1214215217219220333
  • JabJab Senpai
    edited October 2023
    Welp, this is even more scary.
    Okey, it's gone after 2 minutes.
  • @VirMach thank you for keeping this thread updated. I had a VPS in SEA005 which after couple of months of downtime is finally up at LAX1Z012, but I am missing two ip4 from the network. Also, I thought based on what I read these are eventually moving to San Jose is that correct? Or do I request that via ticketing system? Do I wait for 2 missing ip4 to appear magically in sometime as you are working through or should raise ticket? Thanks again.
  • @Jab said: Okey, it's gone after 2 minutes.
    STOP BREAKING THE DATABASE!
    If you didn't get your additional it means at the time it was fixed there were none left so it had to be done that way. Maybe a dozen or so people affected if I recall correctly. Wait a little bit so we have extra IPs available and contact us, or if you need it immediately then feel free to contact us sooner but let us know we can move you anywhere with available IPs.
  • JabJab Senpai
    edited October 2023
    @xTom said: We have PNI with Cloudflare in Frankfurt, we didn't receive any other reports from other customers.
    Thanks for answer, I guess then it's something VirMach related as the same Debian packages/version running on other hosts don't drop Cloudflared/Argo tunnel that many times.
    Dear @VirMach should the network in Frankfurt look like that? I know jackshit how this should be, but getting 1-97 ms icmp ping from gateway is not good, right? :D
    # ip -4 r s | grep "default"
    default via 213.232.115.1 dev ens3 proto dhcp src 213.232.115.X metric 100
    # ping 213.232.115.1
    PING 213.232.115.1 (213.232.115.1) 56(84) bytes of data.
    64 bytes from 213.232.115.1: icmp_seq=1 ttl=64 time=1.27 ms
    64 bytes from 213.232.115.1: icmp_seq=2 ttl=64 time=22.4 ms
    64 bytes from 213.232.115.1: icmp_seq=3 ttl=64 time=8.10 ms
    64 bytes from 213.232.115.1: icmp_seq=4 ttl=64 time=8.46 ms
    64 bytes from 213.232.115.1: icmp_seq=5 ttl=64 time=28.3 ms
    64 bytes from 213.232.115.1: icmp_seq=6 ttl=64 time=21.5 ms
    64 bytes from 213.232.115.1: icmp_seq=7 ttl=64 time=7.74 ms
    64 bytes from 213.232.115.1: icmp_seq=8 ttl=64 time=8.19 ms
    64 bytes from 213.232.115.1: icmp_seq=9 ttl=64 time=5.82 ms
    64 bytes from 213.232.115.1: icmp_seq=10 ttl=64 time=30.2 ms
    64 bytes from 213.232.115.1: icmp_seq=11 ttl=64 time=6.61 ms
    64 bytes from 213.232.115.1: icmp_seq=12 ttl=64 time=2.38 ms
    64 bytes from 213.232.115.1: icmp_seq=13 ttl=64 time=2.31 ms
    64 bytes from 213.232.115.1: icmp_seq=14 ttl=64 time=1.02 ms
    64 bytes from 213.232.115.1: icmp_seq=15 ttl=64 time=32.8 ms
    64 bytes from 213.232.115.1: icmp_seq=16 ttl=64 time=60.1 ms
    64 bytes from 213.232.115.1: icmp_seq=17 ttl=64 time=4.55 ms
    64 bytes from 213.232.115.1: icmp_seq=18 ttl=64 time=6.74 ms
    64 bytes from 213.232.115.1: icmp_seq=19 ttl=64 time=40.1 ms
