1127128130132133432
  • @cybertech said:
    I could be wrong but IIRC, reconfigure networking in SolusVM is designed to work with templates, not ISO installs. So it is a feature not a bug. :)
    yeah except i didnt do that, it was automated.
    i configured my network manually
    This was pinging/not blocked off from ping, right? Looking into our reconfigure script that runs in the background.
    im not sure what the question is, but i had configured manually the new IP correctly and VM was online.
    suddenly it was reconfigured to eth0.
    i manually reconfigured back to ens3 and works again now.
    like what @FrankZ mentioned im using ISO install and not from template, so it may affect those on ISO.
  • edited April 2023
    Node Name: TPAZ003
    https://imgur.com/a/7qdj9Da
  • @cybertech would we be able to ping the public IPv4 address? As in no firewall preventing that?
    edited April 2023
    yes in my case (manual config) it is now pingable , tried from SG/TYO/LAX
  • Change eth0 to ens3
    Restart network solve the problem for Frankfurt location.
  • @cybertech said: yes in my case (manual config) it is now pingable , tried from SG/TYO/LAX
    Figured out the issue. The script doesn't do a heavy level of testing (e.g, running an entire ping.pe) and since it's a newly announced block routing isn't perfect and it could falsely mark one as not pinging if there's a little bit of loss.
    I'm filtering out the list first using mass ping tool and then only inputting that into the script instead. Sorry about that.
  • Received an update from them, verbatim:
    We'll be done in ten minutes
    Going to just wait it out and check for myself before getting everyone's hopes up on the network status page, but I don't mind getting everyone's hopes up here, unofficially. ;)
    Thanked by (2)ZA_capetown FrankZ
  • Nice, I see it back on RADB for a few so far.
    47.87 prefix, or few subnets of it?
  • @ByteVirt said: 47.87 prefix, or few subnets of it?
    All of it, except Frankfurt and Amsterdam which we moved off this morning/afternoon. It'll still take some time of course, it'll come in similarly to how it went out, not all suddenly.
  • @tonyapac said:
    Node Name: TPAZ003
    @VirMach
    https://billing.virmach.com/serverstatus.php
    It does not mention TPAZ003 and IP 47.87.206.*, the situation is the VM is not reachable.
    Lets hope everything goes smoothly
  • @tonyapac said: 47.87.206.*
    That's within 47.87.128.0/17
    TYOC007 just pop'd back online. Thanks VirMach.
  • Any news for 47.87.136.xxx and 47.87.153.xxx ?
  • JabJab Senpai
    edited April 2023
    47.87.128.0/17 = FROM 47.87.128.0 TO 47.87.255.255
    Thanked by (2)Fritz skorous
  • huh?i think tyoc026 has no impact,but actually my network got edited too,turns into eth0, and waste my 1hour of sleep time to fix this.
    how I fix this? waste 55mins for fixing nothing and 5mins later it recovered itself
  • JabJab Senpai
    @VirMach copy-paste from LET, I am to stupid to understand it, but maybe important :D
    @jtk said: I saw reports of intermittent reachability. I suspect, a problem now is that QuadraNet is announcing a /20 in this prefix, but there are only ROAs with Alibaba's origin ASes published in the RPKI for the covered address space, which means many nets will be invalidating and rejecting the QuadraNet announcement. Let's see how long it takes people in the LES thread to figure this out. :-)
  • edited April 2023
    Sounds like they're describing the initial issue?
    (edit) Oh
  • so, if I am reading the service status page correctly, the payment issue or what ever with Alibaba has been resolved and the subnet is getting reassigned and it will just take time? if so, I have a lot of that and thank you for the updates :)
  • Okay so good news is that they're aware, but looks like it's going to take a little longer than the initial "we'll be done in ten minutes." They're keeping me posted.
    Yep, basically.
    Thanked by (2)dgc1980 FrankZ
    I meant. didn't see any news for .136 and .153 but from .225 which is on the same range.
  • Anyone's machine in NY up? Mine is still down.
  • edited April 2023
    NY has just come back up for me.
    Thanked by (1)lesuser
  • All my services are just popping back online :)
    Mine is also up now.
  • Indeed, all green here now. Yay!
