ExtraVM/@MikeA has/had $20/year deal a few days ago, they offer SPanel.
NameCrane/@NameCrane has very affordable yearly plans, DirectAdmin plans start from $8/year and cPanel from $18/year.
CynderHost/@johnk offer cPanel plans from $20.99.
You should worry more about LiteSpeed, CloudLinux, JetBackup (or any other automated backup plugin), App installer like Softaculous than Control Panel.
@sh97 recommendeded HostBRR they have 5$/year plans and their most expensive plan was 15$/year if i remember correctly. So providers you pointed out cost more. Thanks for the suggestion tho.
Sure, if the cheapest is the most important factor. I have nothing against the Brr!
@KenTech said:
Anyone know cheap webhostings with yearly plans?
How much space do you need?
Budget?
Location?
Honestly i don't even know how much storage lol cause i'm currently using https://ct8.pl with their subdomain and they have 3GB of space. Location also doesn't matter but i'd like it to be cheap! Not buying it right now tho. Also if anyone has cheap python discord bot hosting providers too let me know!
If you can manage things by yourself better get cheap vps, that way you can host your site and the bot for peanuts. Ex of cheap vps is 1gb netcup for 12euros/year or 2gb vps from greencloud for 15$/y etc.. There is lot of hosts outhere so do your research before buying 1.
yea i was thinking of buying a yearly vps but @crunchbits doesn't have cheap yearly plans anymore
For myself, the gauge to compare low cost hosting is NameCrane. If the alternative is within the same ballpark pricing as NameCrane, I'll stick to NameCrane. NC has excellent support and quality of the service.
These 2 webhostings still look pretty expensive compared to HostBRR.
However.. If you compare hosting with a cPanel license, which is automatically provided to customers on AVA HOST hosting plans, the price of the minimum package is 1.99 EUR, and as for hosting by the company you mentioned, it is $2 per month. However, AVA HOST provides unlimited bandwidth, which is an advantage
AVA.HOSTING: Webspace Hub | Trustworthy Hosting Provider since 2001
ava.hosting
Bruh i'm pretty sure @HostBRR Had unlimited bandwidth like yesterday.
seems like HostBRR Does have unlimited bandwidth
If you look at my post, I meant cPanel license, not directadmin.. Since cPanel is a more expensive license, however, we are exploring the technical possibilities to implement directadmin also, for our valued clients
ava.hosting
cPanel seems to be cheaper too on HostBRR! I get more storage for the same price!
Depends on how you define cheap.
Pricing
Hardware
Attitude of the host
Visitors you plan to attract.
There is something for everyone,
Including search function in Vanilla
Squats are the new Push-ups
NameCrane.
https://www.namecrane.com/store/da-shared-hosting
Price looks good but DirectAdmin control panel seems a bit sketchy to me.
Here's cPanel:
https://www.namecrane.com/store/shared-hosting
@Labze HostBRR - https://my.hostbrr.com/order/main/packages/cpanel/?group_id=46
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
Having used both over the years, the different to your average user between DA and cPanel is ... minimal.
that's cheap af
Sure, if the cheapest is the most important factor. I have nothing against the Brr!![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
slips MS a memberberry
Yes.
MichaelCee
Budget?
Location?
Is that the same provider as Serv00.com?
yes it is
have you used HostBRR before? are they good?
maybe ill take directadmin cause that seems simpler to use!
Hello.
Please take a look in our Shared Hostings plans that start from 10€ yearly.
https://alexhost.com/shared-hosting/
cPanel is included. If you want to pay monthly, please check LiteSpeed Hosting plans!
Best Regards,
Alexhost
Hello,
For cheap hosting you can review this wonderful plan -> https://my.ava.hosting/cart.php?a=add&pid=272&billingcycle=annually
Or you can check this VPS Nano tariff plan -> https://ava.hosting/vps/vps-nano/
ava.hosting
For VPS, the barometer is BuyVM.
However.. If you compare hosting with a cPanel license, which is automatically provided to customers on AVA HOST hosting plans, the price of the minimum package is 1.99 EUR, and as for hosting by the company you mentioned, it is $2 per month. However, AVA HOST provides unlimited bandwidth, which is an advantage![;) ;)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/wink.png)
ava.hosting
If you look at my post, I meant cPanel license, not directadmin.. Since cPanel is a more expensive license, however, we are exploring the technical possibilities to implement directadmin also, for our valued clients![;) ;)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/wink.png)
ava.hosting