    64 bytes from 213.232.115.1: icmp_seq=20 ttl=64 time=2.35 ms
    64 bytes from 213.232.115.1: icmp_seq=21 ttl=64 time=8.35 ms
    64 bytes from 213.232.115.1: icmp_seq=22 ttl=64 time=2.29 ms
    64 bytes from 213.232.115.1: icmp_seq=23 ttl=64 time=42.5 ms
    64 bytes from 213.232.115.1: icmp_seq=24 ttl=64 time=2.44 ms
    64 bytes from 213.232.115.1: icmp_seq=25 ttl=64 time=5.41 ms
    64 bytes from 213.232.115.1: icmp_seq=26 ttl=64 time=1.08 ms
    64 bytes from 213.232.115.1: icmp_seq=27 ttl=64 time=2.41 ms
    64 bytes from 213.232.115.1: icmp_seq=28 ttl=64 time=77.2 ms
    64 bytes from 213.232.115.1: icmp_seq=29 ttl=64 time=3.92 ms
    64 bytes from 213.232.115.1: icmp_seq=30 ttl=64 time=1.31 ms
    64 bytes from 213.232.115.1: icmp_seq=31 ttl=64 time=21.9 ms
    64 bytes from 213.232.115.1: icmp_seq=32 ttl=64 time=51.1 ms
    64 bytes from 213.232.115.1: icmp_seq=33 ttl=64 time=3.41 ms
    64 bytes from 213.232.115.1: icmp_seq=34 ttl=64 time=8.07 ms
    64 bytes from 213.232.115.1: icmp_seq=35 ttl=64 time=8.30 ms
    64 bytes from 213.232.115.1: icmp_seq=36 ttl=64 time=97.9 ms
    64 bytes from 213.232.115.1: icmp_seq=37 ttl=64 time=3.61 ms
    64 bytes from 213.232.115.1: icmp_seq=38 ttl=64 time=5.39 ms
    64 bytes from 213.232.115.1: icmp_seq=39 ttl=64 time=8.02 ms
    64 bytes from 213.232.115.1: icmp_seq=40 ttl=64 time=1.94 ms
    64 bytes from 213.232.115.1: icmp_seq=41 ttl=64 time=49.6 ms
    64 bytes from 213.232.115.1: icmp_seq=42 ttl=64 time=2.17 ms
    64 bytes from 213.232.115.1: icmp_seq=43 ttl=64 time=9.16 ms
    64 bytes from 213.232.115.1: icmp_seq=44 ttl=64 time=1.07 ms
    64 bytes from 213.232.115.1: icmp_seq=45 ttl=64 time=2.32 ms
    64 bytes from 213.232.115.1: icmp_seq=46 ttl=64 time=22.4 ms
    64 bytes from 213.232.115.1: icmp_seq=47 ttl=64 time=2.19 ms
    ^C
    --- 213.232.115.1 ping statistics ---
    47 packets transmitted, 47 received, 0% packet loss, time 46068ms
    rtt min/avg/max/mdev = 1.020/15.883/97.910/21.362 ms
    Okey, I am even more confused - seems like there are Google DNS route pushed within DHCP as the same route...
    # ip -4 r s | grep "8.8"
    8.8.4.4 via 213.232.115.1 dev ens3 proto dhcp src 213.232.115.X metric 10
    8.8.8.8 via 213.232.115.1 dev ens3 proto dhcp src 213.232.115.X metric 100
    # ping 8.8.8.8
    PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
    64 bytes from 8.8.8.8: icmp_seq=1 ttl=61 time=0.533 ms
    64 bytes from 8.8.8.8: icmp_seq=2 ttl=61 time=0.732 ms
    64 bytes from 8.8.8.8: icmp_seq=3 ttl=61 time=0.979 ms
    64 bytes from 8.8.8.8: icmp_seq=4 ttl=61 time=0.879 ms
    64 bytes from 8.8.8.8: icmp_seq=5 ttl=61 time=0.579 ms
    64 bytes from 8.8.8.8: icmp_seq=6 ttl=61 time=0.558 ms
    64 bytes from 8.8.8.8: icmp_seq=7 ttl=61 time=0.568 ms
    64 bytes from 8.8.8.8: icmp_seq=8 ttl=61 time=0.662 ms
    64 bytes from 8.8.8.8: icmp_seq=9 ttl=61 time=0.776 ms
    64 bytes from 8.8.8.8: icmp_seq=10 ttl=61 time=0.890 ms
    64 bytes from 8.8.8.8: icmp_seq=11 ttl=61 time=0.658 ms
