I need a dedicated server with amd ryzen 9 5900X
I need a dedicated server with this
Amd ryzen 9 5950X
128Gb Ram ( or 256Gb )
1Tb of NVME storage
Ddos protection
unlimited bandwidth from 1gb to 10Gb shared its ok
Location withing ( usa - uk - france - germany - netherland - italy -dubai - russia )
For 100$ at maximum 🙂
And if possible extra ipv4 for 1$
This is my email [email protected]
Nigh is UK.
What ?!
Slightly over budget but Hetzner has a 5950x, 128gb RAM, 2x 4TB SSD, unlimited (fup?) 1gbit in Germany for $115/mo in their server auction
You're only really going to get Hetzner with those budgets, and their CPU cooling situation is absolutely terrible.
You get 2800 single core on 7950X3D versus about 15000 multi-core! That's the equivalent of 5 cores reaching their full potential. Heck! Our 5900X UK servers got a higher GB5 bench than Hetzner's 5950X, by a couple of thousand.
We have a 5950X server being built right now and it will be priced at about £200-250/month depending on the mood, so if you're interested in that, do let me know.
Nowhere mentioned and might be unfair competition/marketing from Hetzner, but the fitting term.
After three-digits TB/m, you'll get kicked.
I have a hard time believing those Geekbench claims unless you have had a faulty server. It's of course true that a desktop grade CPU ment to be cooled by a beefy air cooler or water cooling won't perform at its peak in most datacenters. However, I would say the Hetzner dervers does well.
Firstly, Geekbench multi-core performance far from scales linearly. This is not something related to Hetzner. It's normal. The average performance of a 7950XD is around 2800 single core and 18000 multi core. Hetzner 7950XD does around 16500. I'd say that's perfectly fine. Furthermore, my two Hetzner 5950X servers performs above average compared to the geekbench website numbers. So I have a hard time believing that a 5900X would outperform it.
By taking a look at the YABS you've posted of your VM it doesn't quite add up.
Hostbrr.com - Cheap but powerful VPS - Instant setup
AMD 7950XD and 5950X VPS starting at only $4.99! Order now!
It is impossible to get that configuration for $100/mo, no matter the provider, and Ryzen only supports up to 128GB
lmao you have better chance asking for $7 with the same specs
A great way to set the price of dedicated server is to imagine buying the hardware and dividing that price by 6. Then add the price of internet in your desired location. That will give you a ballpark figure of what it'll cost you. I would say $200 to $250 is a good estimate.
With those budget, Hetzner is the only way. Otherwise, you will end up on 200++ USD.
This is Interserver,
https://www.interserver.net/dedicated/ryzen.html
and this is Mevspace, OOS at the moment.
https://mevspace.com/dedicated
KangServer.id - Doing some benchmarks on VPS / Server
LowEnd VPS Deals - LowEnd / Cheap VPS Deals
Officially only 128GB by now. 48GB modules are already available and it's only a matter of time till mainboard vendors will start listing 4x48GB configurations as possible.
Insane
I guess this budget is too low... You may want to buy your own server and host it somewhere.
Does it still OOM in Chrome every 4 hours?
To clarify, our servers are liquid-cooled, so there's little to no thermal throttling. If you look at Hetzner's CPU temperatures they will heavily throttle upon load. I cannot prove these results to you because all the servers we have are under load - and that wouldn't be a fair result. What I do remember is that our 5900X was getting maybe about 13-15k (taken without water cooling installed), whereas the Hetzner 5950X was getting about 11-12k (this could've been hindered by some load but I'm not sure so my bad if so). I am not saying that Hetzner servers are bad, I use them myself & they are amazing, but what I am insinuating is that for more money you can get a bit more power (and hopefully a server that doesn't restart every hour according to LE* haha)
It is not fair to judge our hardware by a single-core YABS result on a VPS. It is very well known that virtualization hinders the hardware, and there is also a fair amount of load on our UK hypervisor (50% on average)
