A suggestion for @VirMach . When you're doing these IP migrations change the dhcp server early ( maybe a day before ) so it has time to renew to the new address. That way you won't have to do the extra work of converting those people to static addresses.
"Officially" .... so assuming I don't need help setting it up where can I find the unofficial allocation ranges? ;-)
Unofficially it's still on my unofficial list. Just going to officially make sure we don't actually do IPv6. We might officially offer it for those with a higher support package.
The coupon code "RYZEN" only works on NVMe2G (as correctly stated on special offers page) but https://virmach.com/amd-ryzen-kvm-vps-with-nvme-ssd/ still says "Receive 40% off your first order, recurring discount, on 2GB or larger package." and tries to add it to NVMe4G and above too.
Wanted to reinstall my OS on Node: FFME004
Can't reinstall OS: "Total Re-installs: 1 of 1 (0 free) - If you run out, please use the control panel directly."
I can't access Full VPS Control Panel. Reason: "Invalid vserverid or username"
What should I do? I didn't create a ticket, not sure if it's still full or not.
@MallocVoidstar said: The coupon code "RYZEN" only works on NVMe2G (as correctly stated on special offers page) but https://virmach.com/amd-ryzen-kvm-vps-with-nvme-ssd/ still says "Receive 40% off your first order, recurring discount, on 2GB or larger package." and tries to add it to NVMe4G and above too.
How long does the "I'll leave this in a queue for repair." for Missing LVM last for?
I was pretty sure you had scripts for that and this will be semi-automatic? if yes, can you kick the script on FFME02 because it seems it didn't run for last 6 days?
If there is no script and this shit is manual then I will wait, zenbleed > my cheap idle VM
ISO are getting resynced, if there's still issues tomorrow let me know, for any servers. They're also being updated to latest.
Auto script is still being worked on, it's not done yet. Well not actively being worked on, but it was some time ago (a week or two?)
FFME002, they're being tracked on tickets so whenever I get to them in the ticket queue. It's not too long but also not too short, just the right length for them to get stuck there for a week. Only like 3 to 5 people affected so it wasn't prioritized but also not that many so it's easy to manually fix. Just has to hit my queue, should actually maybe be done today. Maybe.
Any news on FFME002? @VirMach
I might miss some news here.
status.virm.ac shows online but VPS off.
https://microlxc.net/
Tokyo Maintenance (Scheduled)High
Affecting System - Tokyo Datacenter
07/21/2023 06:00 Last Updated 07/21/2023 03:17
Network maintenance, up to 30 minute network interruption.
10AM @ July 22nd, Tokyo Local Time.
smartass shitposting satirist
I always prefer this one because the bear is so cute but so obviously angry.
@VirMach why my ticket regarding adding ipv6 being open for 6 months, you said to add it to the list..when?
IPv6 request button removed for now. For all official IPv6 related questions for now, refer to:
https://billing.virmach.com/index.php?rp=/knowledgebase/67/IPv6.html
ColoCrossing is back!
Ignore your victim's ticket for 6 months is a bad experience, no matter officially or not.
Is your VPS up yet? Mine is in the same node and it's still offline.
server-factory: Cheap and Powerful Netherlands VPS/VDS !!! (aff)
My FFME002 just woke up now. After a week figuring what's wrong.
It's automagically woke up. Nice, very nice.
Try all the buttons there, Boot, Reset, Off then Boot.
Change boot order (even you never setup it), Reconfigure network.
Status.Virm.ac shows node online.
Good for ya. I don't have such luck lol. @VirMach maybe you can help me with it ticket #536561
Trust me, you need to access boot order, unmount, set boot order then Boot.
I never touch boot order setting but hey, this is Virmach, anything can happen even if you didn't ask for it.
Just tried all these but didn't work lol
sir, can you unofficially assign an ipv6 for me?
No
But... the poor lad has even properly addressed VirmAch as SIR
RYZE.ATL-Z006.VMS
ATLZ007B
node timeout, looks like is datacentar or network issue there
Is NYCB027 node still locked?
PS: https://github.com/google/security-research/tree/master/pocs/cpus/zenbleed
mount netboot.xyz, install custom OS via VNC
Yo @VirMach, have ya made use of your bought
deadpool
domain?smartass shitposting satirist
Let me check, which one?
Fixed earlier yesterday.
Yeah I'm trying to avoid remembering this exists right now.
ˢᵒᵒⁿ