    64 bytes from 8.8.8.8: icmp_seq=12 ttl=61 time=0.746 ms
    64 bytes from 8.8.8.8: icmp_seq=13 ttl=61 time=0.591 ms
    64 bytes from 8.8.8.8: icmp_seq=14 ttl=61 time=0.569 ms
    64 bytes from 8.8.8.8: icmp_seq=15 ttl=61 time=0.719 ms
    64 bytes from 8.8.8.8: icmp_seq=16 ttl=61 time=0.493 ms
    64 bytes from 8.8.8.8: icmp_seq=17 ttl=61 time=0.673 ms
    64 bytes from 8.8.8.8: icmp_seq=18 ttl=61 time=0.836 ms
    64 bytes from 8.8.8.8: icmp_seq=19 ttl=61 time=0.544 ms
    64 bytes from 8.8.8.8: icmp_seq=20 ttl=61 time=0.814 ms
    64 bytes from 8.8.8.8: icmp_seq=21 ttl=61 time=0.680 ms
    64 bytes from 8.8.8.8: icmp_seq=22 ttl=61 time=0.781 ms
    64 bytes from 8.8.8.8: icmp_seq=23 ttl=61 time=0.625 ms
    64 bytes from 8.8.8.8: icmp_seq=24 ttl=61 time=0.730 ms
    64 bytes from 8.8.8.8: icmp_seq=25 ttl=61 time=0.770 ms
    64 bytes from 8.8.8.8: icmp_seq=26 ttl=61 time=0.825 ms
    64 bytes from 8.8.8.8: icmp_seq=27 ttl=61 time=0.507 ms
    64 bytes from 8.8.8.8: icmp_seq=28 ttl=61 time=0.704 ms
    64 bytes from 8.8.8.8: icmp_seq=29 ttl=61 time=0.672 ms
    64 bytes from 8.8.8.8: icmp_seq=30 ttl=61 time=0.866 ms
    64 bytes from 8.8.8.8: icmp_seq=31 ttl=61 time=0.783 ms
    64 bytes from 8.8.8.8: icmp_seq=32 ttl=61 time=0.686 ms
    64 bytes from 8.8.8.8: icmp_seq=33 ttl=61 time=0.627 ms
    64 bytes from 8.8.8.8: icmp_seq=34 ttl=61 time=0.659 ms
    ^C
    --- 8.8.8.8 ping statistics ---
    34 packets transmitted, 34 received, 0% packet loss, time 33747ms
    rtt min/avg/max/mdev = 0.493/0.697/0.979/0.118 ms
    and those has proper LAN timings - less than 1ms? :D
  • edited October 2023
    @VirMach said:
    rDNS has been added in SolusVM for all new blocks, but I've seen reports of it not working. I haven't had time to go through these specifically so it'd be helpful if we can get anyone here to use the feature and let me know what you're seeing in terms of issues and on which node so we can see if it's just all broken or clusters of problems.
    Receiving "Could not connect to DNS server. Please try again later" for NY server in ip range 141.11.22x.xxx
    also, installed Debian 12 on RYZE.NYC-B013.VMS VM and I'm getting a segfault when I run apt upgrade. (not happening with other templates --- so I assume its a problem with the template.)
  • FrankZFrankZ ModeratorOG
    edited October 2023
    @VirMach rDNS works fine on:
    AMSD026 -   147.78.24x.xx
    FFME001 -   88.214.2x.xxx
    FFME006 -   213.232.11x.xxx
    TYOC007 -   176.119.14x.xx
    TYOC039  -  45.66.21x.xx
    CHIZ003  -  62.192.17x.x
    NYCB045 -   141.11.19x.xxx
    NYCB015 -   46.233.4x.xx
    NYCB013 -   141.11.22x.xxx
    MIAZ012  -  89.37.19x.xxx
    PHXZ003 -   31.222.20x.xx
    LAXA007  -  141.11.9x.xxx
    LAXA009  -  141.11.9x.xxx
    LAX1Z012 -  162.33.16x.xx
    LAX1Z014 -  193.93.5x.xx
    LAXA031 -   141.11.20x.xxx
    SJCZ007   - 50.114.24x.xx
    SJCZ008   - 108.165.16x.x
    Thanked by (1)AlwaysSkint
  • Why the $30 setup fee for Tokyo VPSes?
