14748505253415
  • Some asshole is broadcasting from syncthing on the new PHX range. Why the hell does software get released with this default methodology? (Rhetorical.)
    Thanked by (1)AuroraZero
  • because it is made userfriendly that idiots can now just press a few things and it works, not worried about how it does it, it just does it.
    Just making sure I understand. Are you railing against the injustice or is it actually causing you a problem?
    edited January 2023
    @skorous said: ..or is it actually causing you a problem?
    Seen how often your syslog fills up, from your friendly neighbours?
    dmesg
    up 3:09
    624K Jan 5 11:21 messages
    I have to specifically deploy iptables rules, to limit the Load created by them, manually tailored per subnet etc.
    dmesg
    up 3:09
    right on ... wasn't passing judgement or anything. Just wanted to know. :) My default is DROP without a log so they don't fill up but I get where you're coming from.
    Thanked by (1)AlwaysSkint
    It looks like this person has enabled (it's by default), the localAnnounceEnabled option in Syncthing:
    "Whether to send announcements to the local LAN, also use such announcements to find other devices."
    their system just wants to find friends, friends who send dirty twisted packets .. maybe they want to share shell access with their newfound friends? ;)
    Thanked by (2)AlwaysSkint ATInDaHause
  • SEAZ002 Is back in the game.. Yea baby :)
  • @skorous said: My default is DROP
    With iptables, this still logs activity whereas INVDROP doesn't.
  • skorousskorous OGSenpai
    edited January 2023
    Uuuuhhhhhhh .... which OS? My logs disagree with this.
    EDIT: Oh, likely because I have an explicit rule for dealing with invalid I believe.
    The fat guy has been working :lol:
    edited January 2023
    @skorous said: which OS?
    CentOS7/Alama8 with CSF
    @skorous said: Oh, likely because I have an explicit rule for dealing with invalid I believe.
    Possibly.
    A typical snippet (multi-IP setup):
    /usr/sbin/iptables -I INPUT 3 -s 185.xxx.xxx.0/24  ! -d 185.xxx.xxx.174 -m comment --comment "Noisy neighbours" -j INVDROP
    /usr/sbin/iptables -I INPUT 4 -d 185.xxx.xxx.255 ! -s 185.xxxxxx.1 -m comment --comment "Noisy neighbours" -j INVDROP
    /usr/sbin/iptables -I INPUT 7 -d 255.255.255.255 -m comment --comment "Noisy neighbours" -j INVDROP
    For embitterment's sake/revenge, I should really use REJECT but would just pressure the LAN further.
  • @emperor said: SEAZ002 Is back in the game
    Now, what was I actually going to do with that VPS, there?
    Oh aye, too big for just a nameserver, so I guess my only Washington client might like a site, or two, migrated there.. :)
  • @FrankZ said:
    [> @davi said:
    Sorry, not went through whole thread so not sure if it is already addressed. Want to know if any one got back additional IP4 address which were taken back during Ryzen migration.
    Yes, I heard that @AlwaysSkint and others got their extra IPv4 back. IIRC you had to ticket, but I have tagged him and we should wait for him to chime in before ticketing so he tells us what needs to go in the ticket.
    This is the last mention of feature to request missing IP: https://lowendspirit.com/discussion/comment/101203#Comment_101203
    Summary is that in October a button was added to create automated ticket and user could request either missing IP or discount. It had a bug because some people wanted IP but ticket said discount (I guess default value for choice was IP on form but it was discount in ticket creation). Button was removed to be fixed and @VirMach said he would ask people who had already used it if they would like to make a change.
    My ticket is still open with no answer and I haven't closed it because @VirMach said we would get only once chance at the request
    edited January 2023
    @Linux said: My ticket is still open with no answer and I haven't closed it because VirMach said we would get only once chance at the request.
    (Tag removed)
    Just for you, I looked back..
    Posted by System on 10/08/2022 (00:32)
    This ticket has been marked as completed by a member of our staff. This means your request has been fulfilled, and it has been closed.
    It wasn't completed - note the Americanised date.
    Then..
    Posted by <_AlwaysSkint_> on 12/08/2022 (03:33) Owner
    Hi,
    As mentioned in LES, the previously (re-)assigned two IP addresses have vanished from the admin screens though appear to be still bound to the VM.
    etc.
    Once again, note the date.
    Now that you've tagged Virmach, you may get an indication of what to do next, perhaps directly related to your particular situation.
    Thanked by (2)Linux FrankZ
  • edited January 2023
    Cheers mate
    @AuroraZero said: Ahhh shit here let me fix that for you
    Yo, what's yeti's biz at SEAZ002?
    Thanked by (1)root
    Ontario Dildo Inspector
    @Flying_Chinaman said:
    Cheers mate
    Thanked by (1)root
    Just realized all my Vir US chicken's IP are in the 47.87.0.0/16 block
    shows Unity within the country :)
    Thanked by (1)Flying_Chinaman
    Don't let them breed they are related
    Yeah that's bad for proxy usage
    Ya know back to the day of shitty ColoCrossing
    Virmach's site blocked access from their own IP
    Yeape I remember makes me want to cry sometimes. I am a sensitive Yeti on the inside.
    You should buy Phx location, it's started with 31.222.xxx.xxx
    Thanks, I suppose Phoenix & Denver should be different
    I don wanna click the $3 panic button
    https://hostloc.com/thread-1080085-1-1.html
    MJJ stated VirMach bought 47.87.0.0/16 IP block from Alibaba.
    Chinaman doesn't trust China state controlled company, not even a punctuation.
    so why buy anything from virmach now then
    Thanked by (2)DanSummer AlwaysSkint
    @cybertech said: so why buy anything from virmach now then
    Well, at least Tokyo, Phoenix, Denver and NYC remain intact
    The day has come, $3 PANIC button clicked.
    I will left the 5 core beast at LAX, others will be migrated to those locations.
    Yes, I got mine back. it took about a week or two after submitting the request.
    OK,I know
    Wow! It Back now! Thanks for notice! =)
    K8S worker +1
