver, so I guess my only Washington client might like a site, or two, migrated there..
[> @davi said:
Sorry, not went through whole thread so not sure if it is already addressed. Want to know if any one got back additional IP4 address which were taken back during Ryzen migration.
Yes, I heard that @AlwaysSkint and others got their extra IPv4 back. IIRC you had to ticket, but I have tagged him and we should wait for him to chime in before ticketing so he tells us what needs to go in the ticket.
Summary is that in October a button was added to create automated ticket and user could request either missing IP or discount. It had a bug because some people wanted IP but ticket said discount (I guess default value for choice was IP on form but it was discount in ticket creation). Button was removed to be fixed and @VirMach said he would ask people who had already used it if they would like to make a change.
My ticket is still open with no answer and I haven't closed it because @VirMach said we would get only once chance at the request
@Linux said: My ticket is still open with no answer and I haven't closed it because VirMach said we would get only once chance at the request.
(Tag removed)
Just for you, I looked back..
Posted by System on 10/08/2022 (00:32)
This ticket has been marked as completed by a member of our staff. This means your request has been fulfilled, and it has been closed.
It wasn't completed - note the Americanised date.
Then..
Posted by <_AlwaysSkint_> on 12/08/2022 (03:33) Owner
Hi,
As mentioned in LES, the previously (re-)assigned two IP addresses have vanished from the admin screens though appear to be still bound to the VM.
etc.
Once again, note the date.
Now that you've tagged Virmach, you may get an indication of what to do next, perhaps directly related to your particular situation.
Yes, I got mine back. it took about a week or two after submitting the request.
because it is made userfriendly that idiots can now just press a few things and it works, not worried about how it does it, it just does it.
SEAZ002 Is back in the game.. Yea baby
ServerStatus , slackvpn
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff)
Uuuuhhhhhhh .... which OS? My logs disagree with this.
EDIT: Oh, likely because I have an explicit rule for dealing with invalid I believe.
The fat guy has been working
CentOS7/Alama8 with CSF
Possibly.
A typical snippet (multi-IP setup):
This is the last mention of feature to request missing IP: https://lowendspirit.com/discussion/comment/101203#Comment_101203
(Tag removed)
Then..
etc.
Cheers mate
Yo, what's yeti's biz at SEAZ002?
Ontario Dildo Inspector
Ahhh shit here let me fix that for you
Just realized all my Vir US chicken's IP are in the 47.87.0.0/16 block
shows Unity within the country
Don't let them breed they are related
Yeah that's bad for proxy usage
Ya know back to the day of shitty ColoCrossing
Virmach's site blocked access from their own IP
Yeape I remember makes me want to cry sometimes. I am a sensitive Yeti on the inside.
You should buy Phx location, it's started with 31.222.xxx.xxx
https://microlxc.net/
Thanks, I suppose Phoenix & Denver should be different
I don wanna click the $3 panic button
https://hostloc.com/thread-1080085-1-1.html
MJJ stated VirMach bought 47.87.0.0/16 IP block from Alibaba.
Chinaman doesn't trust China state controlled company, not even a punctuation.
so why buy anything from virmach now then
Well, at least Tokyo, Phoenix, Denver and NYC remain intact
The day has come, $3 PANIC button clicked.
I will left the 5 core beast at LAX, others will be migrated to those locations.
OK,I know
Wow! It Back now! Thanks for notice!
K8S worker +1