    Is it a good location for a VPN to connect from China?
    @JoeMerit said: also, installed Debian 12 on RYZE.NYC-B013.VMS VM and I'm getting a segfault when I run apt upgrade. (not happening with other templates --- so I assume its a problem with the template.)
    This feels like dejavu. We added Debian 12 in the past and it had the same problem, didn't it? And then we removed it because we had to work on our own version not from SolusVM, that never happened, I forgot, and we went back to adding the SolusVM version that's still broken.
    @FrankZ said: Could not connect to DNS server. Please try again later
    Yeah I forgot an important step for all these, I have to go one by one mapping them to specific primary ID for each as they were added to PowerDNS. SolusVM feature, because it'd be impossible to do it any other way that's less labor intensive.
    We still get a good number of purchases, it helps balance out stock levels, and balance out abuse. Will likely be changed again as we usually do based on other factors.
    Thanked by (3)FrankZ imok Wonder_Woman
  • Given $30 are too expensive, any other recommended location to set up a private VPN?
    From China or anywhere?
    If anywhere, just select the nearest location to you.
    From China, usually what I've seen people do is in the order:
    Tokyo
    Hong Kong
    Vietnam (Greencloud)
    Singapore
    US West Los Angeles
    US West Seattle
    Thanked by (2)imok erk
    Novosibirsk, Russia
    Test IP: 91.188.223.6
    Novosibirsk, Russia
    I really wanted to do this location a while back as I was looking at all the global routes and thought it'd be an interesting location, but then it was definitely complicated after 2022.
    Thanked by (2)abiaolaoge fan
  • FAT32FAT32 OGSenpai
    When VirMach SG
    I can be remote hands :wink:
    Thanked by (3)FrankZ imok Not_Oles
    I'll buy 10 of those sir
    Thanked by (1)FAT32
    edited October 2023
    @VirMach said:
    Novosibirsk, Russia
    hey, there are no forever friends nor enemies. russia will be back in one way or another.
    Sorry 10 of my hand or VPS?
    is it too much to ask for both?
    Thanked by (3)FAT32 FrankZ Not_Oles
  • I started working with my phoenix ryzen vps again. Installed Debian 11 and upgraded and it stopped working.
    Reinstallling Debian 11... I suppose I should not upgrade the OS.
    i think its best to use ISO for latest now
    Thanked by (1)imok
    Hmm, I do see a history of things like this happening with Debian. Update, then bug reported of a similar issue, "fixed" and then repeat. Seems like it could be caused by any particular package. Gets even more fun when you add in virtualization, Ryzen, and specific motherboards.
    It sure is going to be fun to see where we're at with everything in 10, 20, 30 years.
    @cybertech said: i think its best to use ISO for latest now
    So minimal ISO is confirmed working? It must be missing whatever's causing this. If someone can confirm exact setup with ISO that works the best I should be able to just make a template.
    i think so yes. it wasn't working for a while then now it is.
  • @VirMach Four of my servers were moved to NYC, two from Dallas and two from Atlanta. Network status page said that nodes in ATLZ010 were not moving?
    I don't want all those servers in NYC. Is it possible to get these servers migrated away from NYC?
  • @mbk said: Is it possible to get these servers migrated away from NYC?
    "If you put your mind to it, anything is possible." -- Kimberly Guilefoyle
    Very long answer but some variation of this will occur, yes.
  • @VirMach said: Very long answer but some variation of this will occur, yes.
    Alright, thanks for the reply. I guess I'll wait on renewing these for now but I hope that something good occurs before BF/CM.
  • My node was migrated from NYCB027 to NYCB035, and there is still no network connectivity.
    Thanked by (1)Caxen
    How about if we had a bunch of servers migrated to NY and we actually like it that way, can they stay?
